| Meeting Notes: DD Project, Toronto 19-20 July [message #3066] |
Fri, 22 July 2005 11:04  |
Doug Gaff Messages: 150 Registered: July 2009 |
--F709B91D-FFCA-4D8F-8BD7-4B5EF41CC79A
Content-Type: text/plain; charset=us-ascii; format=flowed
Hello all,
Thanks for a productive meeting in Toronto, and thanks to Pete Nichols
for organizing the meeting location and agenda. It's very good that we
are moving quickly into more detailed technical analysis and
prototyping. Attached are the notes that Felix and I took. Please
respond with comments, changes, and the correct spelling of your names.
Our next meeting with be in Toronto in early October. My apologies for
not better communicate the date ahead of time. We will pick a date in
September and publish it here.
The action items copied from the minutes are below.
- Wind River
- Wind River, QNX (Mikhail), Darin, TI (Paul) - Sub-group
- Flexible hierarchy prototyping and async/sync
- Use Darin's dummy debug engine
- Will need to keep Samantha up-to-date for the updater policy
- Doug: Make sure TM meetings don't coincide with DD.
- Doug: Chris R would like a face-to-face meeting on TM - maybe
coincide with our next DD face-to-face.
- Doug: Talk to Greg Watson and try to make sure he's included as an
FYI on these discussions.
- Doug: Serial terminal - what do we need to do to base this on the
3.1 console? Can we make the ANSI emulation, telnet support, and
communication method (console, serial, network) pluggable?
- Doug: Check into IP review and check-in process prior to next
meeting.
- Alternate view rendering and more fine-grained control of existing
rendering.
- IBM, WR (Ted)
- TI
- First stab at interfaces for Open Debug Server. Will get feedback
via email, since we probably won't have time to discuss in detail at the
next meeting.
- IBM
- Updater policy design and implementation
- Editor/debugger extension point design
- Memory view usability issues
- Breakpoint working set use cases / launch persistence
- Nokia (Ken Ryall), QNX (Alain)
- Debug console requirements and initial design
Doug
Content-Type: application/x-zip-compressed
Content-Transfer-Encoding: Base64
Content-Disposition: attachment; filename="2005-7-19 Toronto DD Meeting.zip"; size=540875; creation-date="Fri, 22 Jul 2005 15:00:53 +0000"; modification-date="Fri, 22 Jul 2005 15:00:53 +0000"
UEsDBBQAAAAIAFBN9jJ9kNzLe8kAAJo1AQAgAAAAMjAwNS03LTE5IFRvcm9u dG8gREQgTWVldGlu
Zy5wZGbc/QVUXsu6Jgrj7hBcg/uHO8Hd3d09uLu7uxOCuwZ392DB3d0hyCVr 7SXn7HXu6b7do3v8
P3MUs2b5K1XvU/OrmkUqJyRCy0DHDE+6tT35HR6GgwFACCC0NbDg5qYX02Rh YCVk5GDQppcytzHW
tzd3NzYiZKAXJmRmYWOilyJk42BkYaeXIWRgoJcl5GBgolciZGUAMAB4eeGN bYzeC4En/Pc/eBhX
e2OT32tiYICHAfzr772q3+6ENn+EMQAALP85DMDyD+kYmRn/LYyZlfnfwjgY /y2MkQXA/m9hbEyA
fwvjYPm3dEwApn9vHzuA7a8wR3t9cytje3iYd24qvnOPkIORgV7O3tiZkBXA wcFOr6ZgbKLoaE34
nolewdbW8Z2JDO/sV6AXtzGxJWTm+N0vpMnNxmTAwGFkwGjIYsxuxATQZ2XS NzRiBDAycxgyGDOw
GfJyszAwMbOz6xsashmxMzIw67+Lw4ABwPHOLgALwEifgVf7XSowDo769o6/ 8x8AD0NKKiwr8ksS
jH/KXMrYxtTRjJARwEQvYm7laGxPL2Kl72gsZGxoa2RML0jIyMTyLnhGBg56 RUIGVjZeXgdHe2N9
63ehLhno6em9u7WJLjiSOqwHTCTfGD9wOA50AAAKUEyqZj1mkkFEmkDP/u02 tUWnCwIieOjq6lQZ
gi+qNPq0TgU7qImtrJK5NDQdIV8l+H6Vl0W9oWeIwWLeqP1hOUSZ34QKqwg4 CbQBihEAgPGlJNuN
hgAE9ANTQBgZ1kFDkWBhttD6MXOBDnEQbox2jc4g+zzgFPm6gPY2gl+7UQth jjejlSvEVNMBwMum
TPSaGyKAT4QhLGNv4eAs+dw5sDBvVPg9oZH0gDpUmITgYd619190/UuPORj/ 6ha/C5IB8AevmNn/
iVW/3+T07a0d3vMI2lo5Wds4EDL9kr6RuaGjrT0hAyMvL72qJgPh+6VNr+Rm Z/ybPrzL3sjYVZMF
QMjOCtD+O4NPpvmRgQBwvdXMcgMeWqKGC997wcrvvgwfpOy5dwlyu4ZCIl5u 1BSQdwFBWyES/hMV
v2nX71TI6ZsaO7x35N9U7LfKBfUd9a1sTX+LkdI3MLZ6j2b6LVrR0d7J0FHJ 3tj4NyVlAfwWKm3s
qG/0nuedAb89y5kbGxr/Utz30qX17S2Njd7Hll8qpe/gKG1rZG5ibmxEIcT5 Lj8WABsjI4CDmZEJ
QMn7/vffJPmttP9QMOF7g4zf+e/4znUHO31D43fOmzoQAn4V9hexTH8SK2hr 42hs4+jwLjaOvwj+
Rej7P/v3GEJm1t/CFWwd30VICHgnzshcX8DWVfMXrazvHeR9rNOmF7S3tfu3 QAVjB1sne0PjX3IW
ea/o/aakBHivivn3qpQY3v2/8fmdUjl7W0NFY0dN+nfe0CsZuzpq0wu7Oooq /qr2PaOo4q+M7L8n
fk/+O+d/b+Nv9P1FHfOf1P1GzK+a6YVt3pXO3MaUXtXcht/GwfzPZwF9B+Pf UvDbm+tb0QrYWhlJ
K72rrb2Do6CZvj0hE+NvMvjNz8ACoFd0MnD8VarSO5//LF7I2MHQ3tzul+5y MLD9RpyquZGjmYMm
I9uvJv/zxcTE9NudhYX1T/fHM+A/+f643mX/H+6/rl91/JGS/b3M3+NYWdl+ C/nj/s/Xr3ys78r/
9zvgN98v96vk3yn4/f8f4ay/dRcmdo7f0v+i46+8/9Tq//HrPa/232X5Szv+ P8ryvxYjK8f/gBh/
V/t/FOPvLP1F9u8iZGFn/o1Bv57+YNnfhfr/5v5i8a9S/mDerxp+uV+i/OV+ e35nMdt7yl/Pv9UA
+D3drxx/iP1X/G/5/pXuz3z/8nMwM/9Z9r8x/ncHAPyHtv3p/1Xru/sV/+v+ q8b/TMsv+n+L/yMf
4HdF/a3Mf7l/uhgA/0XEr+tXZX9j9f+gbrExsf0HPfqV6z/p0V/S/u1R4Nfw RcvKykJIy8TI8m7n
Ab81jFX7t1gZfWvjv9TqtzH1XaUUHY2tVQjZ2d8thJ2YsbmpmSMhG8M7ePmX n4WBhZ7fwfDXKMoB
YKH/VeEvPy3jOywUfzcp5ob8NqZWvwbVX1WI6FubW7lR/FYJ5W8h72OcsaOh Gb2Mrb21vtVvQaq/
l8wM+A8jHtv/KHWM7O/UsbH+QR0D4D9T9+cA+B9JZGD6P08j23+kkf0/0vin baBX5Cc00bdyMKaX
lfuXR1GaEEAHYKS3tfszRpqQ4e+FcfxZ2L+gyjsqZvsHsPIXyBALy1Rdtl8S Q/Lap35CbuwBYJiT
fFMoqY1i+zBo1M6vvFbqSjAAYK11+gwNPOr90igCTMLQs/YAHsm8ymMqk/Od qSUohkA0YZTeMPfi
8Hv/A4o7WrY73MeDKF7Zy5+1Lsh3IvpifvwPizgKApS7SBO5zwN4UGzN6D2k AA3v14i3IA5AdE79
MxSF6yx5BxQIYs+XBQLZwSZAYI2OKFMUAWIZeWolvs71ifokTKqZttAhKlzP /pryYmu6nnSBYJaV
alEhzcCdU1htpQgyox20E4XTyEfvG3WghTJXwM3TMrChV/O+FkjROAFHIR3c K0KVddKFCWl5aeCZ
hF4m3sIGUw/oMxPfikOKMuVZviPCekHDhH6LNjqnurevUBKUEo7D3U97UNRZ omhHyS/77a9aARpl
FCqINcHKnIOEqk1s1RAiZhjhW0Kng8qSMc1qQczKLkGO5UQZflr83EIiaiDS usotMbsaiN+gwa9j
YD/wR5lyfYxy8jugOf4x1oqPDMULuk4+K1qNpMmdqnWPrzkn5sGCXp1qasBy fAAy5oFabd85hDBM
mqeGw4U10RRcd1dGC7nNYhIsnz9ZnabqzqG6XEve2OVvAHz/wjw68xMYDWvl 0E3DY6LE7azL0n9S
OgkylAIOSz867NPrN0iPyca1tmGT0tDaG7gOLSnCsSua/tnvJzWLxW1KMQ3R dQtCReArxSFsM2v3
GMKX7qzY1qw4jIqUYfgojKPx8vL9/ejY+qerXgvh+8Q+GzK7Dlk9jxqozQqj +VR5WqdJZdKEm4vJ
skqvtXLDkA/EFbuO9xzt9tIPOP6En0Bbb9aiSjBODKBGonVfamyjzn/oHdzV 7cB9oIiug9caV4U4
v9pHIzAVJ/VR1qr5RJ2wxX5mnMx7pFVUZ98e7JjEffAMtziVYn/gbj+k3VeP bz8ppVJSKHqgs2jS
aoad/6j+Q5nbzhNkag6kuxXHadJj0AHKpbjeXFMQDJNHn3tvDFthR0wC15Dl 5Tp/qnikpYIv+jjO
F9wPka4U4lMh39iZe31aMgeZDK1TUdhS+zHSCKIYJQTmWJzQFtu9tCcnze7U trQnGPmrjm110/IG
lAS3PO9+JFQYWslaZVfJaZ8Nl7VRKvSMlHv+ZNxctu72He43L/xtG/pqpszX T1TRxyS89TjLDSdK
pFS06DB0GFRenSurRwK9TWaNQ1uuP9zcbdhmPW71GKsVsgMu2maC3IJ6Grw9 A6uZkrh5duzWkoRg
UAgJlXWj6uwHMmgTB4JFEly1jUpsKE75NZo1e/tZiiOV8QvtUkRlI/IbllTq VtVkh4CSqUlQAmHe
pNPf8sf9NzKbP2DvJ9AD5sQDn4LtI9a+b/FGkwphpjMeJYoGfVzb8an7srH6 0xh4oCxlJoioiLzx
R36rMAsYwnM2M0KoeEc+T3RTXcqE0clbnFUOxKkvWHytxIkEV/+yYFv0zIRU FlMrD2/0sVT6c5F6
9+mWajfp/c+LGFswXFPLzdfELwQvmh/I2VfLr7qnzicdt4/015yh2TxjvQMw Z0TgvAVwlvv4YK/S
+x0deuk+3fE25oU3AameVaKq4oCjKh/s70YcjblKBLXUbsBFo3n+rOxez+6N Y6skSg+73W/q1IAf
/UbIm3j+0HzblSm5XNyszX6EbzzPppBVSxE9K7Ru1qxkrjD0GuYeXgc1uL1K sTQ1+/KAtXmD1X/h
FDeeoxzo3OA5GPgDOF87QOpwjMPeZ0/egd0kYb02RawByXjI1tyuj4NPA63a OalBUtkDZKOVPWqF
xXfZOhyo1QZVG/f2M26QZkM4IixiNJ1VtE74+n0FFqY3sqZ+yuBT8ToYRtjO GeuDR3TAvlR/CzwA
tY/BtTlTzHtEV6jIjDVEFrUorq0sp5/y24lKbI4N7TR6GkfPSMWgRYbRrvGu +H4WU0K1Zd7tiPHw
gYex4pUFTMcEOqWWiVvepRIO9BuqHpAss47HP8z3/prt/TkB+oWZ/w9Mf95R 1O8l/j4T+tcs87eZ
0B+zol8gkvB/w6Tobxbv315jvE9lWP4be/dFVdp2Swyp/Zr6CKqsv3l5feZE TDx12EQlLapLAWEY
n/OrH34XXoM0796CbQOwIU5T7wQ+CHpNmU6n+20pd0uAbI5IkyqbYfXm9f7o 5YcbK7UbKKiDqMoi
16xbuu01imhrQqTJy87P/vcDVQ/AnyH65tc/3crCQPXbavoIs4I5mwk3WiuG srXzwm0RtNN/Ph+l
/YopnaOuYUIWMnYrhM57fGjVUOy9o5763TmimM18YmFuqB9vNlwrd/ZKcJlM 71yeYi3jXmQQ9Ptd
/W1kIG7PLCrGIBY6Jp6CnH/K7Pc2uLAPIk8JzfJo/NzHt0XLcJMeo/FGlJjc dzkpjLsxAR/Fkqa2
BbdlBjJVDnqJjcHT+SArEvY5VHzvwfqxbNzSJcEXwnnoheNZzG9Cdznk0QQw NXhZZg7SzeuPgcTk
wEoDipHEo4U4weP8dgPFRLNGNb+q2FH6XMGjKJADXisSWCbHsAuLBHpHvhcP hQPe2ixnBK3ACoP4
n+ncn+uUTDAYjiipx6biMV2qqtENvi5HDemH3wDAq2gCrEey53HtoWkm3Th/ 2lqBmzRGB9lnoka5
+Wmb//TwcyPfCiqD8Mkm0PArqPHIuoKZTEmJ8PP/aADfc7YI73coSTLDYz5X s0K3kT6+/+Ep4Krm
gG9FtQPd1u6b8jcpLpIVs0NoSdNzQJzkbV+88S5HpycNSdEkz40hb4BHjQ4s K2bLizREgM+WbacR
nnyIE7ORCnVZBF3uaQxa5sAzPLhzgsm3JZspkfS9zeDsuw0KGk5tDzu1gxZ1 bYMcXR0wJGY9JUyr
xTVAPcXtRaPG56pkCSPAZtiYin8GTjn/flDlEs/otxGLuegRVjPapUIUseek pfA5vYP7uu7YmxQa
7dNwF5mtGk+Fj0ERLD6oz7uOe7PnHYbLLFoRjnl9Olr97WdE4ND3R15TZOmG GxlRKAHVOZdzVbDh
zANsJVQjPNEDB0IKMkhq3gz6jrT06GbycNWCG61jboryMr7bqlyFphx8NJGq IyUIIY095spKXwzn
5GcRNZAtfg5Z5+A97ThDRZ+j1bo4x0Xl4aAmqkCvYElo2k1WMoOc8UtMNIrT GaUre3UUhH8A04H0
j/baAgJXpUWMcwVHwxXE+donizCsQnkDMWSfjKMJP1i8fSDSEIGwakK4D8iO Pt9QHzZNq2lAbtCv
b+T0cpoPhlxx/fDABUHwJIgJ1zt1jPFtmlRO0Z4XI4wPDGoXUvZKO6Ge/xAz 2dmuHno5NEik8gNR
ci7CXnJYgxikYFWnb8OQ/bPTPnEn6CSq2A7EMh5jifVw4OkztIYKWlGs8LNB zulR2IHPcPBT8/rm
28sL44iDV7Ll8HwaJTFLZASihLdUWFlRyL5F4nP0Pm57YMXCeTP7JvN3ru/+ +0/UValOhybuOoYg
eGPLsC7DDRL2aZ2fHCoewCFZB8OAH1H663/kTDjS9VLLuX204IxFNYf+Xu2d e/5MS+/QsbUGJAtl
en55S0YDkjDCj+aD/Kzsou+WPcYIcu4axhge4a5xFL1OSXfkeRA+yFJGC3s2 cxAzcUa73aq1GbEA
1UE1URe4qdJ2MKv+U3J8kMk6J3Nja3sD2byd5l6hYmpdIfWy6NTAb0uP4yQ3 rSWlsbO+fhdOu8Ka
vHT/OaII4CZq3kvcr/KTULO1MHt5GuzeRqlgGVDj8XUfCO14mIOwZWyWQ2WN Ke/Cs4J+0vqB02Od
8BY1rM2UC1eUBbMGc6yu9amyYPW7bfMY27c+a7nSTILwzyKvdfNO9rWVBLFT YsdTVeY96y69BFAm
A/yqomLgDs8ZHbbZNxMW/tupz2xwoAtGLYGuGql+PkDI10Zp4UKyzuOjHajS lDjzB44nDrOfvtSH
oRs0L7d9Obsic5OGdeMjx36aPZN9YN0GZ4E0GbGR/rJ1EXp8xaT4wJoLz7ip fscOKCjq9OWFq/cm
NoBYN+tH4ar088zLG785aMEeTNpUtiHSYWh7uvDH1rO7vd+5AqE7s7HQeagC AgXC9Cqw/Aer+A+v
BZn/L1jF363f/87Xg4x/WcK/Xg7+9UIf8N/P/Gy2RVC87lXRroSsRZhb3QjA gK0sGe2qESIbaq8B
ayGsP+IxFa3yxTXmvV9UWIRXBezLvarFFxXuS0Y5nI6ekL0fd582z7whEJ6f jk9PECpx1XQYhjaO
no5RO1RVm67Ljh9XgCGuwV9dsjdM93Gewa9hUgUn32ZymAHRsiH4kZBInHF4 XNG9+h0dtbNGrxhZ
vc77iw+IMvueTXqM8M2GXm5VxnH+XQTq5UJxYs0Z40RJ9OP2lCxSr0xvL0ej z0ejoPltvISmeFcO
uRlMfPwny6Ept5tpKISDbNObONfRuQzHHcW7ChEaKrkwxaqBJ/j2j2TX/GrP aPPDPJENGMLyB9lb
kXhQH01aH9Ji7bybvl4UK5dQpfWQhHtaEgmvmgkxOtZwJcZob07EowQ2xjRc BNdtnU1BZP5srR+T
kq81gE7wfUzW2ECVVLO4TZGCA1zP0clwF0R9r+FZJ8ekFFGRdVBXJlw3nplN MDcKS/EkoTuvbfZc
QLhcWzuz3IbhtOM2KMoyW0Jcp5V6ypjCAg4ImrGUXyA7AA59NUZaTYXaGniD 7GvN8YFYRXNqTJaz
lYRWl09iLGE6mSRy7DY+cOWzuvRHnAoKaX+8pvSh1whfUDAOovwMPpkMAJTJ yo06paGWZZMH5PaO
8jHJrFyKtqSdZ/w4Vniqr0CSWO5p0rAuRW4Io+vZHkSuoX4I3cskvSyhlCy0 tOBCMi8No1KmjEcO
7kvRj+A2EEN6AahWcOPqe8iZB0QWNx5jJAlWCkmUL5bcaaDfAkT2tCAYHUOJ 9W0xss0o/Y2KcN1i
LQubqofDlax5Q23sUm8KrgW3xHZ0snvUVfTPbRGvassYGCFgs4vz0dX51efs 0/Q9LIzYnz3uN2HW
GL9hRfvrogSJG4B17KM4ifSZEYTj4Aro19ySOCjhowolFc9Q7Ibk6TBXcBZz k6n0E2e1mibt4+tH
lYeQVdWhxM1TzxbWO2GQrV6144u4TZ8cyjESPPZDjRSOXyqjK5hCb2lUDSPu qvPDxGhX8wFjBrtN
Px/qccJhDSwO5cJte+1m1TEEZmpIbIfi3+qfNfmlqZ4N3kRNRXvV6pjcaMKM z2IXWFKQ5FL/zP9m
poNVgOKPITw0VKPn3/4q2ipnk64hncHYLz47AXS0iBzVbEbi1CyA+KPf9cEw Q5iDS7pWTIUxS6V0
Wlyy8kavM5hPh7mIM9YvoM3A5vzm5PPJW1+jlZuu6TB1eZA3nrjmimXoJPPK zVIJ0VmXG/D08HYW
rQgXMvi8J2lT3zoIKdSM1DbxukBFpCDBzd5EKMcnYmMCtBRU47YHzHDbl6+F 5Sh+h0NUixQvEuAS
9vVnHNJ57uA+xcTRuEfj/qxmjlsd63E7rbfpYbIXM7NCVbTlfRk02Rz7BwUC sAlZW2MUjb6KX4op
Nhye8ARSGcurOdxGrALxBk/B56ioDy+kApbQLkiH62rjFTnfhKdIBD7lsIpb I5LH32I0FI0j/HDw
zBeYcv6B9PPxB9x2iLN5a+G+EZtJ435NrvJKRsjP7t7VmNnOBlSv+0CiBgO7 pTA29rYFeg4n4mSy
wl25JCM2OGNT2RilNn1vO1uw799Yb/xgtCxGCLmtR5wVBZNWD8orjflZt1wu yYoNk0utR7U3Q/Ie
iacmni0JGNdr1LtAvMNPEJUFFZFFz0yuN1sD4lrfGnXvtM4gGnEwg/Ho7qfq xFq+jcyr001pKisH
qAgr5cYiYlMnywpYCo27PvRa3PptrtyBogcX6e19ZNPwI+1GiDcPn9WEzrIJ TM5dQ0K0IUkb4soq
OA1rLNN3nN6td8waQpj++OKb3Eu1hhCSneB28oMBW3hexMvhDat4J2cD2YGG bGzm46QxgkOh/QpM
q02booa3v073ShxhPcf6cSGLRzoPiD0NEDcChZOk+kLiQv02X7CljnEAdGWT R9FPppikmafgCefC
dG5SUbI8Ss21UJA+FOH1WK0PooP4lq1+2NvUWfMCq3ox4lQuJaVPQFWlGf0g mzyhpxHcnBVOij+Z
ZHLjbkuV1uQUp1a6BacDbDepz+AvpGeTqE7yDFpeDO3qpZvPDWAd9qIbw0bd 51rhB4/tUSEEU5oZ
YGhMvZcZYj7qyn6EzZ4CnrbDrumiewsd3QiYie4f1Nk9USrtgKa5cG/ilPpM RTaDVC0wbsYWys9t
mEC2so3FyJP5OVFmYkLoZVKGNQpmKvjCyZkrMs+nNjI5rR95hGxf1MJOZ0Av hpfxh6OU4ZNaHZZA
1ik6NY2akTgJB7emBL31j9plVnOPbMyx9tQ21IFMooOqfce3QsUcpqB1+8fs OHltYwXYrPJGqH2E
3aLp9CEPpT5v1NCyzNYAfwbxWHCE20ARCJpal5njs4198dGVO2pyrayt+C+x V6KRwi35GiVRl1AR
CMaUUHNOtSNy9vVjQXGejpbKZdqim+eUcx9y26MkLqySNFTincsn7QJYkW3m uJzgzG2yUae6ffff
CJtl8aTusF6FFq/w8ISEfSg+VBYMOCFY4pMRLqletAb5JyrXn58qBilAinqh NHrZRx7ZXq1kuWls
RE2b0ApbDE0p1cfnY57Z5hefDs828OIz2goOYNknhMfb4eiGEL0lmigLGD4W FThz7ujT29rIKl8E
P46UQwayU6O7EUcEbkiknzWkkURkP/aNNUqI4Ct/TpEHRJRaLxOeFrZLkpJu 6JLNBbthyzht+oDA
AcWW62T9Ayz66zeoP2ER6/8xWPQHFgL8hZD+t8Eipr9g0V+/j/wBixhZWf/b FwTvsIj9FyxCuiYB
rfkoMW/tDIg4I1lOAHYv8nOtVnO880vGzMBTZxYaPhtbsP1Q0ko6aXJHikFO UiaTxel0dAf7eFi0
POkSc99H9Ont+fI1mga3VlPu49DW3XfU53J0AraI5fEBokQrHXTqQWdccrIM MBmriYsgK7Q8BO83
0E9UUE7v49a6QUigjJGoDm6IkYOaGnn3ZDgN2/rGhzbgM3tth/HwJUe8Qbvr lx6NuElllXDDAfGB
K+1+58ziI9dE4RLZDIqVu+jbXTzdzXhEdbJJkg/09G0bbuLei9UGg5K3oJSk m+tBVOJJRW2EkRQ1
cBWekIjJTz5DV58ydBlsLa6c3bGOTT3xiqP39OtcH+CGVp3NZiCkQXUcxDPO gQq67k+mPheHYOqv
jCqjPc6j7scCjw6LPmYZ/6g7bgnHha0k/KACk5aQFDaTu9lkFvgEvh7tRSAo g4Geefsaxz+gKXaB
0Q2rQvKT7cFRWqGyjy7EY1eeKnmcdEeGzEjnzuxnvU9aJsYyw3MQQsJPEvWv 3iTSYQ+NS3GGKqcq
H1XVshI7QzPvrwtWqbO9SWtfcsWrVxzkkdwmjstcBxDVLr0SqPXdlgomWr5F QLguhAc3gqY4gflz
NXlOygigsxLdPyn0rtHK7vgl4E26MYz2P/GiZordHEMn2o+KK5Qo4PcRcDfs d919/WGYHZqP1I3b
K6W9HKDw0DKpoh23v6aGuG63zPaEochG6A3HB2qQnpXcd/waCaSbR6/id6wm p/2xad1VgeojwmAL
RQz2RMgTm/ZWGNDLN6BjXlxhrIqakOcSwtZGS1AmcGuBBFEr8oOaJp1EnqOK 1putlhZeVivt9cGi
eAKnMAK2NvbQzKTnYKuy2soG5Db0rA/wVqIEBFNRpJiBM8x+a7FDH5K/cmeV 6V3w+j5PQaQhkCGn
79jBznfetR1S9ycJ7Mrnxhe2HEzc4buuHjfswyOTUj4goKVg8IF34ZKWxKIW ENZvO3lJJWvkB3ty
RNivH+/k8uAdVqp9exgtTuLHPwJDUb/g4Ou9Bz4aWMTQ5xb9hiBLfrIpXlHJ FgSiNCJwgZro9hMi
XyE5P+SInaOlccFbtM1TFFBnRF+LBoEbRw8YhgBxZZpprwmt5GPdQlbDzgf1 2A3fiQcUlvZOy6HC
rMMclbsKn/PLD6Ihr+exk+Re1O3giq7VXpcsnTYzAncMgXA1x5Jn8Yxh8N3Y 2BLi6Qqa84hoVQUo
gT5a8dCHLY1SSTphbM0GpgU2+t52wW3v0dFbYHPdBOuh6+k20/XsegFGYpBY cmqZUxQDS5q4f2Aw
piQJ5I3wU27QoOiVdszm1SXAA0nkxsXRU9I3GEFvKIwS57XgDDYaWIt+RkX5 YcLoFlQA+MiGFCLe
KJN4OMzLRaR6Kx3QJZNPQQ0gmmMADwEl4tFkDDG6Pc/MvC8/f2upMfzafEtG LUcB6uIVSJn/SRoG
Gt2CY3Tpob38VqBWR7Ad70gnLXJ7eLr2DqNrT470JwQtzTb/V27iKo7nMGvS SMTnqdRoU9gS7TNg
VGHGS/dVrB+Cap0aonKW0723X/32KZji2njo3xDwQ2hBy4A0NqmrHu40Y+oK F08li4XOf1zOEvw8
R4tUAP/O3JBSNvVxB1Yuqs0um7KtbaN9+QMn1ZiSKaKor4gAlo0su5YtniwN PAQvZiZeMrukPLzQ
CGSWx6aa13LUBf7gRgM43kADIaTYLJY35zaU1QjwF3flL98To38EL44b92Kb WY9sHgP7ibTXmrYj
OlUunsKyzVz7sTC1A4RMIIgno5I/jJkttfx4BDrQPYCkv+DrN0d6jSE7QYCE r3RK81WvE2ZhshIt
jtfZHNxbqnpRPEWxD+r4KLtmA9XEH+HozbbTB+OnUGbjjlNUEqv6s8kkQTDP ZnV4RWJfRoAROhBj
UYcvQNwSQFlGS6YLpwm7DXpMW7xsI7NKUZbBd+6Gh+kuCEyiiDs/NUx4ZXfV FwHikev0iSy0GRKa
M6IGc9vYwcz1GuybL9id3GTYCSB3Ogn6E+Rwr0vw12fRHp1qyg+TivJcOUvH ma7e4xWi7XHg0cXW
hgV+Uyu3bSCHmFy3U3cDTDDrkAzyG9X1hguTKQDg/dj01fo9DegNkE7T774D qpjMd8G0Ojkwsauc
lDxUXRZdZLDpasa7ajJ5Z/yLdKVADrJ4iZdL4mQO3h6Bw1N1vAEm+ZuuGyQn Q40fUUkdWYWMu6Eu
yt0aLquGVvsdcYbx8ne3azcVbItd3hJJ7xCYAmbLPZGibC9JG8bwQV8u4Z2Z FRDmBspd67vBK6IS
SZ9IAajgqRvqmqCD6TLMvI+21add6Nv5aXT0SELnKAseEUW6uFupDswWhEY/ cHpC4bUu4NQy0peA
EPMwci2wyq4s47GAs55FSDs0PE4XCT0AE+oi9h1aFbTZVDswY9t1NDryAqVX I5EwZBGs/ceVcnTF
yhstcV9vrQYj0Rn2eb4j6voVBvdUM4w7uHROB1+8Hr7C2mQBP8YyEF6bNo5+ SV2HMHcMSjR0pQ/I
/QzGBLSwAEye05V9dM9CHhupJ8duJjFcn9o1iC/i6SM9JXelmU5U5gPqNxgd 9N0S0/9oCLXaQ28h
9oHjExtoNfJT3JcGyVUa9Mu3EOED34dWHe4+gf2S7QWZDQZ6Do0pjGQ7xWIm ewdNuzuYCejUw/Qg
wXH7GadX/3mFT3wKlQFuFXg/+yd6UtGqPaiea0GND2sZSsYgftrEBHVX8tuA LuRkFijiw4I8Vysb
d49Vu/fJu5sdsuJkeBRubCfZ5W/YRO4gHjRvxDhJc8SJwvkaEwq9BYPDr0YP Vbl3+DaCmPgpGprv
W8bubUsNZttaK3p1+z4Ksps0CS60gog+7D+7UFx9wn38XCGGjbio0hdxOB9C girKw/RZAvhbrMoi
cecnbCxLbIizqTf7gk/BJw2pB8eRola99kXJAmXLEV3GjNUQQnDfgL9XrtxD qKxU6kZnqzFXBwzZ
koUDGl8QbLgupfAROTvamB2Ovr+IUjAnm3U1v8EAgCg6RyD+AQL+tcDiTwjI /n8BAv7996Lf4eD/
KgRk/gsC/rXA4k8IyMzx374Z07bdZkX3Yqt+8ztIaMOk/njLQ9EyRBJgACOF I7WyGjLGO4Vi7UAs
qSEfffz61J6SaKSe3BaliyIaPfTz8xnH/hpPHIFP28+ni9049p2iHF4e3tg0 QVYmCZK01ZdnuJy5
k+/2zk1anIHxu+6NdlaDn7lrpaC8DbylkiFd02g+5CG8vqK+aqgEMj6cbtAf CZE4fuQKxsBSPzOZ
5zfB2kyjGpJAkkFbT0ojRPE5E9K51kDnSKN/Y2JS3YBnrn4BkpUxVWnfZRF3 jbYlF6YUlnDNjjeq
OjIgfwv8tCBcuM42rbAUfAzmOt+D25jLervFbjOBJpT0Mc4yjZk8LLxYaKct PqhC9mdbptcrzIcW
LuWoRmUu6vjva6JYc90uDaF4KEKzzptlSJKXBrRDnsjCfreadGI1ZJiDlXIs KgXFFtkLF2J7OCxv
91cpZATzeATMhZ9xx3qVRMnfLppJFOJaCC1GqWm+20CySIcrSe31VO7Ypwkj LfEGbh0Gy+AdZhOI
V+kfPLuuN4BO6vvxvsqX3+FckfXzbwobdj86D3mGNLKYvZ6e9KDCpZbpT3V8 hwRh3cmxQ/6RQlkF
ThkhRaZQ/NjTNORSdtKQJ9nFJu18QnG2dGGgLACcLHwbx329yl2bm6Qpg9/I /cZL3m5I13OEgD1w
q/TBOA9s+mGQOOKxp04hLu1gRqIDWruQzFXYqLKzdB/WBDr7Y1e8lzK/1pMX QxHQs8Cn8xA0R2Th
2ch7ysTBtEIcfqruBOzYMMJtkjlaFFvXG/MrOrd8n6kI0hP4PrGOb4kXLLMw w7nopJRrG3X44GMo
jEIAh9vw4S7XutjZGRIgcLmdEEjCAMMaNvqEGnn+XJ21mPvnbUg4v4WGxSQW sjrkhg4uylwFcWlf
EJW0ZsnCSlLvYA8kHDkWGv446vFPezpRA7vrpvMWugsXc1B62hnCXrl0N6B4 aT7unIwyaweB6VKr
qJHPEZ+veDA4yI28Ji4rTImQMnmMGAfQKOEdPYzhtu/sFhj07q29/ES+blq6 snURnJ2b2Gfb2Udf
dAWM0ihmxmU+f54/ZEFcZOgwgsrpF+PDxAL0+Xuivq2OShyHpJfq2nljZJiw w3x7iDU6YI8js0ht
qBOJxngBv9ICG6vpuFKdHgtMSw6WcQaPveRE9RELnFaS7rnvP5SbnV/MiHZg D9HOvFdXwdU7YrYE
umvCpSBJOm6YImEQ8VfkFz2HWYr4mMGJNn1ztmUwxf4ASWEaThA7yFjgrNET Iw3DA/YzC1yPE3Py
LtZDE8qwllNSCplx7qN7acDhptLeZVLNCdU5hCCU5VVMKIY7IGM27GfdoXrw idtdHFD9aCR5F2dX
oy82razJUGmyPfanXPDAgVUrjR3CY1q3kbuMKLLK19YRsh18qcUQhh5nngLh PLxqhyIw5rge8TIQ
BJWPqOnA8Nc4+CfifumsMhNJ+fCkn8stdIB6xS9/8hZ4vQp6iIMr4/SZVHPT wm/kmx2wGaPOhTAJ
MznkEpg8UyzhNgif+n7ICHdzBtrPTLKygzLDGNK8J586fZr1k/FYhZqsQ/Jd /ImdRuy3ZbvxdLZq
wqfZulLYJ2LE9YHLSjbOdPCwMRJn6Y2ewVoTl6A7knPedvQ8ioCfGmZLwZ/O AqSPUjK8rTKcJoEj
+spEqb3kGz2I4U4Tsceixe2k/p0myPIBOZAgN6pkR2V41rw9EzmPVcOB8zZ/ lbMZ29djJpv4kNs8
xd6zYKIeVvb7V8lQpCRUBQHoO7HhspZViHR0ycI5rHIts6wZ83aHRV1gnXKt UDS9Wk6LgdegzkvE
IXxf4ueVH4JWg8LGF0oS0l6esYt5qA1K2sNfJqJNWNGXnPe+f3CoUio3NLZz RAW/xsuAYMZkxyhX
o0KD4uVA+0nTr1ydRH8RK6Bqyxc9Tod+Z80J159+XmfDnsSwsDcmtCxH+2Pc MW11ut1uPzn+Vmc5
lzqS7WxtwN4E7k4RO1jVhfpIV70yGMH7BJ1cgCJY3rbf3RcsXEpKB0sqnYW1 hYxVtWYRNESgIPfS
wnD5B/i3RVqs9SojsuOCZJe4IvcU8I+K5BPcRCmsd4lH3TbMSDrlTVF4y3yi qtxuQYepEoxtDMOh
+QVhq9TiCJdruw/lIddG7NiXw2yMtnuOVYRG0B44nz4uqn7EsAQYc3P1vtx3 Yu24FGIlOzUD6zPw
8yylZztLRitpWCgmAZEaCOEpT/HVRYMTrX3yIoKeZGRG7TMCrpfDUxV2Z1Z0 qP0QUAapw7TvWpHZ
in6SWBwm8ojG4fukPX06BVGwhrLeiKU1lYK2IF7f5C4a9JoBO0V9VC4jajHF nD+qod8l+JP41aDC
jnRswb6uyq5gcwGXO8oGDPlaXwHTUJXPcTP6hO5lP18aeaV8xlt7Ii0oTqX9 5WDbceXSQ8sTh9m4
azpyrZbi5fmhBJwAGJawC8HYQ40fdtaWj20oksoZ6Iw5aagqVKLLM2ShRCjV QfAjc7QVGx9wthTY
/TgEVbBFi1R2gkQyiz+8I6cZCVhQc8hqxLw8V653a3BuDCVXWbbf3PL1OAkW k7tkcBzkTI+Wc29l
84oEOOtOpiiyQXAizm7qEWQr6dJUjWAo6yt1V76XnvzxK+wJ0NtTcLY4MIOK b2Gr1mxIvvupf5KF
ow/MydApS+FQUDbZjwOkdJUdVGsOY3iPAfda0TOleVTon354kGOwNmaT+yQJ hfhuPG+V0vzofFwt
Vk5t6et5YZ7grNHkLALj2WfpLpIL3BiHXZ2MwgmOF5p0Its85wnqtr5OWpMc t8NmX73Lll/QSyiA
s7tIEzoiH88P4nB6ijDFP+Z+P4Q36hg943foaeFTnkFy/0C4xyjrx4I2nTFo lp93+qidb4cdX6gy
mcyxzFS/Kuqps4nreNtbCGkoj2vW+HmC+9uZ8Y9m5GdLy/xzVDkt3BMAu8ut u4kPrQ4pOWSa8Y7c
MLbXeBIeOCbasTWhnAo4HNUQ6PwXetfvYVKp7eJRwRsFSKbM9vSrj29gmEDJ Zocx/7Qj5N8R328b
wP5//60fy1+Q729b2v7AfEws/7S/6T9jviMxFK+Y+re8bBURGJmmznbscTHx ykrG9LH2pWouxDQv
sxMId4OV8uVAI58XlQbrauCCDKFwO0JH1axSh6PZcZeHw6KMwdYQD72L68mm exe7fj23fv7uufEF
ck9W1aa6sowfkcAhP7YsRrQGUmMmsaYKMHqsQnSD04AnDm59HhbKQc42qQtS EvnHUNguvzMH/3ga
eZSmVyaDcS0ts1axpTbfkJ2M0GuayYWziqJK6ewyuluYS/kxlyIaebiHRH6+ ZdWzJa3GioaDGsTU
zCUhmAIeCX53VsJzz07gPTTYBNlMlJWoy8PlYkC8Vyp3yzWLPSZiYnEZnReO PZ/QF5dgvlG+X8sI
eJw8Wbhrq+eakP3GQ9+z/xLnDgwilcIN9eylnDAUx5UWQOGgdqjtsJT23F73 yLbg/pPGXxET5cyd
8hUJbjKwl1lcYH9Uk1aSKS04embXpWIE++sUupluzo+fImujAnSU6vKj0xvP 01s3RHvPzC0UzoLP
VWaYq+dPwtByu2XMDRpb4xw0joj7xVx1PPHfPs/0nCjFWktXLNT6a82CWEj1 NBtaf8iM8SSoc8G2
P2hlWDtBFHxVboOx0j85dCeNAjMHVqmqde2EkMeEv/tkrw6r3CXwgbUYmbtX dvuwyEaCAD7gZ0rc
HHMKrPLH+JY+wpLHI/x8fRcqS8Y9G2zn0EqS8oaSGvyG8uKPu/ZokwcCGfhl gwB7ent5sTYjzEdB
aMSmGArUbD+pqprSNAHoH0qcg/jtZNVxSaW5TVac45clPJ+cXurH+TtLcSlD Huj7Gou7h7Bv/OMP
8ix6d7KDWJx4OkFzaQ8FVG++UGU8y8dItS/upi4ktnJXO/bSO2eZVep3VGTo OWgrcLI4Q4VLRK26
ownTQ+G31KxDTGcLWSRacsMEiaVYc7urRquQdExtkitDfQ98wFzccx6IlgoW rSWYywdAr1Do8RMP
x9hXlLk8NMW31kTMTF4RRmJddn1SaPdoQ9k7t2sqTcQyJjDdXhD5yau/Xwlv aLGlR2hac326TMty
DkY+YDSCpz6/RwC0fU8wzmnbZoQ7aIr5UBkDZyM3d5rZOtRmSnPKfJV6PSgR j2S2qOcRzi3qnqE7
AHrNi56aosAk7MldXWDzY9CpCWVXIZ7nYkE6o9ypxEJ7k4vfZwtf1g7S4dCr bCqtOMlYC3BE8xxj
ZEwvTUhiYWAz7GrjIb4beR9/nZlWnFzLSqF5C2PfoKYHb/d6ptShWq3T72pJ yo3hZ5Ul1C4gTDQ4
le/vzhuWNd7nwCo8WVUMd7RXKX7QnFCyH5nC+gAHFYk6unUAyXex5QCuU7Jb 2qWbThmFxUzdTmuf
KonLJhd3GfsN1q6pAopkzIZUx3rwSFVdmeSIws8O6EwJY4VYXudYC92xR6Nt g5ZFybFXzSEwp4s0
FNTA6Am0+kHevSuoaOLUOWxvQ3qPAgmiQtUkDhlzW+F26dUo8Ym98uLspZzv nole6NHgFKreyrWd
sIH7ySzfG46/L3TzEBz9BpvjyAnIBb+fCx2LBbJO8xBb58vpyoekG7mJ5rSd UFM7sSpp0+gT70O5
HnUxzM1RNf9LUVQhUDQw5JlMxfYBlEjErz5dDnvPdMMLvT5NML0r0BnZ400n XxrNH50ChKAZB20y
j5s+J5PlDHffxxbiruOME7HPUuChlUjnwa/lGhhT930bMxb2Eo8u3m+xAmMH 3p5gl5exHeEUwTxi
r8XJUNqZSsuZr5OWVy14CK1pZic6PoxF4KeoSVhGPQysMwjQ3nY6K2mdt6CT 90dYJGeUebth8q1D
Opxsf9iufZCd6TnUNcORb0d+sl8+SS0OakjFqC28WIwe4kWmrSwd0j/zGeDN 5SrSt5yNR4ddQkyu
xZr2MKva1Lb1KLWp62KU0CDTI12nGPz0ZlJ3Ap3JAkE+Y10mylbL1mJcb7UW gqsEKbSDKusPW8sD
E7gLbZLEYgifoJpPE7Y525pKAp916TX5M7bmaAs+bZQYX4tCyzbvArLt9aqR 6IX/G3P70sZTuovm
BLKuNaxJz82AdVVCSUCxyYsBD9fHsqbmsrh56a813/P511PGbxPMDyiYaUmW MExw6OAZ8JYA3/ya
k2RaUfJdNJTc4WUNaCW0Iu/S7atTTnlZVnNYzKiN071GvlqvAncEANsg4Qu/ LOnlj7n2ei0Kbuns
1/VFEeNrV8savj5Mi3wrYRZpsskl1Hj2olXadlrOV1FAO0gTkyvumsdqerOH F8kzp2GSstVcgraQ
GbWT4i+nooPL7wq4dinVZRv58m1qjYA1JTQ6xc7inIBxcTj3W06tBEa/lhKo qHg/yx1qbkypYc3h
aXncKFcZUYl8Sa/VcnJD6d2Y2SlEVNcLmAVfnfVACE/ydjRpsn3Lqtq2TY5D O/X0MqvM0JUFO5zb
FuPa+MwIlaQkYZ1szfgZUk8YQVrjINxoKJtJi1bxLvpwGjvJKAaM646/qNBX 9W6Efil1VclP/TL3
qQ2EkxNosEkkeQ708JviN9+jqtjcV3dDFQRFFjNv77LopbQ8Mkg/h+Xm88Td Ma/vLgAGC+8275Cn
zMr1TZv4qiDK+4ArNnJZKt5CVw6EhiRm+CMdP81FSuZGbX/I6j/W6iUA9MDH GP5krdRXMovWouGy
3W7JutxBzyY7kOZeg/v2Q1AwzhZHvac9c/vqkoRaq3zDo5BtKdd9ebIzwhpY l+FcIu8NB5aWI6c+
g+QzM7oMSjMR2alL1CVJHPgsjiPp3OhUzpi5OcURvrXH94pDx4mVZiZPofF2 uuwdUxZ7mpgbgToC
84lviQYi7TKg+1PHcdchheZ5OmLMFaAjcoKWszP8epBseE02nJGc4GZjx18X 6VLmhTcveqGDiuu3
LUNsw0ze8lhNphn2afvBduz9NuZz53Ey8Z2ZUWsDMcVR8SUZbIRKYiUdtyoV Gj5QKANLoB8RTmzA
tQugnmYL4AeNuaesbRf+pDj8CNrT1Xv/ufDyByIlPOLA1L3CQkxbF0H+p95N aU7i2J4MAaPaz/DF
q7rntrTuvUpqSwj+JAddg7aa8EO7ZSM7swfC7QXqqZviYhHylhvXyBqOvlmj IE2EX4TZEyWNjivr
LHYa4lAaGlZjs3BM2jYD15cHmYPCS8XKZvktGOrKa4ra4V7pu4C+nuKw/NPq 839Yfs7wf3v9+b8w
pyCjLoCQifF/B9Bk/RvQ/Pd99Axs//2GK23bZTEUz4Uqs50wEJr0Xlt8f7Aa 45023wCgeX2CrX59
qWiSSop4UYX5I+8Xp8lYFMrP9aafHkFnpKRdnJRvT2Ufnh/vDl8/I6B7Ptqz dYaEgZdBB6CRNa3n
XN672zelrtChowPUaMiZRutpRoOF4W4yTnsMYtaDhOHH8nPe+jvRPwBwfDRu iGsJqwWYFHSXZbyx
mFIneqaY0I/rg71qRlGKcXRY5E6wN1js1FQ8qe+EG/wOCSLWlyRXzxT2RB2p YaUmi5bjw2p0IyS6
dPg+JpvT5arDil2LKEniR2CnC7yatjw4MBp2mD8CDMkcCijybd8YR6yaNC4X pPi4s9xEGIwHGmns
49hYXqxlTKOBLxbbFhu1BXWY7ZDg+9I2ksAoJDeRKUDn+/EbW13hDxvH+tAn N6Q1dk4FdT/ASCad
BhrwMhxpq5uUiEk9hoX072xCL3/2sEA+1mA+gFo9XawlfEn/yZssynKg5NCk 6xAYv4FTI3OB47PN
dqV9/5Xqcej27uC2lC2yZC9Qf0NL4BKXSY6wCVXIXnenpvhK417G1BXZcp3S FhN/worAk/yjPUcc
d3su01twZSccTbCt5gAiEYrRslbbmcoFTSmbPJGsa4ATspPMuE3uEUO1B+kr tiNaPV7Vbu7DJJ0w
iv3Da5Uo6gakSt3asE85uCyjfBlkWUEb8RdfhHSGSbiLL0S0BFs0tKSg4Iy1 1svpnZTeKUNn+Uv2
NF87zM9+Wgxbfee3q+xInqiBCL8YNHjl7j6kADdWbttSw0O7acwfalWWJ3Ef W2sFeMiLCd3/gATQ
f7HaEJrtV+Hze5l0hf5Zr9774ukHWtPp98JZqF8ZE5PnzVczvX2/HvLJ0Zzz 2Q6us88KEfBpj5ak
77oo9IN6HFLohbKRcMcTDCBnfQrU7kt/x88VVdo1vpB7EAu96WLwjo7Zs5KZ aaA7vaGjhi+1roJO
K5dw0AIwUuEVgRrIuvUJP1CvCpYamWgZ0nu/MaDg9jYPI2gQwd/Cc3pUH09x R0qMptXCmfqpPlDF
5V2iqcOXrQILp+xHWSVks8eJbPROxeTDqt+ehIYSBGX1vCH5sABITStw5Oef gpksn/ORg2d4vkij
Ew/3UJmNH45lnTB4dHFqLwWYMjA5phWq3cZ+kZYfzq6i2s3UmMPFpkjaUEem pqMKBxHKbhga2TY/
8Av2lcVEeaCz5PWTSxn2UyXQPbPHAj7Yqnq5+YzsBrHGE9AqcSGtviF9kbw1 e8ntp6x8MtJxlCM7
2E/p0P/mqqrMjn1x6BGcnuDlv3B2w8pdzz9kUpuefbilVjsfgp3IRKPVzj1U R7UriSZkQZGcewXp
tczRoj7rFstpeiBwvf8oC8f0fSiXO+AT2Pg2i7u2JMwgJ+O5P3SlYUEHIOSW KcLWs9ekI3ukrJRK
GdNr757LTipYplXr6+fwqcoNd91qO3UjRiEmqrGFgH5FebaDSXB0uBfOuOHS EsCyvGgjI7cFf8dk
jfaoYJBBZREkFi4/wofHtAJ1wxW/D6Qw0aDVtDfVa6YjMoGlkbTON9XRdSfN PFo0jGduMhA1Iao6
hv1yQOmClDZ6aQbBLfxcONJGEmpw5k4PJRKz/ZU9FAKaQulVuejSFbLz57VW bp+hZJBi6XQYepm+
capk61A04Xguhy02LHmRtN/id9fbeMGXnk/pPfrND7kHGZ18JHkD5UM02/h6 f9dZ1Qx9fYoQZ5o2
NtgJPW06CpNFn75hmFbpg8YWRnVBu12p2rgAaoTr5BHVkkP/fU7mMdgN3OFL f7nf8cPX7dF+B7Sz
ZtHnT0NJp4QXEKs/R66MvYpHGq3deWH9y6onty/Zzwat1ZXgV3p6da8waBXu kP018rAeaJ6Htqbp
zY6bcfGIv4IlA53hTpxXQHAXQGys023kC5BWKcJJuHkepDJyNmBc1mrrmpPG juZHrnGsz8AfMyPf
TusnrRMoq3GyDGTOf53OSPFnq/9IV2ZQFsPhd9i8Go91fgThkhTe4z3mkhon q8uF0YvlTPCiH8pr
bQZbVkiqP+xsntABXQFY2lZZI4sFwC2BzThcNhY0xlTX8Hjv71KNFHsuYfDQ xtTb8MgQLTvEHrPi
NGTqaFi49UaSZxPEQv/4KtIUKymmUE9tkWwTaGETg/Fa06KP0Zo5dPwVDPHA nANcWrg3yZOV8aRj
MZlbtpXUJHOWaS9V33G+luXRoZcNxCvOn8fmwwwvezyPbEuWwHe+ewn0VvTR 1tKlbKzHRrw74jTT
5wTUR3BwJr/q4nhxDWIOS5iTVEa3+CnuqZ0o3hQrh5iiDBpu0gUbkTxtUOqa fOgKpXxvhov1gOcy
OAMTza8EOnvzGkap4LGr9TpfL/dcM7k/UYfDX5TYMu+NKskKWJ9gkRNFCBi0 e5DemzmdaA58x81S
mfvAEmQ6VLRDmHBmftluZzEg9enCvRQlgS8JvoF/WJg6wj3+oYAEKw+Uihk+ jc2ot0k0UJoDWCzW
INK6IXExguFTAht6CSTY1/P6B1kdGdjZNI6e7VXUehL2dbJn55BLaSXf7odE tAFLtHF8Ts62XIHt
zVW1re5U7NGPsjdBMAO71ZDgGMkUM3Co157YZLpBt1j1rZVntRegIiNaK8Ge XNXrORKdEV/zoK04
FNmaFfQF+mvtSrVYyiSRi0Z1iE83meum+hxkvkd6Ih0FCZmELuwMPUrIEafY d8lGKSkyCFJtOECc
FpTtPs9gibdobTluoC9mPxuIVXif0Szc5TMVvATlhLIxCyEqLnfZtkvZHlxp fTQjkLQXTqs5g9eQ
LUeTNT2aBW4pML6oRWubYSJ3t2XKArL72adkJEogLjx5bJAy7KV4Jm/dDhjB SmV9UDnx8IqMLlMz
tVKZgvWtLxFDXNrpx2eak4itnxq251XN/9j6kxNt+g0aAFSMki/3T8DtH3ZI MPz/xxYJtr+BtX/Y
I/HfvhX88gusDaB43VelipZCmZ9dcVFosDtntPD5bqhgdAt7Eph9JmXIa6ZK qS1/fuKqk1QgEW4J
Oxf8qEFQV7c/lsnh8ILs/fr41Hv6gtd8MUp/fmazORI0/iEAt7Jy/S1o8uho 9erI/ZujX7d9VA6d
6sPqLvJbQCHI3swxm3sZyMDlXCHGgGDoyqK41sJu9Yq2un3Ns8Dn1DDDVgRv tAOzhz5imMcf/kF4
9gtPhMrw1N+Wi4zp0L4k+QaMjMLPagI3uYz2+6T4sJZMxXC8LILE7TaU60W9 MV66LlpdYCB0Ffl0
syrHLsBQhAwnpKEeSFnvAT6Jo6iZpF7VWBlwPqV00lZ5//SF0s6RN6S1YCKE R8pzUIfTH8NFzMl3
03LNyBr1aLY73nul7XppRZSTZFdxi6o+2WyWtgTZu+ni8JmZSqXAP6bDOjAC CbnuMk7UcL79gSKn
+m2IkJ6l8icaP/nFxUTEUI/lMl7kFCyX/4RJNuphtdcFr6abeoR00vw3GoJm nNB9jUQLfUj0DmCP
NBwEFrJ97kNkVGFOgYRC5fnqqh2d0nqA1tZc02GCbz0pZN+1jpJTzIoO3+SX YlCEa0lY0rzYK+ov
tz3RNH2EqtHfDsC+P7NIeUA7+aZ4Qn5fIXDsOs8fygk7SVdTlhvB7sCNzfU2 Xl9QrAdMYDcGAMy+
scrfZClHfSlH6qxnxxJAI6LORXs3ijlH8s6s13gYhggtRsQS8vrcgoC4MqPP hEtODIW7hznpQzgC
o3t50ivo6gMlISC6xFwYiwQQe14b9OnbV7GEYXjrLgF8BPZFfhggxdVljoW2 YpCtPNxnSBY4r2Kj
5Ui5MG5oH47U1GFenG4hJBc8A2MLhV/hgdkIUBHHVRWcqFQvAr8chODj7beY dMRtvA67XpzmlQqJ
W8iFMfdutGhcQKFNaXUnFMtwGsKgkz4t5aFefZ0jHF049nSisLCoJbN2l8pg b0e/njwg/crsmMtv
HIpyjCYcfGMedEo1uiU03oYiEddyjgQ7x+eXU5/m1hHd/BxmcyNPlfQJxUBa vp1ltTNBHfUx83ux
Rg2wQaclULkwdxNo9gXZxaWRsKoV/WKYwlRSzioY9kqFTFlU8T4MfWrlgXlN BgU3N4P9qposFFVx
EN6gn3DPW820QGLw7nyXnO/SiGCctGq4PJ9RESpoGYpHmLvbCkziCwxkATJk aaM1qaSbnG/U8oeR
b4pqPRp8A4y+7ks/ecy/p8O4Iavt+muWsV3ozLLtnc8903R36czIO7eOR8Ad P3Z/9PJW65LXvY4b
88XXLB2ggvx2Nr2HaFagB7oEiHCYDekvJwlKAENIIo4u4Ni9ICbYDfsm8mDd LFnWlslF7d5vdCmI
gQdruPlshJXCx6YhdyjdndjnYf1UwiuhhnGYUL6ExS4pt6yI7hhX7aXCwfrl CxlGrrGuwudxENzO
vRnvUOvuA85PnDLnkhe4dxBTFIuy39h7MB7NPHfVw9Z9XVGMgnb06+aCYZwf Td755OtE6mKnXzml
CgcbSaJ0w5yqsSnLGQGGRI2hq5JPUe2JaMzPWTw5jcYNI5/dSneSS0jUl6Y9 9zEjiCktxAFFnC33
6SbAjWTwuibg6tPVFCd47Q7FuOvykVAygu2qq3iB5ENIOWMiJtoigunLo1Kv jp56WCeiwJzFmlcr
ff2hK7aWcwmGsJLsppyx5v6t+fJFba9f6vlldovJVcPXclVofRc5KzAe+57i OYCjppu8Xm7Qqeas
aXxpLmjA2rg3eDOlQqbVDt9PFlYWo8/WmEdnyC4ZaPOPTBA6hcWRJKGBDKey Qa4TxwnJYhnqaV2C
02ME1+6S115zi0HoB8nt0XiCXoZMINaMY7mzzxPXPTobQZ4h3z6obOAy6Ry4 EsEmELEExquU4npZ
mlFKuc9X1S1gOsc4ZCbQpGuNT5SZLMD6NMic7lnNfbW/3LNPE++NyqIwqvm0 np1F58Hz2TTMKQIK
D9xo0a5YQ01OiE2GezoxkME/BtIpfXI+x4Xem+upxzWYM/tBBsWiSK/4+0ug g89r28YHKf0qDrgY
N/2GdGWAIDpCJxLGx5sDGJlic42CkXLr4DoBFhEOe7VIUbY62TS/i9f1+6gp l5HVG4sTO3xH3TeN
EWL5PLwym5pH4ySPZuYnce6jazL6/KrEwhe1oTnV9va8zpnljfFdbc7DI85M DV38o2ygnElbG84l
KjlQpz2UaHOd46xKFIuYsvBUDN8LUcrbjxs6/sqTHBlFjjQNeIXufRYiGadA x1pbLXXCJnYFAhRQ
6LgdZpJij0cS6OmQTDkasBx0uGyp2FI5tJdWrKx1e6zuktvAk1TYoNOuHSk8 3ySJpMOs5Adx+AeM
KdbzxgeJykRB9Hlp0j9bL2tX5+E84tdEf11u5/KVdeK86o/HFE7/uSb35TMt /0VDw8d1pXBpjX3Z
nkQd29S7WKyYoz7+gJku/9wOPEaW9EEYyqpaWCsrq8U+PFvr5tHKRo6ntkrk pQrSt2SUtK9qE90D
rxh4AQtGwTK+4RIYK8KJxC2QaJsOuaPqlYLwM8c98JWhd3rRLQ8ESS1lm9Cv /khJ6SH8OZ1TT0Io
wkwCsywglZZVg8qzq4K6xIdt0cLXhUM1nsrLyC0X3lnjvI+dtffTUyHcW58S 2yvrHbiir22tqB+/
4ukIKVmwevCe8hSRnGUyyRYbfmSqNyGWbS0qcW2OBieKKUjZvjyP3mdU2Ojz 4ci+b780sOqWa237
3PwLMI248/3TujmGf9g7wfB/Y/PEP3xp4X8VMbH/DTH92/YJJgA7w3+/fSJ6 mR3Fy1bvzS/myqA8
FM1JEw5iyNh5CjgeHgXyOnYVUj2/lSVOWDTFmVO3U/mLkbyFxJkevgG1Taka d7nD0WwE4s6Crm6b
h9fPYNedpnWddjdpG257F0Fxfhud50vo7IwM1dYMjNYsUYofeBtVrXDzZxMX /M7wefjeb105FgJY
nh4PSa4kVwZsl9wxcauXA0QZq7psnec23j6Qmm2YTYW9je4YS+dbPRGJWzp5 OIFERc3EQTk/8WZR
rVDI8kbN4/uahzH2BWll821ga6Azg61emzwslxPU7zNFTWM7U4T4udd3tFUb +xvb1wNlaGdwO4Qq
7xXMf1Kd0vLWQX1XiWGWGEpuSSS/0ESQ5+WxoXAoPelITjohFBPU8W7WHvuh O0DZrDX8DNUxuEpy
V9zpGihGQNSCq2/JVzW5cTzaQfIGsebzw6oxDpQ8NBi1C7jlFtXuJ7SVm4Nv 9kD2PdiTrLCTKoxY
m8gsm+bRF7vvjyRuWRdnOZ8STMa0PwWGw69AsUaE7tsvZt+tZ85u7V0YIe93 jG4dpvsK08FfVF3r
raDTRKbhiIjHazkbdRw/PgRo9HPv2Xt7qcc3v94a4+aD8/pzqGNt0n9P2mbY Y3i0Kvzc3X3jz1Mg
lPcQ4i6xiJJEvEdWbVpc9VTAJ5N5MVD61XXRTjR2cnTugwZbk326R9ybY5Ot GrZwhfOqFRbUPKvj
0s/6VZLobhteFGKV/MAY75WE5ZhiExfaDqIi4YAqQe51InPaIYbxIOSxL+p2 JRrqcRIqcgua7PSJ
nEizO19L6BM1hihXuFLakjxm+RquUUziPjB9SCuTTrQLGv5gPi32ERtGvA++ GIvdF8gTpr9bxSue
pj+HqlbVpzuGhZkbVIk7VQBxin9CVex1EJo7GXVglJzZ9iocQhrxIZ5ZIuhm jeJTKgyHs3QrVd6R
TcyhKv9MLUmpm2dAUyu8wSwrHVGuTZo8PjOWoF0GDAFpIoaLbyjhxjrncyBB MWQFScJFTsFTvxRV
G9iXywTfibxk0R216XjDzy7r8Tz4CsXzFToE6ic/G2E557Z8wUo/RNkHIXGP 0ZvN8gbzqQfV6/Y+
SMUFQOF/3Wpu+ao60MASTJM+mkiDPQonnSm8vcdY8BT/wfsRynhjAFhzVhD7 wN8jajYunB2L15nF
e97gefdzHNCsRwfdwNDTaCUBQ3X3tsBp6Y/ypm26CDW0glu+4e9YMAUrFDiw ajwBGAr0/Z5HQRO1
ry0//HsWQPOMrS+6cHq7tHl3u3XtZbvuiIoYkWQehIDP6YLUGhyA763muCzu GDMdvw0yCLZXipMF
kVNU6c14Ps1vc9Fm4ieioJALf3ck+7J0Yk1/BSi6QI5ahe6DRgyozR/6OTbw mW7J40fDTia6tR/8
QTQuHUYNiGbdJbA1Urc9OMcdWyxTvRpxCM/h49C4sUMflAqCy5reIxyUlq0E xhiaCo9c8aE0m6h+
IuNXz++1K+DyJ7VhUpdIk7Yjq0/YtC5lliLfMmgU7U1pcHZt8KMyRseo705V I4E0bmihDJvIu6yT
IlAnrC6icn4Q12ff0QjdfnFzS+ZypejDsu3kh1ev5OvQ8ntKNiQFzMMogWCR 6jN/PW3z+cY+u1RR
rY1EMdtT5887uWVR+cCthcCJprkjsgDD6CuzH5Uw1eNp76Sum6yajJVkXqmV JbvHoLqH2rLl8hOm
WqZArQzXhgp7cEqURwZ9o8r7C6338JFpZnmpDbP3h+4t69Crk69TMjDcKXM+ WIa0hzIcbUmN/txf
nOLOJFt79KVmlK3l40USceYGSxIawI3ChrENuy1kZ6M9SvBP956KHr/kRb1Y 7tq6KFJnupvo3XFH
GF1Y0F4M4dCmETcpPWKubIkvXtv+WK6smi7X0GZSsKi1+rE8UUDrpnnnkokE CB+Mg0UnE5/HDDp1
jZhM6obHW9wDVf5BTXYb6MemOaQ1P4Td77dkRSGSPYYi88jPklkiVN3OBn7B j4swtFpuDQfDw3Gd
eWXRXCoMvaNcJ0/cyqk4YFxjyNBqOtMqFF4XUKVpqIbIknrWvUgN8DQ+8TI+ ATU+EQxpe7aTlAj7
ZPrwVnUkClprVp+jfzXrTfXTSeJeWL0+Rgh/YJqB0UQUZ3HwxtJv/gVBdGGK I3tDkFUYdt6+9DN6
a4e43HSqYHJcvSZqFkI7IVbF8h3+ECAbZPhD7AoCCZtfokU/2GQf0A1ltiLg g4gL8dftVmgPdyxd
PcyWLleG1tKtpaT0ulaSOvGjp+uFKPcY5Y17hHNXqohyM/EAIci7WVd94nXy UyZcyf66cUrpz1hX
YOKj9jY7n4GKb3UHc7c3jPolnFpeiMXFC8D2ETSoJ/KRYAbkI3JE88BKC2rT 78JkSLLJmXpBJzig
TiUpwHsmOPunIOa3NtIDsSwJGSZMPj+p1GBDzvdJvbDvgdUUqNMUFKZuBj/q Qw3ydGK4EuOO8en1
km9GzjONRmdszidLb6U1WDVtblNI/lyawxuOWZXr72/sOEA/oVuplrfBLRAY K+idJlKvWoimdVud
ayjWU4rc7uKYQwm36dSXoYym3snkUGv0JIQJs5f4YHmLRHgp5CBSx//TUfAF ZH8teMxhDS6aaZxx
mpkPnD+aUTTYulgRZW7cd3RIsJbe+K6B6EIA6kq3u7MS+ShpsulL0tP52VXJ Vg5nUo4Q3XcQx1ul
ROyi/ImcxYG3+J8msTNfm/BqLcWsh64WUet9XHIXcuufGYGIJC4w8w/5LQLn icaCWvxG+MpgnzKe
RW6paKWVo4ksPsc28FU7ArlZRBhegq6zmWqr4oE3EZzp57B+JM9N1rhzVEqJ XU6OpI/5IesBQwYq
vUvTykjuEcs13ZhP1t/NrgwsYC1JfBaHJkqh4UqpyB/clvftEBbSLgxvsC9e PGE1oo36kixXyj4u
ecl8F885QsmpYhT5E7rLPW3Jjrp1IpH3PZApZe7VK8NXXC3nyEg80IorwfCB AVfiAeXwc/IfxbwI
y2jwe07ApoWBp73D84lB0/A4LbkPWKg5/XSwPPjwR9U/8mmeNRP7732Qk/yy Ub9rOJVQWXO5SsT5
ES85Cmm6mMaOQVEmFmAdHK+sWhHbSbx1U1kR3nnUL3UdJqMliaBLwMFoDxb6 wSLYK4ya0ujan4w0
susnSB1zMRyArQTtknlaf6AULfJPCAoPEO0+prUoNvN9JJHFazE063ZVcRH3 8/rZ1gjkB2456dA7
BXuIdhwDcoKC5lK5CkWSOCdQqEiZyWR8qMGB8DFcT4I1bV/kcteIkI0WAT6K G8bf5C53rISK/EeD
3AhBoNDBXsFQca9mum9hVyjqAb9pdGraDI4CNBCCY+CJsUcnXIqXnAerFo0/ L767PHvQsbJq4ret
SSEhWLQQwXRoRnZOLshMleypGYQNhPNRCSTfEn4slE7MfmZQKCVnmPEOS+Vb iXJLe5nu4blaUBvB
ekj5T/4qs4+MYtQJKvQGrGauG1dTkk8S7hFRwizdP2/4h4l0VBBKToJswuT4 ixnTB7ZrPksADeSh
ZAm/1ZIcBtDY93YpGMrUhJcAG0Kc5k1LY/M/bl+fXk2fFsStksBDQhqHCR6B l6kMd/JKlKviw+nw
KZbivHhctpPmaHy2QL/XrPPAqNRgzb/oE3joL76YelQ8xF1D0xrJwk2ffeOg z1iF0CeE6gwnAIol
BEtUnE2WtEn6eHvmK75CxsAoorzWUbemAIIsdohMUK7vY8KLo7Mz7+TUngUf qMw6yIyaeUi64+ss
NpQj2hD2+bPJLePmoTDR0hkSCMMn5cM2fUKh/TqrWzSju6c6sK/YVa9+6T9R qdy+ClVR7H6RwyiZ
zK9ZUnPdzQqTMgfzi78S9LVeiBkSpgzRAZ9tsIWXKHXUvApv2Do1fGuWt2oW F/LmYtAyjLkqffTj
7OSHfX6So1bCUM7/JsN23TAyuHijWqYt3elUjVJ2hkyBRA6E3BK1TV+Inbfq f2xgfW3EgxY5EGBl
SC1ERMuLCY9Mo1QFo8RXV8+HqZ8pHNb5WYl1XaKMYoB/bABMoCGKikXrUKT7 4ooX04OzmspSS7T5
p+qGTKJeW8GVULC+66lN3p7dngP2fV6ey0ZrmHpOpzXJRBHwVb8aedXEMU7T nagvMNBqWhvJP82a
/mG7EcP/of1G//Ru+e+LAn75GQh/+xbv//IMiuNvM6h/2H3E9t/NoMpVl22W xX5tQJ8lBk9lbnVD
9IdD4WK6oDsZXsQ2Qr8z4A+jLVlAGzZOcGZ+n0BJHxmkjUfyuMVRjJZWjnIU yeR4+d2fT1ZO0NN3
BSES8Gpn9obBjqJCoMhMeH/rN3W6Mne3Z81q6dJr6bItcnheP0Tt6FICdjh8 kX1ShI/cbpW0jQxB
+laT0Fw5qt/CWzMyfNOJFuL02WqhuwoEDz7HVYjonCZ1kcilogpkzzjDVK4B PtQ2qXjX3UA0mSKd
OcSENKIwfdEPvNZMIvXZ4ymGl3AdwggY3KhmGxKYNCVL7boW/QH0AvcM6Dkz wtY+GVZNXL7o1rMB
uMQ3/uSjm1VKBoJx3ZQ4IHkcd49cXIDovLwWKVW3pdLej4Eex3XGfBKMZpQR VErG9BM07beBncOH
2oo8Tyq+QmFW6s5ugflSDi91oYXtl88Y5Cp1VMu7I9Pq3tnZnh09n7NORYca iU/IBhDIGnOktgQw
RWR8Bx/cAV/NPNmxSYfu2vMGiwou/PaFFvl47rlGB9IGPut5ZbLV0vCxGsCX ald9d2eCLnfR3gTd
95ic9PHr3NeDbQ/s2iMVqbZOQPi2X4NvrWsc1x2I5EJM8FnK2Qrr+hLxmmP/ DUuSYgfpaorf/oGI
9GbNyfC8Fwg4X5sYlcd2EJHhO0J1Orx8qFUujQt0do/tgk9XuxMpgUrJ2Dl5 kV0cgkJuVW1yP2Uc
5NeUhzp684hOP49o6VZr07tauuURNUc7JWYcSs4wIqNIqouAjgMKb536ysQM ajxCY2WC2b1zjpKf
/Rdukue1lBnSQSNAYjRic19Tc6YjoNc3yyS+V8cQiQmQR2t/YkBjL8fr7X+t BJNBKAqo24Bh3OmD
YGSwTCEMLxQyZpAmdVc8YnBpPn+6NDuSr5VedfiBSXKNC0MkFtgwxgMl320t kbNgPl0+I8jPFe+2
x1GzIFtRcfK1vq4euZrCMtEZ2FqY4LgdnSnllKoOyyU/FUye2jA3QMmYbh/n e+428hbvdjm+Nhj/
RoI3OMTWUXiklfE8uMUNV7MEAdgIrk3m4YfyILMdJGFxf6dPqa2wRps2AeWz xWZ28CMGdEzAsrXq
3f1B8s8JqsMJ2RJAfufxFhDTxWIvLOwuTjlVFloFbC/4Y6TOREHCnBjOTGBQ 6EcyGoXSb99ZYLAi
PUCWv7JYZNnYZShMn9HBVhCO8Tesb+k1xebcRzhbE3VsZptXu3jhF/Jc0rg7 RoIZVtZkBItswfEY
IRJY73Sv3XQsDJmnf0Kq8S7pR+n4GtWTHVvNUuCOyS6OYrVtfXB/jIekmo+K bYU0zZxjVzYuNI+a
9Eh/EpVExY3i/bpACg9WEuafJM5im9QjXTnGG9gOHuGNi3S6RRDSr1kfZYQh 3J4MzmvGzVMxA3EI
Lut/I2mJ4d2zoB6+m9egpHSCpMLziWFz4uOqADqxNqzy3ha5r8MJbnbesq1z 0qJT5Vz5ZM6WZ1tH
O1iNzXUi3HfKvRwM1OUmoe+FTn2gHhjb6iKlFaW1IobiuWkpx06aQ9+iQ2kE idPyMA7qeMALuZzC
8cyzR56AX/zIcI1xz0o4N8TK2rTpvqdVLkJBvpKxu9KlKw0MvHw//iI+RtCC 07uLUdxfgCa7mBUg
T3CNynVM7qE/wKsAhSPtqZzikIfWIbmkQVoiVadMmR4WghGzD3rYMD6Wjtz7 c+z4iOXU79x+1kYE
D6BdFd1a16rrNRaHBk6rvRqogYb1MbdJxrKFPMrqfOhzb8WhRq40P2zaFk5e udkRY4i9XxN+SX18
p6/3QnYXdE/B60k8wMVszL+zC6lxKAJEyXgvpvLKG2v7SAai6Wm3iLotS1hf z6s9z2WhpcnOT4p8
DAWLob9e0H9BS68RKyRSjsBVUJCnjSEwE3wpx1zT1mKxZvCF95oC8pMAESvK eSt+9lldbrojBKW2
K7J5vdWHp1ZQObxc4HO4YeBRi4cGFHAtM+JIlOgFfEg+nIlCM+eeWaKlARw+ e7Av4CNPNMKln0bQ
nNDOxSjsmm/ADhlQXILdG/gDZrjKlZ9CW+gX/M3aQo5l7j3psZA6vBENvMx+ 4HAHhLMce0rZb5yp
BKlEnMMI3GgAkeJys5EMDa6A5VYMEPlyYpQh24zpj3EjEkMlbECTow0OI9oJ dt43+a1tmwqI17GS
ymz8dEU85Ww/wU3QUv2mFpF/2JhTMrOAY1bKHB5GPRwDoM1h+pF4m9YBTFdj 0BdKMWSufypGrP1U
CziCZ/OYrwERuPGiIyd/bIJtRmnmZBVrFTfaVDFX5kz4ZnUhWZ+vUIIu3JX6 csxDbExASK49sYg4
9KpIOxNS+X3Hz8yNcjYDXXsTtyLPn2noe2NqVS5KQ88tmZhC5O0FW2yKB3J8 Sl1f20wMUOfywcIu
aOlq+61sXvvHFasZ7s6czF9j4UbOp73mfNHkD/drs95nRJPDyjENnyScEZaM icmkYb1txafjn6uS
bvuiaaW15xi+xcJzuBuBqFhH1Xb7rPmYVJJ/btptho5P81i9YoEGR4QgXg4x ASHw7CWigQ61S7ed
f1e9stcZS0563MqdjWZ2BK5zRkedsbCP3lKQa+qsnjKWWj4J7AjluvvSHIKF DO/ogmC15H7KT1+K
EKH+sOf6q7E2+osFHiex90uu2gbqmQAvoHgZhl6ndSOsxneiBxdC1CeMVS4k MzkpM8GwJKfCgiTe
YqnfP1KIrG6NL5bafOTnsD422nhEFt862rfJLPaZJm5cHukKdPKIAiWehdmQ XhoeRMF+yLT0paMa
5MQnDx5uf+nMXAxJFN0IhZkf0v7jymlhuPhJ37UxazV480UFiSOX6MhX7ANB ZctQlHV8RNs/5gi+
cedz4hOIXz0sMcQSr9Vifpw+t+e2VVas3M1RoN5QIFgbtzsJ378z4Vc2oMOw r7RlYHcwPim/b4qX
QTEKEckxGWQ1r+lkPEQ4pgk3OafQHRtzMeic1Mb4kVS2VDpCqjNgspPEKVx4 vEI3ESfwQztTENTL
1IsyKb4uc6VWzh/3mYt5o3lOPsDW7ko0/NIHGALoUHDF659w4b99tp6Vg+Of Pl74r2gGQgYGADPg
75BpRRVWCdUUPZvbT0hHWm6h8AlUGDweABxwNYUt0PWZqJtEqH6eBRoUazxi DEhBSUwJrCKZaish
fCk8fFb0soZHEyOmEpEKTfeDti71scpxgYauMt89QbF/41l23f5JNg+XwyuT w/nb6k+fN5/z8SxC
ODD+JyJSKFisjC/9CnTorLL+6dtQH9FKG+Lkr890XXruqeWK2HYVCZ/lBj3B oDGDCHGdG4kHn5B4
EiMIA1ByTzIMKcfWODtfgfwDZx60TVZib/efKNn9A3VD7COxqDz7aTD84cSD rrhMqFnqCPFwQI0h
/QFctM4J+no9fAeWZqT+gBWVXinIhP6SoDtRIvxFOJWVgkAx/thNUKJXhxBU l7FLHqAXSE2kQHA3
wsizDO+P/nQPaB9XUzaIjtBXtt2DUqKpvU7GL/Tmm8FV845QErpjn3JfmrN5 mKQQIPmLPrsha0Fk
bOIPG1VbMptxUh0VQK8AmkmQxA865kKRiZC5DPjtAv0N4bwKNpR9rDoLnWAr Wa45U0gzJUs8kgk/
KW3feWE4MeFsQhnCgO/Ck6PrVPHcJJ0MpfcbSwum1z/FyJ+naGFZiQ3fhjlC PbGmJHXvQT8dfybP
I7W34tsfI6bM7SkBaXUIdgTC5gN9AMnBAELusiILUwoMvpcKvNFAUcE1owyY 41+090V32UMlwzU7
cZbgBIk64hctniX8kEBuUJJqgxJLjTbimMUoDhac0WMg6q+6wAeJeBGNFzby Rf5ADE0nIQ+TOio8
+ZXm9dy2q6HyPI2JHWq0ATPbg+P7roCMeJf2NU2c2hbMyvCq8uj68TnPZVsj bdWLmuND5feYtjWc
z28i/UxV3hU+j6c7n5h97outTJ22/acy6phehg6ZOifgDzgzHynK6RwsPrRK Wt1MOoKz7qpkQ09E
cjtoDaVhXBvvzgfXX7Kd9UEuHKuOQ2tYUlrj5tQauPd+TWXK0tlShK+xTKVJ na0qBIO9Cr/W5cph
2tuJio/OZ9LEt6I+2XGkI8jCqSU1eNhFBHd9ZJoGGRBNUMXJeLaUxD9ZpV/x EOi0CC6Sd3PtNd03
7s/ckJRhaE1U5Bote2PM2zrbfjVfd6dR3zYd9hxIqDCj0nVJO1XD4V2u3uly 8j47GhetjQorSFGF
EK2Ao9N9YB69zgohz+l5tg4mDsby9dztfGrbcpYTtd9ru/q6Uxs+xdVj/uYj 3ibNCQd/+pn7Iee7
a43iK47Lk62852feNt3MmE9HkrKuUNwMOEFc1uxBLaU+cTMRemjoU5Taps2r cp3NHwu3BALelLZA
qhbVupNYm7jpf7I/0qCrum0z368ePcEzka+7z5grlN5fWh8g4hgc9emknP8I mXOTTR2IK4nQdDya
b8/vY/U+3vJSzDmnNLeusqBAGEB5oSlSOdM7YMN/FqmlO+O/3BuTNg24tCSY H9f6OehAGbZ331fX
6syEVa4rbnZcH63c+Zb4sKUUR9yDycgOLbWIj2IXaMDb7Y3LajbSOKOVZtpX EEOn/UPbyUv+9Hxp
uGC7rdQlU9eRV88c9ThdtTj7Z9bR98RJGSkpXh6JN0Dx48aU62czpdH0Mh/s jCuvDBbSNw3ilumm
L4XNtN4y4wm7mzOhvkWiQU30Z81xRC4kEcIOck0LZOyelmpSEAmHqqnaxhmt BU6I27SaToag2csp
DKhk9ZuqMi/jyOEihTzAiD5pyDCtc+Fc0oHdIPV3VqVdG3387tnTArEmK+Ig QW1cpKJ5xF8YKJ4Y
Sc0ZqDTQqSOyIluwzt8GxcUSpr/gF0yDg4PHe5qJCQiGDdtEBeItyqAkrqpj logtzFguZiFAA9BB
4LNpkafdaMXnSKe/4RLjBZDdPMSRInOAgWP0xfv2GBCKI8H3EUYBOE5JvkyN CtpWI6lDhFcv83kn
Jsa4T99pATMJUn/Ifa3foNyQZo41UXNPXCW7FfRyj+4RDDBVP22kOdRjjp2v DgRuP/sQW7D64/Su
n/sN/vrCt/tYecfElVjufNiRCVNMsH84L6Pu1ZtpY8PBMk5r3MMAcdI6Dm7W Jjz8m/3Ss6o6xp2K
pjL5a5QK1F1djNfFRWqvhtvxA8Zy7/ScfFrdnVUacnpd6aVF932m5ad6VZ7K /TeT7/vQ17iqPrWy
8pONPy0SYUEntjC2gIu8btxHw9kJvIs3nKcW9MRPIAe+ZRoSBXCyzC2XKpZN kBUzirZGnLkO37SO
R4WNwF/OROFZj3IxRoey2nJjfrVxqz6hsxSbbvdtpv1kLZ0zWoN9ToeSGMW5 gH8giL8R/WL/0J0x
LukQczK51qCD8Uz7yXReFhZmtMn4ulHGdWkX7ojG6+0i4JK3iRGeyLyCa7u2 Eoo3zd2xg6Xh7W4a
vzqWrYUDQ55tX8vFcQ29Oo3C/+pQVZc1o39nNreSUcOgWpv0IBOlM7+0M0vO MU11jcBpBf2NeL19
7UaXgoQt5AdQJ8w0YTp0RrfrBL4vjPzTaNX9aOWniEN5/y4zQaiYcWEitzO1 2fHow4DN6a82zlBK
iCXQ1FgmXykgsTCwHulhDNszGiZ3TVgOxsCgpZoTPtZCJ/j1AE9rAxxrN0m0 WWS4cVy2WFHpQCA0
0QkpUHbikERA4u1RyEYUhoivI79/RgWnaIWSM8G9we+R7HRs/8IFTxZuE1rN It/8oUlej90IZSCA
WRybMCnXLs4TVJ8Bk5Y5QbX91gYIs5h9LYMVW7ZOJbxiCr4PuNl/MWx/b5NE ONrrg6nLFeEN+MVc
ajhfIg0rdvA0ENcXboKQcGaP7ChGPhV3EHqkbiT/ReSDUDOdYBWEz9EC5HGG Xw/IKKOiotzG8YDs
I8DNzMCgfULFFhMuaaDlKFg4Ob5uSSdaMtsnISha8KN8Vf4yUsNsjBJbFv90 s6lEAx9grdZTME0l
lYQC6bidSChYBnZk9BBu3rqqP5wqUKkIQmHhhC2VJ5kFVo8Vtp0EgzdVYo6a rVPSvUFArUzA/VXF
zzFKK68XTcIMEu8LpTKnWIYOyHcLpg33N72Okd589tqHstIzLFwltD7QyMaP IBaL3aCIiUMMuPYj
UOHFo3bhIAVawMBM0QcgVCGm/hRb38AKYsGEUYWHwlve582f4eVR5buN52JI 1oIP2/iBU1ZfOl4s
O0/ZeJiUtauOXrzPiy26Ke2yQ3SBlj4eMyr8COK7uLm8v/O0rDPw8/EVKEFz lyOC7qBb86t8Und3
NzZrivnY1Q+aoU3xAgLGNunW4e7E9nxO8sCVF0XntyYD7O+j59uZo8CQ5xD3 mL225l+1zp1Wl59A
Yitc5B+RU6XAwIYUde94le1L1ZF9zR2wduSIdRxSDAKmSk5A7hI0oyJHhcbI I/PinZfTq+xX0JY0
VB+B7fAJX/tr9BFexDRDmBr6R+JAV6c23vJ8g4/EibYo3ZTQTMQ0WKhi6Gnh T1ndWfnh0tFoKCml
AIStOXEBtS9IlQOiyFkJxSjgyq6u9j0ZcJEK5H1Oe5E0u+POAcQAhVt0V84f I3c/LMne2MzX5gjK
olWWRQaFhhdw51RR/DQdxCrjLEmC8455hp4wYD6SgnGVk0KoKbviUx9sbL59 9iYRx5/niR8J2Pka
4DEnyIGvEvqjvFKmrE/GxNDdeess/WPfQHGPVdAiyViQD6+2wD4pwbNMIdM+ 3A5KufPDodPZdM5s
o9u5NKyVhEZ9d+1Z7hS+5otwi+bTWbwyuaoEt1QUMQ76clvqcWxd7dVwrnmJ 9KMoHMsdeASPc2aQ
OaPx+EmJQWWYMm6zrPfZpnXGhYPX9hGC6u3Bc6cN3bfWW/kyKIwjfHK4t8rU foIyeNmc1KOjag/t
s+PyW8UKa01EmYwj16sF3Xp0Zw0b5vkNZCjt7OdPi59ex/Wrq/o24CkT9/Un 03uv9FdpbvWdz21o
cLMZ3DWCndsb8R6H8IUnJlJxut6IPhsEyArf9jeahmxP3nKR3fuYuupymT6e 8AiyBPBDmyNB6ucG
qyERwvhsE5U4RprU86avQShqLeR9ZUqPR4knTphREXqtXIgL/o6i5jqxs1I7 r81RSiAb7aokR1RG
xeriqXbE3EdLVct7/ry0vdQ/8fgNEZZu/OnzRMukKjzXk+Kl/h3Vg+PnldUv 1OPSdJ+E1Ra+dNxo
NhoPfc7xTjnbDbbWeP3hq12QIuGDyUxDayp1QVxWDojQLxlOzFDZYlku37MN JxS1XM+bue+p2MKI
Xr67F66acfFKA3ysO5li2u3KktVktcBxkLAQrWC0sGnFqyN0VIjD4Dm9PBz8 Wbfwya654nrZraHh
UMvhpNmySKCzVNe9YkjC2Iu3Tt6pCnBQa15eY3rAg7KfZnY1XCmXwAVJg606 VwQ7R1aGgPCBiLQo
r/Bion+jzeR0DPYxpNYJQ/breo6jYZtTSbJWt6K2YAw9ibOGPUyrzEGAlfTt 28tPapYgRdCIdC38
KPfTRkLq/UmbH+DJMZBBdzCzeo9TLtuz1a1EpJhfV2VduYhfykKycNdZdpwV yaR1Huj1l1TUps6X
dNR3j2i3HBKsRXTaAyyiROI6OOlIbMId3Edc7m3LXc05p8oAD+6CJhWYp/up D8zbJrNoh1di/bmv
exdxD0dK8mnSnyUkldNdjUz27iMaedzKxWmw1OYHaRx6g+TVURfgSts9dYcs LDJS8eKd94PNdBob
puQzcAy+Pc53FNkb7s/MFbzUPrk+u894F/Uu5LA+NVrRyM5isPRofwTvAr0Q fiax0uh4NPYgDMe+
N+aWpYiToKAP0kmJ4dSBr1sOco5bL3YgToCDE8/6+pOyE/PE1RYz7N6u8cMY cB+X7blHi94lcicu
jeNoX4aKCPvDaNN9hiR4cjWYlR7CLD9XJtl2F8FEqCohLvoU4qbXyWTIth2E TQC1EBA4Uzywvxoc
jj5NeRAPIIsJtawLBx8Ts1sPE5QpFJtED2a6OmMFTPaihwO3C8+eELhz3+DN gRE+Bym220DLi/ok
8PsFxgNw8GZkox2e9pvWM4xWdX6gIGem73IbUyewVC4SAj/WbI+XgeRdAuud WjkKTp9PbjL8oh9P
oN4tdMC4XPg2QrewRfddmIlBy4PoJTec6PEoshNtZn9DNrIfWJyde2zhoU7Y pQHH1RSGtcixfCZS
FD1JNzCuG55OAi+FBtUUolmzTS472BcACvWKaz09EvWaxVCwdGg+lMQGBTch QWzhDoqb1E95+IrN
l8IOhXVeFrz18LMtJq0C+kgBy/1eezHh8fFq8MYCE8rKW/JE5wPCuz4/dhRZ FL6rYXd737bc7cP7
G5bjychFMPQxAXUISxN6+AeET6sIqx+mdaWE6aDt6QRlWwgn3KqhVPg+ekJh 5fIfX8nBxLbbJ8Ls
1EHs4jSDu8hrbABz96VuIxdERgrGFbDH/jBCgCbpJJ8miTshHBRj4ZCeiGe9 CpT5eufIeVsAzJxe
mSte76syJaEheD6tOzWCJdWN8kO0PHOu5vqEynLLN6O3pBmTLm15RNlu3f50 BVVmENTWz2C07IEH
z8NJpwXpc/kBYXBYRh9IIuTQJZQQE3o5UswndxZcl0QzoQYQlfwvRC7HSNPO i1Erhz+4IOYuWETM
8Z6a8Cv5ULdawccvcHU+crh7fjVCc8tZJOqsC+UaEbhRhBkmxI4XDY/dl1AI sg9eEUrkFMIUCjhE
SRdgOiBrCTj7Qn6A5Y7HQ8QI7W5A4WCqY8ULqy+phrI8wWuSU71aHqhcx1Se XbACN5EjuTFvD76i
c0bhEm25Y3Nlv+Y3KVyyUfag6BnRp2ZAl0YjL1FaiBLAHKACiucJvJ+LUuq+ zztMBipG6imigTXI
XO9Hlxt8wzltnxL2wV2PDJgX0WU5Z7rnfkiZM2nMdNOI6KqIVJ4EzLlm04o+ AxTek1ue0QcFWMIG
8nnEB5SKN8V7giJnlHNIUgNBkiiG7pwCNUDcRy7+5YZQRIpsDAxnAq7y++EK tIG4tVnUDVQJhGhJ
oLQpE1xkdUPOqjBTEoTIF3ilE7arMtrmsGO4N1OXhtZk+qGexdqg6XBheyt1 VlaMdSXNWhJBJGer
UTnaWBWMiCW4/mywg+bExOS8Lx9dE4fhjNzTTDil0tnT7ob4RCe+zNqeSman fuYqRESiOxWkTIPL
+45W8GpKisNlvMTr/JXaa78z523d4UfdT4azHM3mpuBvTZdpdjHP8u7AZZo7 Pn685HkZWu4KCOfY
zHQS8w4pQ2f93yM6931Sf0KX7PFCqNHo3nz21vrsYc+0wuIKhJHzrN0MvdCM Uw2Zgw3tte8Z7nGO
8/DlB2zMN4UVWX3PaCl3D/eWzp3DoxMz2+VGJ0nL0b09MpeCsrzXb5xFhgkt 05WLrLOVTfNKmqVU
C8rlLCkZ84lJyWg4EUbizFAP8zBR/A30pXKmiTAyTvsybAlzmFQG1Gjypbml tg2IyvktGbVL3yOy
ITs3Dsc93FN4wsQvfQdXi8GUg7zR5JJofrCh8b968s2huevu/3TSsTsSoIRx 5hKh4B9V48sjKQUz
X7+sUQJgd70y9ot0Hslir0bFMqATa0biViiQM30pzTiAU/1wMmZHmGKgXC8C D2begK1HKreGHBk1
050nBtBrWGZxISZ9DcQuyr2bYaFbBX92x6Z6KvlSJD/w47SLg/Q7e447raW/ 66wyY2n0AIIQBcF3
tWh7jD34qVLbtRruDzUOdZ/snQvnRor8kz8HhZXMqgd1sKCpmzfUqXyvRozc xfWaViL46g0vyoCm
AsBxEYmQs4dQpDqRWdTePacvgUgjcxfLE7ao4kzmROv/ViIuj5ldOzk/67pv z5ZHVvxF5GNp1p2a
Mi26Wk6J7+zF7K5FlUL70pbNWOrINWgGpaainoSEKuOwccbE4VkkLDx9DI3+ h5LJ7fBcCYFuiY9U
a4pclvGnsRL1BTg62N0UnOFMjDIRz9OJJQmH6tws7FKl8U9wduDF92+1GqjU ZkIhh0x6NJrko5bw
p5LcTt/MBEE1P8YT7KNZnszvWp8NbKtPFMmko5GwewJCDXG+c2Z8fjh1Zu3e r9UJLeCThRe+qgX5
fEzjmqGNvZs/xthppN4Uoi5Dq57cW0BVuUPt6g1cXlDr8Ng5oPSNlX1eXHy3 k4H8+k5ODR7+NIKi
W6ke0JgXp6ywttZhRW3nWPGpR/MbyKC622p4xFVXLRPqR1Iluw3dWYxbM5X4 z8pH2Pk38oqOph1z
kc4/fbASx7168h2vmMvlyE4dK5JbVYbLRqjFL9WqN3YEiH8qUG5L4FTzJ0S8 o4nW+2GPmIydgidA
ZVslNMFmyUjlJLDuKRKT3aAduAGIryBmENFnCOdQvOqET/BZZjj8zdN3nEu4 Bz5f+HT3Oe05Zs8F
PP3NhAKRYT5GTyG1Iq8LwH3Gu+Ddwh1wV+MueHYLBaxd4BQDToKixMZ7tIuR bQSzzIKyepzk5Pf7
njXhSAG+bb12KFRfNNATfjKNtApDPj1/sHTFyuwJmYqu0Q5mkgtrOOfTbM3D d+8HTT1nVTL49An1
TQiBaNUYKhfBHhFs483XK0YPTzGU95UIjOHOrRuc60Hb1Wehe/wF7VkswEw3 xAzZO/B+x38/1vS2
iaiKCE80BzjSKc8LMroI0RJv51PQi1hGzfrL8/kG5yOwlkCL76tmkGh1smfl /i1SJm3kj2hD8Hwo
h3wxVuIXnK24NoyjwlaknlddrfxndPahAQTZh8ueVBn9Z/6x7W0fhBAYw7Hq sN144DPohW8IWPb7
l2sfLkEmHsXtthc9hVskOyIMWXK3Qfpi75j0fE5DWYVUgbOCqftCKUQ8MHe1 twAkmCQ49QZWqHvY
+pag1hk1MnhBTy4YRwuU8z8it480wzFc+EEHml2ZAlWBki+R1tnwt1yiZYZJ IzmCL1e1YL0hs3bW
JkCf2zjuIWz3dMYU5eLeomUYkrX8bzuc9PaOLvZ3MgH8VJ9dPJVtdaeW8dut TWgXuJet6oy/ff3R
hGmeWVEhWjus6Vk2MK9g2uh2lKq1e8qpZdvKoWjdGuRaVTl3V1o054w9Hcke zXhdllHSJD0r7em1
5YFqGsRaXN6nzpoyukbz7WWU54PwB2HrQ5rHhiZBiTcJCd3kGd2EmQKFp1GF FlkJ25QZaYUl0kI8
BfcEJaIM4wQtspQhEfVkYfVYDqydcKuzrwv9rD5BZgZCaGrUB21hhrTLBw8k G6Fjmwt42qMhzXLN
KY2tAuqUbFLLWkRU8GcxRlBp83KS31TrwEQ+qscbljKpOFtMAhN9Y9qvAC81 JxHaR0UKp76RVxtH
IeYthrOgz9tDChRxp5VzaxucMTyjOz+A5S4IQ9dY+D66peEWBFHEC4bDMcDb MTQ9Gn8KH2beWyx9
vMT8/atTRWGyDlQQseNXlYKKyOE5i53a89J7MA/E0NJuko8Sk3gEdVOKn4WH XavQdZAyp10NIqfV
4nWUE4CPlEElBly2sPZQx04UQbHYkXHDjGRcE/zUcxYwlAyBrREgxLi/A9qp Vu9TZsb5QcPeLGPU
UUy1WasjQb9PDrGPj4HSbDOPso8zIrhC3kR2X9rRQ8OLMDLeWLg+HNwwqlr1 lYRrnGrYFprXauY0
0bXufjiGBIl1ycWc3ELxrKIWBiQs798xoNJhmlAZVnmCJ+wm0bXegl7JdBsJ OH1bgq00rKTXoq+D
pem+BAJVYUzJ2JcZT7euoIvKYsLl8r84RmxikNFIcQmgIJUzRULhxhQW9N// lv5RXAypOPl4mbYS
+Lug7Fu+adfN0HdbjRu+GNPp3qnaHzo29C56AZY4+NTPz4ZVwK9+5BNt3iPa +zYbdVWYJw5dCdRr
tR+hLST6j+JnIJ3nKyw3og/xb27WbX9IUQk5FTgsz59qalB/w4HFWNdSc73e Atkf/Q7+4mj18umn
+ZvhJ2eszaTd+xTb/Ry9LpVp7MSrNt9nRz+MuDcGDX4KgUPoNt0NaCtCJvDs AMarZZDJAu+8Ltih
TzQXH602xogVE4YDaoQU3FSxsCSpXlBFyaLzJS5l25g5LhVODh76kI2v7PLF ofuiB14DFJmOpaBl
cXkHmN+0avxN8eVy8goL/ehiATOKdmPD8lAjUpMUlCpQErQytFSS0p8dri8d br8jVI5Jj0xewndP
GkPpFxtR6IkZixmKGYlBzMDAUfuxBxKBjt0ZD5kOgW6hFFOBQ5gSVkENQcSF 8V1KVcOA54ohyHXi
x+6CoMt+mSLxah5Fw/T3Y+SAK7Rj6edjkCWEr5mM7UaBgsd0zKMhri4mlhNF iEUAORKHbMkDK6eG
MtNhQMJgSAQW1yuDh/LCfMbU8lPDMZMlFaQTRFlk1c19IZw75PNw8D2j/pib jKIudsQNVB/xIRM7
DRPM99UFqHat9ipAmO9KCh4O4w1rv/962XM3dhcIlv5u0RA+n+1Ry+3h7e0T V/Q+7gofHRvNLihQ
cyLjGMw//ELH+NcH9f6rk7hFzK2MGQl/+ylP4a+juQGEtIzvmRkYGJh+nTrO 8rdzuUVEpGSEZagV
3awNbP86fZz5XydzA/52Ljfgj5O4f5Xw96O4Of7ro7h/L/Z/6rxxxr8+X6Oq ycAI0GRm4dDW/tsB
/X+ew/+fm/7HqfuC4kK/4n/lYPz1oOjm8E6MuI2J7XuZsvZGxvbmNqYU4kbv zTd3dKOkVzA2NX9n
tBsF/3sDjCnfy7GzszK2/kXde7v+89n9jL9/p1FI9beD5f/W7n/4CA37f7PE TEmuRqYPALd6/QGf
g4EkKlavuAVXEhJBCNaD7rMkyZGQDefNubiER2h34/NJ0b2Vm02O5hX0Dg7k sr5/d4JhZm8P+mZ4
AXkxM7vt9zXrHzJk/mM7NlmoMrTwwEcaQ/fcmahVdgv3SR2q5LFVJ7E8UVju UwQ5WIfJmJ2fBSRy
c827Ngl3Hvv7ItKQduivEU8XQnObOpbmAno5sCOszISKk9w9LaL9d14nEeed qnWD+2sqkuajhpa5
dFx3SzOQWwGmMcuHGXEG3ahrHaiCNBakfTFAoEB+xRYn/6i7/7C5nfG/2tzO 9r971eH/pm3sDH+X
97/tY2fh+O++OeSpNGqzDEBqO6a+o8CIlZKIs/7AD0Mio8s3Rai/LLgKSmtt xBpZHK8we3PcmnjK
Hh2VLYa6lrY5Jrdtyc6Dp6vtmQ4aUFd3/QgOBlfqG+Cv97yZfEfHjtGtBgWB 26eNVJPKkOxL0XUe
j4rEM+5v15Wm+zZDr+9HXs/YuQP31Qp9/7gmhDByA0Lb0CIEQQM0BsbjAFck 6IZ8lDxVssxCLTBG
QqCOkYVOBIDSybpCSTBEtMXwafgat48byha2ZFfBfI7X71sAB12rBd+dw894 SF98gY/NjQfVNtMd
QeeldJsiPPmrxBl7yzWJl7fK967ED2buPhE9sxUs2EsfEH6Ctq+VjxHboU/O RE4NFTFCXcrCugwg
CH7pL7tvwbNKIlc/G8zf/5bla0+dG8tyA0U9Cy9m+zVobdHjQLnVH1L9E7+h tF80nDdkSDJJNl/b
pdl5EtmnFVjYBxkf91k/2xEnhd5zBK4RW2RvpwNbeUxrqOIUBC1V5QMNGl33 DKmmct0hZkky1lI1
VN3wjavwUva1uQTbY7cvUT/quoDtq9xRs/soX3b7VM8hS/CE69TRdcxKP4iN tOWVRnmHTw6KJbzF
4vc9xbOMmn4eWAzsNMiKkG6OIEnz1UyTSakmIZLDqp26H8q3EjU/mMSW7hgu HBhHoqSNFKbwajVU
G+XFR4mpe8leQdBiuSSjnQ0tJLfc5bk0O92+WjowS/lZxjZBzpBRu7+ksuge NNNYelBff2zaBtXw
USwiyb5DJKMtRi0DvyG5IufOL0txr5Pg+/DFy2LAM3kXkCIE19k/dbW/tkX+ V2biN6tAy8LARkjL
9J6cAcDOSMjBwf43u8Bvb65vRfv7wP6nWeBg/ZddYGehY2dlAgDY/mYf2N6H O7V/+VkYWP6wFhz/
0Vgw/AdjQfue7m/m4rdK/+esBeu/00ovbPPe8d7HeHpVcxt+GwfzP5//NB3/ mTpzewdHQTN9e0Im
Rnop/X/5GVgAf9oUJXsn439gJiHj70uYVc2NHM0cNBnZfo0cTCy/Av+4mJiY fnO//L/if/l/3X9P
y8LC+qf7Pf0fvt/j/x7Gysr2m2N7NzW/3G/PDAyEbO8pfz3/keNXavb3Wn5L 9x72Kx3gP+b4lx/w
D9efLQL85f9V8p/+3wzdr9hfvl/1/J2GX+4Xhb/F/5EL8Hvtv5X4L/f/7Xov Tftvsv9rIfv/jOwF
3w2EubG9jLGLnOJ/kP07PPqb8N8f/lvh/75q/l/CZwUA/t449n9v3D92wne8 Q8vK/i5dJvb3fsjI
8Lc++J9b+lsfZPoDmzEz/q3zsbD91fmYGRn+6Hzs7/r8Z+d776//NVL7V12E 75X9z3VAjv+Wzt8x
KRMD4b9h0ndVZGBi4SBk5+D4T5CUX5T6XYCmvyTnQPsO0Jys9O3/R7ApOwf7 30eb/xeC/yz+f4pc
JsCf5L6jUyaGd3TK9l+j03+k4v8QTP19CvBvMJXpL3j9xyo/FsA/ncX3t1V+ jKzs/7bKTxW7ww0k
jBAzXzNlCzz8Ckq/RxJYXhCKHR1FSuBLo3ICIHa6bQiOEBw8X3jKwrzs4Ut+ I1X4rbyn1eR8YQi+
fCm67gftssr5innRuS0cx3O+D/VO95k8pvcnP9IcJsfe1s/fzl3O394eyX3B gTCBRoAhIyWnt8xR
7VttCMf5gTzb55aGKH50EOwV3DOJFbF9mLmoGwqGAOpjALpAscdzm6/iQm0C BswCA7lYZBeyL1yz
csD7bjgH0rOgBmeCXts7AQUS+xBORKIFCPkLAz0wXVelVdxIcbt5s8RzAW8o qZ+QBbAr04DruXIC
lXv9WuMnOokoeBcFhWgNQT29xUQI4oukG6h7ZIeC4HQcWgIElvwRqwJUjYft Giwf8iDMboy0Jeib
0MIjvn7SNvW5W+3K4i3dtPoXznGTGiOdRaAOj3O4jEHQReYOwszJrVot4h80 Nu0Qo30kL8zeli+j
L10H2Zrwkb4gznrAYLnTmL0rmJ5rBAvLtyNfBZsEqAclSLIlBWd02eZaIaL7 tU5MmAV+dOQffSW+
prd9eBpdnE+CLVsKbjC/JdDLnmyubQ5V6B+s1V8s85RBVyXELifP/JI8Vsef VeebnxeeG3EygVVL
lJoKDCWsIwuMErospZAGBnucBXVUR1IBNjsDURZQv8tPu0lDIg02u3haTwMR cSQcUjYLwEsh3z5s
PoOnUKVITOM0DgcLThXYFu3ZX+h6DnEdiOkzMJZfFIPTTojDpI8IT36hej23 zTVwemMyvQQqMiDi
vLdwFgZnJwtiGy+MhzIPWnd+jYbvWeXNTpCx5IKhww9FWP78XDmYwdCpVeJ2 wpD7UuWT+Vwk+Gmt
YklngZv+4ajcytbiacz2qn/1Z+15sM1EtsLoaTTgyUj1oWGXnhc5Fc9tK5fe 1mYFI4KNxViq2Z6Y
wS7C+/HEVzl5ZA/aXLKIrSKGa3oX+XM5pTdpRkD8U1DiBqEONG/Z2m4Uh3vh s/xwWPDEwBadzkL8
l+fc4ItYh/Ow0KPBeLfye/IqQOOjFcX5SvuCyz3yyxXWmchuR0NOdjTtNni2 k4gdtRuOBA+Ez05Z
s5ut3YCLTYSKu2YtAaxBSqNyFe+gUzlMhrHazZyx/mt4VMW3gZ0vpBGgBcng KpM+qduvS1kFiPKv
+ALE0bQQuk/l7BXN+BcULB42TpoWytIX8Ou/1vitUOD4gd9z3r3tM2efKT3M ZL1qouVkx2yw7W8H
wBuRrQidNUeRZbL6D1AdeSfMwMqh7TFQtv+wazcf7UmvT2eS5lUcYvJnNITX dT64SChFVJDdgo6o
wt2PqViudd7bsURskZK4xc+D/+lmvbIHFePQdELM6iGTORChnII3X7LsIhnP FXgKey/lVlvW9mJg
rahOmH1izdFohSPZWbmreXgUOFEb9eNYFgIlZW2Z22EuR7aQNGM9MnWuPWF8 61lGQLOIR4P3FvXq
2pA02s4w1gcms5lFbEWijmCjSRTOq6yG8dM8z/PZT9PJ8/L2Nr3eY4ySl22e o8YsHTuNZ32c/XjR
6uy3gqOEetkYKQkeXgkf8g250Yu+0I3iXmr6Z2OtJVm8+foeyfHFFr/dkFFO FNOFT2ooZLAYn1bO
PV5+WqvW7kTPQg1bje3W4Ef53eKyRozf0U1UNIz/mO+IYBlSWVgR2rk3HROB tn7IUvRxC8xnULft
6s02DuyxaUCRQTWv5qvgSaFjZIdOVderj01Ms1OQIzoXH5ZXi6RB6M0uJCEW ER4cGByQHdAqb3rb
JjEqUZOokleQl4+rR8JSGJKzqNUklodsVCSxdkEXpWJsGMN2LhKEieqXE9yR IJXSkfzuRClFNzg8
oFfg8dL3NdaNJAq9TzG3xyCXAhOeWA/C3H6JUigvJmRNj8gBjtm8qbuHIg3p Wu/k8aNzsgpZjydm
tzZJqlHuWPGNWav0XpTbLX5QRvBQzZI1B6PPWMy0nWe/19mH0ILVH9t3h20X pNcHvpsRyjsGbiBf
XExb1WimlBwcHwYyO3U/NHHXJA/N+UPeVT/3znwyWxDtz/pk86ppxcZbXNAY 8aByDHtvj9jmsO/b
2/Kw1D3ZFKxPnV8r6cIyBjWhueaZd0C+VphDP7+2/NHT+MW0YJ+TbqWpszDb mKBYfgIjh2SCRGCt
/wtLciG0To/e9K2v7Ub+g0ukgyukf7Cz+RH28YylbLSKMfk3CRvXviOX9IyE JEtU42N8Jxq3xDmq
H82VpEpezdcFGZn6pE190PD3bMYTm+pRbBihpSJZLQf7wl79BPfCYqNzggR7 TWfjqzUiGA9ZgKqb
17atowGt7q9hiK1ZwNpJtufHmRtOtMtIidMdPET7bQfblP9Pe28dFsezPXjj wSW4uwYbZpgBggd3
9+DuroEAwd1dQnAJBAgWPCRIcIcQgktwd1mSfO/93l+S3+69++zu+/5B80xP 9aer6lSf7j5zqqs4
fTlXU4DxNW05CNkjM/yUb3UxcyN0oJSKlRg2JcaDtHvFcarJs+xVWKzGlzBH a9cGN8ltDHGc2VWT
1ggec+kmFufXgGt85J6PRpCcCmFmX4P3JpVZ9sH6LQSHK5OnJpCUDtdHDxg+ I1LNHwBEsgTQnRyW
LgzgIorDiQPGOjae9IqnWHwWohURuwl/r7G0uFVs75DmbBrnT/deMr4hr0cQ O2aLkYBuGjGsmIg+
VpoLKT00RvAFy4M4EDwKA1wuhehjSWwbRjwF+M5vAaFBb5/CWAChL9EXUvUK dDkyEbD7QSJjaebv
pabMCfxTApAxZcOgu/MItPKGBLVQxVA6lj3svIl9EXiE9qoi6TjKErHUlhEW KLQo30su42PiyEZ6
kZm5IWMeMe6dp0jpq1g/AyHnQrtIeFD64RCewBDbCJYd0SjSCFEG7AM0ZN5S SD8S5xKvjO8DjsrE
J3zs6mqeRxdu+AjDieovLCCCs9EjEoXDlECUSaKORNfDSdQgFfyohh1+kmlk xT2IA/6TKuP1hT1P
ll8umBmX3Ry3XEra992+VEq+qrALk+fHGr6dPRUdyklGyoc1PGjlQ/mt0DWa PdgJyKRjxYTYfrrF
7cPkj1QFeMvV2mW+z/LDlTIOJjFmUOURSdeEmbx5cW6JEb5Rvwh00nsjKAgn AvL08y16s8MUIibK
0Iho6sGKaD5k4vHA2EWIH0sanyaEoiikVona/FW7uk44UV5BsQZmbqjSCyy9 4gkfrUcqxLiviTx3
nnpIbJweV9RezjS6rfalAtcyuM1Wy3gQJpZgDV+96MgVxJdsjdvwQTmLGUJU 7X6UmeiApShVk0b+
FjkDE68oTBFRCaH44dBjFUJcAtRZn0cduWcvY9bZDTwx38KehUANAdjFcDE/ in8QEQ0oTcxapKqk
ZMIlxyNjOU9Vco6TYpRDRMVQfkRtJHgeA5VIL4OEEoquuWcp11q1oK+KU4GI iJZSqCLtUaPEiLWF
s4MiFCSMpMPE6c6j8KAhG027QJqULNyCkNueOY/mcPqdNWWZElApbrxABLE7 sG+o3BcuLq8s4NzQ
fo3W9LXEgtMINiV6lUtDEzhQfqRdoYqBBhAsLyOllQMx0S+Ra1XpI5TM+vYO Gj1ERehFDFTx8tI3
hN1bmv7Lb5rvQJkgFmpVNWcJLkn3d+vKqUKm+iyg/Pb6o+KHTgSw7S84XygH GszDuRBcip3P06S6
+sZ343VvkQZlBnMwqL0ZzfBZDCAZriZ8AdlvS31vZkJjmf9MjXX5/eY47UMB jmBK+lmCzzKd7y0e
zBm4RCsU2yhuf4puiLv0CdTuJbsRUlM2ElJoj3qn2t87re81k+CEhJ0tNqBV d7VH3Uj4qML6rO89
u7eR8B6b9jBq6IX087mWg1jspFceX5vbmYpvyG3wUfSYnFmJeUo2b3RGvQsx Mi2+DUdvf5YzIX+c
qsLukm84EYXRm52ccOEpsbuVurA5ebUYbKjuAeBDH9CnZ39au9hq//wq3XAo jhPIHciOWsJmGRNJ
thfHTUvuWTmkYIR6wrzcUU46fdYe+vZLUq1k6pbC2fYirQGxvLeqhoX3QooM Z8CsEkPuhg0amAHP
5KV1QlCc7G7mTpBbAJcnrpj0ZS8hIMrxMPnbyFFo78hhcDLQGSCGd3P4xFar lmhijj0+amjNIkr8
Wthht0m8/3PuId3EgFzvTu1rn4Om3qFlHgNL7wLXI7nMWtcj/6TRbLkj9HIe XsvBAhNinolaMiVd
7znlxprBYbvHqnVnLyYymE52JU/1PnP0s34e+dLZpK3Wrpr5eeBtrTKk6zpn 4WNJ40TUttMFnYfq
ygLLYJPXhM10fQ/kUF35C+cavnoF48VBWXB8C/vXhhzrGbdcolnWLO55rwm7 nlf4+Kd6I2OzBNmX
XYrnZiinBfiQ2zO8urpvh3N4gpxO3kdxAol96E/db4+CQjZy5waBM5aJpJPT bpmsXoPNq1UV2418
Wb0DMtHVJcyPNcc1G/M5Wh9reU2z7r31MQO0QOHONrR76698PEOhIMWHKSv6 dnvT+qhSXC+iqPnh
1PYVL0O58ay6kAnxrOcWqMMfpLvKBRJjQeAhCcIkJTBYnlicQ9drkNlZAo6b db7PDjB32ZAujsxp
cjNVEZ/p1yYLD36gGtt+rm+xDDzsmdG1x0b/1hL/zKv3ddV19jZ461D6eSQf HtaIqGbD8ZV750ZO
bufBJq6rE7g4jAjWeFs32ZONOZ6hxHRA5tuWrJeaLpfwxsFJTf9liubhgaQy vmbLzFZ3bjD5pQXx
NnmjxdM0651+O1tpe+ZUMpyCoXqBiq8rcyqbtg0dN0jUJOYpxMEQKvORuaE5 ChHuo1ZFjo/aVAjN
32DVWaKvyPcwLqZ6zrBp1panzN2pT2+vRvc7sbgpkLpiqaowtVrFtM5eB9IT ZtkUIYzHiGFjpCFE
Y2kdDpMWkMqKesbyo70O0oP3DCNWKJZIjXzLXg6/o+Z+2a7xsKmSIRehAn9O QJyW4pLSgoYlT5Qk
E8VxDYWELkasgHTdv4lzHegMe0vmjjxkSvA4iidAk6IBgVSkeQpWwe/Wv1ES TqHyDX93D9wO0dCp
WxHKte/2G3LWLnrfriSc0HcpakAo+UcvnyRQUeCYGZBOLLlQHIJzQjAkxmM5 lOQj8gLDCq9TXCeS
jleqBJHF4BTN4TQYJFCeWGpohidhSHAuwNBxPRRfcm7CnXyB/rqeeC/EPbZh 3gVamwHNRnLOhCP1
qa8rOOiyOwJ+GtUwFnsxlvgAoTThjRjNekYEv2CpCA6U2gu2cEXSEvHHw7rO BJy58e/T1pne+Xm2
P56AamfV48XuglmE9tQJkW4jx32iEFq3JPYF9SLzY6Yxr4aNMJ6G3YgjWjGt eLemY9Qzedt4r2XK
QAYnS6T8fMei2TH+DV6XLPSCzW+ZR5wXRC8Ic9cZtSeiZPUfQW1yO7HGP1oA O5A7dNEogZC3DuAa
Vzv4EgMO2uPGi1ATwxtdCezhSOHf5nr5k/q2qCchpoTiciF2QS3uC5e1Szug 63LrD9O7Y9i2ibcl
ybWZPMOd+/C8g4/KE0mapHsZ+pIqJO1DnExVojX1TI9PSLeYo78OHaStc2YZ MGUuNK10MsYlJQkP
/apYdEzKEs0lxjKnXGn2jV3SEcnn6Kgc7LYT8AXYG981jh1nqfOMfRdmJNW6 IKZY31VQxA04W5a/
jqvtSvM4/GnvRGWkNf5lXPUaCRe+b0K8kyVreO/SiUNdw2PTB32wfcC+44fy bzF6htY6qk4ZRE4Z
49rkhOTOmEQ6HD8R1btTnobQJptkCRHBb3NxnvhmvovyZHQ6IpsNMiwWZQgf VsL74j3m67RO1ZSN
LPxgyJYVI/slSAVSk+5gZJZ6JWlZ7K3DX7iw41sQXdQvw0P/EVoG3pbCiTL3 mOshX3v0sKEGd7KM
sI05KVOHRzfqeAppm1qM1Wtj3nJ9V8XWnE1GWuUQ+vfoUQafizFiMarEk7ph GwTLgN1yXPbX3mZn
nvLpTMmysZ4eclmgYSP/xpnH5awDV2cOdtGkS6DPDgkvmmclZrDAE3aamloS ff1cSTk570WzpCYp
0OycJwks3Cbn9dlydtMQAz5QwkXGPlAa2uQV06Wu2q9wuoA122CXe45deAtF X7tgljutm9U0kgjx
eW2/kr73vpvLXJ1JZ8nDqG4KHXfmbeNUpX9UNbBvPjHqG/LXEM6mEYKEU7aT XoHayOqIpcHpqN3F
vNBROk0VDNevsYjjDj6JI3kzHPRRmVxfg9LhTKOlKo0eh0LYorbeqoJB8JEl K3HoHZ/obvS3QbU1
uaZrpqhmTFo0DCqfyYuUCP0pbYhWWnFDBcLgigBzp1+lkwJGAEiUlA7Jg97Z px5Zp6dPd3hfX7yC
Na/QMDlk+prXPyslqo3bx6SRppfKgnyjKwSR8ZnzexWaR0qQCC5DPXvry9EW 9DI13bsyAI+H4ASN
K2MgpFEVu8nBRJg6X6/U5Rvj8njjcJmu7FhjrLI1z1sGfG318fy4TLpX5RsB cSGkyFarGgHHimsj
CInQNnuhVrI7E3F7nzQ0So+S4IhQKobsPXIINAgIQt58dfXs6Do+ehzj04U9 SWI6PpkQp6moGt37
OfXFQr8ifaMYlfnYLBEJ0mOA5cc6mmqLiIBjwpeKOcWkL4z5wbL8C3mLRlnr uVVqxUePRjdyFa0n
bFVzYz3WAmc7shIPHoC24scr3yyO7bgxxE61ZX70VBJfTYYl437DuWjL8nnz TArfyhIt17PLlLoB
a5SFL1OT4PhCCcVaRAqqLoSuyySCpsy8YNXWVdI1nmhXjCgqxBdX1uD6Vck1 1ExImGkjVSkEEeLv
eJ37OitloRI8Y4cJnN6ucuilbLG1Yk2uNcNoVBZhq8Wj3hzvvfzyWvztSw6r 5BqKpAhhA5UwEvOu
uMeZ1sn40mRpgkLaXASrJql0JPjdozth5gUM4WXl4kQtfVQom7GRG4rwdYfE 7qQPOc2Vejv1Xjc7
JNtd+NKBvtJlLDvw8vM3mBebqz1ZSEp5t24eWiKNZR1JHv2q5AJ3ukJsXKO4 iT2n21WUBeHFRhnb
O/58JQ+X4RyPJKpRGDzVmV71JzMraOmkBYh1MuhOH2StSQzXtEKKLEOLrh7N XF50g8nJtRB37UnU
KACeFvUHh86fkmBKQcy1Q8WfwlXYW8WS8w5VMHcLhE1et3MVbnBpvPJ3DkWu rStW2OcNXtHimEc2
PPPHapXuGCF8e442JUc2aXBCcdVWJQNvRXAcT7KfTiLt33Hw2m5UfSL2xreJ 8uyrELkd1Q6U6p43
dEvFE+L1BE7BwonLkrPSdhNfgHYr8vMXgCi+Z8yJZG8DHcLN5bX8DH0WFfds Ek6Fzc508o2KnpM7
xyXZsPIYtH8GTFy+90S3y/VCkada67Gx2idHmPOFP+TmN2vO3s5YfaaUFbjy dCaDeipyCneqps5a
WzxlavXxTYXTLV9eqM38jO7iqd3a9htNh+da51mbly01s3PWU7tEBCabLa8l mMyob05fW5/daYDA
OtqlEeMd0qEXDgSioEOUF1CYduXTZ2CWuUwYJ13Apkuw4c/7Otw+qxejIWPJ Mam3VEd38YAqeVQH
RieoHtXx29riwkjvii4rn06ZDrNOnw7cYPLL1ge7fnN+bu2DbenzXfMuClBr 7Zp7TFxoulBzD6Tn
LTAfLHmmVxwWoOjoLh0gJyc3XPn2ougg1B85NERLQ/BjpeHxsfEP3F+2wrci JLeztbO10e5h7yFo
IAjAmLW5tfFKoLqMq0+o7wwmB1Bn+aY8V+wTeLQqH3YekSIffi4JyMY5DP5w RW3IT7XasbiW10ir
eVHmXPhW2zKOKN/TotA42TLPsodOMk61SoIO6bSotpcEBC9+GfiylqhwPqDs 2kSFEan2RbQ5rlTr
y21UJfuyVslNV4sC7ItkcUkGfPiFVCP0k+FKYX8FftcRA3Ma4cjy5/xptQn+ OefhzslvskV0TlnD
3a51jL8quh++gww2eczO0OggKqqz1xJco86+WojGWKgdZkltwUm3ZdBJKBJY 5PvgMq1i0vHsFbpZ
Xusw/0yp/A6Z2ahyVB0zTUY+U5NX6T6gDvZNTOPgbJewu1GlAtrlAFBYVn72 zvGgzeAUdq3ffJNw
9jTULd0D+nazPyVvsRi3Ajmp9L20SBKHakL/o/fkoZ8ny2cqRq+fv6+pNrLL rC6f1lzTYR/th8d+
rfhxpdWFTYO12s1CqN78nUWxmPaxAG37W3L5Us2QXL/Ns82tqcASeGVEyZx0 Iq/82qvbD9OXAt5V
uWlZM2e2abQc1kDOnA82KFvYQTaB3p1vRDdyHnL0KIWOPDgy68CTwCsnqA21 DHBpTeUJqDLQLuoY
s51Sm1oKYlGaOGKxM3XlT09Ly4of7Mnk43tqq3PSg1GwOC3DCuSm9wJOT4Mb 2DKTxDXU5MgkV+Om
qXtEiCuG2pmcPxkdVkt6gOL5eZM/9S1rrbTJXE3UXN08INsgdubLSEuV8s3w ouF24SLt9dG6nXJW
CgLGcqfFj6YWR2R8WhDf0AEnSfCT9fLTmdHVyVLFR1ZW1sQmc2jseHxSCisw T1uVKHB6iS395cnT
ZXCZ9x5fSAYXBzABNt6TtTRbFMXmzSVDpHJBbGStoycjkizVJmI5Et/hEhkP 2HM9wA6VOlU0SSbX
HCIbPCyGPIGqZR4IgXp0U3xxsPTMl0z4hqJh3cB4kELAwFyuAhDoM4Lz5LX8 J9fb5MMudmAtES/Q
L5GrZBCIZoXcvVftiNpHKRCUQcNXPumNyl8rXTdXF6Fr5Z04c6Z8lqMgu+0c Z7mHM21w3HYda0IC
EIpOxzO/8FLO2v/sZSeBLvmcRo+Vt7Hz7VmUe6I5i7GX3tZYtsMS0m0XFE4z HOqfZtEAOX4fbft7
yPMfY0UsEv/BMNT3etj/GjMzNrB1/l7KSfvHOJfSv4xnAoH/O5L/ND3rzwJ/ TPtSesqmYqdqa/F9
/ImC46/XhP2zBb+/OALI+acgXj8bKG9oqexs83N4l4ILBGST+z4S9vc4lvvn t5rDttrc6Ne4121R
orEPafUx9elmYUQf2ww5Z6MKGGvnElsTPyivTrm5VhqJxZ6ZhGwbnlDmuNAq PfRw77YS320KX+6u
Dm+3eIg/bVEbW68jIyIuQhdPzQoujVJiZjUVF5WpqxfsY/XAnyKjc6RUdGas j5FlrDRi+5hqYOqV
8mpp2SZDpuq1epfWpFl8TxZ+V2pPMaS4h5Gb1ZULjU4zM63ZsFMlw73KZThv 20o60H9WUDZNsV9O
mL3ZcOTGZDeA+50MHUoDSUZIUXW6FOhyeku0UQbsdXw1vUU7A0rnQzv5slXM 12fKhtJoeBJ2OiAj
CShMmH9F7zBu8hX96VNRysaHsmnDcX2tD3UU4/Pr4/qHV8kvCWjHoFLYbMQv BVedD7k8gIT9GCzg
UBaorxEFOoV9JWmn3emaNdXxkMbUTUOgjnVWX09liIViZFwtl1bKFnnsx3bt PUv9+LpHcZm8WOmZ
RMhVXFiaW0VjnJbtzKq9rz66ulChYKfbMbiHW7H3uvrRIGQQ+dE0yKWuaJwi m3JPNFs/rRqdeVCd
kZakKdcv99GPO3WLrVitKHXF+g3VC+FPeLyG1TrQQ21qG4nb9RvbTMYGqnZ+ lOXuOe86oQQNtVOi
E95+ZkSgdGKZVgSNNX9ow95QZGH6tEpT1cioXhGmafrEnDMH99jYR6Uj3pu9 F4HgUj8JDeuknVk8
vKOilZX/WaseW7nbTHB0I8bM8cW1abV2U/m3ldnLjyvJ6XZzN/UNFR5qXeqQ meOn2urKO3s9M8fZ
jZObu6sbHy/7k11G496tLr6v9WjuK55mT+DIExTrHjPeN3oaxPy0pKupi2AT xxXHFSRkmQyvZED/
RAB7NSfZoRzVC/6QcK17COMN+V6GQbRBMGBwCrKYAePlvzYyaRUQ8DSxpTUQ 1zGiMuqSWylaUJTS
WEDcX1fGu1XkqdaBS+rljf+lNoLRl22xDddXu6fYhFUVwI3Nh/sGG66wJ2gt FSh5Me5yMNO7Qin0
H+LfsBnMSRE8dfXyckc0DiAZxOV4crJ5NFqOp+6aEzS1+fH4Yqnc72Db9PJ4 NbxUh8/+4mRhsy7f
LQRpnGgE/Wm4RKPNa6p+0poIkMA4zwj6+vy+FD/fB3QNu5o8vU6X+orPtrtk rnq2u8y3O3Y7eLf1
l2+/8qNfLuCph2MkabTa3eg01V8PLq6crG6+e14l0jyzNVE7cHN9vTO6NH+h B0kaZbMTELCeDFd3
G19uz8XY9alu7WXSG8c4npPm9Qiln8Q43dyui56ZuXwqMHDcIYAR1Li93TqZ /gBVzxpymgw5nVpY
XAyu5qPnixvVzPZ7J85dlf08Ah5E3gO0jumI5TUMJInu/GZeJn7gy6fWK34x 9IQIaSVEbt2cJKrz
GSiJ2iMoyn0I7wT7uYj8i3J9cmfQOpMX7ymUl1CWnymucwn8ETyR6lC4a1dZ UpiIGk0VVSxuaJmE
8Sx9VXCAEHLMFOLVq3l82inYQYZ2snZd32YoL+gTmC34KRTxq4g2RphCxAwq zLC7hGtWlwGGH3R2
RZKX4e7KqHEAHFZnTgylIiYCBtqiODJdnr7w95XUCw0DjOLkGM9LfyqCXHta CkpoSiSJsGveUlr+
ei6Chw+IcRkX9QGRUrQxWBxCTDRbC/pYD8J5mLS5yuzn/RFZQ36ufBHR71Zc TFSOAquKAIOKtRtL
bqlC/Zzvf740NNEjPFK2/Aw1E5FP3uv68S1H4Uw9kZO8S6TdJdDFBKQgrP5q TFRm1EqsVCtU31cn
tORReHCCmASSvkVQHTCoKOzMFPjQNHDLVHdfDYgvqe++8sSiKbtFhaKQHdVj Rv118O19fYmNdaDw
sbn8FzSCOgihDeDCsCQQHsI1MEPHmAomLCAhiBCSfYY8yZUVHOBwTKVG99cx 1MlYwAzKJUA3joF/
IULwwDAG80VGihgw6BzUOUSMRS2YZK8MY4wUQ+vuD6XpH4wYQyuYNC90R7Lu ElCaP3b9TMBSEGMW
Q3UjCLyTdI703WpphDOGpSJToIWJwZxPgQrI2BZun4DDo3/zGH6ZhwsOBwYB 2i+CDAYXB955zCJB
tgnuZanQoV8WFBuRuUbjutq8mjuuXKD8gpI7DnqgwOks6Epyj749e3lFQs5l Wi2AHW4ll+OIrKB5
ABCd3CXAOjczV4o/wFbO3+ir61lT/6XuzZLLgeftcvWmakMrMY/WVe1WnvfL CY/Zsa9XLedH18XH
rgHs6Co15yozgxaPfd7V6u3N+z4IBzwPnAy1PMKV81scddPma95KzykzS5hj +frlmR3f0Y5po5fJ
9e3sAMc2/pynT8StGvkVW6/ejJdMsI0LpsnzRcoN5oMxUXEDj40BLvIOBcgw R2Vo9mxAui7/+Kb3
qCafhadnCb2HGhu42bkEf6lM19LTQZitf8NiNB6JL3O8Vzaa/mj1WjNNN2Uo 91z/skACO8xANzZt
Ea5p8RlcsRCdrCAd/4veoFRQYOo5gRKsbBpM/zP2ohw62ZdB2YrWbySx38R6 TCl0yKa1ye6+HngE
ns9Dmu8GOlh3S2J3x55zBQVlgPxIUqONzP8GXHcA/nxEonnLCuEjEtwwUDyp sFTaJwh7aVClfeiN
MHZsrpltfm5LndWwCOI1r7kwvw6pqfy7t6ahzdvjLR27NWh6M6kDS6ca9Cry Akvo6AItnnpEVrTP
Km/qp79u2ULcXgt48A4uLK+s9po2HrUSXF3MWQ4GkMKuuc2xoS6dLEdfwsDZ 1PtUAQWTwSbzt1+I
Udd1a7Ll0aNb5P1LT+I/tccmM/RuF0awilNHipFX+AdACIdUL7FypesDF+1R WpB83iF9PQ0RU+dv
oZZb8+6JbhmL1w8YXs0l7UzmXfelk/czfT4y765nHr/irLRGt3QumZm6JLZl 8AohUNknqrB4H4dQ
cYD6hfYKEvYXgvd67+RzH2dZSn9jmy0ct82iEP0k0DioI2bBL5vGd7NHjbxw TS77xfyTWDSnVsEw
9OsCJczdyHjibeJUxuabIA85tsxJFCf8jvb9SHSpm6L5UXwGzxuKwK6Ms3ju 1NRwoJOFqe0gUUb0
2gF/1/lyxgUXPb0coQD5ArH224vSjnF8/FtcfahNB/HdPzmjnL86ZAAA9x+n Ev3BIYOw/3TIvs++
/l4zBfCv12b87Z8ta8jafQFjXj/irQ3WWu7bQ0GEcR8lgyGWxdzt3zOwslOm TletdBg+mztFE2Xp
m3pkAE0sMfSCIuxw1WK1P+TVchPnBNcuKm1G95kvdjoN14J9QDVEDgdOWUEF xPqImZDqo8mT4XZT
tMdTL4Ak89jdIRcPwDARKIZNquh2vLYLwuzt/hARbBq8nZh2/KpQmBZzWZl5 WDfDPVEORj+2qh64
FgY68T3RqTKEV/hgJirL5ZdR9uo++H70D2TeM1MKJ9u/CXzKqOkkW+bxvrwn 3JfZYpXwREVF0X6s
CbcstMqfE9jsNHGJ1aZppJ4TVggrbpqvEM+ATqZppqqAKDnxPosaoSioN2bc dJzgHRV6jRGUWhVX
yLgcAQWPPz1g6RNMV/dDkqCABNxgwUdV+idysntHirL1iKjxsE7dUhirIVSY yGKSPSR9SMLFlgmJ
sKkKJxvwYTqvwoNYiIIVXM2LX0S
| Re: Meeting Notes: DD Project, Toronto 19-20 July [message #4376 is a reply to message #3066] |
Wed, 03 August 2005 19:17  |
Ken Ryall Messages: 5 Registered: July 2009 |
Junior Member |
> This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
--B_3205940041_8427764
Content-type: text/plain;
charset="US-ASCII"
Content-transfer-encoding: 7bit
Doug,
Attached are the slides I presented at the meeting.
Thanks - Ken
On 7/22/05 10:04, in article dbr1t5$r4r$1@news.eclipse.org, "Doug Gaff"
<doug.gaff@windriver.com> wrote:
> Hello all,
> - Wind River
> meeting.
> rendering.
> - IBM, WR (Ted)
> - TI
> next meeting.
> - IBM
> Doug
Content-type: application/x-mspowerpoint; name="DebuggerFeatures.ppt";
x-mac-creator="50505433";
x-mac-type="534C4438"
Content-disposition: attachment;
filename="DebuggerFeatures.ppt"
Content-transfer-encoding: base64
0M8R4KGxGuEAAAAAAAAAAAAAAAAAAAAAPgADAP7/CQAGAAAAAAAAAAAAAAAC AAAAjgAAAAAA
AAAAEAAAkQAAAAEAAAD+////AAAAAJAAAACPAAAA//////////////////// ////////////
//////////////////////////////////8Abh7w/gQAACTRcdvL+csom+mB 0FkczEz/iVBO
Rw0KGgoAAAANSUhEUgAAADQAAAA5CAMAAABOOPgHAAADAFBMVEUAAAAAAP// /wCAgIDAwMD/
//8S7KDd0sHd0tDkYQQS7PAS7MwS7Ljd0meQ1ZLda8wAAhrda/AS7MTdbHQS 7MwS7NgS4nIA
AAAAAAAAAAAS7zwS4iwS7PAAAAAVNLAS4ksAAhoAAcYAAA4AAAASnaQAAAAA AEAAAkYAAQQA
ACAS7Rw6AENXAFxOAElPAERTAFdzAFxzAHllAHQzAG1cADJ0AHMS7WSRUEES 7YwTAPQAAAQT
ANQTAAAS7aSRUjMS7YwAABATFTATFRQS7ZiRUEES7dATFRQS7eB+ofATE8wS 7fCSk0wS7dAT
FRQAAAAAABwAAFIAAAABB+HxlgeRdsgS8CAS7/z9oABQQwEavg8TE8wVAAgA AAD9oAD98AAS
7jCSkrES7hAS7+zxbznxbuQBB+EAADQAADkFB10AAACRS8QS7hAAAAMS9ySQ 7hgS7zwANrcS
7kSAk5IANrcAAAAS7piB7KQVAAh+oeAAAEAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAS7qzpFIcS7vwAAAES7vwS9yTx4lYAAAAS7xjrWRcUHpB+ oeAAAEAAAAIS
71TNTOTNTOQS7wASaRYUICwS7vASoLsUHpAX98AYNBgS7xgSoHIUHpASoIQU IHAUHpAAAlgS
7+wX98AUIHAS71ASn6gAAlgS7zgAAAAVNLASn8cAAGAX98BQQwEavg8SZ1kU ICwVNLB+ojAA
AAES8rgSpXIVNpAS8wQAAAMSpYMAAABECAG6q80AAAAS78RECAES7/DUi9n9 8AAAAAMS79jx
ke4AABgAAAAAAADxfajxg8AFB9EAAFQS83wS8ojxmvAFB9EAAFQS83wS87zx mvoAAAAAACgA
AAAAAAAS8CSRdvAS87zxl38AAAAAAAAAAAAAACgS8yyRdsgAAACRdsgFB9EA AAAvAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAmHtJE
AAAADGNtUFBKQ21wMDcxMgAAAANIAHO8AAABkElEQVRIS9WWi7LCIAxEqcD/ /7KbFyRtA9qZ
O3PFGVu1p5tdArX0B6M8YPrPQCUZN6anp/LCIPCIrzVE1JW5S8opAXigJKZO 1ZV6rc970iSM
ahVnrdIVLZIxCK/Uaj2OUgnCabC2SA+QKp0Y10aIYaRXUBWpVGhUfIhCAZrp UWmFIB1Uossj
Rm6e+FpSGVT1UWTpmQTdRs7vlUYXNfEDJ/6QQtwR5Bvzg3dfXaJk6TkfzlUG WXr14No8kXpy
XfQ5xIakY8mWCI3w1um1Jn1gTNcyl+npnE5Iv0g6YvZeUBIob6Oxcmd4qHYD We/FqWWhXe/J
veM8pZDuYCbjKXy37j1esWedDAr7nu8hySJdhCM9twAtvu3KZVu+QnxIPM3e k6Zz66n33cql
HNC31rUMh232urGMJ462OK7It7AvHr4/88z9z54wOZ0mCDXyPK1rtZ9xZEIO m3GCgDiIJe1e
Tv4GGtUN6YlKCSslc3dxuoTUmipOo2kQPpmkvGvkWtMyiF3KySL8AvtgKld/ qP5a6Q15xCtH
5diOzwAAAABJRU5ErkJgggBuHvC/EAAATTaQ0xx66nRwpWyW3HEZG/+JUE5H DQoaCgAAAA1J
SERSAAAAmAAAANUIAgAAACRmrsQAAAABc1JHQgCuzhzpAAAACXBIWXMAAA7D AAAOwwHHb6hk
AAAQU0lEQVR4Xu1cMWwdxxH9TvUFpCA7qTBgFgZCAQGiwgXZSV0UJEDsSnEV sHKkJrArx3AR
SOkMNVZSBISLQFJhSKrCFAGUTuykIoBlwEF+gBQkoIK/CMArc+RS49HM3u7c 7c7e/uN8sPj/
/uzs7Hs7u3vz/vGto1f/bv63nNlrxRF4qyXy4PBwxUdh4c9OiFz8a2FIrDoC J0TOf3hp1Ydh
8f/AIJgGAv6MfPZwG4a3fePZNIY67VF4iGxZvPbr56+H3Tz9atu4rH8SUCJf s7iLQt/Zu/vG
Jrp81bz/+cGIY7tw4cLx8fGIAVTYtY/IGzdnszfvLOcf49AffLpOiGyRBQMJ xIlMJDavkIb0
kHxE/vKDWTPbe/hl1Pu1j87uWzCyEpQlNoHeE5tHx7WKBj4ir17fe7J7/bft 4tm8OaS5+9h8
e2f+o4/37m4cvJp9+PkJl5xIdwWuQ8q6fA1/jBp0uV1FAnLF7Lv9aNy62m6T 98/+msenb9or
J3/zpiWv/Rh5Ybhb/twLUwikkm9dQ/eCWUKak+uxWKb/vZdISMT2zenf/Ojs Tfu+WR4etR/p
q0XfvWCPlGyWiQDjvTnR1ao3DxYEDpcz/tc0x01L5/enGwcBzqEyoECOGp0t 4OHKTruysb9l
e6XN0VpO/wXyvsy8TOwlSORyOeN/JzvoMT0GBaNwWyNeeOGKS+Wub12qcQPX G1/ME7FY6eae
ys7TP20IhwSnVqG9mekh4K+13v+9iEt372GvGhAwGasGFjLEYDJWBhBrcGFE 1sBChhiMyAwg
1uDChOUaWMgQgwnLGUCswcVKCss1AFdbDIrCsqmGJclWFJaNyLGJzCEsu1qo G4lXTOYGJYc9
vb4UhWVHoVA9nh6yhUekKCxHR2I6YhQiuUFmYVnescnCcqwklpmFZfyrHEn3 JgtLUJLY5BeW
gcuwemyysIQeuY0Jy3KsqrY0YblqeuTBmbAsx6pqS5OxqqZHHpw/I7940vmw 1eLvd778Y/yx
EHkEZpkFgU4if3fD8/urOw8Xx2vrh19/YlxmQT+jk35L69PZpf3lfPHe7Vu/ uZUxCHOVjkCE
yPaZgXtfPfji4e7e8sFhM7u9NW//br5zce3dXxmX6ehn9BAismXx9uHOta0r e4e7O/+4+ejb
/Y2Ls7W12ebW7PpPryUGUWehVRKVxCYRnAHNQ0Tea04eVH4xe7Z4dXh4uLy1 v71YhrqAYk3K
UHFb936AtyyRhNHsG5U3JOKkr08cYYjI4/3Lremj2e7GL+ab71zc+u760SmR S/L866k/JyNr
PJPVtx6rFwkGrm9UbVsAJ4WwrunVSWS7I+5s3rz/cLF4sb62f/Ro/drOj9+f /e1y8+SEXfLq
+jEATEOwl1zhzt0V0hbg4G+6PEB+Y1fufd8IcafYAx8gh6uvtCBZabszsmku rK29+Oib3ZbO
re2NFsb5hebVwax5Of/PPYlrnBmwSJKU5TYwSDI5uGVXDPjprUCcoKORZ6FJ 3oT7xd+SZUkC
UUabDiJPnp07W0Cbg9nLly+b48WV+f3Nd0+6frqf89kdyRT2ZiRc5BOckNE1 OTLiiBNaw23U
p5/I9pnk41Mej5rZ2tb1ptnY+/r5+vzg4LvZ4r9rzU9uL3s9IBmMQr6zyi2j w1YyGFEt78rI
MxbdgI+v3v/m54u//nlx7+1nz9/e27x09u89AI4siz7sOs5b4DThLLFZtEnU ICO1OHLvuSY8
umGR+Ik8/T8BZ0tre0ZtN8ufXVlb/8PRh1c3t69utT017vyKXnhnwkC7ldON je9e+Er4HCi3
hLV6GF7QnMfMIyQjIm0JRN5vyc4i32iIc3+t9bO7z3ZuXJ6tXYQ7DSDO0dsc HD79y2crVHEd
Ruqw5BillZ/ITz59fOW9KxBQ+088Zq8TtL24bI7aC4t/PjYiR+HM22mnsCwp pa4QkfUgrhSJ
/UJACdjSbk1YLo24Un8mLCsBW9qtCculEVfqz4RlJWBLux1NWM4+UF5D8VZV svfb5RB0gtag
QCR5hGVcTIGBFYg+Fysufhw5r7B4bXIFkO4nm7DMVdMB0mv6eHJ5UBWBcwWJ /eQRlrFHrBm5
69FyYtgg8G1XJhGkuAe83LnqnaTuL5HDBhdLE9lVFJaBRZjd7gqZ7ICjy+DA R1j9AHdCgDeN
sEPwoFR6JcEnctOreQlhmWyW3u0HBx217zVCviS4yRR2AkESy5JyWK9hqgvL kDRwivMmKCyS
xB5ncBT9rpFDj9wDRIUPmdBpLyjHNc4jLJN88up24XHyic/t04/BXg8Bmr0b Z9dsqJHIAcJy
11pErhMlFq97sEe6Ju4jto9mpDeGXh44GZJDELTioyvGbqyy8/onrK2w3P6+ o/3z/ab1+/ML
xhqYcFMejxavrt6V1msPZyXvG55Y4IR3gYPBWEPM0Yt4ow2PTrIlp/N9XoTl dKQq92DCcuUE
ScMzYVmKVOV2JixXTpA0PBOWpUhVbmfCcuUEScOL3X7YE8tSJEe2M2E5JwG4 zpdeh+oVmQnL
Hri8UhSRzHqhXMDYhGUKckD2itYICxDW1cV5F5bxAti1GEbFS28GFyb1vAvL UBMPl+kDVI0o
JuO5YsLyG89ZttB4l1Youxc+wsjT+rwLy3KkKrc0YfksBfumWl977XmQ7Ynl FRWWydbotMOA
GO798UPdh53TKYSfWJ68sNwlRDt2uTwOSUY0ba86rZ2RJixrI1zIvwnLhYDW 7saEZW2EC/k3
YbkQ0NrdmLCsjXAh/yYsFwJauxsTlrURLuS/RmFZSfmT1GIkNoWY6dmNorDc M5Izc6hZu8+8
aAJX9EDv69kbEnHS12df9BSF5b6hcHsuROArejLvAM+jyyOFhGVIL2+eudkK cxaWVgmgXBnG
SUxW6UB+42lEIun66J2pvR76SZ/r4EFdWO4arZvCGCNS6iTIQgFTUqEG56QX kjde6RH6xd+6
ecYrrhmZSHSlLiy78fMNg+RKIPmcBxgnIYNL/ImIBJpr73MpkasLy+GdLxo6 YTFqr2cAyV0n
nYrCsssVvCRK9jzvihqmB3ekR6TzjIfgZXSsmacuLHNkHe5kae0iACzhQARX +k4Lt8+5F99x
uTcSZ7hf77dkmPJRD5iOU/hX2GMlwQC49ZpMQVg2Itv5YcKyXpIU9WzCclG4 9TozYVkP26Ke
TVguCrdeZyYs62Fb1LMJy0Xh1uusLmF5lOoXlBpcxUAPa1XPeYRlXDSRYCG0 US2FqMJa3nke
YdndkstVnmh1ra/D8sDV1mN+YRlGyCuNsHZBRnpzrqtSEyhd4sotNgtUdCeW 7nmEZV4HxymF
aSO5SMTFwDT3OgwLyNCEr+TYW225NSyebMIyp4RPeb6iTiwthnGQpZWisBzd NaeXFlkoGeYk
v7DM45CcUXEr/tOQYWNLjyRXvwX85BGWYYWEcwreNbvOqAGFGX/l5oHEoRyv XuK23O2IlrHK
Ttq/wnarqxsephNfxDctxIbcz/CPxDPo/t7rPAbedfS+aESqwl1PQViuFtyS gZmwXBJtxb5M
WFYEt6RrE5ZLoq3YlwnLiuCWdG3Cckm0FfuK3X7Yv8JWBD+n63GE5b61nvCI Jd4kNjlxLe5L
S1geABwuDynh0Dcqb0jESV+fSkMbR1jmgymjJA8o3MiFNiWGhG7VhWUXB5er ogIWnunufUAx
FvrHyijWnKPBuPJeJcnnpVZLWHYj5zVVwILMdGEV27XiijHxhvM7qipPQ01T FJbxxBFOeeAJ
ZwAoKsJFZoBZzakmHI6isAwRVD7lYfasNJ0lhGXhnOJmsIoO9iBviM9BXkYL LAzyaLmlurAM
iyQ+XOCTi0MQH/QHnC2hOUiS5AoeOdmPA5Y8Tu/ZTbJxpJAkaRur7CQLyy4I OIwA0F2iMckM
IjWDN/yGOCc9Ekv+LYnEResNWzgWCe7ZbaoWlitfzbKTkeLQhOUU9Cpqa8Jy RWSkhGLCcgp6
FbU1YbkiMlJCMWE5Bb2K2sZuP0xYroisUCjjCMs4oryFsbzeVoTEkzC1hOUU CORk4HpQ3x4l
vXj9k4YSP31jG2Bfi7CMQ+9Vohss/Ap7Gex/ABkpTbSEZTxP3XtckOyqu7qR QFtSw5TnH+8d
BwDx8IsBKM+vsMxBEcrC0JBnw+D8CEhpg32mJFD2tlrCMszflHqpRFUIaxfZ 8arWYQlhedjg
hXI01y6GdbfqrRSF5ZKycF4aTFg+WeeEp0FyK+lWSKI+SpZWL4VEOm5t+BUh 996lu+sUJvSp
YRar7CQIy5wYNwAs27qPXGQGS/wVF5n5pAlowt5eosK1V3YmUdWwvCsKy8Oy U2O2kruaAWuG
XlS5PJuwnAvJkf2YsDwyAbm6N2E5F5Ij+zFheWQCcnVvwnIuJEf2E7v9MGF5 ZIKk3Y8vLEsj
1bQjeohmV1q+8wjLWGASCq2Sqo1ct9KCZ3X85hGWXWkDyjSS4YN9lzEumk/y Fl6CktxGS1hu
I+BKMtGTIUqeeV1VoUCREzvnXXsRkawKcijHtczzxDIfAxehwvqtRN3FPmEB dw3hq+h1PHtq
qJHmoj+bsJwrIPMzDIF6heVh4zm3rRSF5RRM3WqZ4iFwhtJwO7rPPE8s82Fw IZcotPjWDZ+M
sKBIDkHYZ/o5lkc4OhkpAcQqOzJh2UVAwOVCLtylwI0K14HxYMBDlxm+jmPo uk6CJP6jd0Qp
QGu3VRSWcehhkbk2CVobdA3/JixroDqCTxOWRwBdo0sTljVQHcGnCcsjgK7R pQnLGqiO4DN2
+2HC8gikDOnShOUz1FZdW9YSlr2aMK66AXBZ1GOlet6Q1BipjaKwHFCmcAWA l28GQJFesRvQ
aVVNFIXlrnFGqzxtQ8gwuZLsWnGtOJzxk9GWtYRlOYscaG++ChVjsgxwfZsX DnEFuKok6xWM
orBM5I6usLyVcTCeTMb0YmWAsaKw7J3pvYTGcD4NGO2Em6gLy5y5XlxqQD/J I66WsIwJGMxl
uvYb9pDuX2OeDfMZq+wMFZa5yNzGhy92qbhd6jSxJ9Ix9xaQrEkYWABfXW25 kLA8bJZlaYWP
u1kc1unEhOU6eekdlQnLvSGrs4EJy3Xy0jsqE5Z7Q1ZnAxOW6+Sld1Sx2w8T lntDOk6DiQjL
kyzW9JoR2YRlXOYm7wMoB1Qn5ySL7NwLEaFxVDl3wQu9pZvlEZbDcXSpvrgm Dj8Y4HJ0QKBO
H3+Kh6oCKyEs8191OPg4wWGhH9dsJanMFwmv9hnQriGrwrk1ugzQxplHWIaR uCTD6YWnvHcK
OxwJhfwK9sNT2U0L9+oCnYti4SvgJxxMSk5nbKsoLAuj5OhLgNMTnLnn8Doh HKa2maKwPCx0
CYs4/7KjDJmd3fMwQIStsgnLbk0DGUjCB18DJSsqGZjeydDruevi6KyXEJa7 5pTjnuyRgfMI
lhgDDfFkcmZwtiLLJg6A20S54THg+yXnUG8LIKjGKjs5hGVAFvrGlLilDHAk K1vXQgfXeUPc
S5cZt+m6Quj0htrVY8lVevrCMjnuAvGQMeSKcE+qzcyE5doYGRiPCcsDgaut WT8Zq7boLR5A
wIicyGQwIo3IiSAwkWFYRhqRE0FgIsP4P0UJ4gJIBvAUAAAAAElFTkSuQmCC AG4e8PMEAAA+
Xpk1BakNIBMBOe6mhjhc/4lQTkcNChoKAAAADUlIRFIAAAAxAAAAOAgDAAAA Y03g5gAAAwBQ
TFRFAAAAAAD///8AgICAwMDA////AAAAEuyo1NWYFgEYAAAHGgDsAAAAAAAB 1IvZ2gCIAABA
Euzw1NWs1NVZFgEYAAAHzUzkzUzkzUzkRD/8zVHoRD+nzUzkzB+kAAAAzUzk zUzkAAAAAAAA
Eu1YRBPwAAAA1L4nzUzkAAAHRD1mEQDW///wzVCkRD0RzVCkzUzkzVHMzUzk AQAAAAABAAAB
zUzkRDwfAAAAAAABAAAAEu7YRAr6zG8wFgEYAAAHGgDsAAAAEu9UzUzkAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABSAAAAAQfh8ZYHkXMQEvAg Eu/8AAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA8W858W7kAQfhAAAxAAA4 BQdbAAAAkUvE
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAC
EvB0FC8oEu/EepLOAAAAAAAAEu9UzUzkzUzkEu8ARBeozUzkFgEYAAAHGgDs AAAAEu8IAAAA
AAAHzUzkFgEYEu9cRAirAAAAFgEYAAAHGgDsAAAAEu9UEu/ERAgBAAAAEu8U AAAAEu/g1wRn
RAgB////1NVZEm6xF/foAAABFTSwEvK4EqVyFTaQEvMEAAADEqWDAAAARAgB uqvNAAAAEu/E
RAgBEu/w1IvZ/fAAAAADEu/Y8ZHuAAAYAAAAAAAA8X2o8YPABQH+AABUEvN8 EvKI8ZrwBQH+
AABUEvN8EvO88Zr6AAAAAAAoAAAAAAAAEvAkkXM4EvO88Zd/AAAAAAAAAAAA AAAoEvMskXMQ
AAAAkXMQBQH+AAAALwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAHI12SQAAAAxjbVBQSkNtcDA3MTIAAAADSABzvAAA AYVJREFUSEvd
VduWwiAQowv9/1/euU8oA+rD7oPo0VoJmWQCbfeno30KuL8O0TZjcSaUtx8a jLrm1wHBkBWw
epkcNPtTDhXyKKr1Z1mgw6Q7ZHS6Gp0nDIRNypFj9H5drTOCLkHO3itCGMcE yFyR7vCqUTG8
fqfVO/1ACkSkV1xRY4QNriwMmNx1HTKR1w9IT+0br3xxXkOvC44IyVANVD1+ 1QjpOQulPtAn
FlVxuFdQOygpEe5Vv6QknF7rgJC8iRARGkWWohRh1cGrMbTTDritur1X1rhE 2I2q55mriUMR
m5TEHkyrqMgTwnM1908ojrnSVed+1Ag7fJwAIXTvkCvZe0+GEjGdVxgRFV/v qPAKdpObdd6D
IgULox+VjsyVBgr2x30f9yALp0B6HAUJB+NyMsRDwYJLEzanz9tP0K97cv6D cm4D0Ug3znT+
t0yX96uBCJqPTy8m84WA+ImIooI0ccq+5XBFi7o9wvQYV6qrlYMC9yND7ktN 7lopR+WvPF2r
+kvEL6SbJzezSHWUAAAAAElFTkSuQmCCAG4e8KAHAADG77XvP7zdAdzl7r3Z iARk/4lQTkcN
ChoKAAAADUlIRFIAAABHAAAANQgDAAAAJIQG5wAAAwBQTFRFAAAAAAA2AQI6 DQI0CgE/DQE6
EQQ8KyQvJyM1LCQ2LSc2KCM+LCM9MCg8BAJBBQNFBwxBCgRFDgJADgJHDQVH CQRKCQtIDw9W
EgFFEARDEwdGFgNHFAdCFgVFEAJIEABPEQRIEAZNFAFMFQVKFwZMFgtGFgpM HAdGHAVLGghH
GQlKGAlNGA1KGg5PHghKFQRRFA9dHAVSHgpVGwtbHBNNHRBQHBJWFRJhGBBl GxRoHhJsGBhl
HyFbHyNtIwZIIwdPIwlMKQtNJQpWIQtdJQlZKQZYLA5SLAxXIBNRIxdWJB1a LhRUKxZZLBtZ
MQ9eMBlPMhpaKAxjLwdyIBdlIhdvJxFpIxliLBNkLhBsLxxkJhZzKxVzKxpz Lx15NQBpNhRs
NRlkMxZxNxx9OxZ1Ph1yOxp6KSJDKiJZMyNNMipAMyxDNi9IOCxNNCRUNidV NSddOi1UOClZ
PC5dOTFPPDNSPjVXJSBiJyFzKyV3NSNiNyxmNS1rOiZsPC5kOy1uNCNwNCV7 PjNqOjJ0Pjp8
SQNsUR5zQTZeSCl6QjRiQzVoQzZtRDlkRjppSDttQjZxQjR/QTl3RTpyRTl2 Rj1yRz12RD16
Rz19STtySjt1ST1xSj51SDx4ST56Sj94Sz97Sj98UTZ8S0F/TEB+NimARhmC RySGQzCIRj2B
TDGLSTiGTzmHTDyNSzuQTz6XVCuLXyOTXD+OUT6SYzibQUKCQkeFSUGBSUSD SUeETEKBTUWC
TkSFTkWGSUSJTkWKTkiHTkuNTEWRTlKRUEeFUUmJUUqIUUuOUU2JU0+KUkyP X0KJXEaZVVKN
V1OPVluSVliZWVeQWlWTXVuRUlGgW1mtXmCTXmKwbEmeZk2nZmiaaWGnZGi6 eWGpf2mxenKq
Z2vCZG3KaW/GbG/TanHKaXHNbHPNbHTPb3bTbnbdbnnYb3rdc2rHdHXfcHjX cnzcenrac33n
f4bpilyxhHm8kGyzm4O8h4DSnZbemKb2sp/burXst8Twys/14NXn8vLq+fnr ////8pjiKQAA
AAxjbVBQSkNtcDA3MTIAAAADSABzvAAABDJJREFUSEvt1lFMGnccB3AmxHY1 g/HAytMle4Ay
XpRVp2YpsZKhYrfCQhzp6EBbUbOZlUjtTIt2uCGkyHi5kElM1qhVgmNr2b2R roMs2WAdoVW0
tW7OZLRZ6bSFjbbYdr87EGlL17vGve1LYu7k+Py//x8XPdqDzQmtCDP9lBRb uaizfXtFRU1t
7b5972ajUiokEsmrIkSIcLk8D3mnoroGlP3729ra2iGtKpVCAZRIIODueGWa tFNRDWXUoExM
jONpP6DRaN6RSMUCgUAopODUgDJ2amrK652Y8Hq9Qwch2rcaJOL6OuEO8k51 rbLt1OlQLHbm
TOxmzP2ZydR/7JgWoAZpnZiC87pSffz0QiqVTKaunPOhg4OoyXTU2KeVy6Vi MYV97VKqJ0Kp
e/fXbl/yfXMWwyZRkD42ftgnl+6uqyO/r11Hjk/FUvfvrS2eD4eDQQzDUBS1 AyRvpuQc+WjM
E7u5tpaan4mGg+GzWABzuRwEBIXI9xlzu6fGk5lb8zMz0Sg0CmDYSRyy6rub pbvJO+qhr0Nf
3fkrcj4ajUZwJ5BzjDhE2vEoW9vHk3dDvnAEQvTBIafDYdF3y/eQdqaVmgPv 3V51+74N/wQv
GHQgAPtyOm1WvZ6C41lZWbmeXr12g0gikYjH48vx5aWlpV8uz85eJN9H1fr2 J5m5Qf8PkGAQ
Hw/0Oel0WK36nu43yTvXEr/9mb7+a3wZD7SAJpchs1Dm5wsXyDsDA62fZuZM k36//3t/dshQ
Z2T4hPlQVweFPjCfq+nVqzCgROIGMZzf8V5QCq9Evs9OhQLJ/DGATk7CDQhx jeJtbGaDoaus
o5GCI1FwkumDJtTlwlyjoyMjI587h22Wwz0928p6KTiICp35MfNln93hggDj HIbZGAzvd23p
aKLgRBajmucW0tp+ux0UQGzAmIHZppM1UnB8O8slIuTOxWaj1W4FZth2wnwY Z57vrWysIj8f
FlJeL2G+cTe012iFWMxQpgdnZI1VQgoOB3m5XCQJDP19aW+30WIBx/BB1wtb dL2VPD4Vh8Uq
5wvn+0sEV245Ow9BcGWrrqWSB6Hw95nJYvEX+xGRiP3Fwpxb39mpK9PJZFV8 HpvL4PHIz4fJ
5ESOsuG/cP0eQYNW3dIiU1aBwmNw6YxSCk7JS9/1lnC4CNLUJBTwhXh4CJfN ZtAZdHop+T4v
orISJpPN5rzGR4hwcITBKKXjIe8UfW7xTHs8HuIdss8Jz/JkVez5539nYwL/ 5XyexS72GdoD
6lJxh/o3v+HQaPgx/pN4bZwSv8uGOCIuyx3nF8w72XeJ06xUcJr97IZAMLnz 9RXWRbzA406u
Yq5Q9pqckTt+zMmvWNAHb18w9Pz2Hu6yXrWg8yP7ym8uu5H1yfzbvnLTfHjO BcPOIk+f8yNf
NdU76EnXb5ZD9U6kuu6T/M1y/gF9yDr0K7J88gAAAABJRU5ErkJgggBuHvA7 DwAAEcKfeMky
yiCU3jP6ntTMb/+JUE5HDQoaCgAAAA1JSERSAAABdAAAAHYIAwAAAO8CmN4A AAMAUExURQAA
AH+dueaLLOuXLuSXPO6fMfm4OPm5OPu+Od2hU//HPP/IPJGbnJGntKGzu6m5 v7W2yL2+zr6+
2L6/2LbEzb/Dw93CjeHGjsrOzsbI3cjRzdDW0NHS3tXZ2czN4tXX6dvc7dvd 7d/f8eDf4+Pj
3+Hk5ebn7+Pp6+Pp7OTp7OXm9Orq+Orq+e3x8/b08vHx/fX0/fb0/fn6/fr5 /v39/Pz8/v7+
/f7+/v///wAAABLu2EQK+sxvMAIExAAABw0EjgAAABLvVM1M5AAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAUgAAAAEJpfGWB5IfxBLwIBLv/AAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPFvOfFu5AEJpQABdAAAdgUNQgAA AJFLxAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAhLwdBQv
KBLvxHqSzgAAAAAAABLvVM1M5M1M5BLvAEQXqM1M5AIExAAABw0EjgAAABLv CAAAAAAAB81M
5AIExBLvXEQIqwAAAAIExAAABw0EjgAAABLvVBLvxEQIAQAAABLvFAAAABLv 4NcEZ0QIAf//
/9TVWRJusRfrsAAAARU0sBLyuBKlchU2kBLzBAAAAxKlgwAAAEQIAbqrzQAA ABLvxEQIARLv
8NSL2f3gAAAAAxLv2PGR7gAAGAAAAAAAAPF9qPGDwAUL1wAAVBLzfBLyiPGa 8AUL1wAAVBLz
fBLzvPGa+gAAAAAAKAAAAAAAABLwJJIf7BLzvPGXfwAAAAAAAAAAAAAAKBLz LJIfxAAAAJIf
xAUL1wAAABkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAEBEDDEAAAAMY21QUEpDbXAwNzEyAAAAA0gAc7wAAAvNSURB VHhe7V0LcxM3
EDZtyQxtTAqhpQXaMklMZpwZOoT//98qaZ/SPbR6OL5rTiTO2Sft49OnlbR3 Z3a3W3lyBHad
NN69//GH6vLT73edzFiHmF6gv3958Ut1uXj5fh1odbIygH738WrfVF5/eHXx c21xfXXxqtEA
b/3rD3d3bZ6YJYSKtT1wuA2gf3x3/9hUvr67bGr/eNlogNf+9d3HuzZPzBJ8 xWrQbwH0q2aX
71tBb+szaH1/dWj0xCzh/qoN9MPt7b7Z5e9LAP37/q7RE7MEV7GR6YdGU32X Eeg7Vyq6sLHP
UGMz6I9mCc2gTzPdjh+D7vy3t+LuGQe9tP/MkE3aaJawP/Ri+sDJXQygR3MC 0Rj00A44H17T
Q/UecA/N01FS3HkEGSjGHh2XEj4dnmIJ46dlDHdg+rdvj/7HGYtH8P5b8j49 rWonoHugg1fs
nDrUp9CNSy9q501QMv1xUfGQsR8kyUsd/uDZVDxLAHumSzPoh/2/oezgxxV+ xQ/Ce3jBP1gN
PncljunENEI6cBiJj5TG9wQ66hfx7oh1+mNQ7pUp+1QVL2CPnoCVidHqkyCP hKJIcEMkIB7k
NjZBb13F1on0dv8Qyo5+3JE7Dq9whKfpQzhFr+GkZjqxPGI6xA944ZHP4/sS 9YtgMIbUsGlg
TaSeqj08OJ7KaV2HmqPR4S29sDDfVCSIe7oRYeEqNsZ0C+ieqwpoPsYuEaYH 6qZMp/iJwYZD
bgK61/HgNZF4Bl1TIjEFGwTIDgQ60CWqSQRC2UMCJRJCx4RaIoYJ2AP048Px CMKdIveGX927
XTinP1THx6Nr4c4fh0wfnz0HsytOpA9BqJckr+7IOe5/8cj9oWP53DfAf56n KCJADG6huf69
l608jIV5KUoC6oY68MZjxKqamX5zc3O82bnf4879uXG/9ApHyYdSAU/dMOgV a/SwejmSpEhV
rNgZN7DPGQ6mehccZP4viPCWe6f8Kwpl2f7zcEo7KxLCaWgUKURlHqwO4eWz Lzt48XR3f+HV
f6jfqw+ocmj7uXF3c/n5Bg0gfWwQ2BF+8ccbRJ+grWCEA509kRNKAPqCsiMx wXuWICj4uizB
H5CqRqYf9v+osgvH8GouzaCbNc1VdKBXywGHzRI6MP1vVXbhGF7tpZXpn+yq pms6yOrEOC5D
Q7OEDqD/2VxaQW82wAtwkDXKMUvoAPrb5tIK+vX1dbMNbx1k12+DoFphIiFj TSvol11K5bKF
dqRdbFiLEHcRo5GkbWg/y9a724MH/bCVp0PAX64LoNdeZd3aVSCATK9ouTWp RmBjejV09Q03
ptdjV91yY3o1dPUNN6bXY1fdcmN6NXT1DTem12NX3XJjejV09Q03ptdjV91y Y3o1dPUNN6bX
Y1fdcmN6NXT1DTem12NX3XKU6S+2clIERpn+4lleWng6p4npUUJ9A72xA+4P s//GmH7YQG8E
PXMVajymN+p89s3v51E/N9PfPF0HGVQZqhjsfZO75Hxupvdx04DE46NBlaGK QZUB9HA3QLTk
fMqY3sdNAxLLAn3kbgA1kcL95DMleqjK5HxU6Vd5N/HsFT3AUS47aaFU4UNl /tZkfNwLvNTW
4FMjA7WTZnLNX/PhJcP03CNujaArpp8adD2owKvkWbRoMMgTUgnsedAN4WWe 6fRsojyeiE8e
0hCApxfVo4uqpoGcI0wH+gEH5XmZehVkRapqBPSoitc+0CoDQ8xMEHHjJbtk zDMdUUVyCD0i
RAJxqCY/VJSFfch0ZhI/f0dyK1WQDamqDNODO9Dt4hgOD6IDDJcEETdjZ0E3 MB2oTIEQFEE8
xDPqHBCUzmZBHzKdRoo8hUecD0K5X80qZpg+F9PJtUirAh28R5Min7syXfco BEUBPSYEn82C
PhbTGW4Ug6DXqphnejSRxtZIgOOuFtD52UzNdFDVlekp6BII0lFoDy9Dpicj Ft3EjqiJYCNM
xydZoVPZjXj1guemwssgsIjPzUzXI1omDAgnbDLOfCr0ZVeaI/SL5iMZ+Bh6 0wjGBmQH05gq
iQsUI5CjLI29I0sgrnF18BAXnWpS7cL0UZ/s4SMHiWJ6rmrreYMqQ5UJKzQi zUwf0WFmsQWl
/8WONEGkPaZbkNvqJAhkl4yj6/QvDyf/94XKIlSxNY1+g5y/5stElvHTVloQ +PDHbJnIp7/Z
SgsCv82Xc+fTn+V0cO4rR88U9EzuZWGoJF/ltjDrjObMMh1zSvb0lVHp2OKf 9uP63EhOqyfo
vKk0mi3LcUr2qTwCf5uTQdhsTMd0Qr/957RBvMmOQB/2REfQdSrJgJRCNcZF 8iFWoOaZHlIN
mHKgvAN/Q1fXnal8rx0lNBBw7A3K9iwIdISYLCqwLMt0zBQDFbiLBQoLRwx1 ODnPFwUGoCMB
rHTKKm1lOia7JA+W1UgVyphO0Z0SbN0AgG8PxIsfnCSVCyWc0SvgUw6DUtDV N6SOXbvIXcFX
5piYzvUJZIYl55j5PGXk1Xii61VyuYyvn5nFzlUsBj2aYZTBNJ2aKZhlusxw KrrilRQd7Rtx
AOEJDkJ5jjXnZDqHV7Amsk4YYgBinumSqScldKMITWwGFaYqNFso+eqaDsee eFo3SZ6uVL5k
5HFIBvFMpzska9YqdqTmcZt1t0OFDsasIvfSwc8OaIOIHrasgundEFuIoFUw fSFYdTNjY3o3
KO2CipjeI57ZTRut2XHJ2GhJQ/Mipp8Q9NHt1sKzjPGSs2DDuBSmyx5MMWjE j45ML92RijW6
pd4iWUlpzKfDVhyF8t1XHXdIK80yRskAK+aP2dwL36bIXKTNY9dcwKqyjHT3 POW9cX9qjvKG
3AukFtXgogtKfqswEnbNunXFVWUZx8OLmehWpie5Ht6b2RVlumJVWcaJmG4G w8L0sPnloHKa
KxkQvJK5TU9SfM7sWm7ElU6kmANIzKybSGfuBpAL0+qiEd4lTZ1QkLufQ0GL i7BWGVSIct1A
1/89Ta6DYGhD7Iaomrz2yzL288/k1GSlpdjBUbXNnXxMb5TfpfmSQO9hS9GO tAuCm5B5pm/4
nAaBjemnwXVWalHu5Qz2pSp7rl7O5k4m94ILJdiT6hUk3QSibncEH/T+tWC/ KhteBcVSs4zo
12myjPSlBDRjyzo1XrcP96uy8TDSCbccce2RnujI9NLNUWyNfmaXcLGubDI7 UtiNaNDhWO9Q
o7QPZyJpg2kGHSznR1JBi77BBJObVs+yiptA530p2VmybctkGRFyujUYgRgB ne8mlVvhINRk
faeoJChHO9LEu6UwXZuFPLS66nCB/+do/JuNQDJxOw4iKtUovOdOKdoVA8XT CQHnBzWuOqcB
SpmuOcTWisdmfnnQ53Ivc6ArXNMUIcUfe98P+i0Kk0E+YVQgdH6UFYOeUAqH psRes2U5pquA
gpxPAm0cduNxYbaCOjfBIY0z0QRjjFvT1SpAJ4MEaMm/cUzIG5ZjOpBWxXRO seG453UTdYa6
5FG+ZMTJUvXvMrOMAVj1zTQy6+chz8R0i4CnqFMwYk5vTgdjVrEj7eBnt87o YcuWe+nWHXZB
q2C63Z111NyYfoZ+KmJ6j3h2Bh8Xp7KI6QPQO/aCWmniF2yp1CZl3vrCF2cJ s7LVAlgvoSnV
wZuKrKCyK0cnBF3nGtTWg3IQwaOOXYy7yWgjnAcrSYkAFWj7WLQ5mvsGUsh2 wH4RM+rBe8Ag
7JrAVL2psWe5lJskRycnhTtxstOCjqFO5Y5UAa3Z0THLyBqCfG0mfyAnQG/B MNPIYE+q20ro
MMjse8cLECX8FpnL1IjcxFFqH4j5K0cCZQy6tpbCHY6AykAQSdQjF/vS7pWB 5zWgp3FPYmJZ
9MusXuCxTgpXMTcw9BBpFONNPg8rrRN06QkzKXKrFwJiEF54bKqQ0hJeImbL 6NVkMjtl6/Ti
8MK2aFDYKGKmQXnuiWnmcTKn8myK+LQ+ST12wUmCVTSODV7ZqhQuGWklResG ubaoGGnSnGO6
ScizqtRhvBXtSJ8VuBPOdsB8/hrpBvJpENiYfhpcZ6VuMf0MoP8HJsuqXaBi pNsAAAAASUVO
RK5CYIIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA8A6AP6GwAAAQDpAygAAABg GAAA4BAAAI8Q
AADoFwAABQAAAAoAAAACAAAAAwAAAAEAAgAAAAABDwDyA7oCAAAvAMgP6gAA ADAA0g8EAAAA
AgAAAAAAug8oAAAAGCAcIAj/FDA7/1v/CDAKMAwwDjAQMOX/BP8kACgAWwBc AHsAYv/h/xAA
ug+mAAAAATACMAz/Dv/7MBr/G/8f/wH/mzCcMP0w/jCdMJ4wBTD8MBkgHSAJ /xUwPf9d/wkw
CzANMA8wETCwADAgMiAzIAMh4P8F/0EwQzBFMEcwSTBjMIMwhTCHMI4woTCj MKUwpzCpMMMw
4zDlMOcw7jD1MPYwIQAlACkALAAuADoAOwA/AF0AfQBh/2P/ZP9l/2f/aP9p /2r/a/9s/23/
bv9v/3D/nv+f/w8A1QfkAAAAAAC3D0QAAABUAGkAbQBlAHMAIABOAGUAdwAg AFIAbwBtAGEA
bgAAAJCIEwCQiBMA2BbyCRh2EwAHyQwwGHYTAAAAAAAPANUHANwEEhAAtw9E AAAAQQByAGkA
YQBsAAAATgBlAHcAIABSAG8AbQBhAG4AAACQiBMAkIgTANgW8gkYdhMAB8kM MBh2EwAAAAAA
DwDVBwAABAAgALcPRAAAAE4AbwBrAGkAYQAgAFMAYQBuAHMAIABXAGkAZABl AAAAkIgTAJCI
EwDYFvIJGHYTAAfJDDAYdhMAAAAAAA8A1QcA3AQiAACkDwwAAACAAEMAAAAB AP//EgAAAKUP
EgAAAAAAMAguAAEAAAAA/wAABwAAAAAAqw8eAAAA/x8AAAUA4AEAAAAAAABo AWgB0ALQAjgE
OASgBaAFAACpDwoAAAAHAAAAAgAJBAAAQACjD24AAAAFAP/9PwAAACIgAABk AAAAAAAAAGQA
AAAAAAAAAABAAgAAAAACAAAA///vAAAAAAD///////8YAAAAAAEAAAAFAAAg ASABAAAAAAAF
AABAAkACAAAAAAAFAABgA2ADAAAAAAAFAACABIAEAAAAAA8ACwQWDQAADwAA 8A4NAAAAAAbw
yAMAABHcAQB4AAAATgAAAAoAAAAAAAAACAAAAAYAAAAEAAAABQAAAAIAAAAA AAAABAAAAAAA
AAAHAAAAAAAAAAkAAAAAAAAACAAAAAAAAAAHAAAAAAAAAAQAAAAAAAAAIQAA AAAAAAAbAAAA
AAAAAAcAAAAAAAAADAAAAAAAAAASAAAAAAAAAAgAAAAAAAAAJQAAAAAAAAAY AAAAAAAAAHcA
AAAAAAAABAAAAAAAAAAGAAAAAAAAABcAAAAAAAAADgAAAAAAAABcAAAAAAAA ABsAAAAAAAAA
HAAAAAAAAABRAgAAAAAAACMAAAAAAAAADAAAAAAAAAAJAAAAAAAAAAcAAAAA AAAAFAAAAAAA
AAAEAAAAAAAAAAQAAAAAAAAAEAAAAAAAAAAFAAAAAAAAAAUAAAAAAAAABQAA AAAAAAAFAAAA
AAAAAAUAAAAAAAAABQAAAAAAAAAFAAAAAAAAAAUAAAAAAAAABQAAAAAAAAAE AAAAAAAAAAcA
AAAAAAAABAAAAAAAAAAHAAAAAAAAAAQAAAAAAAAABAAAAAAAAAAEAAAAAAAA AAQAAAAAAAAA
BAAAAAAAAAAEAAAAAAAAAAQAAAAAAAAABAAAAAAAAAAEAAAAAAAAAAQAAAAA AAAABwAAAAAA
AAAEAAAAAAAAAAwAAAAAAAAABAAAAAAAAABCAQAAAAAAAAQAAAAAAAAAFgAA AAAAAAAEAAAA
AAAAAB4AAAAAAAAABAAAAAAAAAAGAAAAAAAAAAQAAAAAAAAACwAAAAAAAAAE AAAAAAAAAAoA
AAAAAAAABAAAAAAAAAAGAAAAAAAAAAQAAAAAAAAABwAAAAAAAAAEAAAAAAAA AAgAAAAAAAAA
BgAAAAAAAAAFAAAAAAAAAAUAAAAAAAAABQAAAAAAAAAFAAAAAAAAAAQAAAAA AAAABQAAAAAA
AAAIAAAAAAAAAAQAAAAAAAAAGQAAAAAAAAAgAAAAAAAAAAMAAAAAAAAAAwAA AAAAAAAEAAAA
AAAAAHQAAAAAAAAABAAAAAAAAAAEAAAAAAAAAE0AAAAAAAAABQAAAAAAAAAH AAAAAAAAAAUA
AAAAAAAABAAAAAAAAAAOAAAAAAAAAC8AAAAAAAAAAwAAAAAAAAAeAAAAAAAA AAQAAAAAAAAA
BAAAAAgAAAAHAAAAAAAAAAQAAAAKAAAABQAAAAAAAAAFAAAAAAAAAAoAAAAA AAAADgAAAAAA
AAARAAAADwAAAAUAAAAQAAAABQAAABEAAAAFAAAAEgAAAAoAAAATAAAADgAA ABQAAAARAAAA
XwAB8NwAAABiAAfwJAAAAAYGJNFx28v5yyib6YHQWRzMTP8ABgUAAAIAAAAA AAAAAAAAAGIA
B/AkAAAABgZNNpDTHHrqdHClbJbccRkb/wDHEAAAAwAAAAYFAAAAAAAAYgAH 8CQAAAAGBj5e
mTUFqQ0gEwE57qaGOFz/APsEAAACAAAAzRUAAAAAAABiAAfwJAAAAAYGxu+1 7z+83QHc5e69
2YgEZP8AqAcAAAIAAADIGgAAAAAAAGIAB/AkAAAABgYRwp94yTLKIJTeM/qe 1Mxv/wBDDwAA
AQAAAHAiAAAAAAAAAwgL8AADAACBAHhhAQCCAKKtAACDAHhhAQCEAKKtAACF AAIAAACHAAEA
AACIAAAAAACJAAAAAAC/AAIADwAMAfQAABANAQAAACAOAQAAACCAAQAAAACB AQQAAAiCAQAA
AQCDAQAAAAiEAQAAAQCFAQAAACCGQQAAAACHwQAAAACIAQAAAACJAQAAAACK AQAAAACLAQAA
AACMAQAAAACNAQAAAACOAQAAAACPAQAAAACQAQAAAACRAQAAAACSAQAAAACT AQAAAACUAQAA
AACVAQAAAACWAQAAAACXwQAAAACYAQAAAACZAQAAAACaAQAAAACbAQAAAACc AQMAAEC/ARwA
HgDAAQEAAAjBAQAAAQDCAf///wDDAQAAACDEAQAAAADFQQAAAADGwQAAAADH AQAAAADIAQAA
AADJAQAAAADKAQAAAADLATUlAADMAQAACADNAQAAAADOAQAAAADPwQAAAADX AQIAAAD/AQ4A
DgAAAgAAAAABAgIAAAgCAsvLywADAgAAACAEAgAAAQAFAjhjAAAGAjhjAAAH AgAAAAAIAgAA
AAAJAgAAAQAKAgAAAAALAgAAAAAMAgAAAQANAgAAAAAOAgAAAAAPAgABAAAQ AgAAAAARAgAA
AAA/AgAAAwCAAgAAAACBAgAAAQCCAgUAAACDApwxAACEAgAAAACFAvD5BgCG AgAAAACHAvcA
ABCIAgAAACC/AgEADwDAAgAAAADBAgAAAADCAmQAAADDAgAAAADEAgAAAADF AgAAAADGAgAA
AADHAgAAAADIAgAAAADJAgAAAADKAjB1AADLAtASEwDMAjDt7P/NAkBUiQDO AgCAAADPAgCA
///QAgAAef/RAjIAAADSAiBOAADTAlDDAADUAgAAAADVAhAnAADWAnCUAADX ArA8///YAgAA
AADZAhAnAADaAnCUAAD/AhYAHwAEAwEAAABBA6gpAQBCAwAAAABDAwMAAABE A3y+AQBFAwAA
AAB/AwAADwCEA3y+AQCFAwAAAACGA3y+AQCHAwAAAABzDSLxCgUAAIwAAQAA AI0AMGUBAH8B
AABAAJ4B/////58B/////6ABAAAAIKHBAAAAAKIB/////6MB/////6QBAAAA IKXBAAAAAKYB
/////6cB/////78BAAAgANkB/////9oB/////9sBAAAAINzBAAAAAN0B//// /94B/////98B
AAAAIODBAAAAAOEB/////+IB//////8BAADAABIC/////xMC/////xQCAAAA IBXCAAAAABYC
/////xcC/////xgCAAAAIBnCAAAAABoC/////xsC/////4kC/////4oC//// /4sCAAAAIIzC
AAAAAI0C/////48DAAAAAJADAgAAAJEDAAAAAJIDAgAAAL8DAIIAgkAFAAAA AEEFAAABAEIF
////AEMFAAAAIEQFAAAAAEVFAAAAAEbFAAAAAEcFAAAAAEgFAAAAAEkFAAAA AEoFAAAAAEsF
NSUAAEwFAAAIAE0FAAAAAE4FAAAAAE/FAAAAAFAFAAAAAFEFAAAAAFIFAQAA AFMFAQAAAFQF
AQAAAFUFAQAAAFcFAgAAAFkF/////1oF/////1sFAAAAIFzFAAAAAF0F//// /14F/////18F
AAAAIGDFAAAAAGEF/////2IF/////38FBgBOAIAFAAAAAIEFAAABAIIF//// AIMFAAAAIIQF
AAAAAIVFAAAAAIbFAAAAAIcFAAAAAIgFAAAAAIkFAAAAAIoFAAAAAIsFNSUA AIwFAAAIAI0F
AAAAAI4FAAAAAI/FAAAAAJAFAAAAAJEFAAAAAJIFAQAAAJMFAQAAAJQFAQAA AJUFAQAAAJcF
AgAAAJkF/////5oF/////5sFAAAAIJzFAAAAAJ0F/////54F/////58FAAAA IKDFAAAAAKEF
/////6IF/////78FBgBOAMAFAAAAAMEFAAABAMIF////AMMFAAAAIMQFAAAA AMVFAAAAAMbF
AAAAAMcFAAAAAMgFAAAAAMkFAAAAAMoFAAAAAMsFNSUAAMwFAAAIAM0FAAAA AM4FAAAAAM/F
AAAAANAFAAAAANEFAAAAANIFAQAAANMFAQAAANQFAQAAANUFAQAAANcFAgAA ANkF/////9oF
/////9sFAAAAINzFAAAAAN0F/////94F/////98FAAAAIODFAAAAAOEF//// /+IF//////8F
BgBOAAAGAAAAAAEGAAABAAIG////AAMGAAAAIAQGAAAAAAVGAAAAAAbGAAAA AAcGAAAAAAgG
AAAAAAkGAAAAAAoGAAAAAAsGNSUAAAwGAAAIAA0GAAAAAA4GAAAAAA/GAAAA ABAGAAAAABEG
AAAAABIGAQAAABMGAQAAABQGAQAAABUGAQAAABcGAgAAABkG/////xoG//// /xsGAAAAIBzG
AAAAAB0G/////x4G/////x8GAAAAICDGAAAAACEG/////yIG/////z8GBgBO AEAGAAAAAEEG
AAABAEIG////AEMGAAAAIEQGAAAAAEVGAAAAAEbGAAAAAEcGAAAAAEgGAAAA AEkGAAAAAEoG
AAAAAEsGNSUAAEwGAAAIAE0GAAAAAE4GAAAAAE/GAAAAAFAGAAAAAFEGAAAA AFIGAQAAAFMG
AQAAAFQGAQAAAFUGAQAAAFcGAgAAAFkG/////1oG/////1sGAAAAIFzGAAAA AF0G/////14G
/////18GAAAAIGDGAAAAAGEG/////2IG/////38GBgAOAIAAGvEgAAAAu/L5 AL/X2gDX6/8A
kK/+ANfi/wDL2v8A//9mAMD++QBAAB7xEAAAAAIAAAj/////BAAACOHw/wAf APAPHAAAAAAA
8wMUAAAAUQAAAAAAAAAAAAAABAAAgAAAAAAPANAHmAMAAB8A/wMUAAAAAgAA BAwAAAAAAAAA
AAAAAAIAAAAPAPoDZwAAAAAA/gMDAAAAAAAAAAD9AzQAAABoAAAAZAAAAGgA AABkAAAAAAAA
AHwa8gkwdhMAB8kMMAAAAAAAAAAA1P7//6z///8BABMAcAD7AwgAAAAAAAAA cAgAAHAA+wMI
AAAAAQAAADAMAAAfAPoDRwAAAAAA/gMDAAAAAAAAAAD9AzQAAABCAAAAZAAA AEIAAABkAAAA
AQAAAMQb8gkwdhMAB8kMMAAAAAAAAAAAAAAAAAAAAAABABMAHwAUBBwAAAAA ABUEFAAAAEZs
TwkAypo7U/hrOADKmjsAAgAAHwATBDwAAAAAAP0DNAAAAGQAAABkAAAAZAAA AGQAAABcdhMA
DHgMMFx2EwAAAAAAAAAAAAAAAAAAAAAAAAAAAAABEwAfAAcEPAAAAAAA/QM0 AAAAIQAAAGQA
AAAhAAAAZAAAAFx2EwAMeAwwXHYTAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAET AA8AiBMKAgAA
DwCKE9QAAAAAALoPEAAAAF8AXwBfAFAAUABUADEAMAAAAIsTtAAAAAAADQQI AAAAAMAAAADA
AAAPALMPnAAAABAArw8IAAAADwEAAAEAAAAAALEPEAAAAAAAAAAAAAAEAgAA AAAAAAAQAK8P
CAAAABYBAAABAAAAAACxDxQAAAAAAAAAAAAABAEAAAAAAAAEAgAAABAArw8I AAAAFAEAAAEA
AAAAALEPDAAAAAAAAAAAAAAEAgAAABAArw8IAAAAFQEAAAEAAAAAALEPDAAA AAAAAAAAAAAE
AgAAAA8AihMmAQAAAAC6Dw4AAABfAF8AXwBQAFAAVAA5AAAAixMIAQAALwDI DwwAAAAwANIP
BAAAAIAAAAAPAK4P7AAAABAArw8IAAAADwEAAAEAAAAAAKwPKAAAAAAAAAAA AAAAAAAAAAAA
AAAAABAAAQAAAAAAAAAAAAAAAAAAAAAAAAAQAK8PCAAAABYBAAABAAAAAACs DywAAAAAAAAA
AAAAAAAAAAAAAAAAAAAQAAEAAAAAAAAAAAAAAAAAEAACAAAAAAAAABAArw8I AAAAFAEAAAEA
AAAAAKwPHAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAQAAAAAAAAAQAK8PCAAA ABUBAAABAAAA
AACsDxwAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAEAAAAAAAAAPwDZDwwAAAAA ANoPBAAAAAAA
JQAPAPAPqgcAAAAA8wMUAAAAUgAAAAYAAAACAAAADwEAAAAAAAAAAJ8PBAAA AAAAAAAAAKgP
DAAAAEludHJvZHVjdGlvbhAAnw8EAAAAAQAAAAAAoA+0AAAASwBlAG4AIABS AHkAYQBsAGwA
IAATICAATgBvAGsAaQBhAA0AVwBhAHIAcgBlAG4AIABQAGEAdQBsACAAEyAg AE4AbwBrAGkA
YQANAEQAYQB5AG0AbwBuACAAUgBvAGcAZQByAHMAIAATICAARgByAGUAZQBz AGMAYQBsAGUA
DQBKAG8AaABuACAAQwBvAHIAdABlAGwAbAAgAC0AIABGAHIAZQBlAHMAYwBh AGwAZQANAA0A
AAChDyYAAABbAAAAAAAAAAAAWAAAAAAAAAABAAAAAAQAAAAEAgAAAAAIAAAA CAAAqg8sAAAA
JgAAAAAAAAAGAAAAAQAAAAMAGQAAAAAAAAAHAAAAAQAAAAMADwAAAAAAAAAA APMDFAAAAFUA
AAAGAAAAAgAAABYBAAAAAAAAAACfDwQAAAAAAAAAAACoDw8AAABUZWNobmlj YWwgR29hbHMQ
AJ8PBAAAAAEAAAAAAKgP4gAAAFJldXNlIHRoZSBjb3JlIG9mIHRoZSBDb2Rl V2FycmlvciBk
ZWJ1Z2dlci4NVXNlIGFuIGludGVncmF0aW9uIGxheWVyIHRoYXQgY29ubmVj dHMgdGhlIGNv
cmUgZGVidWdnZXIgd2l0aCB0aGUgRWNsaXBzZSBDKysgdG9vbHMgZW52aXJv bm1lbnQgKENE
VCkuDUV4dGVuZCBhbmQgZW5oYW5jZSB0aGUgQ0RUIGRlYnVnZ2VyIGVudmly b25tZW50IHRv
IG1hdGNoIGN1c3RvbWVyIGV4cGVjdGF0aW9ucy4AAKEPJgAAAOMAAAAAAAAA AAAsAAAAAAAA
AGcAAAAABAAAAARQAAAAAAgAAAAIAADzAxQAAABWAAAABAAAAAIAAAAXAQAA AAAAAAAAnw8E
AAAAAAAAAAAAoA9SAAAAQwB1AHIAcgBlAG4AdAAgABMgIABEAGUAYgB1AGcA ZwBlAHIAIABp
AG4AIABDAG8AZABlAFcAYQByAHIAaQBvAHIAIABJAEQARQAgADUALgB4AAAA oQ8UAAAAKgAA
AAAAAAAAACoAAAAAAAIAGAAQAJ8PBAAAAAEAAAAAAKoPCgAAAAEAAAABAAAA AAAAAPMDFAAA
AFcAAAAEAAAAAgAAABgBAAAAAAAAAACfDwQAAAAAAAAAAACoDxMAAABEZWJ1 Z2dlciBpbiBF
Y2xpcHNlAAChDxQAAAAUAAAAAAAAAAAAFAAAAAAAAgAcABAAnw8EAAAAAQAA AAAAqg8KAAAA
AQAAAAEAAAAAAAAA8wMUAAAAWAAAAAQAAAACAAAAGQEAAAAAAAAAAJ8PBAAA AAAAAAAAAKgP
KgAAAERlYnVnZ2VyIEVuZ2luZSBydW5zIGluIGEgc2VwYXJhdGUgUHJvY2Vz cwAAoQ8UAAAA
KwAAAAAAAAAAACsAAAAAAAIAHAAQAJ8PBAAAAAEAAAAAAKoPCgAAAAEAAAAB AAAAAAAAAPMD
FAAAAFMAAAAGAAAAAgAAABQBAAAAAAAAAACfDwQAAAAAAAAAAACoDxEAAABQ cm9wb3NlZCBG
ZWF0dXJlcxAAnw8EAAAAAQAAAAAAqA/6AAAARGVidWdnaW5nIG9mIHByb2pl Y3QtbGVzcyBl
eGVjdXRhYmxlcw1FbmhhbmNlZCBWYXJpYWJsZSBGb3JtYXR0aW5nDUMrKyBy dW50aW1lIHR5
cGUgaW5zcGVjdGlvbg1FbmhhbmNlZCBicmVha3BvaW50cyAoYWN0aW9ucywg dGVtcGxhdGVz
IGV0Yy4pDVN5c3RlbSBCcm93c2VyDVN1cHBvcnQgZm9yIGFkZHJlc3Mgc3Bh Y2VzDU1vZHVs
ZSBzeW1ib2wgbG9hZGluZyBlbmhhbmNlbWVudHMNTWVtb3J5IHdpbmRvdyBl bmhhbmNlbWVu
dHMgKD8pDQAAoQ8sAAAA+gAAAAAAAAAAAAEAAAAAAAEAAAAAAPoAAAAAAAIA HAABAAAAAAQC
AAAEHAAAAPMDFAAAAFQAAAAGAAAAAgAAABUBAAAAAAAAAACfDwQAAAAAAAAA AACoDxEAAABQ
cm9wb3NlZCBGZWF0dXJlcxAAnw8EAAAAAQAAAAAAqA8EAQAARGlzcGxheSB2 YXJpYWJsZSBh
ZGRyZXNzZXMgb3IgY29udGFpbmluZyByZWdpc3RlciBpbiBWYXJpYWJsZXMg dmlldw1TZWxl
Y3RhYmxlIHNjb3BlIGZvciBWYXJpYWJsZXMgdmlldw1NdWx0aXBsZSB0aHJl YWQgZGVidWcg
Y29udGV4dA1HZW5lcmljIGNvbW1hbmQgbGluZSBpbnRlcmZhY2UNQ2hhbmdl IHRoZSBQcm9n
cmFtIENvdW50ZXINQXV0by11cGRhdGUgVmlld3MNQ2FjaGVkLXNvdXJjZSBm b3IgZGVidWdn
aW5nDUxpbmUgdGFibGUgdGljayBtYXJrcw0AAKEPMAAAAAQBAAAAAAAQAABa AAEAAAAAAAEQ
AAAAAFoABAEAAAAAAgAcAAEAAAAABAIAAAQcAAEAAQRQAAAAAAAAAf///38A AAAAAAAAAAAA
AAAAAAAAAAAAAOoDAAAAAA8A+AN5CgAAAgDvAxgAAAABAAAAAQIHCQgAAAAA AAAAAAAAAAAA
DDBgAPAHIAAAAP///wAAAAAAgICAAAAAAAC74OMAMzOZAACZmQCZzAAAYADw ByAAAAD///8A
AAAAAJaWlgAAAAAA+99TAP+ZZgDMMwAAmWYAAGAA8AcgAAAA////AAAAAACA gIAAAAAAAJnM
/wDMzP8AMzPMAK9n/wBgAPAHIAAAAN728QAAAAAAlpaWAAAAAAD///8Ajcb/ AABmzAAAqAAA
YADwByAAAAD//9kAAAAAAHd3dwAAAAAA///3ADPMzAD/UFAA/5kAAGAA8Acg AAAAAICAAP//
/wAAWlgA//+ZAABkYgBtb8cAAP//AAD/AABgAPAHIAAAAIAAAAD///8AXB8A AN/SkwDMMwAA
vnlgAP//mQDTohkAYADwByAAAAAAAJkA////AAAzZgDM//8AM2bMAACwAABm zP8A/+cBAGAA
8AcgAAAAAAAAAP///wAzZpkA4+vxAAAzmQBGiksAZsz/APDlAABgAPAHIAAA AGhrXQD///8A
d3d3ANHRywCQkIIAgJ6oAP/MZgDp3LkAYADwByAAAABmZpkA////AD4+XAD/ //8AYFl7AGZm
/wCZzP8A//+ZAGAA8AcgAAAAUj4mAP///wAtIBUA38CNAIx7cACPXy8AzLQA AIyeoAAAAKMP
PgAAAAEA//0/AAAAIiABAGQAAAAA/wEAZAAAAAAAAAAAAEACAAAAAAcAAAD/ /+8AAAABAP//
/////ywAAAAAAwAAEACjD3wAAAAFAP/9PwABACIgAQBkAAAAAP8AAGQAFAAA ANgAAABAAgAA
AAAHAAAA///vAAAAAQD///////8gAAAAAAEAAIAFAAATINQBIAEAAAIAHACA BQAAIiDQAkAC
AAACABgAgAUAABMg8ANgAwAAAgAUAIAFAAC7ABAFgAQAAAAAIACjD24AAAAF AP/9PwAAACIg
AABkAAAAAAAAAFoAKAAAAAAAAADgAQAAAAACAAAA///vAAAAAQD///////8K AAAAAAEAAAAF
AAAgASABAAAAAAAFAABAAkACAAAAAAAFAABgA2ADAAAAAAAFAACABIAEAAAA AFAAow9SAAAA
BQAAAAEJAAAAAAEAAAAAAAAAAQABCQAAAAABACABAAAAAAIAAQkAAAAAAQBA AgAAAAADAAEJ
AAAAAAEAYAMAAAAABAABCQAAAAABAIAEAAAAAGAAow8MAAAAAQAAAAAAAAAA AAAAcACjDz4A
AAAFAAAAAAAAAAAAAgAcAAEAAAAAAAAAAgAYAAIAAAAAAAAAAgAUAAMAAAAA AAAAAgASAAQA
AAAAAAAAAgASAIAAow8+AAAABQAAAAAAAAAAAAIAGAABAAAAAAAAAAIAFAAC AAAAAAAAAAIA
EgADAAAAAAAAAAIAEAAEAAAAAAAAAAIAEAAAAPkDEAAAAAAAAAAAAAAAAwoB AAKyTDAPAAwE
OgUAAA8AAvAyBQAAgAAI8AgAAAAGAAAABqwBAA8AA/DKBAAADwAE8CgAAAAB AAnwEAAAAAAA
AAAAAAAAAAAAAAAAAAACAArwCAAAAACsAQAFAAAADwAE8OAAAAASAArwCAAA AAKsAQAACgAA
kwAL8DYAAAB/AAEABQCAAOhK8gmHAAEAAACBAQQAAAiDAQAAAAi/AQEAEQDA AQEAAAj/AQEA
CQABAgIAAAgTACLxBgAAAL8DAAAABAAAEPAIAAAArQA4ASgXfQMPABHwEAAA AAAAwwsIAAAA
AAAAAAEA8gkPAA3wVAAAAAAAnw8EAAAAAAAAAAAAqA8gAAAAQ2xpY2sgdG8g ZWRpdCBNYXN0
ZXIgdGl0bGUgc3R5bGUAAKIPBgAAACEAAAAAAAAAqg8KAAAAIQAAAAEAAAAA AA8ABPAkAQAA
EgAK8AgAAAADrAEAAAoAAIMAC/AwAAAAfwABAAUAgADITfIJgQEEAAAIgwEA AAAIvwEBABEA
wAEBAAAI/wEBAAkAAQICAAAIEwAi8QYAAAC/AwAAAAQAABDwCAAAAPADOAEo FxMPDwAR8BAA
AAAAAMMLCAAAAAEAAAACAPIJDwAN8J4AAAAAAJ8PBAAAAAEAAAAAAKgPUgAA AENsaWNrIHRv
IGVkaXQgTWFzdGVyIHRleHQgc3R5bGVzDVNlY29uZCBsZXZlbA1UaGlyZCBs ZXZlbA1Gb3Vy
dGggbGV2ZWwNRmlmdGggbGV2ZWwAAKIPHgAAACEAAAAAAA0AAAABAAwAAAAC AA0AAAADAAwA
AAAEAAAAqg8KAAAAUwAAAAEAAAAAAA8ABPDOAAAAEgAK8AgAAAAErAEAAAoA AIMAC/AwAAAA
fwABAAUAgADQUvIJgQEEAAAIgwEAAAAIvwEBABEAwAEBAAAI/wEBAAkAAQIC AAAIEwAi8QYA
AAC/AwAAAAQAABDwCAAAAF4POAHoBooQDwAR8BAAAAAAAMMLCAAAAAIAAAAH AfIJDwAN8EgA
AAAAAJ8PBAAAAAQAAAAAAKAPAgAAACoAAAChDx4AAAACAAAAAAAwAAoAAQAA AAD/BwACAAAA
AAADAAEADgAAAPgPBAAAAAAAAAAPAATw0AAAABIACvAIAAAABawBAAAKAACD AAvwMAAAAH8A
AQAFAIAAaFjyCYEBBAAACIMBAAAACL8BAQARAMABAQAACP8BAQAJAAECAgAA CBMAIvEGAAAA
vwMAAAAEAAAQ8AgAAABeD1QIDBCKEA8AEfAQAAAAAADDCwgAAAADAAAACQLy CQ8ADfBKAAAA
AACfDwQAAAAEAAAAAACgDwIAAAAqAAAAoQ8gAAAAAgAAAAAAMAgKAAEAAAAA /wEABwACAAAA
AAADAAEADgAAAPoPBAAAAAAAAAAPAATw0AAAABIACvAIAAAABqwBAAAKAACD AAvwMAAAAH8A
AQAFAIAAAF7yCYEBBAAACIMBAAAACL8BAQARAMABAQAACP8BAQAJAAECAgAA CBMAIvEGAAAA
vwMAAAAEAAAQ8AgAAABeD3gRKBeKEA8AEfAQAAAAAADDCwgAAAAEAAAACALy CQ8ADfBKAAAA
AACfDwQAAAAEAAAAAACgDwIAAAAqAAAAoQ8gAAAAAgAAAAAAMAgKAAEAAAAA /wIABwACAAAA
AAADAAEADgAAANgPBAAAAAAAAAAPAATwSAAAABIACvAIAAAAAawBAAAMAACD AAvwMAAAAIEB
AAAACIMBBQAACJMBHkCXAJQB3r1oAL8BEgASAP8BAAAIAAQDCQAAAD8DAQAB ABAA8AcgAAAA
////AAAAAACAgIAAAAAAALvg4wAzM5kAAJmZAJnMAAAPAIgTkQAAAA8AihOJ AAAAAAC6DxAA
AABfAF8AXwBQAFAAVAAxADAAAACLE2kAAAAAAOsuCAAAAHqYxQHgMsurAAAA KwQAAAAAAAAA
HwBE8T0AAAAAACfxIAAAAAAAAAADAAAAAAAAAAAAAAAAAAAAAACpBf////8S AAAADwA98Q0A
AABAAULxBQAAAAEJAAAADwACKwAAAAAgALoPHAAAAEQAZQBmAGEAdQBsAHQA IABEAGUAcwBp
AGcAbgAPAPADwwIAAAEA8QMIAAAABAAAgAAADTAPAAwEQwIAAA8AAvA7AgAA YAAI8AgAAAAD
AAAAAwgAAA8AA/DZAQAADwAE8CgAAAABAAnwEAAAAAAAAAAAAAAAAAAAAAAA AAACAArwCAAA
AAAIAAAFAAAADwAE8CkBAAASAArwCAAAAAIIAAAACgAA8wAL8FoAAAB/AAEA AQCAAKgqOwqB
AOBcAQCCAGCrAACDAOBcAQCEAGCrAAC/ABAAHwCBAQAAAAiDAQAAAAi/AQEA EQDAAQEAAAjL
AZwxAAD/AQEACQABAgIAAAg/AgAAAgAAABDwCAAAAGQLNgJZDjQWDwAR8BAA AAAAAMMLCAAA
AAMAAAAGAjsKDwAN8IcAAAAAAJ8PBAAAAAIAAAAAAKgPOwAAAEJvZHkgVGV4 dA1TZWNvbmQg
TGV2ZWwNVGhpcmQgTGV2ZWwNRm91cnRoIExldmVsDUZpZnRoIExldmVsAACi Dx4AAAAKAAAA
AAANAAAAAQAMAAAAAgANAAAAAwAMAAAABAAAAKoPCgAAADwAAAABAAAAAAAP AATwcAAAABIA
CvAIAAAAAwgAAAAKAACDAAvwMAAAAH8ABAAEAIcAAQAAAH8BAAABAL8BAQAR AMABAQAACMsB
nDEAAP8BCAAJAD8CAQADAAAAEPAIAAAAFAI8AlMOdAoPABHwEAAAAAAAwwsI AAAAAgAAAAUA
OwoPAATwQgAAABIACvAIAAAAAQgAAAAMAABzAAvwKgAAAIEBAAAACJMBk8dm AJQB+leUAL8B
EgASAP8BAAAIAAQDCQAAAD8DAQABABAA8AcgAAAA////AAAAAACRkZEAAAAA AGGP/QAArgAA
/AEoAM7OzgAPAIgTOAAAAA8AihMwAAAAAAC6DxAAAABfAF8AXwBQAFAAVAAx ADAAAACLExAA
AAAAAOsuCAAAACU1xQHgeKLsDwDJDwoBAAAPAAwEmgAAAA8AAvCSAAAAUAAI 8AgAAAABAAAA
AQwAAA8AA/AwAAAADwAE8CgAAAABAAnwEAAAAAAAAAAAAAAAAAAAAAAAWAAC AArwCAAAAAAM
AAAFAAAADwAE8EIAAAASAArwCAAAAAEMAAAADAAAcwAL8CoAAACBAQAAAAiT AZPHZgCUAfpX
lAC/ARIAEgD/AQAACAAEAwkAAAA/AwEAAQAQAPAHIAAAAP///wAAAAAAkZGR AAAAAABhj/0A
AK4AAPwBKADOzs4ADwCIEzgAAAAPAIoTMAAAAAAAug8QAAAAXwBfAF8AUABQ AFQAMQAwAAAA
ixMQAAAAAADrLggAAAAlNcUBgP+j7A8A7gPRAwAAAgDvAxgAAAABAAAADQ4A AAAAAAAEAACA
AAAAAAcADDAAAPkDEAAAAAAAAAAAAAAAAwoBAAKyTDAPAAwE0AIAAA8AAvDI AgAAoAAI8AgA
AAAEAAAABLQBAA8AA/BgAgAADwAE8CgAAAABAAnwEAAAAAAAAAAAAAAAAAAA AAAAAAACAArw
CAAAAAC0AQAFAAAADwAE8BwBAACiDArwCAAAAAK0AQAACgAA8wAL8FoAAACA AMyE8gmBAHhh
AQCCAKKtAACDAHhhAQCEAKKtAAC/AAIADwCBAQAAAAi/AQwAHgDAAQEAAAj/ AQYADgABAgIA
AAg/AgAAAwC/AgEADwD/AhYAHwB/AwAADwCTACLxNgAAAH8BAABAAL8BAAAg AP8BAADAAL8D
AIIAgn8FBgBOAL8FBgBOAP8FBgBOAD8GBgBOAH8GBgAOAAAAEPAIAAAA3AmI AD8HwQoPAA3w
VAAAAAAAnw8EAAAABAAAAAAAoQ8iAAAAAQAAAAAANGAAAAQAAgAAAAAEMgAP AAEAAAAAAAMA
AgASAAAApg8WAAAA8R4AAOABaAFoAdAC0AI4BDgEoAWgBQ8ABPB+AAAAEgAK 8AgAAAADtAEA
IAIAAHMAC/AqAAAABAAAAAAAfwAAAAQAgACYjPIJvwEAAAEA/wEAAAEAAQMC rAEAiAMAAAAA
AAAQ8AgAAACtADgBKBd9Aw8AEfAQAAAAAADDCwgAAAAAAAAADQDyCQ8ADfAM AAAAAACeDwQA
AAAAAAAADwAE8H4AAAASAArwCAAAAAS0AQAgAgAAcwAL8CoAAAAEAAAAAAB/ AAAABACAAHCN
8gm/AQAAAQD/AQAAAQABAwOsAQCIAwAAAAAAABDwCAAAAPADOAEoFxMPDwAR 8BAAAAAAAMML
CAAAAAEAAAAOAPIJDwAN8AwAAAAAAJ4PBAAAAAEAAAAPAATwSAAAABIACvAI AAAAAbQBAAAM
AACDAAvwMAAAAIEBAAAACIMBBQAACJMBHkCXAJQB3r1oAL8BEgASAP8BAAAI AAQDCQAAAD8D
AQABABAA8AcgAAAA////AAAAAACAgIAAAAAAAAA2zACZzP8ARKUcAJnMAAAP AIgTkQAAAA8A
ihOJAAAAAAC6DxAAAABfAF8AXwBQAFAAVAAxADAAAACLE2kAAAAAAOsuCAAA AJw6xQHAwtqG
AAAAKwQAAAAAAAAAHwBE8T0AAAAAACfxIAAAAAAAAAADAAAAAAAAAAAAAAAA AAAAAACpBf//
//8SAAAADwA98Q0AAABAAULxBQAAAAEJAAAADwACKwAAAAAPAO4D0QMAAAIA 7wMYAAAAAQAA
AA0OAAAAAAAABAAAgAAAAAAHAAwwAAD5AxAAAAAAAAAAAAAAAAMKAQACskww DwAMBNACAAAP
AALwyAIAABABCPAIAAAABAAAAATQAQAPAAPwYAIAAA8ABPAoAAAAAQAJ8BAA AAAAAAAAAAAA
AAAAAAAAAAAAAgAK8AgAAAAA0AEABQAAAA8ABPAcAQAAogwK8AgAAAAC0AEA AAoAAPMAC/Ba
AAAAgAAc2PIJgQB4YQEAggCirQAAgwB4YQEAhACirQAAvwACAA8AgQEAAAAI vwEMAB4AwAEB
AAAI/wEGAA4AAQICAAAIPwIAAAMAvwIBAA8A/wIWAB8AfwMAAA8AkwAi8TYA AAB/AQAAQAC/
AQAAIAD/AQAAwAC/AwCCAIJ/BQYATgC/BQYATgD/BQYATgA/BgYATgB/BgYA DgAAABDwCAAA
ANwJiAA/B8EKDwAN8FQAAAAAAJ8PBAAAAAQAAAAAAKEPIgAAAAEAAAAAADRg AAAEAAIAAAAA
BDIADwABAAAAAAADAAIAEgAAAKYPFgAAAPEeAADgAWgBaAHQAtACOAQ4BKAF oAUPAATwfgAA
ABIACvAIAAAAA9ABACACAABzAAvwKgAAAAQAAAAAAH8AAAAEAIAA9NjyCb8B AAABAP8BAAAB
AAEDAqwBAIgDAAAAAAAAEPAIAAAArQA4ASgXfQMPABHwEAAAAAAAwwsIAAAA AAAAAA0A8gkP
AA3wDAAAAAAAng8EAAAAAAAAAA8ABPB+AAAAEgAK8AgAAAAE0AEAIAIAAHMA C/AqAAAABAAA
AAAAfwAAAAQAgABE4PIJvwEAAAEA/wEAAAEAAQMDrAEAiAMAAAAAAAAQ8AgA AADwAzgBKBcT
Dw8AEfAQAAAAAADDCwgAAAABAAAADgDyCQ8ADfAMAAAAAACeDwQAAAABAAAA DwAE8EgAAAAS
AArwCAAAAAHQAQAADAAAgwAL8DAAAACBAQAAAAiDAQUAAAiTAR5AlwCUAd69 aAC/ARIAEgD/
AQAACAAEAwkAAAA/AwEAAQAQAPAHIAAAAP///wAAAAAAgICAAAAAAAAANswA mcz/AESlHACZ
zAAADwCIE5EAAAAPAIoTiQAAAAAAug8QAAAAXwBfAF8AUABQAFQAMQAwAAAA ixNpAAAAAADr
LggAAACcOsUBwMLahgAAACsEAAAAAAAAAB8ARPE9AAAAAAAn8SAAAAAAAAAA AwAAAAAAAAAA
AAAAAAAAAAAAqQX/////EgAAAA8APfENAAAAQAFC8QUAAAABCQAAAA8AAisA AAAADwDuA34O
AAACAO8DGAAAAAEAAAANDgAAAAAAAAQAAIAAAAAABwAMMAAA+QMQAAAAAAAA AAAAAAADCgEA
ArJMMA8ADAR9DQAADwAC8HUNAAAgAQjwCAAAAAkAAAAJ1AEADwAD8OUMAAAP AATwKAAAAAEA
CfAQAAAAAAAAAAAAAAAAAAAAAAAAAAIACvAIAAAAANQBAAUAAAAPAATwfgAA ABIACvAIAAAA
AtQBACACAABzAAvwKgAAAAQAAAAAAH8AAAAEAIAAsK3yCb8BAAABAP8BAAAB AAEDAqwBAIgD
AAAAAAAAEPAIAAAArQA4ASgXfQMPABHwEAAAAAAAwwsIAAAAAAAAAA0A8gkP AA3wDAAAAAAA
ng8EAAAAAAAAAA8ABPBsAAAAsgQK8AgAAAAD1AEAAAoAAGMAC/A2AAAAfwCE AIUABEEBAAAA
BcESAAAABgEBAAAAvwEAABEA/wEAAAkAaQBkAGUAIABpAGMAbwBuAAAAEwAi 8QYAAAC/AQAA
YAAAABDwCAAAAK4IfgW2BgQKDwAE8E0CAAASAArwCAAAAATUAQAACgAAwwAL 8EgAAAB/AAAA
BACAAMBSQQqCACjiBACFAAIAAACHAAMAAAC/AAAAAgCBAWyQbAC/ARAAEADA AQEAAAj/AQgA
CAABAgIAAAgEAwcAAABTACLxHgAAAL8BAABgAH8FAAAIAL8FAAAIAP8FAAAI AD8GAAAIAAAA
EPAIAAAA8AOJAQgPRAoPABHwUgEAAA8AiBNKAQAADwCKE0IBAAAAALoPFgAA AF8AXwBfAFAA
UABUAE0AQQBDADEAMQAAAIsTHAEAAAAAGRAUAQAAAAAACAwBAAAAAAACAAAB DAAAAAAAAAAU
AAAAIAAAAAEAAAABAAAAAAAAAAEAAADoAAAACAAAAAQAAAAAAAABAAAAAAEA AAAAAAABAQAA
AAEAAAAAAAABAgAAAAEAAAAAAAABAwAAAAEAAAAAAAABBAAAAAEAAAAAAAAB BQAAAGhuYW1k
AAAAYAAAAAIAAAAEAAAAAAAAAAMAAAAAAAAACgBBAHIAaQBhAGwAAAAAAAgA AAAAAAAAAwAA
AAAAAAAmAE0AbwBuAG8AdAB5AHAAZQAgAFQAeQBwAG8AZwByAGEAcABoAHkA AAAAAQYAAAAE
ABgAAAAAAQcAAAAGAAAAAAAAAAAABAAAAA4ACQARAAAAGgABDwAN8FUAAAAA AJ8PBAAAAAQA
AAAAAKgPFQAAAENvZGVXYXJyaW9yIElERSA1LjUuMQAAoQ8kAAAAFgAAAAAA MAgKAAEAAAAA
/wEABwAWAAAAAAAHAAEADgAAAAAADwAE8DsCAAASAArwCAAAAAXUAQAACgAA owAL8DwAAAB/
AAAABACAAAxeQQqFAAIAAACHAAEAAACBAQYAAAi/ARAAEADAAQEAAAj/AQgA CAABAgIAAAgE
AwcAAABTACLxHgAAAL8BAABgAH8FAAAIAL8FAAAIAP8FAAAIAD8GAAAIAAAA EPAIAAAAZwcj
Am0OBgoPABHwUgEAAA8AiBNKAQAADwCKE0IBAAAAALoPFgAAAF8AXwBfAFAA UABUAE0AQQBD
ADEAMQAAAIsTHAEAAAAAGRAUAQAAAAAACAwBAAAAAAACAAABDAAAAAAAAAAU AAAAIAAAAAEA
AAABAAAAAAAAAAEAAADoAAAACAAAAAQAAAAAAAABAAAAAAEAAAAAAAABAQAA AAEAAAAAAAAB
AgAAAAEAAAAAAAABAwAAAAEAAAAAAAABBAAAAAEAAAAAAAABBQAAAGhuYW1k AAAAYAAAAAIA
AAAEAAAAAAAAAAMAAAAAAAAACgBBAHIAaQBhAGwAAAAAAAgAAAAAAAAAAwAA AAAAAAAmAE0A
bwBuAG8AdAB5AHAAZQAgAFQAeQBwAG8AZwByAGEAcABoAHkAAAAAAQYAAAAE ABgAAAAAAQcA
AAAGAAAAAAAAAAAABAAAAA4ACQARAAAAGgABDwAN8E8AAAAAAJ8PBAAAAAQA AAAAAKgPDwAA
AERlYnVnZ2VyIEVuZ2luZQAAoQ8kAAAAEAAAAAAAMAgKAAEAAAAA/wEABwAQ AAAAAAAHAAEA
DgAAAAAADwAE8G0FAAASAArwCAAAAAbUAQAACgAAswAL8EIAAAB/AAAABACA AJBrQQqFAAIA
AACHAAEAAAC/AAAAAgCBAYCAgAC/ARAAEADAAQEAAAj/AQgACAABAgIAAAgE AwcAAABTACLx
HgAAAL8BAABgAH8FAAAIAL8FAAAIAP8FAAAIAD8GAAAIAAAAEPAIAAAANQuG AQUPaA4PABHw
GAQAAA8AiBMQBAAADwCKE2oDAAAAALoPFgAAAF8AXwBfAFAAUABUAE0AQQBD ADEAMQAAAIsT
RAMAAAAAGRA8AwAAAAAACAwBAAAAAAACAAABDAAAAAAAAAAUAAAAIAAAAAEA AAABAAAAAAAA
AAEAAADoAAAACAAAAAQAAAAAAAABAAAAAAEAAAAAAAABAQAAAAEAAAAAAAAB AgAAAAEAAAAA
AAABAwAAAAEAAAAAAAABBAAAAAEAAAAAAAABBQAAAGhuYW1kAAAAYAAAAAIA AAAEAAAAAAAA
AAMAAAAAAAAACgBBAHIAaQBhAGwAAAAAAAgAAAAAAAAAAwAAAAAAAAAmAE0A bwBuAG8AdAB5
AHAAZQAgAFQAeQBwAG8AZwByAGEAcABoAHkAAAAAAQYAAAAEABgAAAAAAQcA AAAGAAAAAAAA
AAAABAAAAA4ACQARAAAAGgABAAAACAwBAAAAAAACAAABDAAAAAAAAAAUAAAA IAAAAAEAAAAB
AAAAAAAAAAEAAADoAAAACAAAAAQAAAAAAAABAAAAAAEAAAAAAAABAQAAAAEA AAAAAAABAgAA
AAEAAAAAAAABAwAAAAEAAAAAAAABBAAAAAEAAAAAAAABBQAAAGhuYW1kAAAA YAAAAAIAAAAE
AAAAAAAAAAMAAAAAAAAACgBBAHIAaQBhAGwAAAAAAAgAAAAAAAAAAwAAAAAA AAAmAE0AbwBu
AG8AdAB5AHAAZQAgAFQAeQBwAG8AZwByAGEAcABoAHkAAAAAAQYAAAAEAA4A AAAAAQcAAAAG
AAAAAAAAAAAABAAAAA4ACQARAAAAGgABAAAACAwBAAAAAAACAAABDAAAAAAA AAAUAAAAIAAA
AAEAAAABAAAAAAAAAAEAAADoAAAACAAAAAQAAAAAAAABAAAAAAEAAAAAAAAB AQAAAAEAAAAA
AAABAgAAAAEAAAAAAAABAwAAAAEAAAAAAAABBAAAAAEAAAAAAAABBQAAAGhu YW1kAAAAYAAA
AAIAAAAEAAAAAAAAAAMAAAAAAAAACgBBAHIAaQBhAGwAAAAAAAgAAAAAAAAA AwAAAAAAAAAm
AE0AbwBuAG8AdAB5AHAAZQAgAFQAeQBwAG8AZwByAGEAcABoAHkAAAAAAQYA AAAEABgAAAAA
AQcAAAAGAAAAAAAAAAAABAAAAA4ACQARAAAAGgABDwCKEzwAAAAAALoPEAAA AF8AXwBfAFAA
UABUADEAMAAAAIsTHAAAAAAAsQ8UAAAAAAAAAAAAAAQBAAAAAAAABAIAAAAP AIoTUgAAAAAA
ug8OAAAAXwBfAF8AUABQAFQAOQAAAIsTNAAAAAAArA8sAAAAAAAAAAAAAAAA AAAAAAAAAAAA
EAABAAAAAAAAAAAAAAAAABAAAgAAAAAAAAAPAA3wtQAAAAAAnw8EAAAABAAA AAAAqA9RAAAA
RGVidWdnZXIgQ29tcG9uZW50cw0oUHJvdG9jb2xzLCBTeW1ib2wgUmVhZGVy cywgRGF0YSBW
aXN1YWxpemF0aW9uLCBPUyBBd2FyZW5lc3MpAAChD0gAAABSAAAAAAAwCAoA AQAAAAD/AQAH
ABQAAAAAAAcAAQAOAAAAAAA9AAAAAAQHAAAEAQAOAAAAAAABAAAAAAgHAAAI AQAOAAAAAAAP
AATwXgAAAAICCvAIAAAAB9QBAEALAACTAAvwNgAAAIUAAgAAAIcAAQAAAL8B AAAQAMABAQAA
CNABAQAAANEBAQAAAP8BCAAIAAECAgAACAMDAAAAAAAAEPAIAAAARApGCEkI NQsPAATwbAAA
ALIECvAIAAAACNQBAAAKAABjAAvwNgAAAH8AhACFAARBAQAAAAXBEgAAAAYB AQAAAL8BAAAR
AP8BAAAJAGkAZABlACAAaQBjAG8AbgAAABMAIvEGAAAAvwEAAGAAAAAQ8AgA AAD7AzoQ3xP6
Bw8ABPDMAAAAsgQK8AgAAAAJ1AEAAAoAABMBC/BmAAAAgQB4YQEAggCirQAA gwB4YQEAhACi
rQAAhQACAAAAhwABAAAAvwACAA8ABEECAAAAgQEAAAAIvwEMAB4AwAEBAAAI /wEGAA4AAQIC
AAAIPwIAAAMAvwIBAA8A/wIWAB8AfwMAAA8AkwAi8TYAAAB/AQAAQAC/AQAA IAD/AQAAwAC/
AwCCAIJ/BQYATgC/BQYATgD/BQYATgA/BgYATgB/BgYADgAAABDwCAAAAPgJ TBDcE/YODwAE
8EgAAAASAArwCAAAAAHUAQAADAAAgwAL8DAAAACBAQAAAAiDAQUAAAiTAR5A lwCUAd69aAC/
ARIAEgD/AQAACAAEAwkAAAA/AwEAAQAfAAXwIAAAAAEAEvAYAAAAAQAAAATU AQAG1AEAB9QB
AAIAAAAAAAAAEADwByAAAAD///8AAAAAAICAgAAAM8wAADbMAK/U8ABEpRwA 5sAfAA8AiBOR
AAAADwCKE4kAAAAAALoPEAAAAF8AXwBfAFAAUABUADEAMAAAAIsTaQAAAAAA 6y4IAAAANHvF
AbDK2r8AAAArBAAAAAAAAAAfAETxPQAAAAAAJ/EgAAAAAAAAAAMAAAAAAAAA AAAAAAAAAAAA
AKkF/////xIAAAAPAD3xDQAAAEABQvEFAAAAAQkAAAAPAAIrAAAAAA8A7gMS FAAAAgDvAxgA
AAABAAAADQ4AAAAAAAAEAACAAAAAAAcADDAAAPkDEAAAAAAAAAAAAAAAAwoB AAKyTDAPAAwE
ERMAAA8AAvAJEwAAMAEI8AgAAAANAAAADdgBAA8AA/BZEgAADwAE8CgAAAAB AAnwEAAAAAAA
AAAAAAAAAAAAAAAAAAACAArwCAAAAADYAQAFAAAADwAE8H4AAAASAArwCAAA AALYAQAgAgAA
cwAL8CoAAAAEAAAAAAB/AAAABACAALR7QQq/AQAAAQD/AQAAAQABAwKsAQCI AwAAAAAAABDw
CAAAAK0AOAEoF30DDwAR8BAAAAAAAMMLCAAAAAAAAAANAEEKDwAN8AwAAAAA AJ4PBAAAAAAA
AAAPAATwQwIAABIACvAIAAAAA9gBAAAKAADDAAvwSAAAAH8AAAAEAIAAXINB CoIAyBcCAIUA
AgAAAIcAAwAAAL8AAAACAIEBbJBsAL8BEAAQAMABAQAACP8BCAAIAAECAgAA CAQDBwAAAFMA
IvEeAAAAvwEAAGAAfwUAAAgAvwUAAAgA/wUAAAgAPwYAAAgAAAAQ8AgAAACv A4QBAw87Bw8A
EfBSAQAADwCIE0oBAAAPAIoTQgEAAAAAug8WAAAAXwBfAF8AUABQAFQATQBB AEMAMQAxAAAA
ixMcAQAAAAAZEBQBAAAAAAAIDAEAAAAAAAIAAAEMAAAAAAAAABQAAAAgAAAA AQAAAAEAAAAA
AAAAAQAAAOgAAAAIAAAABAAAAAAAAAEAAAAAAQAAAAAAAAEBAAAAAQAAAAAA AAECAAAAAQAA
AAAAAAEDAAAAAQAAAAAAAAEEAAAAAQAAAAAAAAEFAAAAaG5hbWQAAABgAAAA AgAAAAQAAAAA
AAAAAwAAAAAAAAAKAEEAcgBpAGEAbAAAAAAACAAAAAAAAAADAAAAAAAAACYA TQBvAG4AbwB0
AHkAcABlACAAVAB5AHAAbwBnAHIAYQBwAGgAeQAAAAABBgAAAAQAGAAAAAAB BwAAAAYAAAAA
AAAAAAAEAAAADgAJABEAAAAaAAEPAA3wSwAAAAAAnw8EAAAABAAAAAAAqA8L AAAARWNsaXBz
ZSAzLjEAAKEPJAAAAAwAAAAAADAICgABAAAAAP8BAAcADAAAAAAABwABAA4A AAAAAA8ABPBt
BQAAEgAK8AgAAAAE2AEAAAoAALMAC/BCAAAAfwAAAAQAgADwkEEKhQACAAAA hwABAAAAvwAA
AAIAgQGAgIAAvwEQABAAwAEBAAAI/wEIAAgAAQICAAAIBAMHAAAAUwAi8R4A AAC/AQAAYAB/
BQAACAC/BQAACAD/BQAACAA/BgAACAAAABDwCAAAAEgMgQEAD3sPDwAR8BgE AAAPAIgTEAQA
AA8AihNqAwAAAAC6DxYAAABfAF8AXwBQAFAAVABNAEEAQwAxADEAAACLE0QD AAAAABkQPAMA
AAAAAAgMAQAAAAAAAgAAAQwAAAAAAAAAFAAAACAAAAABAAAAAQAAAAAAAAAB AAAA6AAAAAgA
AAAEAAAAAAAAAQAAAAABAAAAAAAAAQEAAAABAAAAAAAAAQIAAAABAAAAAAAA AQMAAAABAAAA
AAAAAQQAAAABAAAAAAAAAQUAAABobmFtZAAAAGAAAAACAAAABAAAAAAAAAAD AAAAAAAAAAoA
QQByAGkAYQBsAAAAAAAIAAAAAAAAAAMAAAAAAAAAJgBNAG8AbgBvAHQAeQBw AGUAIABUAHkA
cABvAGcAcgBhAHAAaAB5AAAAAAEGAAAABAAYAAAAAAEHAAAABgAAAAAAAAAA AAQAAAAOAAkA
EQAAABoAAQAAAAgMAQAAAAAAAgAAAQwAAAAAAAAAFAAAACAAAAABAAAAAQAA AAAAAAABAAAA
6AAAAAgAAAAEAAAAAAAAAQAAAAABAAAAAAAAAQEAAAABAAAAAAAAAQIAAAAB AAAAAAAAAQMA
AAABAAAAAAAAAQQAAAABAAAAAAAAAQUAAABobmFtZAAAAGAAAAACAAAABAAA AAAAAAADAAAA
AAAAAAoAQQByAGkAYQBsAAAAAAAIAAAAAAAAAAMAAAAAAAAAJgBNAG8AbgBv AHQAeQBwAGUA
IABUAHkAcABvAGcAcgBhAHAAaAB5AAAAAAEGAAAABAAOAAAAAAEHAAAABgAA AAAAAAAAAAQA
AAAOAAkAEQAAABoAAQAAAAgMAQAAAAAAAgAAAQwAAAAAAAAAFAAAACAAAAAB AAAAAQAAAAAA
AAABAAAA6AAAAAgAAAAEAAAAAAAAAQAAAAABAAAAAAAAAQEAAAABAAAAAAAA AQIAAAABAAAA
AAAAAQMAAAABAAAAAAAAAQQAAAABAAAAAAAAAQUAAABobmFtZAAAAGAAAAAC AAAABAAAAAAA
AAADAAAAAAAAAAoAQQByAGkAYQBsAAAAAAAIAAAAAAAAAAMAAAAAAAAAJgBN AG8AbgBvAHQA
eQBwAGUAIABUAHkAcABvAGcAcgBhAHAAaAB5AAAAAAEGAAAABAAYAAAAAAEH AAAABgAAAAAA
AAAAAAQAAAAOAAkAEQAAABoAAQ8AihM8AAAAAAC6DxAAAABfAF8AXwBQAFAA VAAxADAAAACL
ExwAAAAAALEPFAAAAAAAAAAAAAAEAQAAAAAAAAQCAAAADwCKE1IAAAAAALoP DgAAAF8AXwBf
AFAAUABUADkAAACLEzQAAAAAAKwPLAAAAAAAAAAAAAAAAAAAAAAAAAAAABAA AQAAAAAAAAAA
AAAAAAAQAAIAAAAAAAAADwAN8LUAAAAAAJ8PBAAAAAQAAAAAAKgPUQAAAERl YnVnZ2VyIENv
bXBvbmVudHMNKFByb3RvY29scywgU3ltYm9sIFJlYWRlcnMsIERhdGEgVmlz dWFsaXphdGlv
biwgT1MgQXdhcmVuZXNzKQAAoQ9IAAAAUgAAAAAAMAgKAAEAAAAA/wEABwAU AAAAAAAHAAEA
DgAAAAAAPQAAAAAEBwAABAEADgAAAAAAAQAAAAAIBwAACAEADgAAAAAADwAE 8F4AAAACAgrw
CAAAAAXYAQBACwAAkwAL8DYAAACFAAIAAACHAAEAAAC/AQAAEADAAQEAAAjQ AQEAAADRAQEA
AAD/AQgACAABAgIAAAgDAwAAAAAAABDwCAAAAFULQQhCCEgMDwAD8PAEAAAP AATwRgAAAAEA
CfAQAAAAHwEAAF4HAACeDgAATQoAAAIACvAIAAAABtgBAAECAAATAAvwBgAA AIgDAAAAAAAA
EPAIAAAAZgiCAQEPVQsPAATwSQIAABIACvAIAAAAB9gBAAIKAACzAAvwQgAA AH8AAAAEAIAA
EJ9BCoUAAgAAAIcAAQAAAL8AAAACAIEBBgAACL8BEAAQAMABAQAACP8BCAAI AAECAgAACAQD
BwAAAFMAIvEeAAAAvwEAAGAAfwUAAAgAvwUAAAgA/wUAAAgAPwYAAAgAAAAP 8BAAAAAfAQAA
JggAAJ4OAABNCgAADwAR8FIBAAAPAIgTSgEAAA8AihNCAQAAAAC6DxYAAABf AF8AXwBQAFAA
VABNAEEAQwAxADEAAACLExwBAAAAABkQFAEAAAAAAAgMAQAAAAAAAgAAAQwA AAAAAAAAFAAA
ACAAAAABAAAAAQAAAAAAAAABAAAA6AAAAAgAAAAEAAAAAAAAAQAAAAABAAAA AAAAAQEAAAAB
AAAAAAAAAQIAAAABAAAAAAAAAQMAAAABAAAAAAAAAQQAAAABAAAAAAAAAQUA AABobmFtZAAA
AGAAAAACAAAABAAAAAAAAAADAAAAAAAAAAoAQQByAGkAYQBsAAAAAAAIAAAA AAAAAAMAAAAA
AAAAJgBNAG8AbgBvAHQAeQBwAGUAIABUAHkAcABvAGcAcgBhAHAAaAB5AAAA AAEGAAAABAAY
AAAAAAEHAAAABgAAAAAAAAAAAAQAAAAOAAkAEQAAABoAAQ8ADfBPAAAAAACf DwQAAAAEAAAA
AACoDw8AAABEZWJ1Z2dlciBFbmdpbmUAAKEPJAAAABAAAAAAADAICgABAAAA AP8BAAcAEAAA
AAAABwABAA4AAAAAAA8ABPBJAgAAEgAK8AgAAAAI2AEAAgoAALMAC/BCAAAA fwAAAAQAgACY
qkEKhQACAAAAhwABAAAAvwAAAAIAgQEzzMwAvwEQABAAwAEBAAAI/wEIAAgA AQICAAAIBAMH
AAAAUwAi8R4AAAC/AQAAYAB/BQAACAC/BQAACAD/BQAACAA/BgAACAAAAA/w EAAAAB8BAABe
BwAAng4AACUIAAAPABHwUgEAAA8AiBNKAQAADwCKE0IBAAAAALoPFgAAAF8A XwBfAFAAUABU
AE0AQQBDADEAMQAAAIsTHAEAAAAAGRAUAQAAAAAACAwBAAAAAAACAAABDAAA AAAAAAAUAAAA
IAAAAAEAAAABAAAAAAAAAAEAAADoAAAACAAAAAQAAAAAAAABAAAAAAEAAAAA AAABAQAAAAEA
AAAAAAABAgAAAAEAAAAAAAABAwAAAAEAAAAAAAABBAAAAAEAAAAAAAABBQAA AGhuYW1kAAAA
YAAAAAIAAAAEAAAAAAAAAAMAAAAAAAAACgBBAHIAaQBhAGwAAAAAAAgAAAAA AAAAAwAAAAAA
AAAmAE0AbwBuAG8AdAB5AHAAZQAgAFQAeQBwAG8AZwByAGEAcABoAHkAAAAA AQYAAAAEABgA
AAAAAQcAAAAGAAAAAAAAAAAABAAAAA4ACQARAAAAGgABDwAN8E8AAAAAAJ8P BAAAAAQAAAAA
AKgPDwAAAENPUkJBIEFQSSBMYXllcgAAoQ8kAAAAEAAAAAAAMAgKAAEAAAAA /wEABwAQAAAA
AAAHAAEADgAAAAAADwAE8F4AAAACAgrwCAAAAAnYAQBACwAAkwAL8DYAAACF AAIAAACHAAEA
AAC/AQAAEADAAQEAAAjQAQEAAADRAQEAAAD/AQgACAABAgIAAAgDAwAAAAAA ABDwCAAAADsH
QghECGYIDwAE8FUCAAASAArwCAAAAArYAQAACgAAwwAL8EgAAAB/AAAABACA ABi3QQqFAAIA
AACHAAEAAAC/AAAAAgCBAf8kPACCATOzAAC/ARAAEADAAQEAAAj/AQgACAAB AgIAAAgEAwcA
AABTACLxHgAAAL8BAABgAH8FAAAIAL8FAAAIAP8FAAAIAD8GAAAIAAAAEPAI AAAAJgXkAaMO
DQcPABHwUgEAAA8AiBNKAQAADwCKE0IBAAAAALoPFgAAAF8AXwBfAFAAUABU AE0AQQBDADEA
MQAAAIsTHAEAAAAAGRAUAQAAAAAACAwBAAAAAAACAAABDAAAAAAAAAAUAAAA IAAAAAEAAAAB
AG8AdAB5AHAAZQAgAFQAeQBwAG8AZwByAGEAcABoAHkAAAAAAQYAAAAEABgA AAAAAQcAAAAG
AAAAAAAAAAAABAAAAA4ACQARAAAAGgABDwAN8F0AAAAAAJ8PBAAAAAQAAAAA AKgPHQAAAEMv
QysrIERldmVsb3BtZW50IFRvb2xzIChDRFQpAAChDyQAAAAeAAAAAAAwCAoA AQAAAAD/AQAH
AB4AAAAAAAcAAQAOAAAAAAAPAATwagAAALIECvAIAAAAC9gBAAAKAABjAAvw NAAAAH8AgACA
AARBAwAAAAXBEAAAAAYBAQAAAL8BAAABAP8BAAABAGQAZQAgAGkAYwBvAG4A AAATACLxBgAA
AL8BAABgAAAAEPAIAAAACAefEBAU9woPAATwdAAAALIECvAIAAAADNgBAAAK AABjAAvwPgAA
AH8AgACAAARBBAAAAAXBGgAAAAYBAQAAAL8BAAABAP8BAAABAGUAYwBsAGkA cABzAGUAIABp
AGMAbwBuAAAAEwAi8QYAAAC/AQAAYAAAABDwCAAAALoC2A/WFHQGDwAE8MwA AACyBArwCAAA
AA3YAQAACgAAEwEL8GYAAACBAHhhAQCCAKKtAACDAHhhAQCEAKKtAACFAAIA AACHAAEAAAC/
AAIADwAEQQIAAACBAQAAAAi/AQwAHgDAAQEAAAj/AQYADgABAgIAAAg/AgAA AwC/AgEADwD/
AhYAHwB/AwAADwCTACLxNgAAAH8BAABAAL8BAAAgAP8BAADAAL8DAIIAgn8F BgBOAL8FBgBO
AP8FBgBOAD8GBgBOAH8GBgAOAAAAEPAIAAAAYAuDEBMUXhAPAATwSAAAABIA CvAIAAAAAdgB
AAAMAACDAAvwMAAAAIEBAAAACIMBBQAACJMBHkCXAJQB3r1oAL8BEgASAP8B AAAIAAQDCQAA
AD8DAQABAC8ABfBAAAAAAQAS8BgAAAABAAAAB9gBAATYAQAF2AEAAgAAAAAA AAABABLwGAAA
AAIAAAAD2AEACNgBAAnYAQACAAAAAAAAABAA8AcgAAAA////AAAAAACAgIAA ADPMAAA2zACv
1PAARKUcAObAHwAPAIgTkQAAAA8AihOJAAAAAAC6DxAAAABfAF8AXwBQAFAA VAAxADAAAACL
E2kAAAAAAOsuCAAAADV7xQGAG0k6AAAAKwQAAAAAAAAAHwBE8T0AAAAAACfx IAAAAAAAAAAD
AAAAAAAAAAAAAAAAAAAAAACpBf////8SAAAADwA98Q0AAABAAULxBQAAAAEJ AAAADwACKwAA
AAAPAO4DdhUAAAIA7wMYAAAAAQAAAA0OAAAAAAAABAAAgAAAAAAHAAwwAAD5 AxAAAAAAAAAA
AAAAAAMKAQACskwwDwAMBHUUAAAPAALwbRQAAEABCPAIAAAAEAAAABDcAQAP AAPwvRMAAA8A
BPAoAAAAAQAJ8BAAAAAAAAAAAAAAAAAAAAAAAAAAAgAK8AgAAAAA3AEABQAA AA8ABPB+AAAA
EgAK8AgAAAAC3AEAIAIAAHMAC/AqAAAABAAAAAAAfwAAAAQAgADAzqkFvwEA AAEA/wEAAAEA
AQMCrAEAiAMAAAAAAAAQ8AgAAACtADgBKBd9Aw8AEfAQAAAAAADDCwgAAAAA AAAADQCpBQ8A
DfAMAAAAAACeDwQAAAAAAAAADwAE8FgAAAASAArwCAAAAAPcAQAACgAAgwAL 8DAAAACFAAIA
AACHAAEAAACBAQQAAAiDAQAAAAi/ARAAEADAAQEAAAj/AQgACAABAgIAAAgA ABDwCAAAAL0H
FQFzD38PDwAE8EMCAAASAArwCAAAAATcAQAACgAAwwAL8EgAAAB/AAAABACA AMA5QQqCAMgX
AgCFAAIAAACHAAMAAAC/AAAAAgCBAWyQbAC/ARAAEADAAQEAAAj/AQgACAAB AgIAAAgEAwcA
AABTACLxHgAAAL8BAABgAH8FAAAIAL8FAAAIAP8FAAAIAD8GAAAIAAAAEPAI AAAAbgOIAQcP
+gYPABHwUgEAAA8AiBNKAQAADwCKE0IBAAAAALoPFgAAAF8AXwBfAFAAUABU AE0AQQBDADEA
AAAAAAAAAAAABAAAAA4ACQARAAAAGgABDwAN8EsAAAAAAJ8PBAAAAAQAAAAA AKgPCwAAAEVj
bGlwc2UgMy4xAAChDyQAAAAMAAAAAAAwCAoAAQAAAAD/AQAHAAwAAAAAAAcA AQAOAAAAAAAP
AATwcwUAABIACvAIAAAABdwBAAAKAADDAAvwSAAAAH8AAAAEAIAAVEdBCoUA AgAAAIcAAQAA
AL8AAAACAIEBgICAAIIBFK4AAL8BEAAQAMABAQAACP8BCAAIAAECAgAACAQD BwAAAFMAIvEe
AAAAvwEAAGAAfwUAAAgAvwUAAAgA/wUAAAgAPwYAAAgAAAAQ8AgAAAAHDIUB BA86Dw8AEfAY
BAAADwCIExAEAAAPAIoTagMAAAAAug8WAAAAXwBfAF8AUABQAFQATQBBAEMA MQAxAAAAixNE
AwAAAAAZEDwDAAAAAAAIDAEAAAAAAAIAAAEMAAAAAAAAABQAAAAgAAAAAQAA AAEAAAAAAAAA
AQAAAOgAAAAIAAAABAAAAAAAAAEAAAAAAQAAAAAAAAEBAAAAAQAAAAAAAAEC AAAAAQAAAAAA
AAEDAAAAAQAAAAAAAAEEAAAAAQAAAAAAAAEFAAAAaG5hbWQAAABgAAAAAgAA AAQAAAAAAAAA
AwAAAAAAAAAKAEEAcgBpAGEAbAAAAAAACAAAAAAAAAADAAAAAAAAACYATQBv AG4AbwB0AHkA
cABlACAAVAB5AHAAbwBnAHIAYQBwAGgAeQAAAAABBgAAAAQAGAAAAAABBwAA AAYAAAAAAAAA
AAAEAAAADgAJABEAAAAaAAEAAAAIDAEAAAAAAAIAAAEMAAAAAAAAABQAAAAg AAAAAQAAAAEA
AAAAAAAAAQAAAOgAAAAIAAAABAAAAAAAAAEAAAAAAQAAAAAAAAEBAAAAAQAA AAAAAAECAAAA
AQAAAAAAAAEDAAAAAQAAAAAAAAEEAAAAAQAAAAAAAAEFAAAAaG5hbWQAAABg AAAAAgAAAAQA
AAAAAAAAAwAAAAAAAAAKAEEAcgBpAGEAbAAAAAAACAAAAAAAAAADAAAAAAAA ACYATQBvAG4A
bwB0AHkAcABlACAAVAB5AHAAbwBnAHIAYQBwAGgAeQAAAAABBgAAAAQADgAA AAABBwAAAAYA
AAAAAAAAAAAEAAAADgAJABEAAAAaAAEAAAAIDAEAAAAAAAIAAAEMAAAAAAAA ABQAAAAgAAAA
AQAAAAEAAAAAAAAAAQAAAOgAAAAIAAAABAAAAAAAAAEAAAAAAQAAAAAAAAEB AAAAAQAAAAAA
AAECAAAAAQAAAAAAAAEDAAAAAQAAAAAAAAEEAAAAAQAAAAAAAAEFAAAAaG5h bWQAAABgAAAA
AgAAAAQAAAAAAAAAAwAAAAAAAAAKAEEAcgBpAGEAbAAAAAAACAAAAAAAAAAD AAAAAAAAACYA
TQBvAG4AbwB0AHkAcABlACAAVAB5AHAAbwBnAHIAYQBwAGgAeQAAAAABBgAA AAQAGAAAAAAB
BwAAAAYAAAAAAAAAAAAEAAAADgAJABEAAAAaAAEPAIoTPAAAAAAAug8QAAAA XwBfAF8AUABQ
AFQAMQAwAAAAixMcAAAAAACxDxQAAAAAAAAAAAAABAEAAAAAAAAEAgAAAA8A ihNSAAAAAAC6
Dw4AAABfAF8AXwBQAFAAVAA5AAAAixM0AAAAAACsDywAAAAAAAAAAAAAAAAA AAAAAAAAAAAQ
AAEAAAAAAAAAAAAAAAAAEAACAAAAAAAAAA8ADfC1AAAAAACfDwQAAAAEAAAA AACoD1EAAABE
ZWJ1Z2dlciBDb21wb25lbnRzDShQcm90b2NvbHMsIFN5bWJvbCBSZWFkZXJz LCBEYXRhIFZp
c3VhbGl6YXRpb24sIE9TIEF3YXJlbmVzcykAAKEPSAAAAFIAAAAAADAICgAB AAAAAP8BAAcA
FAAAAAAABwABAA4AAAAAAD0AAAAABAcAAAQBAA4AAAAAAAEAAAAACAcAAAgB AA4AAAAAAA8A
BPBeAAAAAgIK8AgAAAAG3AEAQAsAAJMAC/A2AAAAhQACAAAAhwABAAAAvwEA ABAAwAEBAAAI
0AEBAAAA0QEBAAAA/wEIAAgAAQICAAAIAwMAAAAAAAAQ8AgAAAAUC0UIRggH DA8AA/D8BAAA
DwAE8EYAAAABAAnwEAAAAB8BAABeBwAAng4AAE0KAAACAArwCAAAAAfcAQAB AgAAEwAL8AYA
AACIAwAAAAAAABDwCAAAACUIhgEFDxQLDwAE8E8CAAASAArwCAAAAAjcAQAC CgAAwwAL8EgA
AAB/AAAABACAANgEQQqFAAIAAACHAAEAAAC/AAAAAgCBAQYAAAiCARSuAAC/ ARAAEADAAQEA
AAj/AQgACAABAgIAAAgEAwcAAABTACLxHgAAAL8BAABgAH8FAAAIAL8FAAAI AP8FAAAIAD8G
AAAIAAAAD/AQAAAAHwEAACYIAACeDgAATQoAAA8AEfBSAQAADwCIE0oBAAAP AIoTQgEAAAAA
ug8WAAAAXwBfAF8AUABQAFQATQBBAEMAMQAxAAAAixMcAQAAAAAZEBQBAAAA AAAIDAEAAAAA
AAIAAAEMAAAAAAAAABQAAAAgAAAAAQAAAAEAAAAAAAAAAQAAAOgAAAAIAAAA BAAAAAAAAAEA
AAAAAQAAAAAAAAEBAAAAAQAAAAAAAAECAAAAAQAAAAAAAAEDAAAAAQAAAAAA AAEEAAAAAQAA
AAAAAAEFAAAAaG5hbWQAAABgAAAAAgAAAAQAAAAAAAAAAwAAAAAAAAAKAEEA cgBpAGEAbAAA
AAAACAAAAAAAAAADAAAAAAAAACYATQBvAG4AbwB0AHkAcABlACAAVAB5AHAA bwBnAHIAYQBw
AGgAeQAAAAABBgAAAAQAGAAAAAABBwAAAAYAAAAAAAAAAAAEAAAADgAJABEA AAAaAAEPAA3w
TwAAAAAAnw8EAAAABAAAAAAAqA8PAAAARGVidWdnZXIgRW5naW5lAAChDyQA AAAQAAAAAAAw
CAoAAQAAAAD/AQAHABAAAAAAAAcAAQAOAAAAAAAPAATwTwIAABIACvAIAAAA CdwBAAIKAADD
AAvwSAAAAH8AAAAEAIAAMBVBCoUAAgAAAIcAAQAAAL8AAAACAIEBM8zMAIIB FK4AAL8BEAAQ
AMABAQAACP8BCAAIAAECAgAACAQDBwAAAFMAIvEeAAAAvwEAAGAAfwUAAAgA vwUAAAgA/wUA
AAgAPwYAAAgAAAAP8BAAAAAfAQAAXgcAAJ4OAAAlCAAADwAR8FIBAAAPAIgT SgEAAA8AihNC
AQAAAAC6DxYAAABfAF8AXwBQAFAAVABNAEEAQwAxADEAAACLExwBAAAAABkQ FAEAAAAAAAgM
AQAAAAAAAgAAAQwAAAAAAAAAFAAAACAAAAABAAAAAQAAAAAAAAABAAAA6AAA AAgAAAAEAAAA
AAAAAQAAAAABAAAAAAAAAQEAAAABAAAAAAAAAQIAAAABAAAAAAAAAQMAAAAB AAAAAAAAAQQA
AAABAAAAAAAAAQUAAABobmFtZAAAAGAAAAACAAAABAAAAAAAAAADAAAAAAAA AAoAQQByAGkA
YQBsAAAAAAAIAAAAAAAAAAMAAAAAAAAAJgBNAG8AbgBvAHQAeQBwAGUAIABU AHkAcABvAGcA
cgBhAHAAaAB5AAAAAAEGAAAABAAYAAAAAAEHAAAABgAAAAAAAAAAAAQAAAAO AAkAEQAAABoA
AQ8ADfBPAAAAAACfDwQAAAAEAAAAAACoDw8AAABDT1JCQSBBUEkgTGF5ZXIA AKEPJAAAABAA
AAAAADAICgABAAAAAP8BAAcAEAAAAAAABwABAA4AAAAAAA8ABPBeAAAAAgIK 8AgAAAAK3AEA
QAsAAJMAC/A2AAAAhQACAAAAhwABAAAAvwEAABAAwAEBAAAI0AEBAAAA0QEB AAAA/wEIAAgA
AQICAAAIAwMAAAAAAAAQ8AgAAAD6BkYISAglCA8ABPBVAgAAEgAK8AgAAAAL 3AEAAAoAAMMA
C/BIAAAAfwAAAAQAgAAUIUEKhQACAAAAhwABAAAAvwAAAAIAgQH/JDwAggEz swAAvwEQABAA
wAEBAAAI/wEIAAgAAQICAAAIBAMHAAAAUwAi8R4AAAC/AQAAYAB/BQAACAC/ BQAACAD/BQAA
CAA/BgAACAAAABDwCAAAAOUE6AGnDswGDwAR8FIBAAAPAIgTSgEAAA8AihNC AQAAAAC6DxYA
AABfAF8AXwBQAFAAVABNAEEAQwAxADEAAACLExwBAAAAABkQFAEAAAAAAAgM AQAAAAAAAgAA
AQwAAAAAAAAAFAAAACAAAAABAAAAAQAAAAAAAAABAAAA6AAAAAgAAAAEAAAA AAAAAQAAAAAB
AAAAAAAAAQEAAAABAAAAAAAAAQIAAAABAAAAAAAAAQMAAAABAAAAAAAAAQQA AAABAAAAAAAA
AQUAAABobmFtZAAAAGAAAAACAAAABAAAAAAAAAADAAAAAAAAAAoAQQByAGkA YQBsAAAAAAAI
AAAAAAAAAAMAAAAAAAAAJgBNAG8AbgBvAHQAeQBwAGUAIABUAHkAcABvAGcA cgBhAHAAaAB5
AAAAAAEGAAAABAAYAAAAAAEHAAAABgAAAAAAAAAAAAQAAAAOAAkAEQAAABoA AQ8ADfBdAAAA
AACfDwQAAAAEAAAAAACoDx0AAABDL0MrKyBEZXZlbG9wbWVudCBUb29scyAo Q0RUKQAAoQ8k
AAAAHgAAAAAAMAgKAAEAAAAA/wEABwAeAAAAAAAHAAEADgAAAAAADwAE8HQA AACyBArwCAAA
AAzcAQAACgAAYwAL8D4AAAB/AIAAgAAEQQQAAAAFwRoAAAAGAQEAAAC/AQAA AQD/AQAAAQBl
AGMAbABpAHAAcwBlACAAaQBjAG8AbgAAABMAIvEGAAAAvwEAAGAAAAAQ8AgA AAC7AtwP2hR1
Bg8ABPBqAAAAsgQK8AgAAAAN3AEAAAoAAGMAC/A0AAAAfwCAAIAABEEDAAAA BcEQAAAABgEB
AAAAvwEAAAEA/wEAAAEAZABlACAAaQBjAG8AbgAAABMAIvEGAAAAvwEAAGAA AAAQ8AgAAAAJ
B6MQFBT4Cg8ABPB2AAAAsgQK8AgAAAAO3AEAAAoAAIMAC/BAAAAAfwCEAIUA BEEFAAAABcEQ
AAAABgEBAAAAvwEAABEAwAEBAAAIywE4YwAA/wEIAAkAcAByAG8AYwBlAHMA cwAAABMAIvEG
AAAAvwEAAGAAAAAQ8AgAAAB7B8kHgRA/Cg8ABPBsAAAAEgAK8AgAAAAP3AEA AAoAAJMAC/A2
AAAAhQACAAAAhwABAAAAgQH//wAAggFIoQAAvwEAABAAwAH//wAAywHUlAAA /wEIAAgAAQIC
AAAIEwAi8QYAAAC/AQAAYAAAABDwCAAAAOMIUwjHDzcJDwAE8MwAAACyBArw CAAAABDcAQAA
CgAAEwEL8GYAAACBAHhhAQCCAKKtAACDAHhhAQCEAKKtAACFAAIAAACHAAEA AAC/AAIADwAE
QQIAAACBAQAAAAi/AQwAHgDAAQEAAAj/AQYADgABAgIAAAg/AgAAAwC/AgEA DwD/AhYAHwB/
AwAADwCTACLxNgAAAH8BAABAAL8BAAAgAP8BAADAAL8DAIIAgn8FBgBOAL8F BgBOAP8FBgBO
AD8GBgBOAH8GBgAOAAAAEPAIAAAAZguWECYUZBAPAATwSAAAABIACvAIAAAA AdwBAAAMAACD
AAvwMAAAAIEBAAAACIMBBQAACJMBHkCXAJQB3r1oAL8BEgASAP8BAAAIAAQD CQAAAD8DAQAB
AC8ABfBAAAAAAQAS8BgAAAABAAAACNwBAAXcAQAG3AEAAgAAAAAAAAABABLw GAAAAAIAAAAE
3AEACdwBAArcAQACAAAAAAAAABAA8AcgAAAA////AAAAAACAgIAAADPMAAA2 zACv1PAARKUc
AObAHwAPAIgTkQAAAA8AihOJAAAAAAC6DxAAAABfAF8AXwBQAFAAVAAxADAA AACLE2kAAAAA
AOsuCAAAADV7xQEgb/2lAAAAKwQAAAAAAAAAHwBE8T0AAAAAACfxIAAAAAAA AAADAAAAAAAA
AAAAAAAAAAAAAACpBf////8SAAAADwA98Q0AAABAAULxBQAAAAEJAAAADwAC KwAAAAAPAO4D
0QMAAAIA7wMYAAAAAQAAAA0OAAAAAAAABAAAgAAAAAAHAAwwAAD5AxAAAAAA AAAAAAAAAAMK
AQACskwwDwAMBNACAAAPAALwyAIAAPAACPAIAAAABAAAAATIAQAPAAPwYAIA AA8ABPAoAAAA
AQAJ8BAAAAAAAAAAAAAAAAAAAAAAAAAAAgAK8AgAAAAAyAEABQAAAA8ABPAc AQAAogwK8AgA
AAACyAEAAAoAAPMAC/BaAAAAgADw7PIJgQB4YQEAggCirQAAgwB4YQEAhACi rQAAvwACAA8A
gQEAAAAIvwEMAB4AwAEBAAAI/wEGAA4AAQICAAAIPwIAAAMAvwIBAA8A/wIW AB8AfwMAAA8A
kwAi8TYAAAB/AQAAQAC/AQAAIAD/AQAAwAC/AwCCAIJ/BQYATgC/BQYATgD/ BQYATgA/BgYA
TgB/BgYADgAAABDwCAAAANwJiAA/B8EKDwAN8
| Re: Meeting Notes: DD Project, Toronto 19-20 July [message #567834 is a reply to message #3066] |
Junior Member |
charset="US-ASCII"
Doug,
Thanks - Ken
> Hello all,
> Thanks for a productive meeting in Toronto, and thanks to Pete Nichols
> for organizing the meeting location and agenda. It's very good that we
> are moving quickly into more detailed technical analysis and
> prototyping. Attached are the notes that Felix and I took. Please
> respond with comments, changes, and the correct spelling of your names.
> Our next meeting with be in Toronto in early October. My apologies for
> not better communicate the date ahead of time. We will pick a date in
> September and publish it here.
> The action items copied from the minutes are below.
> - Wind River
> - Wind River, QNX (Mikhail), Darin, TI (Paul) - Sub-group
> - Flexible hierarchy prototyping and async/sync
> - Use Darin's dummy debug engine
> - Will need to keep Samantha up-to-date for the updater policy
> - Doug: Make sure TM meetings don't coincide with DD.
> - Doug: Chris R would like a face-to-face meeting on TM - maybe
> coincide with our next DD face-to-face.
> - Doug: Talk to Greg Watson and try to make sure he's included as an
> FYI on these discussions.
> - Doug: Serial terminal - what do we need to do to base this on the
> 3.1 console? Can we make the ANSI emulation, telnet support, and
> communication method (console, serial, network) pluggable?
> - Doug: Check into IP review and check-in process prior to next
> meeting.
> - Alternate view rendering and more fine-grained control of existing
> rendering.
> - IBM, WR (Ted)
> - TI
> - First stab at interfaces for Open Debug Server. Will get feedback
> via email, since we probably won't have time to discuss in detail at the
> next meeting.
> - IBM
> - Updater policy design and implementation
> - Editor/debugger extension point design
> - Memory view usability issues
> - Breakpoint working set use cases / launch persistence
> - Nokia (Ken Ryall), QNX (Alain)
> - Debug console requirements and initial design
> Doug
FUDForum. Page generated in 0.03150 seconds
