Home » Eclipse Projects » Standard Widget Toolkit (SWT) » invisible elements in layouts
invisible elements in layouts [message #463133] Thu, 27 October 2005 14:18 Go to next message
Adam Pordzik is currently offline Adam Pordzik
I have an composite with n elements and want to hide one or more
inside this Composite, so that the remainings children share the
remaining space among them.
Just setVisible() on those widgets and calling layout() on parenting
composite doesn't helped me.
Thanks for hints, I have no idea where to look for anymore.
A
| W1 | W2 | W3 | W4 |
should become e.g.:
| W1 | W3 | W4 |
Re: invisible elements in layouts [message #463134 is a reply to message #463133] Thu, 27 October 2005 14:42 Go to previous messageGo to next message
Ricky is currently offline Ricky
> | W1 | W2 | W3 | W4 |
> should become e.g.:
> | W1 | W3 | W4 |
Using a GridLayout and setting the field exclude on a GridData object to
true works for me.
Ricky
Re: invisible elements in layouts [message #463135 is a reply to message #463134] Thu, 27 October 2005 14:49 Go to previous messageGo to next message
> true works for me.
Thanks, but I want to keep compatible to 3.0.
Re: invisible elements in layouts [message #463158 is a reply to message #463135] Fri, 28 October 2005 06:50 Go to previous messageGo to next message
>> to true works for me.
If 3.0 does not differ to much from 3.1 maybe you can extract the class.
Layouts are very independent and GridLayout seems not to have unusual
dependencies.
Ricky
Re: invisible elements in layouts [message #463208 is a reply to message #463158] Sun, 30 October 2005 14:16 Go to previous messageGo to next message
Sebastian Machhausen is currently offline Sebastian Machhausen
Hi Ricky,
is it really true that this field has been removed in 3.1? I'm using swt from the eclipse 3.2M2 branch and it is still in and as far as i can see it hasn't changed since 3.0. There is no compatibilty issue on that.
Greetings
Sebastian
Re: invisible elements in layouts [message #463216 is a reply to message #463208] Mon, 31 October 2005 07:17 Go to previous message
Hi Sebastian,
I think you misunderstood the argument. Adam Pordzik pointed out that
GridLayout is not an option for his problem as he want to stay compatible
to 3.0. I do not know the API differences between 3.0,3.1 and 3.2 but
assume he is right. So I suggested to extract/backport the 3.1 GridLayout
class to 3.0.
Am I right or do I need more coffee? :)
Ricky
PS
I looked at the GridData API and indeed the exclude attribute was
introduced in 3.1. But backporting GridLayout should be possible as it is
common to implement custom layouts and GridLayout does no black magic (as
far as I can see on first glance)
Previous Topic:Home for SWT JFreeChart
Next Topic:How to start swt project? How to use maven on swt project?
Current Time: Wed May 22 20:55:31 EDT 2013
Powered by FUDForum. Page generated in 0.01743 seconds
