Home » Eclipse Projects » JavaServer Faces » Add Managed Bean From Config Editor
Add Managed Bean From Config Editor [message #474951] Tue, 31 July 2007 04:39 Go to next message
Eclipse User
Originally posted by: gurkanerdogdu.yahoo.com
Hi;
When I want to add written managed bean from JSF config editor, I get the
following exception when I hit the Next button;
Scenario:
I used the option "Using an existing Java Class" and browse my class and
Exception : Unhandled Event Loop Exception
java.lang.ClassCastException:
org.eclipse.jst.j2ee.webapplication.internal.impl.WebAppReso urceImpl
org.eclipse.jst.jee.model.internal.Web25ModelProvider.getMod elObject(Web25ModelProvider.java:35)
org.eclipse.jst.jee.model.internal.JEE5ModelProvider.getMode lObject(JEE5ModelProvider.java:113)
org.eclipse.jst.jsf.core.jsfappconfig.JSFAppConfigUtils.getC onfigFilesFromContextParam(JSFAppConfigUtils.java:220)
org.eclipse.jst.jsf.core.jsfappconfig.ContextParamSpecifiedJ SFAppConfigLocater.getFilenames(ContextParamSpecifiedJSFAppC onfigLocater.java:154)
org.eclipse.jst.jsf.core.jsfappconfig.WebContentRelativeJSFA ppConfigLocater.locateProviders(WebContentRelativeJSFAppConf igLocater.java:45)
org.eclipse.jst.jsf.core.jsfappconfig.ContextParamSpecifiedJ SFAppConfigLocater.startLocating(ContextParamSpecifiedJSFApp ConfigLocater.java:47)
org.eclipse.jst.jsf.core.jsfappconfig.JSFAppConfigManager.st artConfigLocaters(JSFAppConfigManager.java:240)
org.eclipse.jst.jsf.core.jsfappconfig.JSFAppConfigManager.in itialize(JSFAppConfigManager.java:201)
org.eclipse.jst.jsf.core.jsfappconfig.JSFAppConfigManager.<init >(JSFAppConfigManager.java:170)
org.eclipse.jst.jsf.core.jsfappconfig.JSFAppConfigManager.ge tInstance(JSFAppConfigManager.java:102)
org.eclipse.jst.jsf.facesconfig.ui.util.ManagedBeanUtil.isBe anDuplicate(ManagedBeanUtil.java:41)
org.eclipse.jst.jsf.facesconfig.ui.util.ManagedBeanUtil.getD efaultManagedBeanName(ManagedBeanUtil.java:81)
org.eclipse.jst.jsf.facesconfig.ui.wizard.ManagedBeanPropert yPage.initialize(ManagedBeanPropertyPage.java:244)
org.eclipse.jst.jsf.facesconfig.ui.wizard.ManagedBeanPropert yPage.setPreviousPage(ManagedBeanPropertyPage.java:217)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog. java:1112)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:820)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:369)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:616)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
org.eclipse.jst.jsf.facesconfig.ui.section.ManagedBeanMaster Section.addButtonSelected(ManagedBeanMasterSection.java:123)
org.eclipse.jst.jsf.facesconfig.ui.section.FacesConfigMaster Section$1.widgetSelected(FacesConfigMasterSection.java:150)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
Re: Add Managed Bean From Config Editor [message #474952 is a reply to message #474951] Tue, 31 July 2007 13:41 Go to previous messageGo to next message
Gerry Kessler is currently offline Gerry Kessler
Hi Gurkan,
Can you tell me more about the application? Was it created from scratch,
or was it imported from a WAR? What JSF version did you specify when you
added the JSF Facet?
Gerry Kessler
WTP JSF Tools Team
Re: Add Managed Bean From Config Editor [message #474954 is a reply to message #474952] Wed, 01 August 2007 02:52 Go to previous messageGo to next message
Eclipse User
Hi Jessler;
I have created the project using Dynamic Web Project with JSF Facet
"1.2". But I did not select the JSF implementation library used in the
project, just selected check box "Server Supplied JSF Implementation", and
adding some component libraries.
In fact the problem(exception) also appears when using the other choice
of managed bean creation; ie "Create a new Java Class" option.
I am using the Eclipse JEE Europa.
But if I added the managed bean descriptions into the faces-config.xml
"Source" tab by hand written, then these beans appeared in "ManagedBean"
tag; but this is very time consuming as you created this editor for easy
manage configuration;
Your help is very appreciated, otherwise I will abondon the use of plugin
and swtich to another options.
Thanks for advance;
Gurkan
Re: Add Managed Bean From Config Editor [message #474955 is a reply to message #474954] Wed, 01 August 2007 12:28 Go to previous message
Gurkan,
I am unable to reproduce your problem.
How was the faces configuration file created? Was it generated during
the JSF facet installation? What about the web.xml? Did you copy
either of these files from somewhere else?
Perhaps you could zip up your project and send it to me?
Gerry Kessler
WTP JSF Tools Team
gerry DOT kessler AT oracle DOT com
Re: Add Managed Bean From Config Editor [message #613256 is a reply to message #474951] Tue, 31 July 2007 13:41 Go to previous message
Hi Gurkan,
Gerry Kessler
WTP JSF Tools Team
Re: Add Managed Bean From Config Editor [message #613260 is a reply to message #474952] Wed, 01 August 2007 02:52 Go to previous message
Eclipse User
Hi Jessler;
Thanks for advance;
Gurkan
Re: Add Managed Bean From Config Editor [message #613261 is a reply to message #474954] Wed, 01 August 2007 12:28 Go to previous message
Gurkan,
Gerry Kessler
WTP JSF Tools Team
Previous Topic:Add Managed Bean From Config Editor
Next Topic:Faces Config editor
Current Time: Fri May 24 02:25:40 EDT 2013
Powered by FUDForum. Page generated in 0.01729 seconds
