Home » Eclipse Projects » Mylyn » Can you remove "Unmatched Tasks"?
Can you remove "Unmatched Tasks"? [message #44968] Fri, 07 March 2008 03:31 Go to next message
Dave Syer is currently offline Dave Syer
Member
I have a category of Mylyn tasks called "Unmatched Tasks" that I didn't
create. Presumbably they come from queries I once set up and then
discarded, or something. Can I get rid of them?
Re: Can you remove "Unmatched Tasks"? [message #45043 is a reply to message #44968] Fri, 07 March 2008 05:59 Go to previous messageGo to next message
Eclipse User
Well, as far as I know you can't get rid of the "unmatched" category
/permanently/, but you when you delete all its entries, the category is
automatically hidden.
It may reappear, though: As soon as a task is no longer matched by at
least one "regular" query it shows up in the "unmatched" category.
BTW: I'm talking about Mylyn 2.3, the behaviour might be different in
older versions.
HTH,
Mark
Re: Can you remove "Unmatched Tasks"? [message #45107 is a reply to message #45043] Fri, 07 March 2008 19:29 Go to previous messageGo to next message
Mik Kersten is currently offline Mik Kersten
To get rid of tasks in the Unmatched container you can Delete them. I
just updated the corresponding FAQ entry:
http://wiki.eclipse.org/Mylyn_FAQ#Why_do_tasks_appear_in_the _Unmatched_container.3F
Mik
Mark Kirchner wrote:
>> didn't create. Presumbably they come from queries I once set up and
>> then discarded, or something. Can I get rid of them?
> older versions.
> HTH,
> Mark
Re: Can you remove "Unmatched Tasks"? [message #45131 is a reply to message #45107] Sat, 08 March 2008 09:22 Go to previous messageGo to next message
Jörg Thönnes is currently offline Jörg Thönnes
Mik, in the FAQ entries the term "Archive Category" is used with regard to filtering and as a
general category. AFAIK, the filtering is no longer supported/needed, and the category is now a
connector specific unmatched category.
Is that correct? Then, the FAQ should be updated.
Cheers, Jörg
> Mik
>> is automatically hidden.
>> older versions.
>> HTH,
>> Mark
Re: Can you remove "Unmatched Tasks"? [message #45283 is a reply to message #45131] Tue, 11 March 2008 14:09 Go to previous messageGo to next message
Eclipse User
Originally posted by: rob.elves.eclipse.org
Jörg,
You are correct, the Archive is a thing of the past and has been
replaced with repository specific Unmatched containers. I've update the
FAQ terminology.
-Rob
> to filtering and as a general category. AFAIK, the filtering is no
> longer supported/needed, and the category is now a connector specific
> unmatched category.
> Cheers, Jörg
>> Mik
>>> Hi,
>>> older versions.
>>> HTH,
>>> Mark
Re: Can you remove "Unmatched Tasks"? [message #46251 is a reply to message #44968] Thu, 27 March 2008 19:43 Go to previous message
Steffen Pingel is currently offline Steffen Pingel
There is also discussion on this bug report to make removing all tasks from
the Unmatched category easier:
223086: allow to remove all tasks from unmatched container
https://bugs.eclipse.org/bugs/show_bug.cgi?id=223086
Steffen
Re: Can you remove "Unmatched Tasks"? [message #588376 is a reply to message #44968] Fri, 07 March 2008 05:59 Go to previous message
Mark Kirchner is currently offline Mark Kirchner
older versions.
HTH,
Mark
Re: Can you remove "Unmatched Tasks"? [message #588397 is a reply to message #45043] Fri, 07 March 2008 19:29 Go to previous message
Mik
> older versions.
> HTH,
> Mark
Re: Can you remove "Unmatched Tasks"? [message #588401 is a reply to message #45107] Sat, 08 March 2008 09:22 Go to previous message
Cheers, Jörg
> Mik
>> older versions.
>> HTH,
>> Mark
Re: Can you remove "Unmatched Tasks"? [message #588447 is a reply to message #45131] Tue, 11 March 2008 14:09 Go to previous message
Robert Elves is currently offline Robert Elves
Member
Jörg,
FAQ terminology.
-Rob
> unmatched category.
> Cheers, Jörg
>> Mik
>>> Hi,
>>> older versions.
>>> HTH,
>>> Mark
Re: Can you remove "Unmatched Tasks"? [message #588755 is a reply to message #44968] Thu, 27 March 2008 19:43 Go to previous message
Steffen
Previous Topic:JIRA custom attributes
Next Topic:Reverse order on Bugzilla comments
Current Time: Fri May 24 16:12:59 EDT 2013
Powered by FUDForum. Page generated in 0.02897 seconds
