Home » Eclipse Projects » Silverlight Development Toolkit (SLDT) » org.soyatec.eclipse4sl.vex.silverlight does not compile
org.soyatec.eclipse4sl.vex.silverlight does not compile [message #469113] Thu, 16 October 2008 02:03 Go to next message
Remy Suen is currently offline Remy Suen
Hi, the org.soyatec.eclipse4sl.vex.silverlight bundle in the SF SVN
repository does not compile at the moment because the
org.soyatec.eclipse4sl.core is not in the repository. Will this be
changed any time soon?
Remy
Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #469115 is a reply to message #469113] Thu, 16 October 2008 13:17 Go to previous messageGo to next message
Yves YANG is currently offline Yves YANG
Remy,
The source is not yet totally updated in sourceforge It could be done at
the end of the month.
Sorry for the inconvenience.
Yves YANG
"Remy Chi Jian Suen" <remy.suen@gmail.com> wrote in message
news:gd6ldh$c4q$1@build.eclipse.org...
> org.soyatec.eclipse4sl.core is not in the repository. Will this be changed
> any time soon?
> Remy
Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #469117 is a reply to message #469115] Fri, 17 October 2008 10:21 Go to previous messageGo to next message
Hi Yves,
> at the end of the month.
Please let us know on the newsgroup when the source has been added to
trunk, thanks. :)
Remy
Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #469118 is a reply to message #469117] Fri, 17 October 2008 14:08 Go to previous messageGo to next message
Sure!
yves
news:gda6v0$g04$1@build.eclipse.org...
> Hi Yves,
> trunk, thanks. :)
> Remy
Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #469119 is a reply to message #469118] Thu, 30 October 2008 19:18 Go to previous messageGo to next message
The soruce is updated in sourceforge.
Yves YANG
"Yves Yang" <yves.yang@soyatec.com> wrote in message
news:gdakb9$8v0$1@build.eclipse.org...
> Sure!
> yves
>> Hi Yves,
>> trunk, thanks. :)
>> Remy
Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #469120 is a reply to message #469119] Fri, 31 October 2008 03:48 Go to previous messageGo to next message
Hi Yves,
I am having compilation problems.
o.s.microsoft.msbuild.edit will not build properly. There appears to be
no MANIFEST.MF file and the plugin.xml has errors (as the plug-in is not
even defined properly in the old Eclipse 2.x format). This problem
indirectly affects the compilation of o.s.microsoft.msbuild.editor.
o.s.csm.tests will not compile because o.s.csm.tools are nowhere to be
found.
Closing the erroneous projects is okay since I can still run SLDT
through PDE, I guess I will just miss some MSBuild features.
Remy
Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #469122 is a reply to message #469120] Sat, 01 November 2008 03:14 Go to previous messageGo to next message
o.s.microsoft.msbuild.edit is okay now as I see that the MANIFEST.MF
file was committed in r78.
Thanks.
Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #469124 is a reply to message #469122] Sat, 01 November 2008 09:16 Go to previous messageGo to next message
The plugins edit/edtor/tests you mentioned are not mandadory. The SVN of
sourceforge is not useful. We have uploaded few files per commit, it takes a
lot of time to upload.
best regards
Yves YANG
news:gegvh7$s1p$1@build.eclipse.org...
> o.s.microsoft.msbuild.edit is okay now as I see that the MANIFEST.MF file
> Thanks.
Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #469126 is a reply to message #469122] Sat, 01 November 2008 09:20 Go to previous message
best regards
Yves YANG
> Thanks.
Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #563254 is a reply to message #469113] Thu, 16 October 2008 13:17 Go to previous message
Remy,
Yves YANG
> any time soon?
> Remy
Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #563277 is a reply to message #469115] Fri, 17 October 2008 10:21 Go to previous message
Eclipse User
Originally posted by: remy.suen.gmail.com
Hi Yves,
trunk, thanks. :)
Remy
Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #563297 is a reply to message #469117] Fri, 17 October 2008 14:08 Go to previous message
Sure!
yves
> Hi Yves,
> trunk, thanks. :)
> Remy
Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #563321 is a reply to message #469118] Thu, 30 October 2008 19:18 Go to previous message
Yves YANG
> Sure!
> yves
>> Hi Yves,
>> trunk, thanks. :)
>> Remy
Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #563347 is a reply to message #469119] Fri, 31 October 2008 03:48 Go to previous message
Eclipse User
Hi Yves,
found.
Remy
Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #563369 is a reply to message #469120] Sat, 01 November 2008 03:14 Go to previous message
Eclipse User
Thanks.
Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #563389 is a reply to message #469122] Sat, 01 November 2008 09:16 Go to previous message
best regards
Yves YANG
> Thanks.
Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #563412 is a reply to message #469122] Sat, 01 November 2008 09:20 Go to previous message
best regards
Yves YANG
> Thanks.
Previous Topic:org.soyatec.eclipse4sl.vex.silverlight does not compile
Next Topic:Project proposal status
Current Time: Fri May 24 10:32:29 EDT 2013
Powered by FUDForum. Page generated in 0.02679 seconds
