Home » Eclipse Projects » JavaServer Faces » standard JSF to iceFaces
standard JSF to iceFaces [message #475967] Fri, 25 April 2008 04:36 Go to next message
Mario is currently offline Mario
Member
I learn jsf but already have a need to use a iceFaces paginatorTable.
Unfortunatelly I have a problems to use iceFaces componentsin a eclipse
tutorial like
http://www.eclipse.org/articles/article.php?file=Article-Ecl ipseDbWebapps/index.html,
so I will ask you forhelp. This is a standard jsf form: <form
action="demo.jsp" method="post">
<table>
<tr>
<td>Your name: (optional)</td>
<td><input type='text' name='name' value="${name}"></td>
</tr>
<tr>
<td>Your comments:</td>
<td><textarea name='comments' rows="6"
cols="40">${comments}</textarea></td>
</tr>
<tr>
<td></td>
<td><input type='submit' name='action' value='Submit'>
</tr>
</table>
<h3>${msg}</h3>
</form>
Can I use iceFaces components instead of standards jsf on a next way?For
example, for textarea: <ice:inputTextarea id="TxtCmt"
value="#{textFields.comments}"
cols="20" rows="4"
partialSubmit="true"
valueChangeListener="#{textFields.effectChangeListener}"
style="width:280px;height:80px;overflow:
auto;" />
Do I need a <form> or bean bellow exist instead of standard jsf form./* MPL
License text (see http://www.mozilla.org/MPL/) */
package
org.icefaces.application.showcase.view.bean.examples.compone nt.textEntry;
import org.icefaces.application.showcase.view.bean.BaseBean;
* <p>The TextFieldsBean class is the backing bean for the Text Entry
* demonstration. It is used to store the values of the input fields.</p>
public class TextFieldsBean extends BaseBean {
* The different kinds of text input fields.
private String name;
private String password;
private String comments;
* Gets the name property.
* @return value of name property
public String getName() {
return name;
* Sets the name property
* @param newValue new value of the name property
public void setName(String newValue) {
name = newValue;
* Gets the password property.
* @return value of the password property
public String getPassword() {
return password;
* Sets the password property.
* @param newValue new value of the password property
public void setPassword(String newValue) {
password = newValue;
* Gets the comments property.
* @return value of the comments property
public String getComments() {
return comments;
* Sets the comments property.
* @param newValue new value of the comments property
public void setComments(String newValue) {
comments = newValue;
  • Attachment: tag_2.gif
    (Size: 0.16KB, Downloaded 159 times)
  • Attachment: tag_3.gif
    (Size: 0.16KB, Downloaded 128 times)
  • Attachment: tag_4.gif
    (Size: 0.16KB, Downloaded 125 times)
  • Attachment: tag_5.gif
    (Size: 0.16KB, Downloaded 126 times)
Re: standard JSF to iceFaces [message #475968 is a reply to message #475967] Fri, 25 April 2008 06:18 Go to previous messageGo to next message
Member
Or, more simplier, I need a "editing database" iceFaces example :)
"Mario" <mzupan@vup.hr> wrote in message
news:fus56k$ehe$1@build.eclipse.org...
>tutorial like
> <table>
> <tr>
> </tr>
> <tr>
> </tr>
> <tr>
> <td></td>
> </tr>
> </table>
> <h3>${msg}</h3>
> </form>
> cols="20" rows="4"
> auto;" />
> MPL License text (see http://www.mozilla.org/MPL/) */
> package
> return name;
> name = newValue;
> return password;
> return comments;
Re: standard JSF to iceFaces [message #475969 is a reply to message #475968] Fri, 25 April 2008 17:27 Go to previous messageGo to next message
Yury Kats is currently offline Yury Kats
www.icefaces.org
And, as far as I remember, ICEfaces has its own set of Eclipse plugins for
integrating into IDE.
Re: standard JSF to iceFaces [message #475970 is a reply to message #475969] Mon, 28 April 2008 02:17 Go to previous message
Member
"Yury Kats" <ykats@us.ibm.com> wrote in message
news:futi7t$udd$1@build.eclipse.org...
> www.icefaces.org
I installed plugin and components works but I need to adjust this example:
http://component-showcase.icefaces.org/component-showcase/sh owcase.iface
to insert, update and delete from the derby database which I add to my
project through the DatabaseExplorer. I also got the data in a standard jsf
table, without the DataTableBase bean.
Re: standard JSF to iceFaces [message #617770 is a reply to message #475967] Fri, 25 April 2008 06:18 Go to previous message
Member
>tutorial like
> <table>
> <tr>
> </tr>
> <tr>
> </tr>
> <tr>
> <td></td>
> </tr>
> </table>
> <h3>${msg}</h3>
> </form>
> cols="20" rows="4"
> auto;" />
> package
> return name;
> name = newValue;
> return password;
> return comments;
Re: standard JSF to iceFaces [message #617773 is a reply to message #475968] Fri, 25 April 2008 17:27 Go to previous message
www.icefaces.org
Re: standard JSF to iceFaces [message #617776 is a reply to message #475969] Mon, 28 April 2008 02:17 Go to previous message
Member
> www.icefaces.org
Previous Topic:standard JSF to iceFaces
Next Topic:Customizing palette in Web Page Editor
Current Time: Mon May 20 10:24:42 EDT 2013
Powered by FUDForum. Page generated in 0.04585 seconds
