| WTP XDoclet EJB spec version [message #470626] |
Tue, 25 October 2005 04:14 |
Originally posted by: barenhoff.spot-media.de
Hello!
I've created a ejb project over the wizzard in WTP. I've selected ejb
version 2.1.
Now I tried to change it back:
<module-type module-type-id="jst.ejb">
<version>2.0</version>
<property name="java-output-path" value="/bin/"/>
</module-type>
in .wtpmodules. But it seems as if he still creates 2.1 deployment
descriptor. In:
~/workspace/.metadata/.plugins/org.eclipse.jst.j2ee.ejb.anno tations.xdoclet/
there are the ant file and a build.properties wich seem to be generated
automaticly. In the build.properties there is a line:
ejb.spec.version=2.1
I've changed it ther too, but it will be overwritten at the next build.
Where can I configure it?
I need this because i want to create an application which will be run on
an ibm websphere 5.1 server which is a j2ee 1.3 server.
thanks
Markus Barenhoff
FUDForum. Page generated in 0.02609 seconds
