Home » Modeling » UML2 » How to access the Property values of a Stereotype?
| How to access the Property values of a Stereotype? [message #478359] |
Tue, 05 May 2009 09:56  |
Timothy Marc Messages: 547 Registered: July 2009 |
Hey all,
i have created a dynamic profile (i know, static profiles are much
better, however :-) ) and assigned it correctly to an uml model. No, i
programmatically traverse the uml model and want to access a property of
an stereotype.
My current approach is the following:
final EList list = (EList)umlMessage.getValue(argument, "values");
which returns an EList of DynamicEObjectImpl object. That's also
correct, because the @value attribute of my stereotyp has a 1..*
cardinality.
But when i traverse the list, i have no idea, how to access the values
of the property? I tried with
((DynamicEObjectImpl)item).eSettings(...);
but this method needs an EStructuralFeature object, and i don't know how
to find it!
I think, im totally on the woodway because, it should be quite easier to
access values of stereotype properties, shouldn't it?
Thx
Timothy
| Re: How to access the Property values of a Stereotype? [message #478361 is a reply to message #478359] |
Wed, 06 May 2009 11:14   |
Rafael Chaves Messages: 362 Registered: July 2009 |
Timothy, what is the type of your stereotype property?
For primitive types, it should return an instance of the corresponding
Java primitive wrapper type.
Is it another stereotype? In that case, this might help:
http://zhaochenting.googlepages.com/usingumlprofilecustomize uml
Rafael
http://abstratt.com/blog/
Timothy Marc wrote:
> Hey all,
> an stereotype.
> cardinality.
> to find it!
> Thx
> Timothy
| Re: How to access the Property values of a Stereotype? [message #478396 is a reply to message #478359] |
Fri, 15 May 2009 09:35  |
Kenn Hussey Messages: 1616 Registered: July 2009 |
Timothy,
You can obtain the Ecore metadata (e.g. structural features) for properties
defined in your profile via the Profile#getDefinition(NamedElement) method.
Once you have the structural feature, you can obtain its value via the
EObject#eGet(EStructuralFeature) method.
Alternatively, you could use the "nested" syntax supported by the
Element#getValue(Stereotype, String) method; there should be previous
threads on this newsgroup on this subject...
Kenn
"Timothy Marc" <timothymarc@freenet.de> wrote in message
news:gtpgcb$rd9$1@build.eclipse.org...
> Hey all,
> i have created a dynamic profile (i know, static profiles are much better,
> an stereotype.
> which returns an EList of DynamicEObjectImpl object. That's also correct,
> because the @value attribute of my stereotyp has a 1..* cardinality.
> But when i traverse the list, i have no idea, how to access the values of
> to find it!
> Thx
> Timothy
| Re: How to access the Property values of a Stereotype? [message #627548 is a reply to message #478359] |
Rafael
Timothy Marc wrote:
> Hey all,
> an stereotype.
> cardinality.
> to find it!
> Thx
> Timothy
| Re: How to access the Property values of a Stereotype? [message #627583 is a reply to message #478359] |
Timothy,
Kenn
> Hey all,
> an stereotype.
> to find it!
> Thx
> Timothy
Current Time: Fri May 24 09:23:48 EDT 2013
Powered by FUDForum. Page generated in 0.01810 seconds
