| Re: Example for Provide and Register for parent doc relationship RPLC [message #45663 is a reply to message #45633] |
Wed, 13 August 2008 18:33   |
Originally posted by: frank.frederick.mckesson.com
Thanks, that helped. Is there a Consumer example that uses a query
based on the UUID for the document?
Frank
Sarah Knoop wrote:
> Check out the MESA JUNIT test in the xds.source - 11748 (this is the
> replace example). Switching all debug loggin on, should print the ebXML
> to the screen (if this is what you are after).
> This test is for XDS.a -- but XDS.b api is virtually identical.
> - Sarah
> Frank wrote:
>> Is there a example in the OHF test code for provide and register a
>> document for the parent document relationship RPLC?
>> Thanks,
>> Frank
| Re: Example for Provide and Register for parent doc relationship RPLC [message #45693 is a reply to message #45663] |
Thu, 14 August 2008 15:08  |
No real name Messages: 292 Registered: July 2009 |
Mesa 11940
org.eclipse.ohf.ihe.xds.consumer\src_tests\org\eclipse\ohf\i he\xds\consumer\test\mesa
part 1 = XDS.a and part 2 = xds.b (in terms of code execution .. though
the resultant on-the-wire-message is identical)
hope this helps,
- Sarah
> Frank
>> ebXML to the screen (if this is what you are after).
>> - Sarah
>>> Thanks,
>>> Frank
| Re: Example for Provide and Register for parent doc relationship RPLC [message #586717 is a reply to message #45563] |
Tue, 12 August 2008 12:29  |
- Sarah
> Frank
| Re: Example for Provide and Register for parent doc relationship RPLC [message #586731 is a reply to message #45633] |
Frank Messages: 49 Registered: July 2009 |
Member |
Frank
> - Sarah
>> Thanks,
>> Frank
| Re: Example for Provide and Register for parent doc relationship RPLC [message #586743 is a reply to message #45663] |
Mesa 11940
hope this helps,
- Sarah
> Frank
>> - Sarah
>>> Thanks,
>>> Frank
FUDForum. Page generated in 0.01819 seconds
