Home » Eclipse Projects » JavaServer Faces » Missing JSF facet config for Dynamic Project using latest all-in-one w/ wtp
Missing JSF facet config for Dynamic Project using latest all-in-one w/ wtp [message #471935] Sun, 14 May 2006 12:27 Go to next message
Eclipse User
Originally posted by: mark.slytechs.com
I've been following the instructions given using ht WTP Tutorials (MS5):
http://www.eclipse.org/webtools/jsf/dev_resource/JSFTutorial -M5/JSFTools_milestone5_tutorial.html
I'm able to setup the JSF libraries (Win->pref->Web&XML->JSF Libraries)
according to the instructions using Sun's JSF RI and Apache's JSTL.
The problem is in the Dynamic Web Project dialog. I don't see the JSF
facelet on screen #2 of the dialog and I don't see the "JavaServer Faces
v1.1 Project" preset either.
I tried setting it up without it and going back to Project
Properties->Project Faces -> Add/Remove Facets, but the JSF facets don't
appear there as well.
I installed a clean version of the
wtp-all-in-one-sdk-R-1.0.2-200604280245-win32 and
wtp-jsf-I-I200604261958-200604261958 of the JSF plugin in brand new
workspace.
Any help would be greatly apprechiated, already spend 3 days on this and
can't really afford any more delay in getting this working.
I've tried to setup JSF manually as well by dropping all the libraries
in WEB-INF/lib directory in Tomcat 5.5(15), but can't get it to work.
Always some kind of error, usually with missing TLDs, unresolvable URI
or unknown tag such as 'taglib'. So far this has been a major pain to
setup in Eclipse.
mark...
Re: Missing JSF facet config for Dynamic Project using latest all-in-one w/ wtp [message #471939 is a reply to message #471935] Sun, 14 May 2006 14:26 Go to previous messageGo to next message
Eclipse User
I resoled the issue with the manual install and can get JSF working
manually. The problem was that, I had to clear the Eclipse's
internet-cache, it had cached empty/corrupt files and that is why none
of my XML files were validating.
I still would like to know why the JSF facets don't appear. Also one
more piece of information. When I click on Projet Properties->JSF
Libraries I get an error message saying that view contains invalid values.
mark..
> workspace.
> setup in Eclipse.
> Cheers,
> mark...
Re: Missing JSF facet config for Dynamic Project using latest all-in-one w/ wtp [message #471947 is a reply to message #471939] Mon, 15 May 2006 13:13 Go to previous messageGo to next message
Gerry Kessler is currently offline Gerry Kessler
Mark,
Does this happen with a new workspace?
Gerry Kessler
WTP JSF Tools Team
Re: Missing JSF facet config for Dynamic Project using latest all-in-one w/ wtp [message #471950 is a reply to message #471939] Mon, 15 May 2006 13:17 Go to previous messageGo to next message
Justin Chen is currently offline Justin Chen
Member
Mark,
Do you happen to capture the log file for the JSF Library Reference
property page error? I.e., view contains invalid values.
You probably saw this error because a JSF library was not configured
during project creation. This is a bug in JSF Library Reference property
page if no
JSF library configured first. This bug should be fixed in next build.
Justin
Re: Missing JSF facet config for Dynamic Project using latest all-in-one w/ wtp [message #471957 is a reply to message #471947] Tue, 16 May 2006 07:19 Go to previous messageGo to next message
Eclipse User
Yes, the workspace is brand new and thus was initially empty.
Gerry Kessler wrote:
> Mark,
> Gerry Kessler
> WTP JSF Tools Team
Re: Missing JSF facet config for Dynamic Project using latest all-in-one w/ wtp [message #471961 is a reply to message #471950] Tue, 16 May 2006 07:28 Go to previous messageGo to next message
Eclipse User
Justin Chen wrote:
> Mark,
> property page if no JSF library configured first. This bug should be
> Justin
The log file contains a lot of error messages that are pretty much the
same with the stack traces:
!SESSION 2006-05-13 17:00:37.896
eclipse.buildId=M20060118-1600
java.version=1.5.0_06
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.wtp.jsf.core 1 0 2006-05-13 17:01:05.15
!MESSAGE Could not load JSF Library Registry; creating new registry
!STACK 0
java.io.FileNotFoundException: E:\Documents and
Settings\markbe\workspace-3.2\.metadata\.plugins\org.eclipse .wtp.jsf.core\JSFLibraryRegistry.xml
(The system cannot find the path specified)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(Unknown Source)
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createF ileInputStream(URIConverterImpl.java:462)
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createI nputStream(URIConverterImpl.java:424)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:829)
org.eclipse.wtp.jsf.core.internal.JSFCorePlugin.loadJSFLibra ryRegistry(JSFCorePlugin.java:126)
org.eclipse.wtp.jsf.core.internal.JSFCorePlugin.start(JSFCor ePlugin.java:83)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:994)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:988)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:969)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:316)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:264)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:116)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:386)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
org.eclipse.wtp.jsf.ui.internal.classpath.JSFLibrariesPrefer encePage.getJSFLibraries(JSFLibrariesPreferencePage.java:184 )
org.eclipse.wtp.jsf.ui.internal.classpath.JSFLibrariesPrefer encePage.createContents(JSFLibrariesPreferencePage.java:91)
org.eclipse.jface.preference.PreferencePage.createControl(Pr eferencePage.java:232)
org.eclipse.jface.preference.PreferenceDialog.createPageCont rol(PreferenceDialog.java:1371)
org.eclipse.jface.preference.PreferenceDialog$12.run(Prefere nceDialog.java:1138)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
org.eclipse.jface.preference.PreferenceDialog.showPage(Prefe renceDialog.java:1132)
org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.sho wPage(FilteredPreferenceDialog.java:351)
org.eclipse.jface.preference.PreferenceDialog$8.selectionCha nged(PreferenceDialog.java:638)
org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:763)
org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(StructuredViewer.java:761)
org.eclipse.jface.viewers.StructuredViewer.handlePostSelect( StructuredViewer.java:1042)
org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected( StructuredViewer.java:1062)
org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(O penStrategy.java:231)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.ja va:226)
at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java: 392)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3102)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2761)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPrefer encesAction.java:66)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3125)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2758)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!ENTRY org.eclipse.wst.common.project.facet.ui 4 0 2006-05-13 17:03:58.905
!MESSAGE Version [2.4 of project facet jst.web has not been defined.
!STACK 1
org.eclipse.core.runtime.CoreException: Version [2.4 of project facet
org.eclipse.wst.common.project.facet.core.internal.VersionMa tchExpr.parseVersion(VersionMatchExpr.java:95)
org.eclipse.wst.common.project.facet.core.internal.VersionMa tchExpr. <init>(VersionMatchExpr.java:73)
org.eclipse.wst.common.project.facet.core.internal.Versionab le.getVersions(Versionable.java:55)
org.eclipse.wst.common.project.facet.ui.internal.Conflicting FacetsFilter.check(ConflictingFacetsFilter.java:117)
org.eclipse.wst.common.project.facet.ui.internal.Conflicting FacetsFilter.check(ConflictingFacetsFilter.java:61)
org.eclipse.wst.common.project.facet.ui.internal.Conflicting FacetsFilter.check(ConflictingFacetsFilter.java:52)
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel.isFilteredOut(FacetsSelectionPanel.java:1247)
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel.access$0(FacetsSelectionPanel.java:1242)
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel$TableRowData.getVersions(FacetsSelectionPanel.java :1491)
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel$TableRowData.isVisible(FacetsSelectionPanel.java:1 542)
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel$ContentProvider.getElements(FacetsSelectionPanel.j ava:1591)
org.eclipse.jface.viewers.StructuredViewer.getRawChildren(St ructuredViewer.java:848)
org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren( AbstractTreeViewer.java:896)
org.eclipse.jface.viewers.StructuredViewer.getFilteredChildr en(StructuredViewer.java:790)
org.eclipse.jface.viewers.StructuredViewer.getSortedChildren (StructuredViewer.java:905)
org.eclipse.jface.viewers.AbstractTreeViewer.updateChildren( AbstractTreeViewer.java:1707)
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh Struct(AbstractTreeViewer.java:1268)
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:1245)
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:1201)
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:1188)
org.eclipse.jface.viewers.StructuredViewer$7.run(StructuredV iewer.java:1264)
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1201)
org.eclipse.jface.viewers.CheckboxTreeViewer.preservingSelec tion(CheckboxTreeViewer.java:364)
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1262)
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1221)
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel.refresh(FacetsSelectionPanel.java:1079)
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel.addFilter(FacetsSelectionPanel.java:760)
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPage.createControl(FacetsSelectionPage.java:159)
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.ja va:179)
org.eclipse.wst.common.project.facet.ui.AddRemoveFacetsWizar d.createPageControls(AddRemoveFacetsWizard.java:259)
org.eclipse.jface.wizard.WizardDialog.createPageControls(Wiz ardDialog.java:611)
at org.eclipse.jface.wizard.WizardDialog.setWizard(WizardDialog .java:965)
org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDi alog.java:1016)
at org.eclipse.jface.wizard.WizardDialog.access$2(WizardDialog. java:1013)
at org.eclipse.jface.wizard.WizardDialog$4.run(WizardDialog.jav a:1003)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog. java:1001)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:753)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:345)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction .java:114)
!SUBENTRY 1 org.eclipse.wst.common.project.facet.core 4 0 2006-05-13
17:03:58.905
!ENTRY org.eclipse.wst.common.project.facet.ui 4 0 2006-05-13 17:03:58.915
!MESSAGE Version [2.3 of project facet jst.web has not been defined.
!STACK 1
org.eclipse.core.runtime.CoreException: Version [2.3 of project facet
17:03:58.915
!ENTRY org.eclipse.wst.common.project.facet.ui 4 0 2006-05-13 17:03:58.935
!STACK 1
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel.refreshPresetsCombo(FacetsSelectionPanel.java:1112 )
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel.addFilter(FacetsSelectionPanel.java:761)
17:03:58.935
!ENTRY org.eclipse.wst.common.project.facet.ui 4 0 2006-05-13 17:03:58.945
!STACK 1
17:03:58.945
!ENTRY org.eclipse.wst.common.project.facet.ui 4 0 2006-05-13 17:04:35.447
!STACK 1
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel$TableRowData.isSelected(FacetsSelectionPanel.java: 1517)
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel.getSelectedProjectFacets(FacetsSelectionPanel.java :673)
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel$12.check(FacetsSelectionPanel.java:440)
org.eclipse.wst.common.project.facet.ui.internal.RuntimesPan el.isFilteredOut(RuntimesPanel.java:254)
org.eclipse.wst.common.project.facet.ui.internal.RuntimesPan el.access$0(RuntimesPanel.java:247)
org.eclipse.wst.common.project.facet.ui.internal.RuntimesPan el$LabelProvider.getForeground(RuntimesPanel.java:514)
org.eclipse.jface.viewers.StructuredViewer$ColorAndFontColle ctorWithProviders.setFontsAndColors(StructuredViewer.java:17 6)
at org.eclipse.jface.viewers.TableViewer.doUpdateItem(TableView er.java:439)
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:434)
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:1763)
at org.eclipse.jface.viewers.TableViewer.createItem(TableViewer .java:344)
org.eclipse.jface.viewers.TableViewer.internalRefreshAll(Tab leViewer.java:850)
org.eclipse.jface.viewers.TableViewer.internalRefresh(TableV iewer.java:748)
org.eclipse.jface.viewers.TableViewer.internalRefresh(TableV iewer.java:737)
org.eclipse.jface.viewers.CheckboxTableViewer.preservingSele ction(CheckboxTableViewer.java:289)
org.eclipse.wst.common.project.facet.ui.internal.RuntimesPan el.refresh(RuntimesPanel.java:265)
org.eclipse.wst.common.project.facet.ui.internal.RuntimesPan el$4.handle(RuntimesPanel.java:172)
org.eclipse.wst.common.project.facet.core.runtime.internal.R untimeManagerImpl.notifyRuntimeListeners(RuntimeManagerImpl. java:261)
org.eclipse.wst.common.project.facet.core.runtime.internal.R untimeManagerImpl.bridge(RuntimeManagerImpl.java:418)
org.eclipse.wst.common.project.facet.core.runtime.internal.R untimeManagerImpl.getRuntimes(RuntimeManagerImpl.java:129)
org.eclipse.wst.common.project.facet.core.runtime.RuntimeMan ager.getRuntimes(RuntimeManager.java:84)
org.eclipse.wst.common.componentcore.datamodel.FacetProjectC reationDataModelProvider.getValidPropertyDescriptors(FacetPr ojectCreationDataModelProvider.java:289)
org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elImpl.getValidPropertyDescriptors(DataModelImpl.java:320)
org.eclipse.wst.web.ui.internal.wizards.DataModelFacetCreati onWizardPage.launchNewRuntimeWizard(DataModelFacetCreationWi zardPage.java:65)
org.eclipse.wst.web.ui.internal.wizards.DataModelFacetCreati onWizardPage$1.widgetSelected(DataModelFacetCreationWizardPa ge.java:101)
17:04:35.447
!ENTRY org.eclipse.wst.common.project.facet.ui 4 0 2006-05-13 17:04:35.457
!STACK 1
17:04:35.457
!ENTRY org.eclipse.wst.common.project.facet.ui 4 0 2006-05-13 17:04:35.487
!STACK 1
org.eclipse.wst.common.project.facet.ui.internal.RuntimesPan el$LabelProvider.getImage(RuntimesPanel.java:482)
org.eclipse.jface.viewers.StructuredViewer.buildLabel(Struct uredViewer.java:1878)
at org.eclipse.jface.viewers.TableViewer.doUpdateItem(TableView er.java:458)
17:04:35.497
!ENTRY org.eclipse.wst.common.project.facet.ui 4 0 2006-05-13 17:04:35.507
!STACK 1
at org.ec
Re: Missing JSF facet config for Dynamic Project using latest all-in-one w/ wtp [message #471964 is a reply to message #471961] Tue, 16 May 2006 20:56 Go to previous message
Member
Mark,
I a look at your log file and there are many project facets not defined
errors.
I realized that you installed WTP all-in-one 1.0.2 + JSF 0426 development
build. You should use WTP 1.5 RC2 and JSF development build instead.
Justin
Re: Missing JSF facet config for Dynamic Project using latest all-in-one w/ wtp [message #600424 is a reply to message #471935] Sun, 14 May 2006 14:26 Go to previous message
Eclipse User
mark..
> workspace.
> setup in Eclipse.
> Cheers,
> mark...
Re: Missing JSF facet config for Dynamic Project using latest all-in-one w/ wtp [message #600441 is a reply to message #471939] Mon, 15 May 2006 13:13 Go to previous message
Mark,
Gerry Kessler
WTP JSF Tools Team
Re: Missing JSF facet config for Dynamic Project using latest all-in-one w/ wtp [message #600446 is a reply to message #471939] Mon, 15 May 2006 13:17 Go to previous message
Member
Mark,
page if no
Justin
Re: Missing JSF facet config for Dynamic Project using latest all-in-one w/ wtp [message #600465 is a reply to message #471947] Tue, 16 May 2006 07:19 Go to previous message
Eclipse User
> Mark,
> Gerry Kessler
> WTP JSF Tools Team
Re: Missing JSF facet config for Dynamic Project using latest all-in-one w/ wtp [message #600478 is a reply to message #471950] Tue, 16 May 2006 07:28 Go to previous message
Eclipse User
Justin Chen wrote:
> Mark,
> Justin
!STACK 0
!STACK 1
17:03:58.905
!STACK 1
17:03:58.915
!STACK 1
17:03:58.935
!STACK 1
17:03:58.945
!STACK 1
17:04:35.447
!STACK 1
17:04:35.457
!STACK 1
17:04:35.497
!STACK 1
at org.ec
Re: Missing JSF facet config for Dynamic Project using latest all-in-one w/ wtp [message #600484 is a reply to message #471961] Tue, 16 May 2006 20:56 Go to previous message
Member
Mark,
errors.
Justin
Previous Topic:Missing JSF facet config for Dynamic Project using latest all-in-one w/ wtp
Next Topic:JSF Tools Project Milestone RC2 build posted..
Current Time: Sat May 18 05:30:29 EDT 2013
Powered by FUDForum. Page generated in 0.02438 seconds
