| How do I refer to Types in another uml model? [message #473050] |
Wed, 30 May 2007 16:37  |
Pradeep Messages: 54 Registered: July 2009 |
Member |
I have two uml models and corresponding ecore exported files. I would like
to refer the Types in one of these uml models in another uml model. Is it
possible? Also how do I make sure that corresponding ecore files are
referenced as well?
Currently I am creating primitive types whenever I need to refer to such a
type. But they are simply too many of them.
Pradeep
| Re: How do I refer to Types in another uml model? [message #473075 is a reply to message #473069] |
Fri, 01 June 2007 09:07  |
Kenn Hussey Messages: 1616 Registered: July 2009 |
See also the "Introduction to UML2 Profiles" article
( http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Intro duction_to_UML2_Profiles/article.html)
on the UML2 documentation page for an explanation of how to reuse types from
type libraries.
Kenn
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:f3n9ui$r77$2@build.eclipse.org...
> Hi Pradeep,
> You could do something like what is done with the primitive types
> libraries
> under org.eclipse.uml2.uml.resources\libraries.
> If you want to use those, you could select "Load Resource..." from your
> "UML
> Editor" menu, then you use use the types in the libraries.
> When you export to ecore, you should get prompted to export those
> referenced
> libraries at that time.
> - James.
> "Pradeep" <eclipseuser123@yahoo.com> wrote in message
> news:f3kn9p$fkv$1@build.eclipse.org...
>> like
>> referenced as well?
>> a
>> Thanks
>> Pradeep
| Re: How do I refer to Types in another uml model? [message #619425 is a reply to message #473050] |
Thu, 31 May 2007 16:07  |
james bruck Messages: 1724 Registered: July 2009 |
Hi Pradeep,
You could do something like what is done with the primitive types libraries
If you want to use those, you could select "Load Resource..." from your "UML
When you export to ecore, you should get prompted to export those referenced
- James.
> referenced as well?
> Thanks
> Pradeep
| Re: How do I refer to Types in another uml model? [message #619438 is a reply to message #473069] |
type libraries.
Kenn
> Hi Pradeep,
> libraries
> "UML
> referenced
> - James.
>> like
>> referenced as well?
>> a
>> Thanks
>> Pradeep
FUDForum. Page generated in 0.02114 seconds
