Home » Eclipse Projects » EclipseLink » MergeChangeSetCommand NullPointerException" in remote EclipseLink Session
MergeChangeSetCommand NullPointerException" in remote EclipseLink Session [message #478727] Thu, 06 August 2009 10:53 Go to next message
No real name is currently offline No real name
I am using EclipseLink 1.0.2.
I have Parent & Child with 1:m relationship. When I delete a child object
which is held in Parent's child collection (ValuHolder)I am getting
"command type MergeChangeSetCommand Internal Exception:
java.lang.NullPointerException" in remote EclipseLink session. I didn't
get this kind of error in toplink.
Parent has 1: m with Child.
OneToManyMapping childsMapping = new OneToManyMapping();
childsMapping.setAttributeName("childs");
childsMapping.setReferenceClass(Child.class);
childsMapping.setRelationshipPartnerAttributeName("parent");
childsMapping.privateOwnedRelationship();
childsMapping.useBasicIndirection();
Child has back reference to Parent.
DirectToFieldMapping parentIdMapping = new DirectToFieldMapping();
parentIdMapping.setAttributeName("parentId");
parentIdMapping.setFieldName("t_Child.parent_id");
descriptor.addMapping(parentIdMapping);
OneToOneMapping parentMapping = new OneToOneMapping();
parentMapping.setAttributeName("parent");
parentMapping.setReferenceClass(Parent.class);
parentMapping.setRelationshipPartnerAttributeName("childs");
parentMapping.useBasicIndirection();
parentMapping.addForeignKeyFieldName("t_Child.parent_id", "t_Parent.id");
I am using ValueHolder for holding relationship object.
When I remove child from Parent's child collection, everything works fine
in local session. But following exception occures in remote EclipseLink
session. In remote session, When Eclipselink tries to remove child object,
it doesn't get entry of child object in its identityMap. Hence while
removing child object,following excpetion comes.
Internal Exception: java.lang.NullPointerException
org.eclipse.persistence.exceptions.RemoteCommandManagerExcep tion.errorProcessingRemoteCommand(RemoteCommandManagerExcept ion.j
ava:208)
org.eclipse.persistence.internal.sessions.coordination.broad cast.BroadcastRemoteConnection.processReceivedObject(Broadca stRem
oteConnection.java:184)
org.eclipse.persistence.internal.sessions.coordination.jms.J MSTopicRemoteConnection.onMessage(JMSTopicRemoteConnection.j ava:1
79)
org.eclipse.persistence.internal.sessions.coordination.jms.J MSTopicRemoteConnection$JMSOnMessageHelper.run(JMSTopicRemot eConn
ection.java:348)
org.eclipse.persistence.internal.queries.MapContainerPolicy. keyFrom(MapContainerPolicy.java:277)
org.eclipse.persistence.internal.queries.MapContainerPolicy. removeFrom(MapContainerPolicy.java:339)
org.eclipse.persistence.internal.queries.ContainerPolicy.mer geChanges(ContainerPolicy.java:653)
org.eclipse.persistence.mappings.CollectionMapping.mergeChan gesIntoObject(CollectionMapping.java:756)
org.eclipse.persistence.internal.descriptors.ObjectBuilder.m ergeChangesIntoObject(ObjectBuilder.java:2476)
org.eclipse.persistence.internal.sessions.MergeManager.merge ChangesIntoDistributedCache(MergeManager.java:417)
org.eclipse.persistence.internal.sessions.MergeManager.merge Changes(MergeManager.java:247)
org.eclipse.persistence.internal.sessions.MergeManager.merge ChangesFromChangeSet(MergeManager.java:344)
Can anyone please give suggestions?
Thanks for any help.
Re: MergeChangeSetCommand NullPointerException" in remote EclipseLink Session [message #480792 is a reply to message #478727] Tue, 18 August 2009 09:55 Go to previous messageGo to next message
James Sutherland is currently offline James Sutherland
I would recommend logging a bug. You may also try to see if the issue
still occurs in 1.1 or 2.0. The bug seems to be related to using a Map
container policy, but your mapping did not seem to include this?
As a workaround, you may consider switching cache coordination to use
invalidation instead of change sets.
http://www.eclipse.org/eclipselink/api/1.1.2/org/eclipse/per sistence/descriptors/ClassDescriptor.html#setCacheSynchroniz ationType(int)
James
James : Wiki : Book : Blog
Re: MergeChangeSetCommand NullPointerException" in remote EclipseLink Session [message #481027 is a reply to message #480792] Wed, 19 August 2009 07:22 Go to previous messageGo to next message
Hi James,
Thanks a lot for your reply.
I didn't include full mapping for 1:m relationshoip. Parent descriptor
uses Map container policy for containing child collection.
Is it a bug related to Map container policy?
Here are the mappings.
Parent Descriptor
DirectToFieldMapping idMapping = new DirectToFieldMapping();
idMapping.setAttributeName("id");
idMapping.setFieldName("t_Parent.id");
descriptor.addMapping(idMapping);
childsMapping.useMapClass(java.util.HashMap.class, "getAnotherid");
childsMapping.addTargetForeignKeyFieldName("t_Child.parent_id ",
"t_Parent.id");
descriptor.addMapping(childsMapping);
Child Descriptor
idMapping.setFieldName("t_Child.id");
DirectToFieldMapping anotheridMapping = new DirectToFieldMapping();
anotheridMapping.setAttributeName("anotherid");
anotheridMapping.setFieldName("t_Child.anotherid");
descriptor.addMapping(anotheridMapping);
parentIdMapping.readOnly();
descriptor.addMapping(parentMapping);
Thanks a lot for any help.
Re: MergeChangeSetCommand NullPointerException" in remote EclipseLink Session [message #481060 is a reply to message #481027] Wed, 19 August 2009 09:01 Go to previous message
Yes, the issue is related to the MapContainerPolicy. There seems to be an
issue with the distributed merge code when something is removed and it is
not in the target server's cache.
Please log the bug, as a workaround either remove the Map, or use
invalidation for the cache coordination.
Previous Topic:Source Attach for EclipseLink
Next Topic:JPA DAO in Desktop Application
Current Time: Mon May 20 15:29:34 EDT 2013
Powered by FUDForum. Page generated in 0.03211 seconds
