Home » Modeling » VIATRA2 » Plug-in was unable to load class
Plug-in was unable to load class [message #468737] Sat, 01 November 2008 06:44 Go to next message
Acher is currently offline Acher
I have installed the last version of Viatra2 Plugin (version
3.0.0.20081009).
I'm using Eclipse Platform Version: 3.4.1.
When I want to select one of the Viatra Wizard (three options are possible
-- textual command, textual modeling, model space), I have systematically
this error message :
The selected wizard could not be started.
Plug-in org.eclipse.viatra2.editor.text was unable to load class
org.eclipse.viatra2.editor.text.wizards.NewVTMLWizard.
Bad version number in .class file
I think is should be fixed.
Of course, I am able to give any additional questions about my
configuration.
Your tools are very promising, hope to play with!
Thanks in advance,
Mathieu
PS : In a first attempt, I want to report this bug on Bugzilla Eclipse,
but it seems there is not there a product called Viatra
Re: Plug-in was unable to load class [message #468748 is a reply to message #468737] Fri, 22 May 2009 21:28 Go to previous message
Eclipse User
Originally posted by: tim.baumgartner.gmx.de
Hi Mathieu,
I had the same problem with build 3.0.0.20081009. I solved it by
starting with a Java 6 VM instead of Java 5.
Tim
Acher wrote:
> Hello,
> 3.0.0.20081009).
> possible -- textual command, textual modeling, model space), I have
> systematically this error message :
> I think is should be fixed. Of course, I am able to give any additional
> questions about my configuration.
> Thanks in advance,
> Best regards,
> Mathieu
Re: Plug-in was unable to load class [message #575053 is a reply to message #468737] Fri, 22 May 2009 21:28 Go to previous message
Eclipse User
Hi Mathieu,
Tim
Acher wrote:
> Hello,
> 3.0.0.20081009).
> Thanks in advance,
> Best regards,
> Mathieu
Previous Topic:Plug-in was unable to load class
Next Topic:VIATRA2 R3.1 is available immediately
Current Time: Tue May 28 20:03:16 EDT 2013
Powered by FUDForum. Page generated in 0.05148 seconds
