Home » Eclipse Projects » EclipseLink » loader constraint violation
loader constraint violation [message #479287] Mon, 10 August 2009 10:58 Go to next message
Tom Eugelink is currently offline Tom Eugelink
What does this exception mean?
java.lang.LinkageError: loader constraint violation: loader (instance of sun/misc/Launcher$AppClassLoader) previously initiated loading for a different type with name "nl/reinders/bm/Batch"
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:621)
at java.security.SecureClassLoader.defineClass(SecureClassLoade r.java:124)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:260)
at java.net.URLClassLoader.access$000(URLClassLoader.java:56)
at java.net.URLClassLoader$1.run(URLClassLoader.java:195)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320 )
at nl.reinders.bm.generated.Article.<clinit>(Article.java:248)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:247)
at org.eclipse.persistence.internal.security.PrivilegedAccessHe lper.getClassForName(PrivilegedAccessHelper.java:86)
at org.eclipse.persistence.descriptors.ClassDescriptor.convertC lassNamesToClasses(ClassDescriptor.java:956)
at org.eclipse.persistence.sessions.Project.convertClassNamesTo Classes(Project.java:289)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl. deploy(EntityManagerSetupImpl.java:200)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.getServerSession(EntityManagerFactoryImpl.java:69)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.createEntityManagerImpl(EntityManagerFactoryImpl.java:118)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.createEntityManager(EntityManagerFactoryImpl.java:108)
at nl.reinders.bm.BM.createEntityManager(BM.java:97)
at nl.reinders.Reinders$24.actionPerformed(Reinders.java:2855)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButto n.java:1995)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractB utton.java:2318)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultBu ttonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel .java:242)
at javax.swing.AbstractButton.doClick(AbstractButton.java:357)
at javax.swing.AbstractButton.doClick(AbstractButton.java:337)
at nl.reinders.Reinders.startJpaScreenSwing(Reinders.java:2911)
at nl.reinders.Reinders.access$4(Reinders.java:2797)
at nl.reinders.Reinders$23.run(Reinders.java:2789)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java :199)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at org.tbee.swing.EventQueue.dispatchEvent(EventQueue.java:83)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDis patchThread.java:284)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispat chThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDis patchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread. java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread. java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:12 2)
Re: loader constraint violation [message #479723 is a reply to message #479287] Wed, 12 August 2009 03:58 Go to previous messageGo to next message
Ugh. So I have an entity called a "batch" representing an amount of the same article in a certain form. Such a batch has "amount providers", these are entities that either add to or remove an amount from the batch.
These amount providers all implement the BatchAmountProvider interface:
public interface BatchAmountProvider
public java.math.BigInteger getAmount() ;
public void setAmount(java.math.BigInteger value);
This has worked fine, until I needed to add two methods to the interface allowing me to access the batch they are part of. These methods were already present in all of the implementing classes, I only formalized that by adding them to the interface:
public nl.reinders.bm.Batch getBatch();
public void setBatch(nl.reinders.bm.Batch value);
Either of these two lines are the culprit and cause the loader constraint violation. I still don't understand why.
Tom
Re: loader constraint violation [message #479726 is a reply to message #479723] Wed, 12 August 2009 04:11 Go to previous messageGo to next message
It turns out it is a known bug
https://glassfish.dev.java.net/issues/show_bug.cgi?id=2625
I needed to externalize the interface (it was part of the Batch class) and add it to the persistence.xml.
I did not find an equivalent bug entry in Eclipselink's bugzilla. This is done using Eclipselink 1.1.1.
Tom
Re: loader constraint violation [message #480803 is a reply to message #479726] Tue, 18 August 2009 10:33 Go to previous message
James Sutherland is currently offline James Sutherland
Unusually bug, my guess would be that this is resolved in EclipseLink 2.0,
you may wish to try this. For 1.1, you can add the interface to the
persistence.xml.
James
James : Wiki : Book : Blog
Previous Topic:EclipseLink - ordering of tables for join statement
Next Topic:Pessimistice locking hint - hanging locks
Current Time: Tue May 21 05:26:54 EDT 2013
Powered by FUDForum. Page generated in 0.02020 seconds
