Home » General (non-technical) » Eclipse Foundation » eclipse instalation
eclipse instalation [message #45670] Mon, 30 April 2007 19:12 Go to next message
Eclipse User
Originally posted by: kraftwerk22.hotmail.com
I downloaded Eclipse-3.2.1,
but. when I execute, eclipse doesn´t find javaw.exe file.
How can I do to install it?
Re: eclipse instalation [message #45698 is a reply to message #45670] Tue, 01 May 2007 06:20 Go to previous messageGo to next message
Eclipse User
Originally posted by: alex_blewitt.yahoo.com
This isn't the right place to ask this question. You should instead ask on Ask EZ.
What you need to do is to install Java, from http://java.sun.com.
Alex.
Re: eclipse instalation [message #45728 is a reply to message #45670] Tue, 01 May 2007 09:42 Go to previous message
Eclipse User
Originally posted by: marcelabx.gmail.com
Before using eclipse you need JRE(execution environment)
But I recommend you to install JDK (development environment)
because without JDK you can not depurate in eclipse.
In summary you have to set the environment vars "PATH" AND "JAVA HOME"
Example
If you installed java in the directory:
/usr/java/jdk-1.5
you have to do:
JAVA_HOME=/usr/java/jdk-1.5
PATH=/usr/java/jdk-1.5/bin
good luck
Previous Topic:synchronize the method start
Next Topic:Test First Development Webinar by Wayne Beaton
Current Time: Sat May 18 23:07:19 EDT 2013
Powered by FUDForum. Page generated in 0.27436 seconds
