Home » Eclipse Projects » Eclipse Platform » custom ant build script: how to get the project's classpath ?
custom ant build script: how to get the project's classpath ? [message #478694] Thu, 06 August 2009 08:39 Go to next message
Laurent Petit is currently offline Laurent Petit
Member
I searched the archives and just found this subject discussed about once or twice in 2005.
I want to run a custom ant build script after the java builder. This ant build script will have to call some targets that need the project's classpath ?
Back in 2005 it was considered an interesting idea, but not possible at that time.
Is there a possibility to do so now ?
Thanks in advance for your answers,
Laurent Petit
Re: custom ant build script: how to get the project's classpath ? [message #478767 is a reply to message #478694] Thu, 06 August 2009 14:51 Go to previous messageGo to next message
Member
Replying to myself since I may well have found a solution (more by chance than by a rational approach to google / documentation browsing etc. :-).
by making my ant script "run inside the same JVM as eclipse", I have access to a lot of interesting (though undocumented) task.
Among them : eclipsetools.getclasspath
Which I found can be used as :
<eclipsetools.getclasspath javaproject="<my-eclipse-project-name>" property="build.ide.classpath" />
and then use it to create a classpath:
<path id="project.classpath">
<pathelement path="${build.ide.classpath}" />
</path>
Of course, since I now have asked my script to execute from within eclipse,
* I can no longer use it headless but I don't care because I already have an headless build with custom targets :-)
* I must be careful using the fork="true" attribute when I call the java task.
Laurent
Laurent Petit wrote:
> Hello,
> or twice in 2005.
> classpath ?
> that time.
Re: custom ant build script: how to get the project's classpath ? [message #478839 is a reply to message #478767] Fri, 07 August 2009 04:21 Go to previous messageGo to next message
Member
> etc. :-).
> </path>
> java task.
Re: custom ant build script: how to get the project's classpath ? [message #478840 is a reply to message #478767] Fri, 07 August 2009 04:22 Go to previous message
Member
My bad, I didn't verify the "provider" of this "eclipsetools.getclasspath".
It was provided by a commercial licensed product, so it's not at all the solution I was looking for.
Still searching ....
Laurent
> etc. :-).
> </path>
> java task.
Previous Topic:INewWizard without pages
Next Topic:Property page vs preference page
Current Time: Sun May 19 00:22:51 EDT 2013
Powered by FUDForum. Page generated in 0.07231 seconds
