| Infocenter web app: configuring logging in JBoss 4.2.1 [message #472519] |
Tue, 08 April 2008 00:08  |
Peter Desjardins Messages: 21 Registered: July 2009 |
Junior Member |
I've been using the Infocenter web application in JBoss 4.0.1 for some
time now. I am required to also make it work under JBoss 4.2.1.
Unfortunately JBoss 4.2.1 will not run the web application because of
some incompatibility between log4j in JBoss and commons-logging in the
WAR file.
I see this error when I try to open the infocenter.
org.apache.commons.logging.LogConfigurationException:
org.apache.commons.logging.LogConfigurationException: No suitable Log
constructor [Ljava.lang.Class;@1cfc277 for
org.apache.commons.logging.impl.Log4JLogger (Caused by
java.lang.NoClassDefFoundError: org/apache/log4j/Category) (Caused by
java.lang.NoClassDefFoundError: org/apache/log4j/Category))
Has anyone else run the infocenter web application under JBoss 4.2 or
higher? Did you see this problem and were you able to fix it?
One developer I consulted suggested configuring the web application to
use Java logging instead of log4j. I am trying to try that but have not
succeeded yet.
Thanks for your help.
Peter Desjardins
FUDForum. Page generated in 0.01566 seconds
