Home » Eclipse Projects » Standard Widget Toolkit (SWT) » JFace outside eclipse still needs eclipse core runtime?
JFace outside eclipse still needs eclipse core runtime? [message #463896] Tue, 15 November 2005 10:51 Go to next message
Eclipse User
Originally posted by: brigitte.ilsanker.gi-de.com
I'm trying to develop a standalone application, which should be a wizard
that users can use as a GUI without using Eclipse.
I understand from the documentation and from the article
"Developing JFace wizards Using the JFace toolkit" by Jeff Gunter found at
the IBM site
http://www-128.ibm.com/developerworks/java/library/os-ecjfw
that this should be possible.
Now I try to run the example provided at that site with the following
Error:
java.lang.NoClassDefFoundError: org/eclipse/core/runtime/IProgressMonitor
This sounds to me, that I do need eclipse core runtime classes. Is that
true?
Or do I simply use an outdated example and should change to newer
resources? If so, where to find it (I searched the eclipse site already
and even IBM's).
Bridget
Re: JFace outside eclipse still needs eclipse core runtime? [message #464008 is a reply to message #463896] Wed, 16 November 2005 09:23 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
> I understand from the documentation and from the article "Developing
> JFace wizards Using the JFace toolkit" by Jeff Gunter found at the IBM
> site http://www-128.ibm.com/developerworks/java/library/os-ecjfw
> Error:
> true? Or do I simply use an outdated example and should change to newer
> and even IBM's).
You don't need to run eclipse, but you do need the runtime jar in your
classpath (org.eclipse.core.runtime_XXX.jar). Or you could extract the
that class from the runtime jar ... It doesn't seem to have any other
dependancies on runtime.
That's the quick fix. You can also open a
https://bugs.eclipse.org/bugs/ against Platform/UI and ask about the
dependancy.
And lastly, I'm moving this to eclipse.platform, they work on JFace.
Later,
PW
Re: JFace outside eclipse still needs eclipse core runtime? [message #464012 is a reply to message #463896] Wed, 16 November 2005 09:28 Go to previous messageGo to next message
Radoslaw Grzanka is currently offline Radoslaw Grzanka
> Error:
> and even IBM's).
> Bridget
It is strange.. I have tried it with 3.1 not so long ago and it worked
only with swt and jface libraries.. No other were neccesary.
Radek.
Re: JFace outside eclipse still needs eclipse core runtime? [message #464030 is a reply to message #464012] Wed, 16 November 2005 10:16 Go to previous messageGo to next message
> Cheers,
> Radek.
It'll only show up if you use a JFace class that refers to the
IProgressMonitor ... otherwise the JVM will never try and load the class.
Later,
PW
Re: JFace outside eclipse still needs eclipse core runtime? [message #464212 is a reply to message #464030] Fri, 18 November 2005 13:39 Go to previous messageGo to next message
Boris Bokowski is currently offline Boris Bokowski
You can add yourself to the cc list of
https://bugs.eclipse.org/bugs/show_bug.cgi?id=49497 - a subset of the
core.runtime classes will be available as a separate JAR soon.
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:dlfihd$669$1@news.eclipse.org...
> > Cheers,
> > Radek.
> Later,
> PW
Re: JFace outside eclipse still needs eclipse core runtime? [message #464397 is a reply to message #464212] Tue, 22 November 2005 14:47 Go to previous messageGo to next message
John Arthorne is currently offline John Arthorne
Today, in fact. In I20051122 there remains only one JFace dependency
outside the small (65KB) org.eclipse.equinox.common plugin. See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=88577
Re: JFace outside eclipse still needs eclipse core runtime? [message #464526 is a reply to message #464397] Wed, 23 November 2005 14:06 Go to previous message
Douglas Pollock is currently offline Douglas Pollock
Member
As of N20051124-0010 and later, you need to add the following to your
classpath to run JFace standalone. Note that you need an SWT JAR that is
appropriate for your operating system and widget tool kit. The sizes are
approximate, and the "version" will vary from release to release.
729K org.eclipse.jface_version.jar
1.5M org.eclipse.swt.gtk.linux.x86_version.jar
4.0K org.eclipse.swt_version.jar
76K org.eclipse.core.commands_version.jar
64K org.eclipse.equinox.common_version.jar
There is no longer any dependency on the "org.eclipse.core.runtime" plug-in.
cheers,
d.
Previous Topic:How to open Web page from my plugin???
Next Topic:Table Column: displaying the & character
Current Time: Tue May 21 03:35:01 EDT 2013
Powered by FUDForum. Page generated in 0.06550 seconds
