Home » Eclipse Projects » DSDP - Device Debugging » Device Debugging
Device Debugging [message #470101] Wed, 09 July 2008 08:03 Go to next message
Eclipse User
Originally posted by: vitaly.panor.zoran.com
I'm new to Eclipse, and seek some help with debugging embedded software.
As I understood, there is one main project, DSDP, which encapsulates some
other feature-driven projects. The one for device/on chip debugging is DD.
I've downloaded the latest Eclipse version (3.4) with CDT 5.0 and added DD
(1.0) to it.
What I can't understand is how I can debug with it. I know it should use
GDB for debugging, or at least I think so, but how can I make them work
together, download an executable to a target and run it?
Could someone please pour some light on how should I use this project, or
at least point me to some sort of a guide (if there is such)?
Vitaly
Re: Device Debugging [message #470102 is a reply to message #470101] Fri, 11 July 2008 08:30 Go to previous message
Anton Leherbauer is currently offline Anton Leherbauer
Vitaly Panor wrote:
> some other feature-driven projects. The one for device/on chip debugging
> is DD.
> DD (1.0) to it.
> or at least point me to some sort of a guide (if there is such)?
Maybe the information at http://wiki.eclipse.org/DSDP/DD/GDB provides a
starting point. It describes the steps for self-hosted development and
debugging a local sample application, but this might be useful as well.
Anyway, the basic steps are:
1. Create a C/C++ project with sources and binaries.
2. Create a launch configuration (under Run > Debug Configurations...)
of the right type, e.g. for remote debugging select "C/C++ Remote
Application (Experimental - DSF)" and enter the required information.
3. Click "Debug" to start the debugger
HTH
Anton Leherbauer
Wind River CDT Team, Austria
Re: Device Debugging [message #590387 is a reply to message #470101] Fri, 11 July 2008 08:30 Go to previous message
Vitaly Panor wrote:
> is DD.
> DD (1.0) to it.
HTH
Anton Leherbauer
Previous Topic:Device Debugging
Next Topic:Disassembly editor
Current Time: Wed May 22 18:34:45 EDT 2013
Powered by FUDForum. Page generated in 0.01783 seconds
