Home » General (non-technical) » Board committer reps  » Reporting Europa bugs
Reporting Europa bugs [message #4457] Thu, 10 May 2007 10:29 Go to next message
Dave Orme is currently offline Dave Orme
Hi Committer reps,
I'm having trouble loading Europa and am having trouble finding the
official channels for reporting the problems I'm encountering:
1) Is there a cross-project bug bucket for Europa this year? I don't
see any top-level Bugzilla classifications that would make sense...:
Should I mail the Planning Council list?
BIRT: The BIRT Project: http://www.eclipse.org/birt/
DataTools: The DataTools Platform Project:
DSDP: The Device Software Development Platform:
Eclipse: The Eclipse Project - Eclipse SDK and Platform...
Eclipse Foundation: Community bugs
Modeling: The Modeling Project: http://www.eclipse.org/modeling/
STP: The SOA Tools Platform Project: http://www.eclipse.org/stp/
Technology: The Technology Project
Tools: The Tools Project - AJDT, AspectJ, CDT, EMF, GEF, PHP, VE,
UML2: http://www.eclipse.org/tools/
TPTP: The Test & Performance Tools Platform:
WebTools: The WebTools Project: http://www.eclipse.org/webtools/
2) I just tried to load Europa M7 via UM and ran into two difficulties:
A) If I just check all of Europa in UM, I get failed dependencies.
B) If I then remove the projects responsible for the failed
dependencies, everything downloads, the hard drive chatters, and then I
get a dialog saying simply "Update failed". No hint of what went wrong
and apparently no way to install Europa via UM.
Dave Orme
Re: Reporting Europa bugs [message #4526 is a reply to message #4457] Thu, 10 May 2007 10:56 Go to previous messageGo to next message
Eclipse User
David,
This is a good question that's best addressed by the planning council,
though I think the note should be posted to
cross-project-issues-dev@eclipse.org since more people are subscribed to
that and I would certainly expect all the planning council folks to see
a posting to that mailing list. It sounds like you are running into
some pretty serious issues! :-(
David Orme wrote:
> Hi Committer reps,
> VE, UML2: http://www.eclipse.org/tools/
> I get a dialog saying simply "Update failed". No hint of what went
> wrong and apparently no way to install Europa via UM.
> Dave Orme
Re: Reporting Europa bugs [message #4596 is a reply to message #4457] Thu, 10 May 2007 11:39 Go to previous messageGo to next message
Eclipse User
Originally posted by: john.eclipsefaq.org
Note that Europa M7 isn't scheduled to be available until May 22nd:
http://wiki.eclipse.org/index.php/Europa_Simultaneous_Releas e. Maybe
you're seeing a combination of M6/M7?
David Orme wrote:
> Hi Committer reps,
> Dave Orme
Re: Reporting Europa bugs [message #4872 is a reply to message #4596] Fri, 11 May 2007 09:48 Go to previous messageGo to next message
Maybe. Although I tried because I thought I saw a message on the
Planning Council list (to which I'm still subscribed as a former project
lead) saying it was ready.
But a good point nonetheless.
Dave
Re: Reporting Europa bugs [message #4942 is a reply to message #4872] Fri, 11 May 2007 09:51 Go to previous message
Looks like you're right here. Thanks.
Dave Orme
Re: Reporting Europa bugs [message #560334 is a reply to message #4457] Thu, 10 May 2007 10:56 Go to previous message
Ed Merks is currently offline Ed Merks
David,
David Orme wrote:
> Hi Committer reps,
> Dave Orme
Re: Reporting Europa bugs [message #560342 is a reply to message #4457] Thu, 10 May 2007 11:39 Go to previous message
John Arthorne is currently offline John Arthorne
http://wiki.eclipse.org/index.php/Europa_Simultaneous_Releas e Maybe
David Orme wrote:
> Hi Committer reps,
> Dave Orme
Re: Reporting Europa bugs [message #560364 is a reply to message #4596] Fri, 11 May 2007 09:48 Go to previous message
Dave
Re: Reporting Europa bugs [message #560368 is a reply to message #4872] Fri, 11 May 2007 09:51 Go to previous message
Dave Orme
Previous Topic:The First 100 Days
Next Topic:Board Meeting
Current Time: Sat May 18 16:58:25 EDT 2013
Powered by FUDForum. Page generated in 0.01892 seconds
