Home » Eclipse Projects » Platform - User Assistance (UA) » Eclipse Help System WAR file does not pick up plugin_customization
Eclipse Help System WAR file does not pick up plugin_customization [message #475643] Thu, 18 June 2009 16:38 Go to next message
robert ly is currently offline robert ly
I am migrating some plugins that were previously hosted in the IEHS
standalone Eclipse help system to a Eclipse 3.4 Help system WAR
deployment. I set the eclipse.product property in config.ini to the plugin
that contains my plugin_customization.ini
(eclipse.product=com.emc.ic.help), but the customizations are not picked
up. They worked fine in the IEHS deployment. Here is the
plugin_customization file:
org.eclipse.help.base/banner=/com.emc.ic.help/banner.htm
org.eclipse.help.base/banner_height=110
org.eclipse.help.base/windowTitlePrefix=false
org.eclipse.help.base/linksView=false
org.eclipse.help.base/help_home=/com.emc.ic.help/using_syste m/about_the_system.html
org.eclipse.help/baseTOCS=/com.emc.ic.help/toc.xml
So, I went ahead and modified preferences.ini in org.eclipse.help.base to
get the banner to show up. That worked fine, but I assume this isn't
ideal. So I went to go do the same thing in the org.eclipse.help plugin to
get my plugins to be ordered, and even when modifying the preferences.ini
inside that plugin, I can't get my books to be ordered correctly.
Also, I clear my Tomcat cache every time I make a change. Any ideas? The
documentation on the WAR deployment is very sparse.
Re: Eclipse Help System WAR file does not pick up plugin_customization [message #475651 is a reply to message #475643] Thu, 18 June 2009 16:51 Go to previous message
Nevermind, i found the answer to this in an older thread. You have to
include the plugin ID and extension ID for the eclipse.product property.
The docs only mention that you need plugin ID I believe...
Re: Eclipse Help System WAR file does not pick up plugin_customization [message #623417 is a reply to message #475643] Thu, 18 June 2009 16:51 Go to previous message
Previous Topic:Eclipse Help System WAR file does not pick up plugin_customization
Next Topic:Standalone infocenter home page and locale
Current Time: Thu May 23 06:06:02 EDT 2013
Powered by FUDForum. Page generated in 0.01643 seconds
