| Testing an exported rcp-app [message #467921] |
Mon, 03 August 2009 07:49  |
Denis Ungemach Messages: 3 Registered: July 2009 |
Junior Member |
I ran all examples listed on the swtbot site succesfully, so i tried to
run new tests with an exported rcp-application.
I reimported the plugins and was able to start the application in eclipse,
but i the tests didnŽt run. After i added the plugins of my application to
the swtbotlauncher (at the plugins-tab), i couldnŽt even run the basetests
on eclipse.
Maybe someone got an idea, what the problem is. Of course, it seems, that
my plugins disturb the swtbot, but i donŽt know, how to prevent that.
I got this error:
org.eclipse.swtbot.swt.finder.exceptions.WidgetNotFoundExcep tion: Could
not find widget.
org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntilWidgetA ppears(SWTBotFactory.java:346)
org.eclipse.swtbot.eclipse.finder.SWTEclipseBot.view(SWTEcli pseBot.java:111)
org.eclipse.swtbot.eclipse.finder.SWTEclipseBot.view(SWTEcli pseBot.java:93)
at TestCase.canCreateANewJavaProject(TestCase.java:27)
org.junit.internal.runners.TestMethodRunner.executeMethodBod y(TestMethodRunner.java:99)
org.junit.internal.runners.TestMethodRunner.runUnprotected(T estMethodRunner.java:81)
org.junit.internal.runners.BeforeAndAfterRunner.runProtected (BeforeAndAfterRunner.java:34)
org.junit.internal.runners.TestMethodRunner.runMethod(TestMe thodRunner.java:75)
org.junit.internal.runners.TestMethodRunner.run(TestMethodRu nner.java:45)
org.junit.internal.runners.TestClassMethodsRunner.invokeTest Method(TestClassMethodsRunner.java:66)
org.junit.internal.runners.TestClassMethodsRunner.run(TestCl assMethodsRunner.java:35)
org.junit.internal.runners.TestClassRunner$1.runUnprotected( TestClassRunner.java:42)
at org.junit.internal.runners.TestClassRunner.run(TestClassRunn er.java:52)
org.eclipse.swtbot.swt.finder.junit.SWTBotJunit4ClassRunner. run(SWTBotJunit4ClassRunner.java:55)
org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.r un(JUnit4TestReference.java:45)
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
org.eclipse.swtbot.eclipse.core.RemotePluginTestRunner.main( RemotePluginTestRunner.java:64)
org.eclipse.swtbot.eclipse.core.UITestApplication.runTests(U ITestApplication.java:117)
org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.java:68)
at java.lang.Thread.run(Unknown Source)
Caused by: org.eclipse.swtbot.swt.finder.widgets.TimeoutException: Timeout
after: 5000 ms.: Could not find view matching: (an instance of
org.eclipse.ui.IViewReference and with name '"Welcome"')
org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBot Factory.java:396)
org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBot Factory.java:370)
org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBot Factory.java:358)
org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntilWidgetA ppears(SWTBotFactory.java:344)
... 27 more
FUDForum. Page generated in 0.07312 seconds
