Home » Eclipse Projects » DSDP - Device Debugging » Problem in debugging with DSF.
Problem in debugging with DSF. [message #470108] Tue, 06 January 2009 03:12 Go to next message
Dmitri Pikus is currently offline Dmitri Pikus
I have several problems when using DSF.
Environment:
OS: Windows XP Professional, SP2.
Eclipse: 3.4.1
CDT: 5.0.1
DSF: 1.1.0 - latest plugins taken from CVS (dev.eclipse.org, /cvsroot/dsdp)
Debugged application: simple C application with single method( main() )
that contains several printouts.
SCENARIO1:
1. Line breakpoint without actions is set.
2. Application is debugged with DSF.
Problem1: Threads change to 'Suspended' state, but call stack isn't shown.
Problem2: Line with reached breakpoint isn't colored.
Problem3: The following mesages are displayed in console:
mi_cmd_stack_info_depth: Usage: [MAX_DEPTH]
mi_cmd_stack_list_frames: Usage: [FRAME_LOW FRAME_HIGH]
SCENARIO2:
1. Line breakpoint without Resume action is set.
Problem: ClassCastException happens:
org.eclipse.dd.gdb.internal.provisional.service.command.GDBC ontrolDMContext
incompatible with
org.eclipse.dd.dsf.debug.service.IRunControl$IExecutionDMCon text
Changing GDBControlDMContext class to implement IExecutionDMContext
doesn't help much:
I see problems 1 and 2 as in scenario 1, and message
'mi_cmd_stack_info_depth: Usage: [MAX_DEPTH]' is displayed.
Sincerely,
Dmitri Pikus
Re: Problem in debugging with DSF. [message #470109 is a reply to message #470108] Tue, 06 January 2009 03:36 Go to previous message
1. There is a misprint in my original post:
In SCENARIO2, Line breakpoint WITH Resume action is set.
2. There is also the problem with the Update Policy selection not showing
in the variables view menu.
Thanks!
Sincerely,
Dmitri Pikus.
Re: Problem in debugging with DSF. [message #590455 is a reply to message #470108] Tue, 06 January 2009 03:36 Go to previous message
Thanks!
Sincerely,
Dmitri Pikus.
Previous Topic:Problem in debugging with DSF.
Next Topic:Projects on DSDP-DD
Current Time: Wed May 29 02:23:10 EDT 2013
Powered by FUDForum. Page generated in 0.01623 seconds
