Home » Modeling » OCL » def expression?
def expression? [message #443993] Fri, 31 July 2009 12:08 Go to next message
Joel Greenyer is currently offline Joel Greenyer
I'm confused whether or how the "def:" expression is supported. My intuition is that I e.g. type
def: s: String = 'Hello'
in the console and that I can use the variable s when evaluating subsequent expressions. However, that doesn't seem to work.
What am I missing?
Joel
Re: def expression? [message #444438 is a reply to message #443993] Fri, 31 July 2009 13:10 Go to previous messageGo to next message
Hi Joel
def defines an additional feature Property/Operation in the prevailing
context.
That feature can be used in subsequent expressions.
[Arguably it should be useable in preceding expressions too, though a
detailed reading of the OCL specification of Environment mutation seems
to imply that it can only be used in nested environments.] Anyway,
MDT-OCL currently supports subsequent expressions.
If you want to create a variable you should use let or an iterator.
As always "doesn't seem to work" is never a good way of asking for help.
What did you do? What did you expect to happen? What actually happened?
What was the context of your experience? What versions of the software
were you using?
Ed Willink
Joel Greenyer wrote:
> What am I missing?
> Joel
Re: def expression? [message #450333 is a reply to message #444438] Sat, 01 August 2009 03:57 Go to previous messageGo to next message
Ed,
thanks for your explanation.
I'll start by explaining the context of my problem: I'm developing a TGG transformation engine (remember that we've
talked at TOOLS'07) that shall now support OCL constraints/assignments, similar to QVT-R. While matching a precondition
graph, I add matched nodes as bound variables in an OCL environment/evaluationEnvironment. Those variables I can now use
in OCL expressions. Sometimes, it's useful to use let-expressions to define a variable that I can reuse multiple times
in an expression. However, in some cases, I find myself writing the same let-expression again for other constraints.
Then, instead I thought to use a def-expression to define a variable that I can reuse in other constraints. I started
out with a simple expression "def: s: String = 'Hello'" which gave me a error ""inv:" misplaced construct(s)"
So, as so often, I went back to the OCL console and tried the same expression with the same result. I can't really say
what I expected, maybe that there was so particular result and I could just reuse the variable s in subsequent expressions.
I have the feeling that I don't understand def-expressions or that I'm missing something in the way that the OCL engine
works. I'm using OCL 1.3.0.v200901271800 (in the modeling package of the Galileo release).
Thanks for helping
Joel
Ed Willink wrote:
> Hi Joel
> context.
> were you using?
> Regards
> Ed Willink
>> What am I missing?
>> Joel
Re: def expression? [message #450817 is a reply to message #450333] Sat, 01 August 2009 04:40 Go to previous messageGo to next message
Hi Joel
Re-useable let expressions is exactly what I use def's for.
You might find /org.eclipse.qvt/oclsrc/QVTRelation.ocl or
/org.eclipse.qvt.declarative.examples.ocl.royalandloyal/ocls rc/RoyalAndLoyal/RoyalAndLoyal.ocl
helpful. Each may be found in /cvsroot/modeling
org.eclipse.m2m/org.eclipse.qvt.declarative.
I mostly use OCL within the OCL Editor currently available from CVS for
org.eclipse.qvt.declarative. This will be migrating to MDT-OCL for
Helios. (Watch this space for an Update Site announcement).
I'm afraid that I've never used the OCL Console, so I suspect that you
may be hitting a 'multi-line' limitation of a 'single-line' interface.
Ed Willink
> Ed,
> transformation engine (remember that we've talked at TOOLS'07) that
> matching a precondition graph, I add matched nodes as bound variables in
> define a variable that I can reuse multiple times in an expression.
> again for other constraints. Then, instead I thought to use a
> constraints. I started out with a simple expression "def: s: String =
> expression with the same result. I can't really say what I expected,
> missing something in the way that the OCL engine works. I'm using OCL
> Thanks for helping
> Joel
> Ed Willink wrote:
>> Hi Joel
>> context.
>> seems to imply that it can only be used in nested environments.]
>> Anyway, MDT-OCL currently supports subsequent expressions.
>> were you using?
>> Regards
>> Ed Willink
>>> Hi,
>>> What am I missing?
>>> Joel
Re: def expression? [message #460200 is a reply to message #450817] Sun, 02 August 2009 04:21 Go to previous messageGo to next message
Hi Ed,
I took a def expression from the royal-and-loyal example
def :
initial : String = self.name.substring(1, 1)
and execute it (in the context of an object that has a "name" attribute). I did that in the OCL console as well as in my
transformation rules. Either way, I get
org.eclipse.ocl.SyntaxException: "inv:" misplaced construct(s)
Any idea? The OCL interpreter/environment does really not have to be set up in any certain way to support def-expressions?
Joel
Ed Willink wrote:
> Hi Joel
> Regards
> Ed Willink
>> Ed,
>> TGG transformation engine (remember that we've talked at TOOLS'07)
>> While matching a precondition graph, I add matched nodes as bound
>> I can now use in OCL expressions. Sometimes, it's useful to use
>> same let-expression again for other constraints. Then, instead I
>> in other constraints. I started out with a simple expression "def: s:
>> Thanks for helping
>> Joel
>> Ed Willink wrote:
>>> Hi Joel
>>> prevailing context.
>>> software were you using?
>>> Regards
>>> Ed Willink
>>>> Hi,
>>>> What am I missing?
>>>> Joel
Re: def expression? [message #467843 is a reply to message #443993] Mon, 03 August 2009 02:58 Go to previous messageGo to next message
Hi Joel
I've loaded up the Interpreter example. (We really must move this to a
non-example UI feature). I got it working under Ganymede by copying
UML.ecore to the UMLPackageImpl folder - wierd.
It is clear that the Console is there solely to evaluate a single query
that does not change the model. A def: is not a query.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=259922 suggests a variety
of improvements.
Ed Willink
Re: def expression? [message #468430 is a reply to message #443993] Wed, 05 August 2009 09:46 Go to previous messageGo to next message
So, the def-expression is no query and createQuery(String expression) does not work. Instead, I have to use
OCLHelper.defineAttribute(String defExpression), right?
The problem is that I can't find any examples of using the OCL API in the right way to handle different cases of
expressions (queries and def-expression) that I have in my transformation rules.
Could anyone please provide a snippet how to do that or point me to some example that demonstrates how to do it?
Thanks a lot
Joel
> What am I missing?
> Joel
Re: def expression? [message #479596 is a reply to message #460200] Tue, 11 August 2009 12:40 Go to previous messageGo to next message
Christian W. Damus is currently offline Christian W. Damus
--=-U6F5mCtO3V5LduTGHT6X
Content-Type: text/plain
Hi, Joel,
The current "official" OCL Console example does not support def:
expressions by any means. It only supports query expressions (in "M2"
mode) or constraints (in "M1" mode; invariants on classifier selection,
post-conditions on operation selection, derive on attribute selection).
In particular, there is no support for any of the concrete syntax of
context declaration (which includes the "def:" keyword) and the console
internal always constructs this context declaration according to the
selected object.
In your case, the console is prepending to your 'expression' (which
includes the "def:" keyword) a context declaration ending with "inv:"
because it thinks you want to define an invariant constraint or a query.
Christian
On Sun, 2009-08-02 at 10:21 +0200, Joel Greenyer wrote:
> Hi Ed,
> def :
> Joel
Content-Type: text/html; charset="utf-8"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.24.1.1">
</HEAD>
<BODY>
Hi, Joel,<BR>
<BR>
The current &quot;official&quot; OCL Console example does not support def: expressions by any means.&nbsp; It only supports query expressions (in &quot;M2&quot; mode) or constraints (in &quot;M1&quot; mode; invariants on classifier selection, post-conditions on operation selection, derive on attribute selection).&nbsp; In particular, there is no support for any of the concrete syntax of context declaration (which includes the &quot;def:&quot; keyword) and the console internal always constructs this context declaration according to the selected object.<BR>
<BR>
In your case, the console is prepending to your 'expression' (which includes the &quot;def:&quot; keyword) a context declaration ending with &quot;inv:&quot; because it thinks you want to define an invariant constraint or a query.<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
Hi Ed,
def :
and execute it (in the context of an object that has a &quot;name&quot; attribute). I did that in the OCL console as well as in my
org.eclipse.ocl.SyntaxException: &quot;inv:&quot; misplaced construct(s)
Joel
</PRE>
</BLOCKQUOTE>
<BR>
</BODY>
</HTML>
--=-U6F5mCtO3V5LduTGHT6X--
Re: def expression? [message #479597 is a reply to message #468430] Tue, 11 August 2009 12:42 Go to previous messageGo to next message
--=-N7nqXePYbegdqjxfyRQe
Hi, Joel,
If the SDK documentation doesn't provide examples, then your best bet is
to look into the JUnit tests. Search for invocations of the OCLHelper
methods in the org.eclipse.ocl.ecore.tests plug-in, for example. They
should all be covered, IIRC.
HTH,
Christian
> Thanks a lot
> Joel
> > Hi,
> > What am I missing?
> > Joel
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Joel,<BR>
<BR>
If the SDK documentation doesn't provide examples, then your best bet is to look into the JUnit tests.&nbsp; Search for invocations of the OCLHelper methods in the org.eclipse.ocl.ecore.tests plug-in, for example.&nbsp; They should all be covered, IIRC.<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
Thanks a lot
Joel
&gt; Hi,
&gt; I'm confused whether or how the &quot;def:&quot; expression is supported. My
&gt; intuition is that I e.g. type
&gt;
&gt; def: s: String = 'Hello'
&gt;
&gt; in the console and that I can use the variable s when evaluating
&gt; subsequent expressions. However, that doesn't seem to work.
&gt;
&gt; What am I missing?
&gt;
&gt; Joel
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-N7nqXePYbegdqjxfyRQe--
Re: def expression? [message #480234 is a reply to message #479597] Fri, 14 August 2009 09:32 Go to previous messageGo to next message
Hi Christian,
thanks for pointing me to the JUnit tests. However, I am still a bit lost. Or, maybe, my problem is bit more tricky than
just using def-expressions.
What I am doing is the following: I have a graph matcher that matches typed nodes to eObjects. When named nodes are
bound in the matching process, I add a variable with the node's name and the bound eObject to the OCL
environment/evaluationenvironment. The graph matcher also backtracks at times, and when it does, I remove those
variables corresponding to the back-tracked nodes again from the OCL environment/evaluationenvironment.
Before nodes can be bound, I check OCL constraints that are attached to them. Those constraints
may contain variables that already exist (when the corresponding nodes were bound) or not (when the corresponding nodes
are not yet bound). In the latter case, I catch a parseException and try evaluating the expression again when matching
the next node and so on, until I can successfully evaluate the expression. I put all successfully evaluated expressions
in a map (node where evaluation was successful->expression) and upon backtracking, I put them back into a list of
yet-to-be-evaluated expressions.
Now I'd like to use expressions that allow me to define reusable values (and also operations in the long term).
One general thing that confuses me is that the def-expressions define attributes of some context classifier. In
let-expressions, for example, I just define a variable that I can reuse in the in-expression. That is rather what I
want. I'd just like to create a variable to reuse.
Right now I am thinking of processing the "def: <varname> : <typename> = " part of the def-expression in my own code,
let the OCL-helper evaluate the subsequent expression, and define a variable in the same way I do for my nodes.
Then again I wonder whether the OCL fragmework could help me do that? Or do you have any better idea to define my variables?
Mind, that I also have to "undefine" those variables again when I backtrack past the point of where I successfully
evaluated it.
Thanks for helping
Joel
Christian W. Damus wrote:
> Hi, Joel,
> HTH,
> Christian
>> Thanks a lot
>> Joel
>> > Hi,
>> > What am I missing?
>> > Joel
Re: def expression? [message #480245 is a reply to message #480234] Fri, 14 August 2009 10:34 Go to previous messageGo to next message
Hi Joel
I'm not sure about your whole problem but when you mention removing
variables from environments I get very uncomfortable. It is much easier
to created a nested environment for the nested scope and revert to the
outer ebvironment when you want to recover context.
I know Let and Iterate current use dynamically changing environments,
but that is likely to change to nested environments in the next MDT-OCL
release.
Ed Willink
> Hi Christian,
> lost. Or, maybe, my problem is bit more tricky than just using
> def-expressions.
> times, and when it does, I remove those variables corresponding to the
> were bound) or not (when the corresponding nodes are not yet bound). In
> expression again when matching the next node and so on, until I can
> expressions in a map (node where evaluation was successful->expression)
> in the in-expression. That is rather what I want. I'd just like to
> " part of the def-expression in my own code, let the OCL-helper evaluate
> for my nodes.
> backtrack past the point of where I successfully evaluated it.
> Thanks for helping
> Joel
>> Hi, Joel,
>> is to look into the JUnit tests. Search for invocations of the
>> example. They should all be covered, IIRC.
>> HTH,
>> Christian
>>> the right way to handle different cases of expressions (queries and
>>> Thanks a lot
>>> Joel
>>> > Hi,
>>> > > What am I missing?
>>> > > Joel
Re: def expression? [message #480364 is a reply to message #480245] Sun, 16 August 2009 04:26 Go to previous messageGo to next message
Hi Ed,
comments below
Ed Willink wrote:
> Hi Joel
Why is that?
> It is much easier
I haven't worked with these nested environments yet, but I'll keep it in mind. However, I'd have to create a nested
environment for each variable that I add. Adding and removing variables is easy and works well for me so far.
> release.
> Regards
> Ed Willink
>> Hi Christian,
>> def-expressions.
>> at times, and when it does, I remove those variables corresponding to
>> list of yet-to-be-evaluated expressions.
>> reuse in the in-expression. That is rather what I want. I'd just like
>> = " part of the def-expression in my own code, let the OCL-helper
>> Thanks for helping
>> Joel
>>> Hi, Joel,
>>> HTH,
>>> Christian
>>>> in the right way to handle different cases of expressions (queries
>>>> Thanks a lot
>>>> Joel
>>>> > Hi,
>>>> > > What am I missing?
>>>> > > Joel
Re: def expression? [message #480375 is a reply to message #480364] Sun, 16 August 2009 08:03 Go to previous messageGo to next message
Hi Joel
> Why is that?
It means that the Environment has a very clear locality. Nested
environments are always valid for the context that initialised them.
Note that OCL 2.0 does not support remove of elements from an Environment.
>> It is much easier
You'll find nested environments are easy too, and you cannot forget to
match your adds with removes.
> mind. However, I'd have to create a nested environment for each variable
> so far.
If it works for you fine. Just beware that if you start to do more
interesting things, it might bite later.
Ed Willink
Re: def expression? [message #481244 is a reply to message #480375] Thu, 20 August 2009 04:58 Go to previous messageGo to next message
Ed,
I've been trying to get familiar with nested environments, You promised that they were easy to use ;), but unfortunately
I can't find code examples--at least not any that point in the direction that I need to go.
In short, my problem is that I match a graph pattern to a model and, during the matching process, I need a scope that
constantly reflects the bound nodes by bound variables, i.e. the scope must contain a bound variable per named node that
is currently bound.
While I backtrack, I need to remove variables from my environment/scope that will possibly be added again. So, you
suggest to do this with nested environments--How do I create a nested environment (I think I understood that...) and how
to I go back to an outer environment when I backtrack?
Thanks for helping!
Joel
Ed Willink wrote:
> Hi Joel
>> Why is that?
>>> It is much easier
>> in mind. However, I'd have to create a nested environment for each
>> well for me so far.
> Regards
> Ed Willink
Re: def expression? [message #481397 is a reply to message #481244] Thu, 20 August 2009 15:12 Go to previous messageGo to next message
Hi Joel
The following snippets all come from org.eclipse.qvt.declarative.parser
or org.eclipse.qvt.declarative.parser.qvtrelation with added C++-style
class names for clarity.
* Overridden to provided a nested scope for nested variables.
protected OCLExpression<EClassifier> AbstractQVTAnalyzer::letExp(
LetExpCS letExpCS,
Environment<EPackage, EClassifier, EOperation,
EStructuralFeature, EEnumLiteral, EParameter, EObject,
CallOperationAction, SendSignalAction, Constraint, EClass,
EObject> env) {
return super.letExp(letExpCS,
createdNestedEnvironment(letExpCS, env));
protected IQVTrNodeEnvironment
AbstractQVTrAnalyzer::createdNestedEnvironment(CSTNode cstNode,
EObject> env) {
return new
QVTrNestedEnvironment((IQVTrNodeEnvironment)env,
cstNode);
public class QVTrNestedEnvironment extends
QVTrEnvironment<IQVTrNodeEnvironment, EModelElement, CSTNode>
public QVTrNestedEnvironment(IQVTrNodeEnvironment env, CSTNode cstNode) {
super(env, null, cstNode);
the construction just propagates down through 7 level of inheritance to
an EcoreEnvironment.
The initial letExp override for AbstractOCLAnalyzer::letExp just ensures
that the let body has a nested environment, which is instantly forgotten
about when proceeding past the let.
Ed Willink
> Ed,
> that they were easy to use ;), but unfortunately I can't find code
> during the matching process, I need a scope that constantly reflects the
> variable per named node that is currently bound.
> that will possibly be added again. So, you suggest to do this with
> understood that...) and how to I go back to an outer environment when I
> backtrack?
> Thanks for helping!
> Joel
> Ed Willink wrote:
>> Hi Joel
>>> Why is that?
>> Environment.
>>>> It is much easier
>>> well for me so far.
>> Regards
>> Ed Willink
Re: def expression? [message #481476 is a reply to message #481397] Fri, 21 August 2009 04:07 Go to previous messageGo to next message
Hi Ed,
I'm afraid that that doesn't help me yet...
Again: I want to be able to evaluate constraints in an environment/evaluationEnvironment where I can specifically define
the available variables and their bindings.
What I extract from the code snippets is that you create a nested environment by using the appropriate constructor of
the ECoreEnvironment that takes the parent environment as parameter--okay.
My question is, however:
1. How do I make sure that this nested environment is used when I call
ocl.evaluate(context, expression)
the next time.
2. And, how can I control to again evaluate an expression with an outer environment?
3. And, probably I have to create nested evaluationEnvironments also. How do I deal with those?
Is it maybe easier to just dispose the old OCL and create new one and initialize it with the variables+bindings every
time I evaluate a constraint?--That doesn't seem to be the way to use OCL though...
Thanks for helping
Joel
Ed Willink wrote:
> Hi Joel
> @Override
> LetExpCS letExpCS,
> EObject> env) {
> @Override
> EObject> env) {
> return new
> cstNode);
> cstNode) {
> Regards
> Ed Willink
>> Ed,
>> promised that they were easy to use ;), but unfortunately I can't find
>> need to go.
>> bound variable per named node that is currently bound.
>> environment/scope that will possibly be added again. So, you suggest
>> environment (I think I understood that...) and how to I go back to an
>> Thanks for helping!
>> Joel
>> Ed Willink wrote:
>>> Hi Joel
>>>> Why is that?
>>> Environment.
>>>>> It is much easier
>>> to match your adds with removes.
>>>> it in mind. However, I'd have to create a nested environment for
>>> Regards
>>> Ed Willink
Re: def expression? [message #481485 is a reply to message #481476] Fri, 21 August 2009 04:28 Go to previous messageGo to next message
Hi Joel
Nested environments are appropriate for nested parsing and possibly
evaluation of a complex expression. My recommendations were for parsing.
It seems that you have some bigger application that provides context
across OCL evaluations.
You have described a push-model whereby the application continually
pushes its context to OCL.
You might find it worthwhile to create a derived EcoreEnvironment
that reimplements at least lookupLocal so that you can reuse the
environment and just pull your application resolutions when you want them.
Ed Willink
> Hi Ed,
> environment/evaluationEnvironment where I can specifically define the
> environment by using the appropriate constructor of the ECoreEnvironment
> the next time.
> environment?
> initialize it with the variables+bindings every time I evaluate a
> Thanks for helping
> Joel
> Ed Willink wrote:
>> Hi Joel
>> org.eclipse.qvt.declarative.parser or
>> @Override
>> LetExpCS letExpCS,
>> EObject> env) {
>> @Override
>> EObject> env) {
>> return new
>> cstNode);
>> cstNode) {
>> to an EcoreEnvironment.
>> ensures that the let body has a nested environment, which is instantly
>> forgotten about when proceeding past the let.
>> Regards
>> Ed Willink
>>> Ed,
>>> I need to go.
>>> Thanks for helping!
>>> Joel
>>> Ed Willink wrote:
>>>> Hi Joel
>>>>>> removing variables from environments I get very uncomfortable.
>>>>> Why is that?
>>>> Environment.
>>>>>> It is much easier
>>>>>> the
>>>> Regards
>>>> Ed Willink
Re: def expression? [message #481499 is a reply to message #481485] Fri, 21 August 2009 06:01 Go to previous message
I'll have a look at that,
thanks
Joel
Ed Willink wrote:
> Hi Joel
> Regards
> Ed Willink
Previous Topic:Problem with Link Constraint (OCL)
Next Topic:changing context of existing query
Current Time: Thu May 23 12:53:51 EDT 2013
Powered by FUDForum. Page generated in 0.02504 seconds
