Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Non-embedded ActiveX application automation
Non-embedded ActiveX application automation [message #464529] Wed, 23 November 2005 16:31 Go to next message
Stephen Goldbaum is currently offline Stephen Goldbaum
Member
I'm trying to integrate Excel with an SWT application to call into Excel
to perform some tasks. Ideally, I'd just embed a Sheet in the SWT app,
but displaying Excel in SWT has some serious problems. So I attempted to
automate an Excel application using the IBM bridge2java libraries via the
"Excel.Application" progID. This works outside of SWT, but the
bridge2java and SWT libraries won't co-exsist. I though I might try the
same approach with SWT's OLE functionality. Unfortunately, opening
"Excel.Application" doesn't work. Does anyone know of a another way to
control an Excel app? Can the SWT-OLE libraries by tweeked or augmented
to allow this.
Stephen
Re: Non-embedded ActiveX application automation [message #464534 is a reply to message #464529] Wed, 23 November 2005 16:50 Go to previous messageGo to next message
Veronika Irvine is currently offline Veronika Irvine
Have a look at DsoFramer:
http://support.microsoft.com/default.aspx?scid=kb;en-us;311765
You can embed the DSOFramer ActiveX control in SWT using OleControlSite and
DSOFramer can host Excel.
The following bug describes an issue with DsoFramer with a workaround:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=73673
"Stephen Goldbaum" <stephen.goldbaum@lehman.com> wrote in message
news:221ea9ab68370cf9f7aa4c72d0bf23d0$1@www.eclipse.org...
> to allow this.
> Stephen
Re: Non-embedded ActiveX application automation [message #464643 is a reply to message #464534] Fri, 25 November 2005 14:28 Go to previous messageGo to next message
Member
Hi Veronika,
Thanks for the info. This will certainly do the trick for me. After
playing with brige2java, I've decided I like opening the full Excel
application so the user can open/close files as needed. Is it possible to
accomplish this with the OLE and COM classes?
Stephen
Re: Non-embedded ActiveX application automation [message #464644 is a reply to message #464643] Fri, 25 November 2005 16:01 Go to previous messageGo to next message
How are you launching "the full Excel"?
From the DSOFramer doc:
Open documents
You can also open and edit Office documents that exist on a local drive,
Universal Naming Convention (UNC) share, or Web folder. A standard Open
dialog box that can be displayed by the user or called by code has been
provided, and allows the user to find and select a file to open. You can
also call the Open method directly and give the control a specific file to
open.
news:8f71f1563cc2acc1c88f3ea311eb383a$1@www.eclipse.org...
> Hi Veronika,
> Stephen
Re: Non-embedded ActiveX application automation [message #464702 is a reply to message #464644] Mon, 28 November 2005 18:16 Go to previous messageGo to next message
Member
I took a better look at DSOFramer. It does look like this would be the
best solution for me. Unfortunately, I can't get it to embed anything.
The "File" dialog appears, but won't react to mouse events. I get
"Catastrophic Failure" when I call "Open", "CreateNew" and "ShowDialog"
(after I've picked a file). Does anyone have a working sample with SWT?
My earlier question was basically whether I could use the COM and OLE
classes to interact with a non-ActiveX or non-visual COM server. WIth
Bridge2Java, I use ProdId "Excel.Application" and it runs an new Excel
process in it's own window. I was wondering if I could do something
similar.
Stephen
Re: Non-embedded ActiveX application automation [message #464954 is a reply to message #464644] Thu, 01 December 2005 16:12 Go to previous message
Member
Did you happen to get any of the code from the thread at
http://dev.eclipse.org/newslists/news.eclipse.platform.swt/m sg17556.html?
I can't seem to get past the "Catastrophic failure" I get whenever I try
to open a document.
Stephen
Previous Topic:Table Column Width
Next Topic:TreeViewer only has small +/- buttons
Current Time: Mon May 20 08:48:14 EDT 2013
Powered by FUDForum. Page generated in 0.01637 seconds
