| DDL Generation working okay on M2? [message #433784] |
Tue, 25 April 2006 12:12  |
Kevin Sutter Messages: 104 Registered: July 2009 |
Is anybody else having problems generating DDL with the M2 driver? I had
a problem report (134825) open for this in the M1 timeframe, but it
magically went away when I re-installed the Dali driver. Now, with the M2
driver, I am getting an NPE whenever I attempt to bring up the DDL wizard:
Error
Tue Apr 25 10:53:53 CDT 2006
org.eclipse.wst.rdb.internal.models.sql.datatypes.impl.Chara cterStringDataTypeImpl.eSet(CharacterStringDataTypeImpl.java :364)
org.eclipse.dali.db.ddl.OrmDdlGenerator.copyDataType(OrmDdlG enerator.java:373)
org.eclipse.dali.db.ddl.OrmDdlGenerator.addJoinColumn(OrmDdl Generator.java:334)
org.eclipse.dali.db.ddl.OrmDdlGenerator.addRefColumns(OrmDdl Generator.java:309)
org.eclipse.dali.db.ddl.OrmDdlGenerator.createDdl(OrmDdlGene rator.java:214)
org.eclipse.dali.ui.actions.GenerateDdlAction.execute(Genera teDdlAction.java:28)
org.eclipse.dali.ui.actions.ProjectAction.execute(ProjectAct ion.java:90)
org.eclipse.dali.ui.actions.ProjectAction.execute(ProjectAct ion.java:71)
at org.eclipse.dali.ui.actions.ProjectAction.run(ProjectAction. java:63)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:254)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:925)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3346)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2966)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:169)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:64)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:615)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Any ideas? If I could kick off the ddl generation at either the package
or the file level (hint, hint), I could possibly help narrow down the
offending annotation. :-)
Kevin
FUDForum. Page generated in 0.01916 seconds
