Home » Eclipse Projects » Nebula » Suggestions for display of editable and non-editable cells in Grid
Suggestions for display of editable and non-editable cells in Grid [message #47160] Wed, 23 January 2008 02:02 Go to next message
Eclipse User
Originally posted by: chethan.kumarbr.in.bosch.com
Can anyone give suggestions for my below points,
1.In grid as the default background is white; we can't differentiate
between editable and non-editable cells till we select the cell.
So what would be the better GUI approach to represent editable and
non-editable cells?
2.What is the better GUI approach to display default values in grid
(editable/non-editable)? Default values are values that the user has not
entered but a possible value he could enter in the cell.
Thanks & Regards,
Chethan
Re: Suggestions for display of editable and non-editable cells in Grid [message #47589 is a reply to message #47160] Sun, 27 January 2008 09:59 Go to previous messageGo to next message
Chris Gross is currently offline Chris Gross
Hi Chethan,
If you wrote your own cell renderer, you could put watermarks or other
decorations inside the cell to denote any special information.
-Chris
Chethan wrote:
> Hello,
> non-editable cells?
> Thanks & Regards,
> Chethan
Re: Suggestions for display of editable and non-editable cells in Grid [message #49541 is a reply to message #47589] Mon, 18 February 2008 02:26 Go to previous message
Eclipse User
Hello Chris,
Thanks for the answer...
I am already painting the background and setting images,text in columns
using 'GridColumnLabelProvider', which does the same work as cell
renderers i feel.
Is this cell renderer different from 'GridColumnLabelProvider'? If same,
which will be the better one to use in Grid viewer, cell renderers or
Chethan
Re: Suggestions for display of editable and non-editable cells in Grid [message #587988 is a reply to message #47160] Sun, 27 January 2008 09:59 Go to previous message
Hi Chethan,
-Chris
Chethan wrote:
> Hello,
> non-editable cells?
> Thanks & Regards,
> Chethan
Re: Suggestions for display of editable and non-editable cells in Grid [message #588628 is a reply to message #47589] Mon, 18 February 2008 02:26 Go to previous message
Eclipse User
Hello Chris,
renderers i feel.
Chethan
Previous Topic:DateChooser selects value by arrow keys and ignores modifiers.
Next Topic:Gallery Item event listeners
Current Time: Tue May 21 22:34:49 EDT 2013
Powered by FUDForum. Page generated in 0.01966 seconds
