Home » Modeling » UML2 » UML(2) constraints
UML(2) constraints [message #472223] Wed, 04 April 2007 03:55 Go to next message
Manar El-Kady is currently offline Manar El-Kady
Member
In the “Customizing UML” article, it is mentioned that the Ultra
heavyweight extension can removing an existing constraint, while in the
PPT “What_do_YOU_want_UML_to_be”, it said that the middleweight
extension can’t modify constraints. Could you illustrate it?
“As the open source project stands today, those OCL constraints would
not be executed at run-time. “Do you mean that currently there is no
effect for any addition of the OCL constraints while modeling or
metamodeling??
Thanks in advance,
Manar
Re: UML(2) constraints [message #472500 is a reply to message #472223] Mon, 09 April 2007 11:14 Go to previous message
james bruck is currently offline james bruck
Hi Manar,
Some comments below ...
- James.
"Manar El-Kady" <manar.elkady@gmail.com> wrote in message
news:euvlmd$m7t$1@build.eclipse.org...
> In the
Re: UML(2) constraints [message #607426 is a reply to message #472223] Mon, 09 April 2007 11:14 Go to previous message
Hi Manar,
- James.
> In the
Previous Topic:template expansion
Next Topic:Add an association into a package
Current Time: Mon May 20 15:02:07 EDT 2013
Powered by FUDForum. Page generated in 0.01570 seconds
