Home » Modeling » UML2 » Creating Profile, applying stereotype on a Class, saving model --> trouble
Creating Profile, applying stereotype on a Class, saving model --> trouble [message #472540] Mon, 16 April 2007 10:15 Go to next message
Eclipse User
Originally posted by: guillaume.clement.gmail.com
I use the 2 tutorials (getting started and Introduction to UML2 profiles)
to simply create a model, add a package and a stereotyped class.
The creation of the model, the package and the profile (with stereotype)
seem to be good. (I follow the turorials)
The model is serialized into an output file.
Here is the code :
IntroductionToUML2Profiles.registerResourceFactories();
IntroductionToUML2Profiles.registerPathmaps(URI.createURI(ar gs[0]));
Model model = UMLFactory.eINSTANCE.createModel();
model.setName("MonModele");
Package package_ =
GettingStartedWithUML2.createPackage(model.getNearestPackage (), "UnPackage");
Profile test = IntroductionToUML2Profiles.createProfile("documentation");
Stereotype stereotype = IntroductionToUML2Profiles.createStereotype(
test, "document", false);
Class metaclass = IntroductionToUML2Profiles
.referenceMetaclass(test, UMLPackage.Literals.CLASS.getName());
.createExtension(metaclass, stereotype, false);
test.define();
package_.applyProfile(test);
Class maClasse =
GettingStartedWithUML2.createClass(package_,"UneClasse",false);
maClasse.applyStereotype(stereotype);
GettingStartedWithUML2.save(model,URI.createURI("test.uml"));
But when I try to see the model with the editor I got an error message
from the details panel :
java.lang.ArrayIndexOutOfBoundsException: -1
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:5 14)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObjectF orURIFragmentRootSegment(ResourceImpl.java:642)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject( ResourceImpl.java:692)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject( ResourceImpl.java:671)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardRefer ences(XMLHandler.java:989)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.endDocument(XMLHan dler.java:1071)
org.eclipse.uml2.uml.internal.resource.UMLHandler.endDocumen t(UMLHandler.java:43)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .endDocument(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
Source)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:180)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:179)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1094)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:900)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:249)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:264)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:390)
org.eclipse.uml2.uml.editor.presentation.UMLEditor.createMod elGen(UMLEditor.java:879)
org.eclipse.uml2.uml.editor.presentation.UMLEditor.createMod el(UMLEditor.java:912)
org.eclipse.uml2.uml.editor.presentation.UMLEditor.createPag es(UMLEditor.java:1012)
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:277)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:609)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:379)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:219)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2571)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2504)
org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2496)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2481)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2476)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2461)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:515)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:474)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:285)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:138)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:19 5)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:17 6)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:268)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:244)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:310)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(PackageExplorerPart.java:618)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:819)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:850)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:45)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:15 3)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:817)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1078)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1177)
org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3465)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3079)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1945)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1909)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:425)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hod(EclipseAppContainer.java:522)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:147)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:104)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:354)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:170)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:339 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:283)
at org.eclipse.core.launcher.Main.run(Main.java:984)
at org.eclipse.core.launcher.Main.main(Main.java:959)
Any idea ?
Thx
Guillaume
Re: Creating Profile, applying stereotype on a Class, saving model --> trouble [message #472551 is a reply to message #472540] Wed, 18 April 2007 09:50 Go to previous message
Kenn Hussey is currently offline Kenn Hussey
Guillaume,
I'm thinking that we'll need to change the sample code for these articles
since this issue comes up fairly often (you should be able to find similar
threads if you search the newsgroup)... :(
The cause of the problem is that you are saving the model (adding it to a
resource set an serializing it) without the profile having been added to the
same resource set (and serialized). To avoid the problem, be sure that you
save the profile first.
Kenn
"Guillaume Clement" <guillaume.clement@gmail.com> wrote in message
news:5f6958b23dc63f94bdb486d03c152727$1@www.eclipse.org...
> Here is the code :
> Package package_ =
> Profile test =
> test.define();
> Class maClasse =
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Any idea ?
> Thx
> Guillaume
Re: Creating Profile, applying stereotype on a Class, saving model --> trouble [message #607715 is a reply to message #472540] Wed, 18 April 2007 09:50 Go to previous message
Guillaume,
Kenn
> Here is the code :
> Package package_ =
> Profile test =
> test.define();
> Class maClasse =
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Any idea ?
> Thx
> Guillaume
Previous Topic:minor extensions to the UML metamodel
Next Topic:UML Testing profile
Current Time: Wed May 22 22:25:22 EDT 2013
Powered by FUDForum. Page generated in 0.01652 seconds
