Home » Eclipse Projects » JavaServer Faces » NPE from faces config editor
NPE from faces config editor [message #476058] Mon, 10 November 2008 09:15 Go to next message
Michael Giroux is currently offline Michael Giroux
Member
As background, it is important to note that this error occurs in a project
that was originally a simple Java project. It has been migrated to
Dynamic Web Project by manually updating .project and .classpath files so
there may well be some issues with my changes.
That said, does the stack trace suggest anything obvious. If not, don't
spend any time on this.
Michael
eclipse.buildId=M20080911-1700
java.version=1.6.0_10
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
This is a continuation of log file
C:\EclipseWorkspace\Default\.metadata\.bak_1.log
Created Time: 2008-11-07 15:11:24.084
Error
Mon Nov 10 07:07:44 GMT-07:00 2008
Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
org.eclipse.jst.jsf.facesconfig.ui.FacesConfigEditor.getDele gatingZoomManager(FacesConfigEditor.java:950)
org.eclipse.jst.jsf.facesconfig.ui.FacesConfigEditor.getAdap ter(FacesConfigEditor.java:995)
org.eclipse.gef.ui.actions.ZoomComboContributionItem$1.partA ctivated(ZoomComboContributionItem.java:83)
at org.eclipse.ui.internal.PartListenerList$1.run(PartListenerL ist.java:72)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
org.eclipse.ui.internal.PartListenerList.fireEvent(PartListe nerList.java:57)
org.eclipse.ui.internal.PartListenerList.firePartActivated(P artListenerList.java:70)
org.eclipse.ui.internal.PartService.firePartActivated(PartSe rvice.java:186)
at org.eclipse.ui.internal.PartService.setActivePart(PartServic e.java:305)
org.eclipse.ui.internal.WorkbenchPagePartList.fireActivePart Changed(WorkbenchPagePartList.java:56)
at org.eclipse.ui.internal.PartList.setActivePart(PartList.java :126)
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:3491)
org.eclipse.ui.internal.WorkbenchPage.requestActivation(Work benchPage.java:3034)
at org.eclipse.ui.internal.PartPane.requestActivation(PartPane. java:272)
at org.eclipse.ui.internal.EditorPane.requestActivation(EditorP ane.java:98)
at org.eclipse.ui.internal.PartPane.setFocus(PartPane.java:318)
at org.eclipse.ui.internal.EditorPane.setFocus(EditorPane.java: 127)
org.eclipse.ui.internal.PartStack.presentationSelectionChang ed(PartStack.java:846)
at org.eclipse.ui.internal.PartStack.access$1(PartStack.java:82 9)
at org.eclipse.ui.internal.PartStack$1.selectPart(PartStack.jav a:139)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation$1.handleEvent(TabbedStackPresentation.java:133)
org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:267)
org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:276)
org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder.access$1(DefaultTabFolder.java:1)
org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder$2.handleEvent(DefaultTabFolder.java:87)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:7 70)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.ja va:3242)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:20 17)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.j ava:320)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Re: NPE from faces config editor [message #476059 is a reply to message #476058] Mon, 10 November 2008 13:34 Go to previous message
Cameron Bateman is currently offline Cameron Bateman
It looks like a bug. I opened one:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=254777.
Most likely what is happening is that the editor doesn't think you're in a
dynamic web project. Adding the dynamic web projects manually (which
isn't "supported" behaviour, but should work) requires to you to edit
settings/org.eclipse.wst.common.project.facet.core.xml. To see what
should do there, create a new empty dynamic web project with the JSF facet
and look at the file that gets created.
--Cam
Re: NPE from faces config editor [message #618728 is a reply to message #476058] Mon, 10 November 2008 13:34 Go to previous message
--Cam
Previous Topic:NPE from faces config editor
Next Topic:JSF 2.0 support?
Current Time: Tue May 21 02:53:22 EDT 2013
Powered by FUDForum. Page generated in 0.01541 seconds
