| Eclipse remote help server (BindException) [message #470160] |
Wed, 24 October 2007 13:33  |
Lyndsey Padget Messages: 2 Registered: July 2009 |
Junior Member |
One of the documented limitations of Java Web Start is that the Eclipse
help system cannot be deployed [1]. As a workaround, Eclipse suggests
running your own help server (also known as running help in infocenter
mode), which I have done on the server serving our application [2]. This
server can be reached by hitting
http://<serverName>:<portNumber>/help/index.jsp in a browser. Note that
I'm using version 3.2.0 to 3.2.2 for most of my Eclipse plugins.
Now I would like to configure our application to use this help server
rather than trying to start its own help server. I have tried to
accomplish this in two ways:
1) use the org.eclipse.help.appserver product customization options as
defined here [3] and
2) use the host and port fields in the Help Server preference page [4]
Of course, I use <serverName> as the host name and <portNumber> as the
server port in both cases. However, when I try to start help by going to
Help -> Help Contents in the workbench, I get a message stating the
following:
Help cannot be displayed. The embedded application server could not run
help web application. Check the log for details.
I find a stack trace in the log file, but it seems vague to me:
!ENTRY org.eclipse.help.base 4 0 2007-10-23 13:19:28.273
!MESSAGE The embedded application server could not run help web
application.
!STACK 1
org.eclipse.core.runtime.CoreException: Exception occurred starting
application server.
org.eclipse.tomcat.internal.TomcatAppServer.start(TomcatAppS erver.java:271)
org.eclipse.help.internal.appserver.AppserverPlugin.startWeb appServer(AppserverPlugin.java:162)
org.eclipse.help.internal.appserver.AppserverPlugin.getAppSe rver(AppserverPlugin.java:50)
org.eclipse.help.internal.appserver.WebappManager.start(Weba ppManager.java:63)
org.eclipse.help.internal.base.BaseHelpSystem.ensureWebappRu nning(BaseHelpSystem.java:246)
org.eclipse.help.internal.base.HelpDisplay.displayHelpURL(He lpDisplay.java:164)
!SUBENTRY 1 org.eclipse.tomcat 4 0 2007-10-23 13:19:28.273
!MESSAGE Exception occurred starting application server.
I found this, which describes where the REAL exception can be found:
http://www.eclipsezone.com/eclipse/forums/t59199.html
Looking in the Tomcat Catalina log (as described in the link), I see the
following exception. Note that this log file is on the client (the one
trying to connect to the help server), not the machine running the help
server. Replace <portNumber> with the actual port number below. Ive
tried several different ports, and there is a specific exception I should
be seeing if the port was already in use. Since Im not seeing that
exception, it must be something else
LifecycleException: Protocol handler initialization failed:
java.net.BindException: Cannot assign requested address:
JVM_Bind:<portNumber>
org.apache.coyote.tomcat4.CoyoteConnector.initialize(CoyoteC onnector.java:1231)
org.apache.catalina.startup.Embedded.addConnector(Embedded.j ava:432)
org.eclipse.tomcat.internal.TomcatAppServer.start(TomcatAppS erver.java:239)
org.eclipse.help.internal.appserver.AppserverPlugin.startWeb appServer(AppserverPlugin.java:143)
org.eclipse.help.internal.appserver.AppserverPlugin.getAppSe rver(AppserverPlugin.java:41)
org.eclipse.help.internal.appserver.WebappManager.start(Weba ppManager.java:58)
Any insight would be appreciated.
Thanks!
[1]
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/java_web_start.htm
[2]
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/ua_help_setup_infocenter.htm
[3]
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/ua_help_setup_preferences.htm
[4]
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. platform.doc.user/reference/help_preferences_server.htm
| Re: Eclipse remote help server (BindException) [message #470930 is a reply to message #470929] |
Wed, 21 November 2007 12:36   |
Dieter Cailliau Messages: 5 Registered: July 2009 |
Junior Member |
This doesn't work after all, because the code still prefers tomcat over my
extension, because it only inspects the first plugin (from
AppserverPlugin), in stead of iterating them: the [0] is too bad...
// We need to pick up the non-default configuration
IConfigurationElement[] elements =
extensions[0].getConfigurationElements();
What does work is this: set the AppserverPlugin.appServer field to your
implementation, using reflection.
Field field = AppserverPlugin.class.getDeclaredField("appServer");
field.setAccessible(true);
field.set(AppserverPlugin.getDefault(),new RemoteWebServer());
The problem here is, that we need to get this done before any other code
calls that plugin: otherwise tomcat will be launched before we bypassed
it.
For example if the help view is open at startup-time, it reaches
AppserverPlugin faster, than my hack, giving trouble.
| Re: Eclipse remote help server (BindException) [message #470932 is a reply to message #470930] |
Wed, 21 November 2007 14:26  |
Chris Goldthorpe Messages: 815 Registered: July 2009 |
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=124831 for a
discussion of this problem.
> my extension, because it only inspects the first plugin (from
> calls that plugin: otherwise tomcat will be launched before we bypassed it.
| Re: Eclipse remote help server (BindException) [message #594304 is a reply to message #470160] |
Wed, 21 November 2007 11:38  |
Junior Member |
Bypass tomcat, insert your own IWebappServer.
<extension
point="org.eclipse.help.appserver.server">
<server
class="com.barco.compose.mode.RemoteWebServer"
default="false"/>
</extension>
package com.barco.compose.mode;
import org.eclipse.core.runtime.CoreException;
import org.eclipse.core.runtime.IPath;
import org.eclipse.help.internal.appserver.AppserverPlugin;
import org.eclipse.help.internal.appserver.IWebappServer;
public class RemoteWebServer implements IWebappServer {
public RemoteWebServer() {
System.out.println("YEPLA");
private boolean running = true;
public String getHost() {
return
AppserverPlugin.getDefault().getPluginPreferences().getStrin g( "host");
public int getPort() {
return
AppserverPlugin.getDefault().getPluginPreferences().getInt("port ");
public boolean isRunning() {
return running;
public void start(int port, String host) throws CoreException {
public void start(String webappName, IPath path, ClassLoader
customLoader) throws CoreException {
public void stop() throws CoreException {
running = false;
public void stop(String webappName) throws CoreException {
| Re: Eclipse remote help server (BindException) [message #594310 is a reply to message #470929] |
Junior Member |
it.
| Re: Eclipse remote help server (BindException) [message #594318 is a reply to message #470930] |
FUDForum. Page generated in 0.01710 seconds
