Home » Eclipse Projects » Rich Client Platform (RCP) » How to add a browser editor in RCP ?
How to add a browser editor in RCP ? [message #436358] Wed, 07 September 2005 06:36 Go to next message
Cedric Hyppolite is currently offline Cedric Hyppolite
I am trying to add a browser editor in my RCP.
I need the browser editor instead of a browser view to be able to open
multiple html at the same time.
I am running Eclipse 3.1 (on MacOS), where there is an internal browser
that I can use in the IDE.
Does anyone has a pointer on the API documentation explaining how to
open a browser editor on an URL ?
Doc on opening any editor if it can apply to the browser would be
welcome too.
Thanks.
Cédric
Re: How to add a browser editor in RCP ? [message #436359 is a reply to message #436358] Wed, 07 September 2005 06:52 Go to previous messageGo to next message
Ricky is currently offline Ricky
Its not what you asked for but it is possible to have more than one view
instance of a given view. "allowMultiple" in plugin.xml and the concept of
secondary IDs are starting points.
hth,
Ricky
Re: How to add a browser editor in RCP ? [message #436366 is a reply to message #436358] Wed, 07 September 2005 10:01 Go to previous messageGo to next message
Neil Bartlett is currently offline Neil Bartlett
Member
Assuming you have the org.eclipse.ui.browser plugin installed in your RCP
application, IWorkbench.getBrowserSupport().createBrowser(...) will open a
new browser in an Editor.
Re: How to add a browser editor in RCP ? [message #436411 is a reply to message #436366] Wed, 07 September 2005 13:10 Go to previous messageGo to next message
> RCP application, IWorkbench.getBrowserSupport().createBrowser(...) will
> open a new browser in an Editor.
Thanks.
The following bug discussion thread gives an overview of the history of
the browser support addition including the function call.
PlatformUI.getWorkbench().getBrowserSupport().createBrowser
(AS_EXTERNAL, "myId", null, null).openURL(url);
https://bugs.eclipse.org/bugs/show_bug.cgi?id=69647
Cedric
Re: How to add a browser editor in RCP ? [message #448554 is a reply to message #436366] Wed, 26 April 2006 04:58 Go to previous messageGo to next message
martin is currently offline martin
Member
I also have troubles with this. I currently do:
PlatformUI.getWorkbench().getBrowserSupport().createBrowser(
IWorkbenchBrowserSupport.AS_EDITOR, "Preview", "Preview", "")
..openURL(url);
This starts the external browser application but does not open a new
editor. How can I make the browser to be hosted inside an eclipse editor
window instead?
M
Re: How to add a browser editor in RCP ? [message #667870 is a reply to message #448554] Mon, 02 May 2011 10:27 Go to previous messageGo to next message
Iago Seara is currently offline Iago Seara
Hi, I have the same problem, did you solve the problem?
Thanks!
I
Re: How to add a browser editor in RCP ? [message #776727 is a reply to message #667870] Mon, 09 January 2012 02:03 Go to previous message
Mostafa Barmshory is currently offline Mostafa Barmshory
in the preference > general > Web Browser you should chick 'use internal browser' to take an effect.
However I know anything about its key and scope with in the preference storage to manipulate it from the code.
I also have the problem. With external browser all things is ok, but with internal browser it goes wrong with following exception:
at org.eclipse.ui.internal.browser.DefaultBrowserSupport.getWindowKey(DefaultBrowserSupport.java:77)
at org.eclipse.ui.internal.browser.DefaultBrowserSupport.createBrowser(DefaultBrowserSupport.java:141)
at org.eclipse.ui.internal.browser.DefaultBrowserSupport.createBrowser(DefaultBrowserSupport.java:162)
at org.eclipse.ui.internal.browser.WorkbenchBrowserSupport.createBrowser(WorkbenchBrowserSupport.java:104)
Previous Topic:How to limit Label control height?
Next Topic:Editors not reflecting Appearance changes in RCP application
Current Time: Fri May 24 04:02:19 EDT 2013
Powered by FUDForum. Page generated in 0.01921 seconds
