Home » Modeling » UML2 » Applying stereotype on Class
Applying stereotype on Class [message #472226] Wed, 04 April 2007 11:09 Go to next message
Eclipse User
Originally posted by: guillaume.clement.gmail.com
I have a model on which I apply a profile.
model.applyProfile(profileDocumentation);
The profileDocumentation isn't null ;-) It cames from an other model.
I get stereotype as I want.
Stereotype stereotype = profileDocumentation.getOwnedStereotype("CU");
Then I create a Class on which I want to apply the stereotype.
org.eclipse.uml2.uml.Class class_ = package_.createOwnedClass(name,
isAbstract);
class_.applyStereotype(stereotype);
But when I look in the UML editor the stereotype isn't applied to my class.
If I select the class and use the menu Element to add a stereotype it
works fine.
Any idea ??
Thx
Guillaume
Re: Applying stereotype on Class [message #472496 is a reply to message #472226] Sun, 08 April 2007 20:46 Go to previous messageGo to next message
james bruck is currently offline james bruck
Guillaume,
From what is described, I cannot tell why applying a stereotype would work
from the editor but not programatically in your application.
You could set a breakpoint in ApplyStereotypeAction where the call to
element.applyStereotype() is being called and see if you are making the same
calls in your application and to make sure the stereotype is applied
properly.
Are there any errors in the log?
Is your stereotype applicable to the given element ?
The article:
http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Intro duction_to_UML2_Profiles/article.html
describes this in detail.
- James.
"Guillaume Clement" <guillaume.clement@gmail.com> wrote in message
news:5722f98c5d32a7a53eb09a4ed38bd2b1$1@www.eclipse.org...
> isAbstract);
> class.
> works fine.
> Any idea ??
> Thx
> Guillaume
Re: Applying stereotype on Class [message #472503 is a reply to message #472496] Tue, 10 April 2007 04:36 Go to previous messageGo to next message
Eclipse User
I use a break point to track the stereotype and its value. Everything
seems to be good.
The stereotype has the right value.
The very ammzing thing is that the stereotype is available in the uml
editor and I can directly aplly it on a class.
Any idea
Thx
Guillaume
Re: Applying stereotype on Class [message #472508 is a reply to message #472503] Wed, 11 April 2007 11:08 Go to previous messageGo to next message
Eclipse User
Still fighting against stereotype...
A few more information...
Here is the code I use to apply stereotype on a class.
The profile comes from an other model 'm' as parameter.
Profile profileDocumentation = m.getAppliedProfile("Documentation");
I apply this profile to a package
specificationTopLevelPackage.applyProfile(profileDocumentati on);
A stereotype is already defined in the profile, its metaclass (already
defined) is UML::Class.
class1 is an instance of Class.
class1.applyStereotype(profileDocumentation.getOwnedStereoty pe( "CU"));
When I look into the uml editor the profile is well applied to the package
but the stereotype isn't applied.
I can obviously apply it with the editor but not with my code.
Any idea ?
Thx
Guillaume
Re: Applying stereotype on Class [message #472509 is a reply to message #472508] Wed, 11 April 2007 11:42 Go to previous messageGo to next message
Guillaume,
Post your profile, and your application and I'll have a look.
It is difficult to say what is going on from the description.
- James.
news:d142486b2f3af7a39bbfc3827990ce35$1@www.eclipse.org...
> Any idea ?
> Thx
> Guillaume
Re: Applying stereotype on Class [message #472532 is a reply to message #472509] Thu, 12 April 2007 04:00 Go to previous messageGo to next message
Eclipse User
Here is my profile (Documentation.profile.uml2):
<uml:Profile xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:uml="http://www.eclipse.org/uml2/1.0.0/UML"
xmi:id="_NQileegqEdulJtUB9wa0tQ" name="Documentation"
metamodelReference="_NQilgugqEdulJtUB9wa0tQ">
<eAnnotations xmi:id="_NQileugqEdulJtUB9wa0tQ" source="attributes">
<details xmi:id="_NQile-gqEdulJtUB9wa0tQ" key="version" value="0"/>
</eAnnotations>
<eAnnotations xmi:id="_NQilfOgqEdulJtUB9wa0tQ" source="ePackages">
<contents xmi:type="ecore:EPackage" xmi:id="_NQilfegqEdulJtUB9wa0tQ"
name="Documentation_0"
nsURI="http:///Documentation_0_NBMdYugqEdulJtUB9wa0tQ.profile.uml2"
nsPrefix="Documentation_0">
<eClassifiers xmi:type="ecore:EClass"
xmi:id="_NQilfugqEdulJtUB9wa0tQ" name="Documentation__CU">
<eAnnotations xmi:id="_NQilf-gqEdulJtUB9wa0tQ" source="stereotype"
references="_NQilhegqEdulJtUB9wa0tQ"/>
</eClassifiers>
xmi:id="_NQilgOgqEdulJtUB9wa0tQ" name="Documentation__RG">
<eAnnotations xmi:id="_NQilgegqEdulJtUB9wa0tQ" source="stereotype"
references="_NQilh-gqEdulJtUB9wa0tQ"/>
</eClassifiers>
</contents>
</eAnnotations>
<packageImport xmi:id="_NQilgugqEdulJtUB9wa0tQ" visibility="private">
<importedPackage xmi:type="uml:Model"
href=" pathmap://UML2_METAMODELS/UML2.metamodel.uml2#_m8qbA686EdiEh 75YJ_3n8g"/>
</packageImport>
<packageImport xmi:id="_NQilg-gqEdulJtUB9wa0tQ">
href=" pathmap://UML2_LIBRARIES/UML2PrimitiveTypes.library.uml2#_Ef RZoK86EdieaYgxtVWN8Q"/>
</packageImport>
<packageImport xmi:id="_NQilhOgqEdulJtUB9wa0tQ">
href=" pathmap://UML2_LIBRARIES/JavaPrimitiveTypes.library.uml2#_Rj myoK86EdieaYgxtVWN8Q"/>
</packageImport>
<ownedMember xmi:type="uml:Stereotype" xmi:id="_NQilhegqEdulJtUB9wa0tQ"
name="CU">
<ownedAttribute xmi:id="_NQilhugqEdulJtUB9wa0tQ" name="base_Class"
visibility="private" association="_NQiliegqEdulJtUB9wa0tQ">
<type xmi:type="uml:Class"
href=" pathmap://UML2_METAMODELS/UML2.metamodel.uml2#_m88uxq86EdiEh 75YJ_3n8g"/>
</ownedAttribute>
</ownedMember>
<ownedMember xmi:type="uml:Stereotype" xmi:id="_NQilh-gqEdulJtUB9wa0tQ"
name="RG">
<ownedAttribute xmi:id="_NQiliOgqEdulJtUB9wa0tQ" name="base_Class"
visibility="private" association="_NQiljegqEdulJtUB9wa0tQ">
</ownedAttribute>
</ownedMember>
<ownedMember xmi:type="uml:Extension" xmi:id="_NQiliegqEdulJtUB9wa0tQ"
memberEnd="_NQiliugqEdulJtUB9wa0tQ _NQilhugqEdulJtUB9wa0tQ">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_NQiliugqEdulJtUB9wa0tQ"
name="extension_CU" visibility="private" type="_NQilhegqEdulJtUB9wa0tQ"
association="_NQiliegqEdulJtUB9wa0tQ" aggregation="composite">
<upperValue xmi:type="uml:LiteralUnlimitedNatural"
xmi:id="_NQili-gqEdulJtUB9wa0tQ" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger"
xmi:id="_NQiljOgqEdulJtUB9wa0tQ"/>
</ownedEnd>
</ownedMember>
<ownedMember xmi:type="uml:Extension" xmi:id="_NQiljegqEdulJtUB9wa0tQ"
memberEnd="_NQiliOgqEdulJtUB9wa0tQ _NQiljugqEdulJtUB9wa0tQ">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_NQiljugqEdulJtUB9wa0tQ"
name="extension_RG" visibility="private" type="_NQilh-gqEdulJtUB9wa0tQ"
association="_NQiljegqEdulJtUB9wa0tQ" aggregation="composite">
xmi:id="_NQilj-gqEdulJtUB9wa0tQ" value="1"/>
xmi:id="_NQilkOgqEdulJtUB9wa0tQ"/>
</ownedEnd>
</ownedMember>
</uml:Profile>
And my application:
private static Profile profileDocumentation;
public static Model createModelFromModel(Model m) {
Model model = UMLFactory.eINSTANCE.createModel();
Package specificationTopLevelPackage =
UseCaseModelToDocumentModel .createPackage(model.getNearestPackage(),"org.application.specification ");
//try to create a class with the CU stereotype
Class myClass = specificationTopLevelPackage.createOwnedClass("my
class",false);
myClass.applyStereotype(stereotype);
return model;
Thx,
Guillaume
Re: Applying stereotype on Class [message #472536 is a reply to message #472532] Thu, 12 April 2007 22:21 Go to previous messageGo to next message
Kenn Hussey is currently offline Kenn Hussey
Guillaume,
This profile is based on an older version of UML2 (1.x) and it looks like
you are trying to apply it to a model based on a newer version (2.x). To
apply this profile, you'll need to migrate it to the new format first - see
the migration guide on the UML2 documentation page
( http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 0_Migration_Guide/guide.html)
for details.
Kenn
news:ef39695386120905aafb7d432a1f2e64$1@www.eclipse.org...
> </eAnnotations>
> </eClassifiers>
> </eClassifiers>
> </contents>
> </eAnnotations>
> </packageImport>
> </packageImport>
> </packageImport>
> name="CU">
> </ownedAttribute>
> </ownedMember>
> name="RG">
> </ownedAttribute>
> </ownedMember>
> </ownedEnd>
> </ownedMember>
> </ownedEnd>
> </ownedMember>
> </uml:Profile>
> And my application:
> Package specificationTopLevelPackage = UseCaseModelToDocumentModel
> class",false);
> return model;
> Thx,
> Guillaume
Re: Applying stereotype on Class [message #472538 is a reply to message #472536] Fri, 13 April 2007 03:47 Go to previous messageGo to next message
Eclipse User
Hi Kenn.
Thanks a lot for your post.
I was very surprising beacause I use MagicDraw to design this profile and
export it. But you're right the export are for version 1.x
I will migrate my profile.
Guillaume
Re: Applying stereotype on Class [message #472539 is a reply to message #472538] Fri, 13 April 2007 11:08 Go to previous messageGo to next message
Eclipse User
I just migrate the profile to a new file with the link you gave me Kenn.
Here it is (version 2.1):
<uml:Profile xmi:version="2.1"
xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:uml="http://www.eclipse.org/uml2/2.0.0/UML"
xmi:id="_6FnduejzEdulJtUB9wa0tQ" name="Documentation"
metamodelReference="_6FndwujzEdulJtUB9wa0tQ">
<eAnnotations xmi:id="_6FndvOjzEdulJtUB9wa0tQ"
source="http://www.eclipse.org/uml2/2.0.0/UML">
<contents xmi:type="ecore:EPackage" xmi:id="_GSAO8OmSEduTONvRJBt5Ow"
nsURI="http:///schemas/Documentation/_GR2d8OmSEduTONvRJBt5Ow/1"
nsPrefix="Documentation">
xmi:id="_GSAO8emSEduTONvRJBt5Ow" name="CU">
<eAnnotations xmi:id="_GSAO8umSEduTONvRJBt5Ow"
references="_6FndxejzEdulJtUB9wa0tQ"/>
<eStructuralFeatures xmi:type="ecore:EReference"
xmi:id="_GSAO8-mSEduTONvRJBt5Ow" name="base_Class" ordered="false"
lowerBound="1">
<eType xmi:type="ecore:EClass"
href="http://www.eclipse.org/uml2/2.0.0/UML#//Class"/>
</eStructuralFeatures>
</eClassifiers>
xmi:id="_GSAO9OmSEduTONvRJBt5Ow" name="RG">
<eAnnotations xmi:id="_GSAO9emSEduTONvRJBt5Ow"
references="_6Fndx-jzEdulJtUB9wa0tQ"/>
xmi:id="_GSAO9umSEduTONvRJBt5Ow" name="base_Class" ordered="false"
lowerBound="1">
</eClassifiers>
</contents>
<contents xmi:type="ecore:EPackage" xmi:id="_6FndvejzEdulJtUB9wa0tQ"
nsURI="http:///Documentation_0_57fJA-jzEdulJtUB9wa0tQ.profile.uml2"
xmi:id="_6FndvujzEdulJtUB9wa0tQ" name="Documentation__CU">
<eAnnotations xmi:id="_6Fndv-jzEdulJtUB9wa0tQ"
xmi:id="_Dc9UcOmSEduTONvRJBt5Ow" name="base_Class">
</eClassifiers>
xmi:id="_6FndwOjzEdulJtUB9wa0tQ" name="Documentation__RG">
<eAnnotations xmi:id="_6FndwejzEdulJtUB9wa0tQ"
xmi:id="_DdGeYOmSEduTONvRJBt5Ow" name="base_Class">
</eClassifiers>
</contents>
</eAnnotations>
<packageImport xmi:id="_6FndwujzEdulJtUB9wa0tQ" visibility="private">
href="pathmap://UML_METAMODELS/UML.metamodel.uml#_0"/>
</packageImport>
<packageImport xmi:id="_6Fndw-jzEdulJtUB9wa0tQ">
href="pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#_0"/>
</packageImport>
<packageImport xmi:id="_6FndxOjzEdulJtUB9wa0tQ">
href="pathmap://UML_LIBRARIES/JavaPrimitiveTypes.library.uml#_0"/>
</packageImport>
<packagedElement xmi:type="uml:Stereotype"
xmi:id="_6FndxejzEdulJtUB9wa0tQ" name="CU">
<ownedAttribute xmi:id="_6FndxujzEdulJtUB9wa0tQ" name="base_Class"
visibility="private" association="_6FndyejzEdulJtUB9wa0tQ">
href="pathmap://UML_METAMODELS/UML.metamodel.uml#Class"/>
</ownedAttribute>
</packagedElement>
xmi:id="_6Fndx-jzEdulJtUB9wa0tQ" name="RG">
<ownedAttribute xmi:id="_6FndyOjzEdulJtUB9wa0tQ" name="base_Class"
visibility="private" association="_6FndzejzEdulJtUB9wa0tQ">
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Extension"
xmi:id="_6FndyejzEdulJtUB9wa0tQ" memberEnd="_6FndyujzEdulJtUB9wa0tQ
_6FndxujzEdulJtUB9wa0tQ">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_6FndyujzEdulJtUB9wa0tQ"
name="extension_CU" visibility="private" type="_6FndxejzEdulJtUB9wa0tQ"
aggregation="composite" association="_6FndyejzEdulJtUB9wa0tQ">
xmi:id="_6Fndy-jzEdulJtUB9wa0tQ" value="1"/>
</ownedEnd>
</packagedElement>
xmi:id="_6FndzejzEdulJtUB9wa0tQ" memberEnd="_6FndyOjzEdulJtUB9wa0tQ
_6FndzujzEdulJtUB9wa0tQ">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_6FndzujzEdulJtUB9wa0tQ"
name="extension_RG" visibility="private" type="_6Fndx-jzEdulJtUB9wa0tQ"
aggregation="composite" association="_6FndzejzEdulJtUB9wa0tQ">
xmi:id="_6Fndz-jzEdulJtUB9wa0tQ" value="1"/>
</ownedEnd>
</packagedElement>
</uml:Profile>
I'm able to load this resource from disk :
ResourceSet resourceSet = new ResourceSetImpl();
profileDocumentation_2_x = UMLElementLoader.loadProfile(
"Documentation.profile.uml", resourceSet);
public static Profile loadProfile(String modelFile, ResourceSet
resourceSet) {
Profile profile = null;
Resource inputResource = resourceSet.createResource(URI
.createFileURI(modelFile));
try {
inputResource.load(null);
} catch (IOException exception) {
exception.printStackTrace();
Iterator iterator = inputResource.getAllContents();
while (iterator.hasNext()) {
Object currentObject = iterator.next();
if (currentObject instanceof Profile) {
profile = (Profile) currentObject;
break;
return profile;
And I can get owned stereotype.
and try to apply them:
But The sterotype is never apply and I can do it with the editor.
Re: Applying stereotype on Class [message #472543 is a reply to message #472539] Mon, 16 April 2007 14:54 Go to previous message
Guillaume,
What do you mean by "stereotype is never apply"? Are you seeing any
exceptions (e.g. IllegalArgumentException)? Or is the stereotype application
just not being serialized?
Kenn
news:2ae8e100ac7cf4d54f4f21c30322a62a$1@www.eclipse.org...
> lowerBound="1">
> </eClassifiers>
> lowerBound="1">
> </eClassifiers>
> </contents>
> </eClassifiers>
> </eClassifiers>
> </contents>
> </eAnnotations>
> </packageImport>
> </packageImport>
> </packageImport>
> </ownedAttribute>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> </uml:Profile>
> resourceSet) {
> try {
> break;
> return profile;
Re: Applying stereotype on Class [message #605447 is a reply to message #472226] Sun, 08 April 2007 20:46 Go to previous message
Guillaume,
properly.
The article:
- James.
> isAbstract);
> class.
> works fine.
> Any idea ??
> Thx
> Guillaume
Re: Applying stereotype on Class [message #607432 is a reply to message #472496] Tue, 10 April 2007 04:36 Go to previous message
Eclipse User
seems to be good.
Any idea
Thx
Guillaume
Re: Applying stereotype on Class [message #607444 is a reply to message #472503] Wed, 11 April 2007 11:08 Go to previous message
Eclipse User
Any idea ?
Thx
Guillaume
Re: Applying stereotype on Class [message #607446 is a reply to message #472508] Wed, 11 April 2007 11:42 Go to previous message
Guillaume,
- James.
> Any idea ?
> Thx
> Guillaume
Re: Applying stereotype on Class [message #607451 is a reply to message #472509] Thu, 12 April 2007 04:00 Go to previous message
Eclipse User
</eAnnotations>
</eClassifiers>
</eClassifiers>
</contents>
</eAnnotations>
</packageImport>
</packageImport>
</packageImport>
name="CU">
</ownedAttribute>
</ownedMember>
name="RG">
</ownedAttribute>
</ownedMember>
</ownedEnd>
</ownedMember>
</ownedEnd>
</ownedMember>
</uml:Profile>
And my application:
class",false);
return model;
Thx,
Guillaume
Re: Applying stereotype on Class [message #607461 is a reply to message #472532] Thu, 12 April 2007 22:21 Go to previous message
Guillaume,
for details.
Kenn
> </eAnnotations>
> </eClassifiers>
> </eClassifiers>
> </contents>
> </eAnnotations>
> </packageImport>
> </packageImport>
> </packageImport>
> name="CU">
> </ownedAttribute>
> </ownedMember>
> name="RG">
> </ownedAttribute>
> </ownedMember>
> </ownedEnd>
> </ownedMember>
> </ownedEnd>
> </ownedMember>
> </uml:Profile>
> And my application:
> class",false);
> return model;
> Thx,
> Guillaume
Re: Applying stereotype on Class [message #607669 is a reply to message #472536] Fri, 13 April 2007 03:47 Go to previous message
Eclipse User
Hi Kenn.
Guillaume
Re: Applying stereotype on Class [message #607675 is a reply to message #472538] Fri, 13 April 2007 11:08 Go to previous message
Eclipse User
lowerBound="1">
</eClassifiers>
lowerBound="1">
</eClassifiers>
</contents>
</eClassifiers>
</eClassifiers>
</contents>
</eAnnotations>
</packageImport>
</packageImport>
</packageImport>
</ownedAttribute>
</packagedElement>
</ownedAttribute>
</packagedElement>
</ownedEnd>
</packagedElement>
</ownedEnd>
</packagedElement>
</uml:Profile>
resourceSet) {
try {
break;
return profile;
Re: Applying stereotype on Class [message #607697 is a reply to message #472539] Mon, 16 April 2007 14:54 Go to previous message
Guillaume,
Kenn
> lowerBound="1">
> </eClassifiers>
> lowerBound="1">
> </eClassifiers>
> </contents>
> </eClassifiers>
> </eClassifiers>
> </contents>
> </eAnnotations>
> </packageImport>
> </packageImport>
> </packageImport>
> </ownedAttribute>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> </uml:Profile>
> resourceSet) {
> try {
> break;
> return profile;
Previous Topic:mapping of an association (with an interface as member end) to a link in the instance diagram !?
Next Topic:minor extensions to the UML metamodel
Current Time: Fri May 24 12:59:47 EDT 2013
Powered by FUDForum. Page generated in 0.07106 seconds
