Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Which ActiveX controls are used by the browser?
Which ActiveX controls are used by the browser? [message #466699] Fri, 13 January 2006 14:01 Go to next message
Eclipse User
Originally posted by: Tanja.Buttler.FernUni-Hagen.de
We have a problem with a particular machine using XP and IE (version
6.0.2900.2180.xpsp_sp2_gdr.050301-1519), that does not receive Location
Events. On an other machine with the same version of IE this works fine.
According to Bug 107438, this might be a problem related to some ActiveX
controls.
Does anyone know which AxtiveX-controls could cause this problems?
Tanja Buttler
Re: Which ActiveX controls are used by the browser? [message #466759 is a reply to message #466699] Tue, 17 January 2006 10:00 Go to previous message
Veronika Irvine is currently offline Veronika Irvine
Please add comments to the bug report with specifics about the machine for
which this fails. What VM are you using, what service packs do you have
installed etc.
I have noticed that the person who reported Bug107438 and you have a German
email address. Is there some language extension or special
internationalization extension on the machine that shows the problem?
Anything that you can think of which might be unique to the machine with the
failure would be helpful.
"Tanja Buttler" <Tanja.Buttler@FernUni-Hagen.de> wrote in message
news:dq8tec$536$1@utils.eclipse.org...
> controls.
> Tanja Buttler
Previous Topic:plz help! how we can use the FieldEditorPreferencePage with SWT controls
Next Topic:Why these cursor can not be disposed??
Current Time: Wed May 22 02:46:01 EDT 2013
Powered by FUDForum. Page generated in 0.01727 seconds
