| UML API : BehavioralFeature::setMethod(Behavior behavior) is missing ? [message #478401] |
Sat, 16 May 2009 04:56  |
Deepak Messages: 53 Registered: July 2009 |
Member |
I have an UML Activity and a class model. Now I want to connect them to
each other programmatically.
The class model has one UML::operation which refers to the UML activity
model. I noticed that UML::operation API has the "getMethod()"
(inherited from UML::BehavioralFeature). I am just wondering why there
is no "setMethod(org.eclipse.uml2.uml.Behavior behavior)" available. I
think this method would perfectly match my needs.
Deepak
| Re: UML API : BehavioralFeature::setMethod(Behavior behavior) is missing ? [message #478421 is a reply to message #478403] |
Tue, 19 May 2009 13:03  |
Member |
Rafael Chaves schrieb:
> Deepak, behavioural feature can have multiple methods. You can either use:
> operation.getMethods().add(behavior)
> or
> behavior.setSpecification(operation)
> HTH,
> Rafael
> http://abstratt.com/textuml/
Thanks Rafael !
> Deepak wrote:
>> Hello,
>> to each other programmatically.
>> activity model. I noticed that UML::operation API has the
>> "getMethod()" (inherited from UML::BehavioralFeature). I am just
>> wondering why there is no "setMethod(org.eclipse.uml2.uml.Behavior
>> behavior)" available. I think this method would perfectly match my needs.
>> Regards,
>> Deepak
| Re: UML API : BehavioralFeature::setMethod(Behavior behavior) is missing ? [message #627590 is a reply to message #478401] |
Sun, 17 May 2009 13:17  |
Rafael Chaves Messages: 362 Registered: July 2009 |
or
HTH,
Rafael
Deepak wrote:
> Hello,
> Deepak
| Re: UML API : BehavioralFeature::setMethod(Behavior behavior) is missing ? [message #627606 is a reply to message #478403] |
Member |
> or
> HTH,
> Rafael
Thanks Rafael !
> Deepak wrote:
>> Hello,
>> Regards,
>> Deepak
FUDForum. Page generated in 0.01912 seconds
