| run "WTP JSF Tools Tutorial" with requested resource is not available [message #470816] |
Wed, 21 December 2005 00:45  |
Originally posted by: bolixie.gmail.com
I create the FirstJsfApp under the direction in "WTP Tutorials -
JavaServer Faces Tools(Milestone1) Tutorial"
but when i run the login.jsp tomcat reports bellow
type Status report
message /FirstJSFApp/login.faces
description The requested resource (/FirstJSFApp/login.faces) is not
available.
Apache Tomcat/5.5.9
plz tell me what is wrong with me?
my eclipse version is 3.1.1;wtp jsf tool version is 1
| Re: run "WTP JSF Tools Tutorial" with requested resource is not available [message #470819 is a reply to message #470816] |
Wed, 21 December 2005 02:19   |
bolixie 写道:
> type Status report
> available.
> Apache Tomcat/5.5.9
the problem is trouble shooted.But i dont know how could it workes fine
after restart eclipse several times. :(
| Re: run "WTP JSF Tools Tutorial" with requested resource is not available [message #470831 is a reply to message #470828] |
Thu, 22 December 2005 02:07  |
Justin Chen
> Just performed a test using TC 5.5.12 + WTP10RC5 on Windows 2K.
> It seems to work fine.
> If you perform a "Run on Server" on the login.jsp while TC is started,
> you could restart TC as Gerry points out here.
> You might also try perform "Run on Server" again but need to close the
> web browser
> first.
> Justin
> Gerry Kessler wrote:
>> Next time check the server view before restarting Eclipse. The
>> Tomcat server may need to be restarted after a change to the
>> application and the view will display that status.
>> Regards,
>> Gerry Kessler
>> WTP JSF Tools Team
>> "bolixie" <bolixie@gmail.com> wrote in message
>> news:doavl4$tlv$1@utils.eclipse.org...
>>> bolixie ??:
>>>> type Status report
>>>> available.
>>>> Apache Tomcat/5.5.9
>>> fine after restart eclipse several times. :(
Thanks for Gerry Kessler and Justin Chen! TC 5.5.12 did work fine.So
give advice to fellows uese wtp should use TC 5.5.12 first!!! :)
| Re: run "WTP JSF Tools Tutorial" with requested resource is not available [message #580364 is a reply to message #470816] |
bolixie 写道:
> type Status report
> available.
> Apache Tomcat/5.5.9
| Re: run "WTP JSF Tools Tutorial" with requested resource is not available [message #580463 is a reply to message #470819] |
Wed, 21 December 2005 15:50  |
Gerry Kessler Messages: 125 Registered: July 2009 |
Next time check the server view before restarting Eclipse. The Tomcat
server may need to be restarted after a change to the application and the
Gerry Kessler
WTP JSF Tools Team
> bolixie ??:
>> type Status report
>> available.
>> Apache Tomcat/5.5.9
| Re: run "WTP JSF Tools Tutorial" with requested resource is not available [message #580474 is a reply to message #470827] |
Wed, 21 December 2005 16:43  |
Justin Chen Messages: 39 Registered: July 2009 |
Member |
You might also try perform "Run on Server" again but need to close the web browser
first.
Justin
> Gerry Kessler
> WTP JSF Tools Team
>>bolixie ??:
>>>type Status report
>>>available.
>>>Apache Tomcat/5.5.9
| Re: run "WTP JSF Tools Tutorial" with requested resource is not available [message #580530 is a reply to message #470828] |
Justin Chen
> web browser
> first.
> Justin
>> Regards,
>> Gerry Kessler
>> WTP JSF Tools Team
>>> bolixie ??:
>>>> type Status report
>>>> available.
>>>> Apache Tomcat/5.5.9
FUDForum. Page generated in 0.03396 seconds
