Home » Eclipse Projects » JavaServer Faces » JSF with Eclipse - Tutorial
JSF with Eclipse - Tutorial [message #476061] Wed, 12 November 2008 19:05 Go to next message
Lars Vogel is currently offline Lars Vogel
I created a small JSF with Eclipse WTP JSF Tutorial. Feedback welcome.
Link: http://www.vogella.de/articles/JavaServerFaces/article.html
Best regards, Lars
Re: JSF with Eclipse - Tutorial [message #476062 is a reply to message #476061] Thu, 13 November 2008 07:47 Go to previous messageGo to next message
Wolfgang Knauf is currently offline Wolfgang Knauf
Member
Hi Lars,
good tutorial!
Some minor things:
1.5 Value and Method Binding:
"Tip: Expression Language statements either start with "${" or "#{" and end with
"}" " => could you explain the difference beetween "$" and "#" (I know that
there is one, but I don't know it myself ;-) )
3.3. Download the JSTL library
"If you know where I find the standard JSTL1.2 reference implementation please
email this information to me." => there is no separate download, it seems to be
part of the JavaEE5 RI (http://java.sun.com/javaee/downloads/index.jsp). I found
it also as part of JBoss 5.
4.4. Create Java Server Page
Image and code snippet seem to be swapped (correct: first image, then code)
5.4. Validators
I miss the implementation of the "validate" (with check for login="tester").
5.5. Resource bundle for messages -> typo in file name: "message.properites"
Best regards
Wolfgang
Re: JSF with Eclipse - Tutorial [message #476063 is a reply to message #476062] Thu, 13 November 2008 16:18 Go to previous messageGo to next message
Hi Wolfgang,
thank you for the feedback.
To 1.5 I believe the following is true (I added it also to the article):
JSP EL expressions are using the ${...} syntax. These EL expressions are
immediately evaluated. JSF EL expressions are of the type #{...}. These
are only evaluated when needed (and otherwisestored as strings).
To 3.3. Shame, I really would like to have a separate download for this.
I'm neither using JBoss nor do I want to download glassfish just for
these libs. So I hope for a better and brighter future and leave this
comment in the article... ;-)
4.4 Fixed
5.4. Fixed
5.5 Fixed
Best regards, Lars
Wolfgang Knauf wrote:
> Hi Lars,
> good tutorial!
> Some minor things:
> end with "}" " => could you explain the difference beetween "$" and "#"
> (I know that there is one, but I don't know it myself ;-) )
> please email this information to me." => there is no separate download,
> it seems to be part of the JavaEE5 RI
> (http://java.sun.com/javaee/downloads/index.jsp). I found it also as
> part of JBoss 5.
> 5.4. Validators
> login="tester").
> Best regards
> Wolfgang
Lars Vogel
http://www.vogella.de/eclipse.html - Tutorials about Eclipse
http://www.vogella.de/articles/RichClientPlatform/article.ht ml - Eclipse
RCP Tutorial
Re: JSF with Eclipse - Tutorial [message #476064 is a reply to message #476063] Fri, 14 November 2008 07:02 Go to previous messageGo to next message
Member
Hi Larx,
I found this article about the "Unified EL":
http://java.sun.com/products/jsp/reference/techart/unifiedEL .html
If I find the time to read it, it will hopefully remove the fog in my brain ;-).
There seems to be more about it than just deferred evaluation.
Here is a direct download link:
https://javaserverfaces.dev.java.net/servlets/ProjectDocumen tList?folderID=5220&expandFolder=5220&folderID=8467
Best regards
Wolfgang
Re: JSF with Eclipse - Tutorial [message #476065 is a reply to message #476064] Fri, 14 November 2008 14:25 Go to previous messageGo to next message
> Hi Larx,
>> article): JSP EL expressions are using the ${...} syntax. These EL
>> expressions are immediately evaluated. JSF EL expressions are of the
>> type #{...}. These are only evaluated when needed (and otherwisestored
>> as strings).
> brain ;-). There seems to be more about it than just deferred evaluation.
Thanks. I'll include this in the references of the articles.
>> this. I'm neither using JBoss nor do I want to download glassfish just
>> for these libs. So I hope for a better and brighter future and leave
>> this comment in the article... ;-)
Thanks.
> Best regards
> Wolfgang
Lars Vogel
RCP Tutorial
Re: JSF with Eclipse - Tutorial [message #476066 is a reply to message #476061] Fri, 14 November 2008 17:15 Go to previous messageGo to next message
Cameron Bateman is currently offline Cameron Bateman
This looks really good! One thing you will be interested to know is that
starting in Galileo, the current JSF library concept is going to be
replaced by a pure classpath container concept. This solve some
outstanding bugs like ones related to broken source attachments.
I'll see if we can link this from the JSF tools project page. It is
definitely more up to date than the current tutorial.
--Cam
Re: JSF with Eclipse - Tutorial [message #476108 is a reply to message #476064] Fri, 14 November 2008 17:23 Go to previous messageGo to next message
In JSP 2.0 and before the main difference is, as you say, early vs.
late-bound compilation. ${} is resolved when the JSP page is compiled
into Java. #{} is not resolved until the compiled Java for a JSP is
executed.
So the expression: bean.foo
When it's in ${bean.foo}, the variable 'bean' must be defined when the JSP
page is compiled. You can think of this as similar to variables in Java.
When it's in #{bean.foo}, the variable bean need not be defined until
runtime. That's why it is used in JSF, since JSF injects things into the
runtime that JSP doesn't know about at compile time, like managed beans.
In JSP 2.1 (Faces 1.2), Unified EL created a separate standard for EL. In
the new standard, the meaning of $ vs. # is left to the implementer.
However, I believe in the JSP context the meaning is the same. On the
other hand, in something like Facelets all EL is "late-bound" regardless
of $ or #.
--Cam
Re: JSF with Eclipse - Tutorial [message #476109 is a reply to message #476066] Fri, 14 November 2008 17:41 Go to previous message
Thank you.
> that starting in Galileo, the current JSF library concept is going to be
Very good: I saw today the announcement:
detailshttp://www.eclipse.org/webtools/development/news/3.1M 3/
> --Cam
Thank you. Thank would be very nice.
Re: JSF with Eclipse - Tutorial [message #618731 is a reply to message #476061] Thu, 13 November 2008 07:47 Go to previous message
Member
Hi Lars,
good tutorial!
Some minor things:
5.4. Validators
Best regards
Wolfgang
Re: JSF with Eclipse - Tutorial [message #618732 is a reply to message #476062] Thu, 13 November 2008 16:18 Go to previous message
Hi Wolfgang,
4.4 Fixed
5.4. Fixed
5.5 Fixed
Best regards, Lars
> Hi Lars,
> good tutorial!
> Some minor things:
> part of JBoss 5.
> 5.4. Validators
> login="tester").
> Best regards
> Wolfgang
Lars Vogel
RCP Tutorial
Re: JSF with Eclipse - Tutorial [message #618733 is a reply to message #476063] Fri, 14 November 2008 07:02 Go to previous message
Member
Hi Larx,
Best regards
Wolfgang
Re: JSF with Eclipse - Tutorial [message #618734 is a reply to message #476064] Fri, 14 November 2008 14:25 Go to previous message
> Hi Larx,
>> as strings).
Thanks.
> Best regards
> Wolfgang
Lars Vogel
RCP Tutorial
Re: JSF with Eclipse - Tutorial [message #618735 is a reply to message #476061] Fri, 14 November 2008 17:15 Go to previous message
--Cam
Re: JSF with Eclipse - Tutorial [message #618736 is a reply to message #476064] Fri, 14 November 2008 17:23 Go to previous message
executed.
of $ or #.
--Cam
Re: JSF with Eclipse - Tutorial [message #618737 is a reply to message #476066] Fri, 14 November 2008 17:41 Go to previous message
Thank you.
> --Cam
Previous Topic:JSF with Eclipse - Tutorial
Next Topic:Visual Editor
Current Time: Sat May 18 11:41:50 EDT 2013
Powered by FUDForum. Page generated in 0.02140 seconds
