Home » Modeling » UML2 Tools » uml2tools 0.9.0M2 requirements
| uml2tools 0.9.0M2 requirements [message #475803] |
Fri, 31 October 2008 18:20  |
Jörg von Frantzius Messages: 15 Registered: July 2009 |
Junior Member |
<html>
<head>
</head>
Hi,<br>
<br>
I downloaded the modeling package of eclipse 3.4.1 and tried to install
uml2tools 0.9.0M2 from the MDT update site. Unfortunately, update
manager (p2) it tells me:<br>
<blockquote>Cannot find a solution satisfying the following
requirements Match[requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.ui.workbench/[3.5.0,4. 0.0)]. <br>
<br>
</blockquote>
Now does uml2tools really require eclipse 3.5.0 by itself, or through
one of its dependencies? I may also have just messed up my installation
by installing some available updates, though.<br>
<br>
Regards,<br>
Jörg<br>
</body>
</html>
| Re: uml2tools 0.9.0M2 requirements [message #475804 is a reply to message #475803] |
Fri, 31 October 2008 19:09   |
Junior Member |
<html>
<head>
</head>
Indeed <a class="moz-txt-link-freetext" href=" http://www.eclipse.org/modeling/mdt/downloads/?project=uml2t ools"> http://www.eclipse.org/modeling/mdt/downloads/?project=uml2t ools</a>
lists eclipse 3.5 as a requirement for 0.9.0.<br>
<br>
However, after downloading eclipse 3.5 and installing all requisites
from the appropriate update managers, this one remains:<br>
<blockquote>Cannot complete the request. See the details.<br>
Cannot find a solution satisfying the following requirements
org.eclipse.emf.edit [2.5.0.v200809231800].<br>
</blockquote>
When I look at my installed plugins, though, there is
org.eclipse.emf.edit 2.5.0.v200809231800 in the list.<br>
<br>
Uhm, what could be the problem here?<br>
<br>
Thanks for any hints,<br>
Jörg<br>
<br>
Jörg von Frantzius wrote:
<blockquote cite="mid:gefsq3$ogb$1@build.eclipse.org" type="cite">Hi,<br>
<br>
<br>
</blockquote>
<br>
Regards,<br>
Jörg<br>
</blockquote>
<br>
</body>
</html>
| Re: uml2tools 0.9.0M2 requirements [message #475870 is a reply to message #475866] |
Tue, 04 November 2008 11:14  |
Originally posted by: joerg.von.frantzius.artnology.com
Hi Michael,
thanks a lot for checking this. I must admit that in the meantime I
decided to go for the Topcased UML editor, since I found it to be more
easily useable. Also the Topcased SMUC plugin allows for generating Java
source code for a UML2 statemachine, which is exactly what I had been
looking for.
Sorry for stealing your time,
Jörg
Michael Golubev wrote:
> Hello Jörg,
> I have just re-checked that U2T 0.9.0M2 can be installed from update
> manager into the following environment:
> Eclipse platform 3.5M2 OCL 1.3.0M2 EMF 2.5.0M2 EMF Query 1.2.0 EMF
> Transaction 1.3.0M2 EMF Validation 1.3.0M2 GEF 3.5.0M2 GMF 2.2.0M2
> UML2 3.0.0M2
> In this configuration, P2 does not claim any problems while installing
> U2T M2. Please make sure that you have all of these features in place.
> As a possible workaround, you can install U2T dependencies without P2
> by downloading all dependencies in separate zips, and unpacking
> everything manually into eclipse installation folder (dropins should
> aslo work).
> Just in case, below is the list of URLs that were actually used by M2
> build.
> http://download.eclipse.org/eclipse/downloads/drops/S-3.5M2- 200809180100/
> http://download.eclipse.org/modeling/emf/emf/downloads/drops /2.5.0/S200809231800/emf-sdo-xsd-SDK-2.5.0M2.zip
> http://download.eclipse.org/modeling/mdt/uml2/downloads/drop s/3.0.0/S200809240156/mdt-uml2-SDK-3.0.0M2.zip
> http://emft.eclipse.org/modeling/mdt/ocl/downloads/drops/1.3 .0/S200809241410/mdt-ocl-SDK-1.3.0M2.zip
> http://download.eclipse.org/modeling/emf/query/downloads/dro ps/1.2.0/R200806091744/emf-query-SDK-1.2.0.zip
> http://download.eclipse.org/modeling/emf/transaction/downloa ds/drops/1.3.0/S200809241724/emf-transaction-SDK-1.3.0M2.zip
> http://download.eclipse.org/modeling/emf/validation/download s/drops/1.3.0/S200809241617/emf-validation-SDK-1.3.0M2.zip
> http://download.eclipse.org/tools/gef/downloads/drops/3.5.0/ S200809240157/GEF-SDK-3.5.0M2.zip
> http://emft.eclipse.org/modeling/gmf/gmf/downloads/drops/2.2 .0/S200809301125/gmf-sdk-2.2.0M2.zip
> Please note that for any other build you can always find the list of
> actually used binaries at the build log. Say, log for M2 is here:
> http://download.eclipse.org/modeling/mdt/uml2tools/downloads /drops/0.9.0/S200810040708/buildlog.txt,
> and at the very beginning of the log you can see the list of
> dependencies download URL's.
> Hope it helps, Michael
| Re: uml2tools 0.9.0M2 requirements [message #623083 is a reply to message #475803] |
Junior Member |
<html>
<head>
</head>
<br>
</blockquote>
<br>
<br>
Jörg<br>
<br>
<br>
<br>
</blockquote>
<br>
Regards,<br>
Jörg<br>
</blockquote>
<br>
</body>
</html>
| Re: uml2tools 0.9.0M2 requirements [message #623092 is a reply to message #475866] |
Hi Michael,
looking for.
Jörg
> Hello Jörg,
> UML2 3.0.0M2
> aslo work).
> build.
Current Time: Sun May 26 01:18:31 EDT 2013
Powered by FUDForum. Page generated in 0.01902 seconds
