Home » Modeling » OCL » OCLExpressions
OCLExpressions [message #478753] Thu, 06 August 2009 13:02 Go to next message
mary is currently offline mary
I am new to OCL and I am trying to use it with QVT. I want to create an
OCL Expression from a string. I created a type StringLiteralExp and in the
stringSymbol attribute i give it the OCL string.
var strExp:=object
OCL::expressions::StringLiteralExp{stringSymbol:='self.name= Class1'};
now i want to use this OCLExpression inside an if condition to evaluate it
and check if it is true or false. However, it seems that the if condidtion
always returns false. Which I guess because it is not correctly evaluating
the ocl expression.
if(strExp=true) then 'true'.dump() else 'false'.dump() endif;
So my questions are : 1. Am-I using the correct way to build an OCL
Expression from a string?
2. Is it possible to use the OCL expression inside an IF statement and to
evaluate it ?
Thanks in advance..
Mary
Re: OCLExpressions [message #478771 is a reply to message #478753] Thu, 06 August 2009 15:05 Go to previous messageGo to next message
Hi Mary
You should ask this question on the M2M newsgroup with a [QVTo] subject
prefix.
What you are doing does not seem to make sense. OCL is built-in to all
the QVT languages so you do not have to construct OCL expressions from
their AST elements. You appear to be working at what seems like two
extra levels of encoding.
I would have thought that
if (self.name=Class1) then 'true'.dump() else 'false'.dump() endif
would have met your requirements.
Ed Willink
mary wrote:
> Hello, I am new to OCL and I am trying to use it with QVT. I want to
> create an OCL Expression from a string. I created a type
> StringLiteralExp and in the stringSymbol attribute i give it the OCL
> string.
> var strExp:=object
> it and check if it is true or false. However, it seems that the if
> condidtion always returns false. Which I guess because it is not
> correctly evaluating the ocl expression.
> to evaluate it ?
> Thanks in advance.. Mary
Re: OCLExpressions [message #478777 is a reply to message #478771] Thu, 06 August 2009 15:50 Go to previous message
Hi Ed,
Please find my answers in-line..
Ed Willink wrote:
> Hi Mary
> prefix.
Actually I did ask in the M2M newsgroup and they provided help but then i
had this question about OCL and i thought its better to ask it here.
Actually you are right.. this would meet my requirement. However, my
problem is that the expression inside the if statement is not static. It
should depend on an elemnet in the user model. So, i need to read this
element from the user model and then test it. Thats why i had to build the
OCL expression !
> Regards
> Ed Willink
Previous Topic:UML OCL and Date
Next Topic:OCL, AnyType and FeatureMaps
Current Time: Sun May 19 00:21:57 EDT 2013
Powered by FUDForum. Page generated in 0.01538 seconds
