| Eclipse-cobol and windows [message #469670] |
Sat, 13 December 2008 07:52  |
soude Messages: 1 Registered: July 2009 |
Junior Member |
I want to use eclipse cobol under windows platform for a personal usage.
but which compiler must be used where download this compiler
Thank you for information , setup parameters , links and examples
Andy
| Re: Eclipse-cobol and windows [message #469671 is a reply to message #469670] |
Thu, 08 January 2009 01:01  |
Tetsuya Suehisa Messages: 14 Registered: July 2009 |
Junior Member |
As told in ML, you have some choices to get cobol compiler. One is get
free cobol compiler such as OpenCOBOL, the other is get Fujitsu cobol
academic edition.
To use OpenCOBOL you have to modify the plugin, I mean, eclipse(Java)
programming skill is required.
To use free Fujitsu cobol, although, the download page have disappeared
and it seems to be impossible to get free anymore. If you'd rather spend
money to purchase Fujitsu cobol academic edition, see
http://www.netcobol.com/order/index.htm
thanks.
FUDForum. Page generated in 0.02049 seconds
