Home » Eclipse Projects » JavaServer Faces » extend JSF facet install page
extend JSF facet install page [message #474148] Thu, 12 April 2007 12:16 Go to next message
William is currently offline William
I wonder if there is a easy way to extend or customize JSF facet install
page. For example I want to create another facet depending on jsf facet
so that the pre-built component library can be selected by default in
JSF facet install page.
Re: extend JSF facet install page [message #474149 is a reply to message #474148] Thu, 12 April 2007 16:21 Go to previous message
Cameron Bateman is currently offline Cameron Bateman
Can you not use the JSF library extension point
(org.eclipse.jst.jsf.core.jsfLibraries) to contribute your component
library? Why do you need your own facet? Are there other things it would
do besides contributing a library to the install page?
--Cam
William wrote:
> Thanks
Re: extend JSF facet install page [message #609328 is a reply to message #474148] Thu, 12 April 2007 16:21 Go to previous message
--Cam
William wrote:
> Thanks
Previous Topic:extend JSF facet install page
Next Topic:Updating org.eclipse.jem to version 1.2.3
Current Time: Fri May 24 00:19:29 EDT 2013
Powered by FUDForum. Page generated in 0.11369 seconds
