| Using Dali in a non-J2EE environment. [message #434633] |
Thu, 15 November 2007 11:45  |
Alexandros Karypidis Messages: 32 Registered: July 2009 |
Member |
Hi all,
I've recently started using Eclipse to develop RCP applications. I am
using Dali in that context. One of my apps uses the OpenJPA
implementation and Derby for the backend. The other uses Hibernate and
Oracle 10g. I'd like to share a couple of thoughts on my experience:
1) One thing that I find inconvenient is that Dali projects are defined
as J2EE projects. Since JPA can be used in non J2EE environments, I'd
very much prefer it if they were pure Java projects.
Currently, I create a Dali project with no target runtime and then
convert it to a plug-in using the context menu "PDE Tools->Convert
projects to plug-in projects".
One gets the following irritating warnings (perhaps because the J2EE
module not being included in an EAR?):
Classpath entry org.eclipse.jdt.USER_LIBRARY/OpenJPA 1.0.1 will not be
exported or published. Runtime ClassNotFoundExceptions may result.
dali.prj P/dali.prj 1195066325500 1308
Severity and Description Path Resource Location Creation Time Id
Classpath entry org.eclipse.pde.core.requiredPlugins will not be
dali.prj P/dali.prj 1195066325500 1309
2) It'd be quite convenient to be able to generate beans instead of
pojos. A lot of entities in client-server apps are presented to users
for editing using data-bound widgets. Adding an extra menu entry
"Generate entity beans..." that has the code generator add javabeans
property change listeners, should be fairly trivial. It would greatly
enhance ease use of entities with GUI controls.
I know (1) is just a nuisance, but I believe (2) is a legitimate
enhancement. Any comments on that? Would the Dali team be willing to add
such a feature?
| Re: Using Dali in a non-J2EE environment. [message #434634 is a reply to message #434633] |
Fri, 16 November 2007 11:35  |
Neil Hauge Messages: 460 Registered: July 2009 |
Regarding item 1 - There is actually a bug filed for this issue against
the component that produces this warning -
https://bugs.eclipse.org/bugs/show_bug.cgi?id=190783. In your case, since
you are using JPA in a pure SE situation, it is probably safe to disable
the "Classpath Dependency Validator" in the Project Properties->Validator
page. This will stop this warning from displaying, and you aren't
concerned with other deployment related issues.
Unfortunately we don't have the bandwidth to maintain a Nature and Facet
structure for the Dali project, and since we pretty much have to be a
Facet to integrate with Java EE project, that is what we have to do. That
said, we are going to add support to add the JPA Facet to a pure Java
project for 2.0.
Regarding item 2 - I think what you mean to say is that you would like
for Dali to generate POJO's that implement java bean property change
notification. I think this is a valid enhancement request, but I'm not
sure that it is a trivial enhancement. Please enter this as an
enhancement in bugzilla and I will put it in the "helpwanted" category.
This basically means that this is a fine enhancement request, but we would
likely need someone to contribute the functionality for us to include it
in an upcoming release.
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Dali%20J PA%20Tools&bug_severity=enhancement
Thanks for your feedback. We do appreciate it.
Neil
Alexandros Karypidis wrote:
> Hi all,
> such a feature?
| Re: Using Dali in a non-J2EE environment. [message #607409 is a reply to message #434633] |
https://bugs.eclipse.org/bugs/show_bug.cgi?id=190783 In your case, since
project for 2.0.
Neil
> Hi all,
> such a feature?
FUDForum. Page generated in 0.01535 seconds
