| Bugzilla Connector and Target Milestone [message #46600] |
Fri, 04 April 2008 10:35  |
Originally posted by: mauro.molinari.cardinis.com
Hello all!
I just noticed that with Mylyn 2.3.1, I can't change the Target
Milestone field in our internal Bugzilla 2.18 installation tasks using
the built-in editor. The problem is that the Target Milestone field is
rendered as a simple edit box, instead of a combo box with all the
available values...
I'm sure in the past I had no problem with that. The workspace I'm using
has tasks and repositories imported from a previous one: could be this
the main problem? I tried to do an "update attributes" on the task
repository, but this didn't help.
Any hint?
Mauro.
| Re: Bugzilla Connector and Target Milestone [message #46624 is a reply to message #46600] |
Fri, 04 April 2008 10:38   |
Sorry, I fixed the issue right now...
I did an "update attributes", then closed and reopened the task editor,
but it was not enough. I had to refresh the task with "synchronize
incoming changes" in order to get the Target Milestone combo box
populated...
Maybe as a user I would expect that "update attributes" on the task
repository should update the currently open task editor view...
Mauro.
| Re: Bugzilla Connector and Target Milestone [message #46693 is a reply to message #46624] |
Fri, 04 April 2008 21:35   |
Originally posted by: rob.elves.eclipse.org
Agreed! There may be some tricky side effects due to dirty editor state
etc, but please post a new bug report for this Mauro.
-Rob
> populated...
> Mauro.
| Re: Bugzilla Connector and Target Milestone [message #588903 is a reply to message #46600] |
Mauro Molinari Messages: 277 Registered: July 2009 |
populated...
Mauro.
| Re: Bugzilla Connector and Target Milestone [message #588911 is a reply to message #46624] |
Robert Elves Messages: 87 Registered: July 2009 |
Member |
-Rob
> populated...
> Mauro.
FUDForum. Page generated in 0.01820 seconds
