Home » Modeling » UML2 » update problem with Bidirectional composite aggregation
update problem with Bidirectional composite aggregation [message #473071] Thu, 31 May 2007 18:55 Go to next message
Pradeep is currently offline Pradeep
Member
When I have bi-directional associations, if I update oneside otherside is
automatically getting updated.
Does it anyway differ if I one side of the relationship is composition.
i.e
A contains a list of Bs, and Each B has a reference to A.
class A {
// I set the association to composite aggregation.
EList<B> bs;
class B {
A a;
Now, I am forced to update both the objects. Otherwise it is resulting in
NullPointerExeception.
Pradeep
Re: update problem with Bidirectional composite aggregation [message #473081 is a reply to message #473071] Fri, 01 June 2007 11:01 Go to previous messageGo to next message
james bruck is currently offline james bruck
Hi Pradeep,
You can make your composition association navigable in one way by doing the
following...
Create a class call it "Class1".
Create a class call it "Class2".
Create an association call it "A".
Create a property under Class1.
Set the aggregation to composite.
Set the association to "A".
Set its type to Class2.
Set multiplicity .
Create a property under "A"
Set its type to Class1.
Set its association to "A"
Set its aggregation to "none"
For association "A"
Set the Member ends to the two newly created properties.
When you convert that to .ecore you should see..
Class1 with EReference of type Class2.
Class2.
It sounds like that is what you want to do.
- James.
"Pradeep" <eclipseuser123@yahoo.com> wrote in message
news:f3njpp$jm2$1@build.eclipse.org...
> i.e
> class A {
> EList<B> bs;
> class B {
> A a;
> Thanks
> Pradeep
Re: update problem with Bidirectional composite aggregation [message #473082 is a reply to message #473071] Fri, 01 June 2007 11:39 Go to previous messageGo to next message
Kenn Hussey is currently offline Kenn Hussey
Pradeep,
Bidirectional compositions should not be a problem. I assume you set the
aggregation kind to 'composite' for just the owning end?
Kenn
> i.e
> class A {
> EList<B> bs;
> class B {
> A a;
> Thanks
> Pradeep
Re: update problem with Bidirectional composite aggregation [message #473084 is a reply to message #473081] Fri, 01 June 2007 12:49 Go to previous messageGo to next message
Member
I did exactly the way James suggested earlier. My question is how do I get
bidirectional navigation in case of composite aggregation.
Yes, I did set the aggregation kind to composite just for the owned end.
But changing the other end to composite is not helping either.
i.e.
If I say
a.getBs().add(b)
and call b.getA() it is returning null.
Pradeep
Pradeep,
Kenn
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:f3pcbe$t50$2@build.eclipse.org...
> Hi Pradeep,
> the
> following...
> Set multiplicity .
> For association "A"
> Class2.
> - James.
>> i.e
>> class A {
>> EList<B> bs;
>> class B {
>> A a;
>> Thanks
>> Pradeep
Re: update problem with Bidirectional composite aggregation [message #473086 is a reply to message #473084] Fri, 01 June 2007 15:02 Go to previous message
If you want a bidirectional composite association then you need to do
something a bit different...
( I thought you really wanted a "one way navigable" composite association ).
Try this ...
Set multiplicity .
Create a property under Class2
For association "A"
James.
news:f3pin7$4oi$1@build.eclipse.org...
> i.e.
> If I say
> a.getBs().add(b)
> Thanks
> Pradeep
> Pradeep,
> Kenn
> > Hi Pradeep,
> > the
> > following...
> > Set multiplicity .
> > For association "A"
> > Class2.
> > Regards,
> > - James.
> >> Hi,
is
> >> i.e
> >> class A {
> >> EList<B> bs;
> >> class B {
> >> A a;
in
> >> Thanks
> >> Pradeep
Re: update problem with Bidirectional composite aggregation [message #619669 is a reply to message #473071] Fri, 01 June 2007 11:01 Go to previous message
Hi Pradeep,
following...
Set multiplicity .
For association "A"
Class2.
- James.
> i.e
> class A {
> EList<B> bs;
> class B {
> A a;
> Thanks
> Pradeep
Re: update problem with Bidirectional composite aggregation [message #619670 is a reply to message #473071] Fri, 01 June 2007 11:39 Go to previous message
Pradeep,
Kenn
> i.e
> class A {
> EList<B> bs;
> class B {
> A a;
> Thanks
> Pradeep
Re: update problem with Bidirectional composite aggregation [message #619672 is a reply to message #473081] Fri, 01 June 2007 12:49 Go to previous message
Member
i.e.
If I say
a.getBs().add(b)
Pradeep
Pradeep,
Kenn
> Hi Pradeep,
> the
> following...
> Set multiplicity .
> For association "A"
> Class2.
> - James.
>> i.e
>> class A {
>> EList<B> bs;
>> class B {
>> A a;
>> Thanks
>> Pradeep
Re: update problem with Bidirectional composite aggregation [message #619674 is a reply to message #473084] Fri, 01 June 2007 15:02 Go to previous message
Try this ...
Set multiplicity .
For association "A"
James.
> i.e.
> If I say
> a.getBs().add(b)
> Thanks
> Pradeep
> Pradeep,
> Kenn
> > Hi Pradeep,
> > the
> > following...
> > Set multiplicity .
> > For association "A"
> > Class2.
> > Regards,
> > - James.
> >> Hi,
is
> >> i.e
> >> class A {
> >> EList<B> bs;
> >> class B {
> >> A a;
in
> >> Thanks
> >> Pradeep
Previous Topic:Where did getAppliedVersion and applyProfile move to?
Next Topic:heavyweight extension in OMG specifications
Current Time: Sat May 25 14:01:26 EDT 2013
Powered by FUDForum. Page generated in 0.05398 seconds
