| an Eclipse launch config specifically for Help? [message #468998] |
Wed, 21 February 2007 11:52  |
Richard Curtis Messages: 4 Registered: July 2009 |
Junior Member |
Is there a way to create an Eclipse launch
configuration that will launch the Help browser
immediately rather than having it launch a runtime
workbench from which you can launch the Help? I've
tried a couple of likely suspects (e.g. adding
org.eclipse.help.base_3.1.0/helpbase.jar
org.eclipse.help.standalone.Help -command displayHelp
to the "Arguments") to no avail.
thanks,
Richard O. Curtis
ClearCase Information Architect
IBM Rational Software
20 Maguire Rd.
Lexington, MA 02421-3112
781-676-2691 //voice
rocurtis@us.ibm.com //inet
| Re: an Eclipse launch config specifically for Help? [message #469006 is a reply to message #468998] |
Fri, 23 February 2007 18:22   |
Originally posted by: someone.somewhere.com
Hi Richard,
Can you describe more what you mean by "launch a runtime workbench"? What is
the artifact you're trying to avoid spawning?
Or is it that you're trying to make a launch configuration that adheres to
Eclipse launch configuration standard?
--Lee Anne Kowalski
kowalski at us dot ibm dot com
"Richard O. Curtis" <rocurtis@us.ibm.com> wrote in message
news:erhtbv$c50$1@utils.eclipse.org...
> thanks,
> Richard O. Curtis
> 20 Maguire Rd.
| Re: an Eclipse launch config specifically for Help? [message #469011 is a reply to message #468998] |
Wed, 28 February 2007 15:48   |
So what populates the "Run a product" set with the list that allows you to
select "org.eclipse.platform.ide" in the first place?
I mean, what populates that list of choices?
If it comes from the config.ini file (in eclipse/configuration), then it
would be to
somehow get an:
eclipse.product=<something>
Where the <something> is a thing that launches headless Eclipse and
the standalone help system call:
org.eclipse.help.base_[version].jar
So it depends on what are the rules for what can be eclipse.product? The
Product Configuration Editor might help in creating a configuration that is
headless Eclipse and the startup command for the standalone help system.
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. pde.doc.user/guide/tools/editors/product_editor/editor.htm
I haven't seen a .product file for running the standalone help system, but
that doesn't mean it couldn't be built. :-)
--Lee Anne
> We normally test our Help plug-ins by creating a run
> configuration (Eclipse main menu Run > Run..., then
> select "Eclipse application". We typically specify "Run
> a product" and select "org.eclipse.platform.ide" and
> then configure it to use the workspace doc plug-ins
> we're developing.
| Re: an Eclipse launch config specifically for Help? [message #560274 is a reply to message #468998] |
Hi Richard,
--Lee Anne Kowalski
> thanks,
> Richard O. Curtis
> 20 Maguire Rd.
| Re: an Eclipse launch config specifically for Help? [message #560278 is a reply to message #468998] |
would be to
somehow get an:
--Lee Anne
> we're developing.
FUDForum. Page generated in 0.02362 seconds
