Home » Eclipse Projects » Standard Widget Toolkit (SWT) » bundles vs. .project file
bundles vs. .project file [message #464731] Tue, 29 November 2005 04:35 Go to next message
Eclipse User
Originally posted by: philipp.kutter.org
Dear all.
I asked the following in the newcommers newsgroup, but got never an answer.
We are still very interested in the topic.
Dear all.
We work on a large Java project, and we have used the normal project file
for dependencies between Java projects.
Some people in the project propose that we switch completly
to bundles, using manifest.mf files to define the dependencies
and the jar files which we use.
Since we are not using runtime workbenches and since
we do not create plugins, not all people do see the
advantage.
Especially they noted that the use of visility rules in
the .project file give exactly the same advantage as package import and
export in bundles.
Can you please advice us whether to move to bundles or not?
Best Regards, Philipp
Re: bundles vs. .project file [message #464735 is a reply to message #464731] Tue, 29 November 2005 05:13 Go to previous messageGo to next message
Stefan Langer is currently offline Stefan Langer
Are you planning on dstributing your project in an OSGI Enviroment? Is
the visibility of packages the only reason why you are considering bundles?
If not I would not use the manifest approach since you are not using any
of the features that it is intended for.
If you are distributing in an OSGI Enviroment I would recommend going
the bundle way.
Stefan
Philipp Kutter wrote:
> Dear all. I asked the following in the newcommers newsgroup, but got
> never an answer.
> Dear all.
> file for dependencies between Java projects.
> advantage.
> export in bundles.
Re: bundles vs. .project file [message #464823 is a reply to message #464731] Wed, 30 November 2005 09:31 Go to previous messageGo to next message
Veronika Irvine is currently offline Veronika Irvine
You will probably get a better response to this Eclipse Workbench question
on the eclipse platform newsgroup.
news://news.eclipse.org/eclipse.platform
"Philipp Kutter" <philipp@kutter.org> wrote in message
news:c05796decf728691385f1e15f59a4226$1@www.eclipse.org...
> Dear all. I asked the following in the newcommers newsgroup, but got never
> an answer.
> Dear all.
> advantage.
> export in bundles.
Re: bundles vs. .project file [message #464842 is a reply to message #464731] Wed, 30 November 2005 11:11 Go to previous message
Alex Blewitt is currently offline Alex Blewitt
Bundles (and the OSGI manifest) are necessary when you're running in an OSGI environment, such as you get with Eclipse plugins. However, if you're just using Eclipse as a Java IDE, then it's really unlikely that it will bring you any benefit at all.
In order for Manifest.MF files to be useful (as OSGI bundles), you'll have to have them hosted in another OSGI-aware system. It's highly unlikely you've got that.
Lastly, Eclipse uses the .project to track dependencies between projects (and the corresponding entries in .classpath), so if you want Eclipse to have inter-project dependencies for compilation, you *have* to use the .project/.classpath dependencies.
Alex.
Previous Topic:OleAutomation parameters problem
Next Topic:ProgressBar.getSelection()
Current Time: Sat May 25 01:30:24 EDT 2013
Powered by FUDForum. Page generated in 0.02006 seconds
