Home » Eclipse Projects » Dali » NullPointerException when opening DDL wizard.
NullPointerException when opening DDL wizard. [message #433708] Wed, 12 April 2006 16:57 Go to next message
Michael Dick is currently offline Michael Dick
Hi all,
I've run into a similar problem to bug report 134825. I noticed that the bug has been closed, but I've tried a clean install and I'm still getting the problem.
Whenever I try to generate DDL from a project I get this exception in the error log :
at org.eclipse.wst.rdb.internal.models.sql.datatypes.impl.Chara cterStringDataTypeImpl.eSet(CharacterStringDataTypeImpl.java :364)
at org.eclipse.dali.db.ddl.OrmDdlGenerator.copyDataType(OrmDdlG enerator.java:384)
at org.eclipse.dali.db.ddl.OrmDdlGenerator.addJoinColumn(OrmDdl Generator.java:345)
at org.eclipse.dali.db.ddl.OrmDdlGenerator.addRefColumns(OrmDdl Generator.java:320)
at org.eclipse.dali.db.ddl.OrmDdlGenerator.createDdl(OrmDdlGene rator.java:225)
at org.eclipse.dali.ui.actions.GenerateDdlAction.execute(Genera teDdlAction.java:28)
at org.eclipse.dali.ui.actions.ProjectAction.execute(ProjectAct ion.java:90)
at org.eclipse.dali.ui.actions.ProjectAction.execute(ProjectAct ion.java:71)
at org.eclipse.dali.ui.actions.ProjectAction.run(ProjectAction. java:63)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:246)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1021)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2867)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2572)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:64)
My environment might be a contributing to the problem, here's what I'm using :
Eclipse : Version: 3.1.2 Build id: M20060118-1600
OS : Ubuntu Linux 2.6.12-10-386
Java : java full version "J2RE 1.5.0 IBM Linux build pxi32dev-20060222 (SR1)"
Dali : dali-N-0.5M1-200603170005.zip
WTP : 1.0.1 ( I can get the full build if needed).
I also have a few third party plugins installed, I can post them if they'll help.
Has anyone else seen this error? Are there any other logs I should look at (I've only looked at the Error Log view in Eclipse).
Thanks in advance for any help you can offer,
Michael Dick
Re: NullPointerException when opening DDL wizard. [message #433709 is a reply to message #433708] Wed, 12 April 2006 17:33 Go to previous messageGo to next message
Karen Butzke is currently offline Karen Butzke
Hi Michael,
Could you open a bug against Dali for this problem? It looks like a
different issue than bug 134825. This looks specific to your entities, if
you have a particular entity that you can reproduce this problem with,
please include it in the bug report.
thanks,
Karen
Re: NullPointerException when opening DDL wizard. [message #433711 is a reply to message #433708] Wed, 12 April 2006 18:04 Go to previous messageGo to next message
Neil Hauge is currently offline Neil Hauge
Michael,
What type of database are you connected to? The problem might be related
to an unsupported datatype.
Neil
Re: NullPointerException when opening DDL wizard. [message #433719 is a reply to message #433711] Thu, 13 April 2006 11:08 Go to previous messageGo to next message
Neil,
I've only tried with Derby 10.1 and MySQL 4.1. I've switched between the two with no discernible difference in behavior
(maybe I'm looking in the wrong place(s) though).
I opened bug 136658 to report/track the problem.
I think Karen was on to something though - the problem appears to be due to the entities that I'm using.. I'm able to bring
up the wizard with a simple entity, but I get the NPE if I use a more complicated example (stolen from the JPA spec).
I've included the source for the entities in the bug report, I can post it here too if you'd like.
-Mike
Neil Hauge wrote:
> Michael,
> Neil
Re: NullPointerException when opening DDL wizard. [message #433724 is a reply to message #433719] Thu, 13 April 2006 15:24 Go to previous message
Michael,
It appears that the M-M on DeliveryService is the culprit. Removing that
gets rid of the NPE. DDL gen supports M-M mappings, so we will need to
look into this figure and figure out why this is failing.
Neil
Re: NullPointerException when opening DDL wizard. [message #581596 is a reply to message #433708] Wed, 12 April 2006 17:33 Go to previous message
Hi Michael,
thanks,
Karen
Re: NullPointerException when opening DDL wizard. [message #581627 is a reply to message #433708] Wed, 12 April 2006 18:04 Go to previous message
Michael,
Neil
Re: NullPointerException when opening DDL wizard. [message #581772 is a reply to message #433711] Thu, 13 April 2006 11:08 Go to previous message
Neil,
-Mike
Neil Hauge wrote:
> Michael,
> Neil
Re: NullPointerException when opening DDL wizard. [message #581890 is a reply to message #433719] Thu, 13 April 2006 15:24 Go to previous message
Michael,
Neil
Previous Topic:UNCONFIRMED bug reports?
Next Topic:Dali, Toplink (GlassFish) and DB2
Current Time: Tue May 21 05:19:07 EDT 2013
Powered by FUDForum. Page generated in 0.02104 seconds
