Home » Modeling » M2T (model-to-text transformation) » <java:class> in non source-folder
<java:class> in non source-folder [message #45706] Fri, 16 May 2008 11:41 Go to next message
Felix Dorner is currently offline Felix Dorner
Hey Paul,
some time ago I read about problems when the srcFolder attribute of a
<java:class> tag is not a "source folder". This is a problem for me, so I think
about switching to the <ws:file> tag. Before trying, I'd like to ask about
possible problems, e.g. in the template which is responsible for generating the
class content I use all other kinds of <java> tags. Do these in some way rely on
being "inside" a <java:file> tag?
What is the general advantage from using <java:class> over <ws:file>?
Felix
Re: <java:class> in non source-folder [message #45767 is a reply to message #45706] Fri, 16 May 2008 12:50 Go to previous messageGo to next message
I don't seem to get it done. The problem is that I suddenly get no more
exception traces. Jet just says "errors during execution".
I tried it like that. Maybe someone finds what I do wrong, I am unsure about
those variables in xpath functions..
<c:iterate select="//Class" var="_class">
<ws:file path="{concat($genpath,replace($_class/@__qname, '.','/'),'.java')}"
template="templates/class.jet"/>
</c:iterate>
<c:iterate select="//Enumeration" var="_enum">
<ws:file path="{concat($genpath,replace($_enum/@__qname, '.','/'),'.java')}"
template="templates/enumeration.jet"/>
</c:iterate>
Felix
Re: <java:class> in non source-folder [message #46056 is a reply to message #45706] Wed, 21 May 2008 20:17 Go to previous messageGo to next message
Paul Elder is currently offline Paul Elder
Felix:
Sorry, somehow I missed the messages earlier...
The only real advantage of java:class over ws:file is that you don't have to
any mapping from java package names to directory names.
The java:class tag does use the JDT apis to find source folders and
packages, but ultimately, it turns all this info into an IFolder, and then
creates an IFile with a .java extension.
The one bit of magic that java:class does is if you specify a project name
as the source folder. If that project has explicitly specified source
folders, then java:class will use the first one.
I'm not aware of any problems with java:class.
Paul
Re: <java:class> in non source-folder [message #46085 is a reply to message #45767] Wed, 21 May 2008 20:20 Go to previous message
Felix:
I prefer:
<ws:file path="{$genpath}/{replace($_class/@__qname, '.','/')}.java"
but, I don't see anything wrong with your example, unless $genpath doesn't
end with a /
Is there anything in the error log?
Paul
Previous Topic:Re: jet editor java syntax coloring
Next Topic:Re: package explorer doesn't show source folders
Current Time: Sun May 19 00:30:01 EDT 2013
Powered by FUDForum. Page generated in 0.01578 seconds
