Home » Eclipse Projects » Standard Widget Toolkit (SWT) » cairo no longer shipped with 3.2M3?
cairo no longer shipped with 3.2M3? [message #464646] Fri, 25 November 2005 19:50 Go to next message
Jason Grant is currently offline Jason Grant
Member
It was nice that eclipse 3.1 shipped with a pre-built libcairo version
that matched SWT's needs. Eclipse 3.2M3 doesn't ship with this library.
Does the absence of the bundled library suggest that libcairo will no
longer will be supplied with eclipse? (I realise that this is only a
temporary measure until libcairo is included with the major linux
distros, but this still seems to be some way off). I'm keen for eclipse
to continue to ship with the libs, since it will make installation of my
RCP product much simpler.
For the benefit of others, I found the following rpms were required to
support advanced graphics under fedora core 4:
cairo-1.0.2-1.1.fc4.nr.i386.rpm
glitz-0.4.3-1.1.fc4.nr.i386.rpm
libpixman-0.1.5-1.1.fc4.nr.i386.rpm
and I got them from
www.nrpms.net.
Jason.
Re: cairo no longer shipped with 3.2M3? [message #464651 is a reply to message #464646] Sun, 27 November 2005 18:54 Go to previous message
Billy Biggs is currently offline Billy Biggs
Member
Please watch this bug:
http://bugs.eclipse.org/bugs/show_bug.cgi?id=110924
Shipping a dependency is a tricky thing to do, since you're doomed to
be behind what modern distributions ship, it increases the size of the
download, and you're vulnerable to bugs. However, you're correct that
cairo isn't yet in the major distributions (it's in SuSE 10 and the
latest from Ubuntu, but won't appear until FC5, etc).
What we're experimenting with now is giving the ability to include
a "libcairo-swt.so" alongside the SWT JNI libraries, and only load this
if we can't find a suitable version of cairo already installed on the
system. This code should appear in 3.2M4, and hopefully we can ship
with it a pre-built cairo 1.0.
Note that cairo 1.0.2 includes libpixman (really, we stopped
distributing a separate libpixman and put the code in cairo proper),
and glitz isn't used by cairo/GTK+ so you don't need that either.
-Billy
Previous Topic:Display.getActiveShell()
Next Topic:SWT Programming Techniques
Current Time: Sun May 19 23:58:56 EDT 2013
Powered by FUDForum. Page generated in 0.01486 seconds
