Home » Eclipse Projects » Eclipse Platform » show a view from a LaunchDelegate
show a view from a LaunchDelegate [message #427812] Thu, 30 July 2009 10:12 Go to next message
Christoph Höger is currently offline Christoph Höger
Member
after my launch delegate succeeded I would like to open a special view
that shows the output of the launch to the user. But I am not able to
get an active IWorkbenchwindow from "down there" (aka the launch()
method) is there any trick to do that?
Re: show a view from a LaunchDelegate [message #441836 is a reply to message #427812] Fri, 31 July 2009 07:32 Go to previous messageGo to next message
Prakash G.R. is currently offline Prakash G.R.
Christoph Höger wrote:
Probably the launch() method is from a class of debug core plugin. Did
you try PlatformUI.getWorkbench().getActiveWindow()?
- Prakash
http://blog.eclipse-tips.com
Re: show a view from a LaunchDelegate [message #451364 is a reply to message #441836] Sat, 01 August 2009 06:27 Go to previous message
Member
Am 31.07.2009 13:32, schrieb Prakash G.R.:
Yeah, that returned null. The trick is to run that via
Display.asyncExec(). Ugly - but works.
Previous Topic:What Restrictions Does Eclipse Impose On Plugin Development
Next Topic:[commands] override a handler
Current Time: Mon May 20 17:19:02 EDT 2013
Powered by FUDForum. Page generated in 0.01780 seconds
